- red-x injector cleaner
- what intercooler for nova
- Tips on improving MPG on Mk3 Astra 1.4i
- alternator xel to xe
- ICV and EGR part numbers
- c20let compression figures
- gearbox help please
- f28??????????
- Off Topic - Mercedes c200 broke !
- Help! Radiator fan flow rate needed
- f18 hydraulic clutch??
- how do i set up my fse boost valve...cheers for any help.
- How Many Volts should these parts have
- small block clutch (uprated)
- at last the engine number!!!!!!!!!!.
- rods
- gear box problem on astra gsi Mk3
- Best Actuator for LET
- Help With C20ne !
- f28 differential question.
- HELP-info needed on phase 1 eds software
- Flywheel help needed
- Fault codes on Corsa 1.4 16v
- corsa XE to LET conversion
- 1.6xe Cylinder head height
- 1.4 sr queston's
- C20Let misfire
- reprofiled cams - anyone done it? Also cam theory Q, someone answer pls!!!
- c20let idle's high. CTS?
- is this exhaust eco or redtop? c pics..
- TPS?
- vectra sri loom, 1 wire to find!! help...
- carlton 3.0 throttle body on 20se
- C20LET Injector possible fault
- good spark plugs for hi boosting let on phase 3
- c20xe valve guides
- Oil in water
- f28 into nova
- corsa sri c14se engine mods
- exhaust
- x20xev into a 02 plate astra
- Z20let Tis Software
- vectra s reg, headlights stuck on full beam
- Early and late x20xev engines
- Do I really need a dial gauge to set up cam?
- Astra Turbo Coupe ABS/Traction Control lights
- 8v camshaft removal
- turbo kit on 1.8 16v
- x16xel cam part no.??
- corsa xe wiring help please
- Headlight Differences
- Whooosh of air when removing petrol cap?
- Subframes - Astra/Cavalier/Calibra turbo - are they the same?
- Let Dizzy Cap
- Has my head gasket gone? C20LET
- Techniclutch.com - Number 1 For All Clutches...?
- c20let astra spitting pops out of exhaust under boost!!!
- LET Throttle sensor bosch part number?
- X18XE1 Problem
- Help Please, NO OIL PRESSURE!
- bleed valve for a let motor
- C14NZ Tuning (NEWBIE)
- Fuel pressure gauge leaking! GRR
- nove gsi engine in to 1.0 nova
- What BHP, would a let
- Astra Mk4 Engine Upgrade.
- F28 sometimes jumps out of 1st & 2nd, worn syncros ?
- Best injectors to match in batched injection
- LET Boosting. pressure drops an missfires
- 4x4 Astra Mk3?
- Will a CTS do this
- spark plugs for let
- Lowering My Astra Coupe Turbo
- rough running and misfire on cylinder 4 (video of wot it is doing)
- Anyone bought and oil pump from autovaux - LET
- Auto Transmission cooler as Oil Cooler.
- driveshaft question???
- Carbs or throttle bodies
- 4x4 nova turbo?
- turbo tech
- What diff. oil for my MV6 with LSD?
- Piper backbox
- small engine tune up
- 3 types of clutches..explain?
- omega won't start
- C16 & X16 Clutches - are they the same???
- some numbers from my redtop
- C20let Oil Return on block
- fao:anyone running 45's on an xe
- calibra XEV oil pressure sender unit
- mini cooper s supercharger to corsa gsi engine
- turbo info
- Standalone management vs MSD live mapped ECU (C20LET)
- ZLET Downpipe removal..
- Calibra Turbo ... still running sh*t
- decent sump gasket for c20let
- xe ignition amplifier HELP
- omex mapping for let
- NOVA 2.0 16v EXHAUST?
- Astra G 1.7tdi timing belt HELP!!
- getting info directly from CTS ?
- What does the '20' in F20 signify?
- Nova F20 cv joint
- Dry sumps(LET)
- Gearbox?? F16 or other
- cally 4x4 transfer box
- egr valve help needed please
- Problems with XE
- diesel manafold
- f16 to f20 help
- Tigra 1.4 Alternator belt/pas belt
- 4 branch manifold for mk4 astra sport
- Cooling Probs
- c16xe engine work
- XE cooling question
- Astra Z20LET fault code 1106?
- C20LET Piston pins
- X16XEL starter motor - where the heck is it ..???
- chipped XE doesnt seem wat it shud be
- how to tell which red top u have??
- Turbo steering rack question
- ecotec 2.0 in corsa
- camshaft sensor vectra HELP !!
- xe inlet cam on a c20let
- really really need some advice!
- 18s 20seh and mk1 gte cam shaft choice!
- Driveshafts
- Has any1 swopped an f18 for an f20 with a early flywheel and clutch?
- please help 1.4 16v lost power
- Another Phase 2/440cc injector thread..
- X16XEL hose kits?
- Astra 1.7 DTI turbo upgrade
- is my oil pressure too high?
- seam weld corsa
- Question On Xe Diz
- Internal fuel pump, uprated c20let.
- Running in new turbo...?
- How to check a coil with no markings?
- f16 gear box
- This is a Corsa 1.4 16v EGR valve isnt it
- C20LET Fueling Question.,
- Nova-now a non starter......
- x20xev clutch change time
- Calibra turbo has two fans?
- astra g gsi fault light on dash??
- port and polished head c20xe
- xe shafts
- will a nova exhaust fit a corsa ????????
- What clutch for a Phase 3.5 LET?
- Wiring up Emerald ECU/ Vx loom?
- X16XEL performance air intake manifold (like dbilas)
- corsa 2.0xe exhaust needed help
- red top
- Astra F: Cable route from engine to interior
- To Cam or not To Cam,,,, That is my queston!
- LET Fuel Rail Blank ??
- Help Please (fuel Leak)!!!!!!!!!!
- help please i need to lose my cat!!!!!!!!!!!!!!!!!
- Lambda Wires
- x20xev help, i am in the shi*!
- What sealant is used for F28 FWD Conversion plate?
- is it possible to fit a c20xe into a daewoo nexia?
- exploding front mount intercooler pipes!!!
- WON TPS to C20LET
- X18XE1 Lambda Sensor Problems
- c20 let corsa
- C20Xe Inlet size
- xe and let starter motor help???????
- Evo5 spark plugs tec needed..
- heat problem in engine bay?
- Valve angle????
- Turbo
- eds phase 1 power switch??
- N reg Vaux Tigra 1.4 engine management light??
- knock sensor 1 let
- nova mis-firing problem c20xe
- Lambda sensors.
- fuel pumps
- C20xe Loom Help (56k Warning)
- F16 gearbox
- Nova 1.6 8v turbo conversion
- Only turbo for C14NZ
- Performance gains from Hybrid turbos
- X20XEV info
- Best route to get fuelling on Vmax Evo 5 (306bhp chips)
- which one better "impressive" pistons cooling ??
- corsa c20xe wide belt pas
- Samco Air pipe(HELP)
- c20let engine inquirey!
- crankshaft sensor part #
- what driveshafts are these?
- let with 2.0 ne bottom end
- Oil for C20LET?
- c20let clutch
- f20 gear box. can you get different types
- gear linkage on f20 gearbox in corsa
- vectra sri, 1.8>2.0 gearbox problems
- Lambda Wire On Loom
- z20let smokin on tick over
- Fuel Pump connections
- f28?
- noisy water pump on astra mk3
- astra mk3 sport blowin fuses(indicators)
- Indicator Problem on Nova Sri
- fuel constantly coming through bores when turning over?
- 2.5 Motronic ECU Code (With Lambda)
- dashboard lights on a calibra turbo (newbie sorry)
- oil pressure: 5 or 10 bar aftermarket gauge?
- head gasket c20xe
- gear linkage corsa xe
- Z20let advice needed.
- mk 3 Astra, wont start - sometimes!!
- C20XE Sump problems
- Cavalier Gearbox help.
- Would you use this cam box?
- Nova feul tank breather...
- xe conversion wiring diagram
- flywheel question
- New Head Gasket and Rattle
- LET fuel pump, handle 300bhp?
- Corsa c20let help
- nova turbo
- quick question.
- vectra B headlight intake
- HEX files for C20XE needed...
- my calibra xe, a big thanks
- Vectra MK1 Engine query
- ecotec engine differences? 1.8>2.0 help,...
- c20let-fitted evo5's and gettin engine management light on!
- Chip or Remap?
- [X16XE] Exhaust Manifold
- mk4 astra projector headlights.
- early or late LET pipe?
- corsa exhaust problem
- C20Let Turbo Recon
- 1600 8V Vauxhall pistons (Rebuild)
- engine rebore??
- I have a brand new KKK......
- oil pump faulty
- problem with astra c20xe
- astra gsi bike carb conversion ?
- Astra Sri 2.0 16v On A V Plate - Head Busting Problem???
- anyone know the size of the main TB on the LET
- Valve Stem Seals
- corsa diesel 1.5 oil leak from top of cambelt cover
- 1.2corsa runing probs.????
- Engine Builders - need to keep parts order
- What Carb??
- Would you uprate the turbo???
- 1.8 8v nova help!!
