- another thread repair thread brought to you by rodgerq
- smokey let
- Removing Cork Gasket
- can i leave amal valve disconnected//?
- external wastegate vacuum pipe connections
- F23 gearbox - how much oil?
- Ecotec to redtop
- Turning up the boost
- redtop int nova
- nova gsi lump into a 1.2 nova
- Fuel Economy Problems Corsa 1.4
- C20LET boost problems
- GTE 16v having a few problems-now won't start.
- C20XE throttle bodies - Emmissions
- Cambelt difference between LET and XEV ?
- 1.4 sri tuning suggestions
- Vauxhall Astra Mk3 Hydraulic Clutch
- LET Gearbox....
- Inlet Pipe
- Oil leak...
- missfire/boost limit at 7-10psi in every gear?
- Calibra turbo engine conversion
- what psi on v-max evo 5 306bhp chips please
- Janspeed Exhaust for a Nova SR
- fuel keeps pumping
- 10 pin aldl ecu plug on c20let
- Relaying headlights....
- XE Nova Wiring again
- Headlight beam height
- compression on an let help
- Fitting the Head on my C20LET
- nova induction kit
- Disadvantages increasing CC on a 16XE
- Pressure plate c20xe/c20let fitments (pot type)
- Using a non lamba ECU on an XE.
- Pinking problem on C14SE
- Nova C20XE fuel tank vent
- just tried starting XE nova for 1st time...
- Nova Turbo Misfire and 3 cylinder like idle
- vx W/O abs but with hydro Clutch
- alternator fuse on c16xe corsa gsi (need help as quick as possible!)
- z18xe with x16xe head
- New clutch & lywheel fitted, still slipping !!!!!
- GTE turbo suspension question
- C20XE 16V MOTRONIC BOSCH ECU NUMBERS, plus all others
- Manifold Help
- gear linkage mods
- E16SE engine help - bit lumpy lumpy
- part no. Koni top ajustable shocks for astra Mk3 with c20let
- How can i relocate the dissy on a C20xe
- What Bearings? Corsa GSi C20XE
- fitted eds phase 2 now eml flashing
- Leaky Fuel Line; Calibra V6
- Bizarre Q - XE belt cover
- Nova C20LET AFM to Turbo induction pipe
- Piston Rings oversized??
- Testing Lambda Voltage, little help (maybe Andy K to the rescue?)
- Performance clutch x20xev??
- lambda sensor and A/F mix
- flashing management light on tigra 1.4 16v
- C20LET Boost limiter
- gearbox number!
- Nova C20xe "how To"
- Nova spax coilovers advise please!!
- egr valve
- new c20let running problems
- mk 4 engine swap
- F18 gearbox troubles
- Redtop Camshaft Confusion
- sachs clutches
- Knock sensor problems on redtop?
- squeaky engine?
- question about EGR valve - Vaux Tigra
- what intercooler for corsa b
- xe breather mod.
- coilover conversion??
- Intercooler sizes and lag...
- Omega X20XEV/Simtec Climate Control Wiring and Connector
- clutch problems
- MK2 Astra GTE Cambelt change
- corsa drive shafts from f18 box
- c20xe reving prob
- ecu and loom for a c20xe
- XE compression figures???
- how to make a 24v gear display?
- uprated XE Mounts Nova?
- id please regarding a red top
- Is there a place in west yorks that chips vectras ?
- LET Coolant problem
- Alternator help !!!
- how do you convert a omega 3.0 to run transversely
- mk astra gsi blowing fuel relays HELP!
- fuel pump bad earth maybe?
- c20xe camshafts,are all the same?help
- twin 40 webers
- F20 box Q's
- Head bolt torque for Let
- Which 1.6 engines have no AFM, just a MAP and inlet temp???
- Corsa B 1.5td timing belt degrees
- Need a pic of a LET FPR
- EXHAUSTS
- Getting the air/fuel mixture correct
- 1.4 16v vs x16xe similarities/swaping parts??
- Power boost valve c20xe
- nova 1.2 to 1.4 conversion advise please!!
- best alternator for c16xe?
- AFM question
- clutch
- xe cams in to a ecotec
- snapped the cambelt cover bolt in the side of the head!!!
- ZLET Boost Solenoid?
- c16se turbo?
- Lsd for F28
- Gauge face, chip.
- 3 inch exhaust tubing?
- re locating the wiper motor (nova)
- Vectra Engine Mounts
- Which bolts to use for C20NE rubber sump gasket on C20XE?
- Crank bolt removal? no pistons in...
- gear box question on mk3 astra gsi
- need cam pulley
- c20xe conversion prob
- c20xe TB RR plot
- upgrade cams or not??
- Adjusting hydrolic clutch?
- Nova Camber Problem!!!!!!
- good mods for c20ne, calibra 8v?!
- ohhh look what i found
- gear selection
- need to sort fueling. will this be ok?
- 20xe turbo head torque settings
- How big should i go with head valves?
- C20XE/LET breather question...
- F20 box mechanical or electrical??
- can i run my XE without the idle motor?
- code 81,injector valve 1/low voltage...how do i fix it?
- Gear linkage catching steering rack
- replace valve springs ?
- corsa gear linkage
- Problems stopping my Corsa c20xe
- mk3 1.4 astra leak and rough idle - linked?
- Standard xe fuel pressure?
- afm has 6 pins...loom has 5 pins...is this normal?
- 2.0DTi EGR issues
- petrol filling problem
- lightened flywheel
- engine swap and otther questions
- What Rad for corsa let
- Problem after engine rebuild
- where to get spax coilover uprated springs
- nova exhaust fir corsa and vice versa?
- Xe running poorly
- Cracks in flywheel - ok to use ?
- Wiring in twin headlights.
- Rocker cover gasket - 1.6 8v spi
- car wont start
- Which (XE / LET) cars had a flat type flywheel ?
- My cav's clutch cable...
- corsa conversion mounts
- C20XE which dizzy port to which plug to which cylinder???
- cheap clutch kit
- again... metal head gasket
- C20XE no lambda issues
- 20SEH Alt holding bracket onto LET nova
- C20Let - code 57 and 71
- Rear disc'd axel from mk 3 ?
- engine remaps
- would the temp sensor make the engine run rough c20xe
- How many miles to a fuel tank (Mk3 Astra LET's)
- nova gte oil pressure
- Head bolt torque settings (is this right)??
- astra gte 16v wiring diagramme
- What Is This Header Tank Off (pics)
- vibration on acceleration?
- Kent cams
- EDS Phase 3 - Fuel pressure
- Xe head skimming
- Wahay - fixed my water leak on the Vectra
- Removing engine
- stainless steel exhaust
- picture request = lower half of 16xe inlet manifold. thanks
- C20LET Fuel Pump
- imobiliser
- Random squeel coming from the engine + red battery light
- XE Problem - Second Opinion Needed...
- C20XE Cutting Out
- Is there a web page for the vaux diesel fault codes?
- injectors
- camshafts
- calibra 8v - turbo?!
- metal head gasket
- 2ltr turbo corsa help
- c16xe turbo - ignition timings
- astra engine into corsa
- Cally turbo suspension???
- Calibra Volts/oil pressure gauges
- Which broken sensors = No rev counter?
- Oil temp sender help needed!
- corsa engine probs
- corsa xe shafts
- Starter motor troubles, bad earth??
- c20xe corsa
- Help me with my red top conversion.. please??
- Cav Turbo Boosting Problem ?
- anyone helicoiled an XE head?
- Max Cam Profile
- Exhaust size??
- To chip or not to chip...that is the question
- TB Fuel pressure?
- Help changing timing belt with a 1.4 8v Corsa ('98 S)
- c20let fuel pump upgrade??? help asap....
- 95 Cav Ecotec MOT failure on fast idle test
- cambelt breaks ?
- how many different types of c20let engine?
- Cam belt rollers
- Cally Turbo has a duff transfer box
- phase 3 code 38 ?
- pics of my head.
- URGENT - Head bolt torque settings for E16SE
- omex people...help with map 3000
- Astra Coupe turbo with VXR injectors, what difference?
- LET spaek plug thread size? and where to get a helicoil kit?
- c20 let management
- LET Injectors
- 1.8 gsi info
- Xe Running Carbs.what Dizzy Do I Use?
- 1.8 8v and 2.0v cam sensor
- 2nd gear vibration
- Shafts for a let in a corsa
- squealing water pump
- Ideas for a corsa backbox?
- zafira and astra GSI driveshafts question?
- cat converter.
- why a dump valve?
- lamba sensor: what happens if it's gone? (c20let)
- Carlton 3.0 fuel pump
- X20XEV DIS vs Astra VXR's Coil-on-Plug ??
- idleling up and down and a strange sucking noise by the inlet manifold...
- Clutch..
- LET Intermittent Surging....
- Were do i put in my oil for my f28 gearbx
- Pulleys on a LET / Corsa Conversion
- What flywheel for v6
- 1litre corsa sump change. prices?
- enlarged throttle body on 2ltr ecotec
- throttle bodies 'spitting'
- xe baffled sump
- corsa turbo help
- Corsa C Indicator Problem
