: Engines and Transmission
  1. Manifolds?
  2. a few let fpr questions please help
  3. HOW TO - EGR blanking for X14XE & X16XE
  4. problem with astra h turbo
  5. f26 gearbox
  6. Help removing c20xe what tools sizes i need..?
  7. head bolt question please help confused
  8. Can i use 87mm pistons with MLS Elring gasket?
  9. oil pressure relief valve
  10. ECU
  11. MSD Injectors
  12. Isuzu 1.7td / Manta release bearing
  13. fitting a longer 5th gear?
  14. 20xe idle control valve diagnosis
  15. help needed engine missing on bodies
  16. Nova Engine Suggetions
  17. Transform x14xe into a c16xe ?! possible??
  18. twin 45 xe. wont start.
  19. Nova fuel tank whats needed ??
  20. Bag 'o' spanners .
  21. Name this part? (.....no prizes to be won!)
  22. Corsa running like a bag of sh*t :(
  23. c20xe coil wiring
  24. C20xe wiring
  25. Yellow Stuff on oil cap
  26. Astra 2.2 lumpy tickover when warm?
  27. V6 Throttle
  28. cav t gearbox oil?
  29. xe running lean
  30. xe running lean
  31. Help Needed ASAP!!
  32. c20xe drive shafts + mini loom
  33. Best oil to put in a 20xe engine
  34. What oil????
  35. mk4 astra 2.5 v6 driveshaft help?????
  36. How much is this coscast head worth?
  37. C20XE cutting out
  38. F15 gearbox strength??
  39. z20let standard boost pressure?
  40. Gearbox - constantly engaged in 5th??
  41. 2002 x18xe timing marks.
  42. vxr vectra 2.8 v6 turbo
  43. drive shafts for 2.0 8v corsa with 1.4 box
  44. C20LET Phase 3.5 Switch, Injectors and Fuel Pressure
  45. upgrading to T34 on CLET
  46. vivaro-running lumpy????help!!
  47. Astra G 1.6 8v cambelt change?
  48. 99 astra 1.7td starting problems!!
  49. C20XE head gasket max compression
  50. How much preasure should be coming out of the rocker cover breather pipe on Z20LET?
  51. Xe With Stiff Bottom End!!
  52. c20xe bad idle /stall/smoke on first start-up!
  53. Astra 2.2 running problems
  54. 1400 engine transplant - what do i need?
  55. Cav Turbo Smoking habit and xe inlet cam...
  56. Beru C20XE Leads
  57. Corsa 1.7d to 1.7td conversion
  58. Astra 97 1.7 TD GM lump Overheating issue
  59. how does one go about fitting a GT28RS
  60. R1 carbs???
  61. z20let and c20let oil pumps!!!
  62. What oil filter???
  63. F20 in a 2000 Corsa Speedo problem
  64. Boost gauge....where do I connect it to?
  65. vectre 1.7td turbo prob
  66. dispac c20xe timing?help please
  67. Another rough running let
  68. Astra MK4 4x4 project.
  69. C20XE engine block weight
  70. What cam do you recommend.
  71. c20xe conversion
  72. c20xe oil pressure too high (?!)
  73. 1.2i nova wont start helpppp!!!!!!!!!!
  74. c20xe engine mounts
  75. x16xe crank the same as x14xe
  76. golf wheel bearings?
  77. Anyone help z19dth wont start
  78. what turbo for tubular c20let manifold
  79. combo van 1300 3 years old keeps losing power
  80. torque settings 2l 8v
  81. Back box recommendations - Astra 2.0 MK3
  82. EGR Valve Problem
  83. Fault code 27 -injector no3 High voltage what does this mean?
  84. C20XE weird behaviour
  85. c20xe tapping please help
  86. c20xe f20, when push clutch down can hear spinning coming from engine
  87. anyone for a cheap c20let?
  88. best first mods for 2.0 8v astra gte engine??
  89. Piston rings
  90. engine was alive 1 day dead the next any help???
  91. why does my oil still look old?
  92. f28 gear box from a f20
  93. 3 way bleed valve
  94. let running rough at bottom end ???
  95. xe let cranks any difference???
  96. cavalier c20xe hatchback exhaust?
  97. rough running c20let
  98. x18xe on x20xev
  99. C20let Bottom End Rebuild
  100. W Corsa Engine Cut out
  101. Car Sound
  102. Fuel Pressure Gauge C20LET Rail
  103. c20let trigger wheel
  104. *F20 Gearbox Fluid!*
  105. f28
  106. Gasket or porous one or the other ??
  107. C20xe Crank sensor
  108. ecu light coming on a 5k
  109. xe/let dry sump
  110. c2olet first start problems
  111. c20let wiring
  112. injector colours
  113. Power boost valve - help
  114. Snapped Cambelt - Likely damage???
  115. corsa x14xe
  116. re-circulating dump valve? yay or nay?
  117. external wastegate on t25
  118. std let pistons
  119. kkk smoking slightly after rebuild
  120. engine code
  121. Bleed valve.....Turbo
  122. Stem seals?Help!
  123. Dump Valve before the turbo ???
  124. help fault code on astra
  125. HELP astra fault code p1o45 2005 1.4
  126. Opening A LET Ecu?
  127. zlet head
  128. Notchy gears
  129. Nova 1.2 carb runs on choke but won't idle
  130. Toe cap cover
  131. astra gte 2l 16v cold starter sensor
  132. bike carb rubber hoses
  133. Isuzu cold starting
  134. corsa c20xe tapping
  135. injectors into jenvey throtte bodies??
  136. ebay quality alert: Let forged and stell rods package
  137. C20LET Pulls Ignition With Sum Revs
  138. c20let in corsa d
  139. Cam sensor
  140. Signum 3.0 V6 Diesel Management light
  141. Reinforced bottom plate
  142. Bike carbs for my ne
  143. tank vent valve removmal mk2 astra c20let
  144. Bike carb sizes
  145. What lift pump?
  146. z20let coupe bacbox on z18xe coupe
  147. Snapped Manifold Stud
  148. C20let dont want to start wen cold??
  149. Still problems bleeding xe new build!
  150. Engine code; 99 T plate Corsa Envoy 1.2 16v
  151. Does the porous modd work ???
  152. 8v corsa shafts into f16????
  153. 8v corsa shafts into f16????
  154. Any ideas what this could be vectra v6
  155. c20xe Lambda sensor help?
  156. IAT sensor for DTA on C20XE
  157. cold running
  158. 20xe hesitating
  159. Corsa redtop CV Joint Help
  160. C14NZ coolant bleeding procedure
  161. Turbo Blanket
  162. c20xe problem
  163. How do I wire in speedo on an electronic F28???
  164. changes needed 2 have a garrett on a c20let
  165. no fuel or spark on c20let
  166. Roughly how much is a clutch release bearing??
  167. Tank And Pump.... PLEASE HELP!
  168. engine temp sensor whereabouts
  169. Derestricting an airbox
  170. Starting Problems, Any Ideas?
  171. Knocking hell....
  172. Lowering Astra Coupe
  173. det
  174. cranks ?
  175. C20XE - Blocking off heater matrix outlets on water bar
  176. Trouble bleeding a c20xe freshly built!
  177. Gear Change Impossible! :(
  178. c20ne into manual dizzy
  179. Stubborn Grub screw removal...
  180. retarding timing on C12NZ
  181. Disabling EGR on Vectra/X20XEV
  182. corsa c20let cutting out????
  183. fuel pump
  184. C20XE Coolant Pipe Connections
  185. M32 vxr box onto X25XE
  186. Corsa B conversion
  187. zlet engine conversion
  188. Torque setting for XE
  189. c20xe crank into a c20ne engine block?
  190. C20NE erratic idle
  191. vectra help plz
  192. big ends posibly going on LET??
  193. c20xe vs a civic type r
  194. turbo chatter and boosting +1bar
  195. 2.2 16v X22XE crank sensor part number
  196. Custom inlet manifolds...
  197. Can Someone please read this fault code (C20LET)
  198. XE oil flow ( which way? )
  199. help needed on rebuild !!
  200. Engine code?
  201. Management questions...
  202. f28 2wd adapter, f20?
  203. fuel promblems
  204. Problems with gear selector
  205. itbīs conection
  206. quick astra mk3 quiery
  207. 1.9 cdti engine timing
  208. Gearbox Oil
  209. c20let compression
  210. cav v6
  211. heater matrix leaking..please help
  212. Milky gunk
  213. 20XE Fuel Rail and Breather Questions
  214. c20xe coilpack problems
  215. X14XE engine problems
  216. Y17DTL won't start (fault codes present)
  217. o2 sensor circuit malfunction astra mk4
  218. What can I freshen up during my rebuild??
  219. My Engine started to die this morning
  220. Retard pulleys performance...
  221. xe on bikecarbs
  222. F28 gearbox rebuild manual
  223. c20xe into corsa
  224. My poor pourus head...
  225. Gearbox question
  226. wheres the fuse located on a 1.7td isuzu vectra
  227. C20LET running problems - surprise surprise
  228. Next Stage in Throttle Body Tuning?
  229. help with piston sizes
  230. Astra MK3 3" Exhaust
  231. twin 45 xe, altenator clearance problem
  232. Pressure drop with an extra 90 bend
  233. Isuzu diesel hot starting
  234. 20xe
  235. 2L 8v NE Ignition
  236. help with z20net
  237. z20net
  238. Oil pump kits....
  239. Bailey dump valve issues. HELP!
  240. fan on constantly
  241. Best way to flush out pipe work..
  242. which block to make 22let is it se or xe
  243. Trying to get my head, about HEADS ???
  244. isuzu 1.7 td
  245. r1 carbs
  246. x14 x16 EGR valve on the right side thinghy...
  247. Boost pipe work..
  248. c20xe UNDERHEATING
  249. ER Info
  250. Servicing My Astra Coupe
