Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 [68] 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. C20Let: Code 22 - Throttle sensor
  2. Red top failed the emitions test
  3. Help F2o Gearbox
  4. MY Engine needs help
  5. astra 1.8 sri just not right
  6. gear box noises f28
  7. How to set up a fuel pressure regulator on a let
  8. can someone post the c20xe inlet port spacings and widths? thanks.
  9. How to remove injectors from a c20let
  10. removing backbox
  11. general query f28 6speed onto a 2.5 v6
  12. 2 z20let head gaskets on a c20let
  13. 20NE idle problem after stopping hot engine and starting again
  14. Injectors for phase 4 LET
  15. C20LET head size
  16. egr valve
  17. cylinder head repair....where???
  18. twinport engine with missfire
  19. Intercooler
  20. C20XE head on X20XEV?
  21. Does anyone know if...
  22. Engine Swap
  23. Oil light......pressure?
  24. is this normal (let)
  25. Corsa C 1.0 12v Wont start (ouch)
  26. C20let people; Manual Control Boost Valve
  27. how much wirin will i need to do wen i do my engine swap
  28. Throttle cable on a C16xe nova
  29. Pot type to standard type flywheel?
  30. Astra GTE shafts- will they fit a nova xe?
  31. Corsa XE Help! - No ECU light & Car Wont Start
  32. MS-I v3.0 MSnS_E
  33. my new group a corsa shell with pics and advice needed on 4x4 sytem
  34. Looking at Up-Rated Turbos
  35. calibra turbo stearing rack
  36. xe on f28
  37. Head studs question
  38. Do C20XE AFM's fit LET airboxes?
  39. Need some help for tomorrow: Redtop conversion
  40. Need some help for tomorrow: Redtop conversion
  41. Corsa b e/mount on Corsa c?
  42. c20let valves
  43. Cavalier turbo head help needed
  44. Corsa LET Radiator and Fan H&A Please
  45. frontera intercooler, any good???
  46. phase 2 transit lol
  47. ecu light and hesitating when low on fuel
  48. c20ne tuning advice / cam advice please
  49. need help with performance modification
  50. C20LET Standard Cam Profiles
  51. Which Fuel Pump ?
  52. x20xev corsa PAS?
  53. Fuel Gauge Issue
  54. Is it worth boring out to a 2.1 from an XE?
  55. how do you recon a gearbox ?
  56. Effects of increasing track width using spacers?
  57. Whats the std deck height of an X20XEV block???(cilinder)
  58. C20NE and 20SEH ecu help
  59. corsa b 20l 16v gearbox
  60. xe nova exhaust
  61. what sort of power can a t3 put out
  62. LET wiring problems
  63. alpha gold kit mk4 astra 2ltr ecotec
  64. LET ECU differences - PK, PJ?
  65. Knocking / Clunk on gear change
  66. 1.7cdti fuel temp sensor position?
  67. Blocking re-circ .
  68. mk 3 astra gsi let problems
  69. fanbelt slipping off all the time :(
  70. R1 carbs on E16se
  71. X16XE EGR blanking cover
  72. Astra GSi rear engine mount
  73. z20let exhaust decatting
  74. Spark Plugs
  75. Compresion Results Form 2.0 Ecotec
  76. Caliper Identification
  77. zlet using water and oil but where is it going
  78. Fairly hot cam and emissions
  79. What does a C20XE Little Ends Knock sound like???
  80. 1.4 16v Corsa immobiliser - whats does it stop working?
  81. Conrods Stretching (20xej Engine)
  82. Help Required ASAP - 1400 16v Nova wont start!!
  83. water leak on a c20let
  84. Releasing track rods from Corsa PAS rack
  85. digidash - oil pressure
  86. Corsa / Nova rear engine mount?
  87. Is cali/Cav turbo standard suspension the same?
  88. SBD idlers assembly
  89. Fitting multi ribbed c20xe into corsa, advised not to?
  90. how do i check the pressure releif valve C20XE
  91. corsa b 20xe shafts
  92. corsa gsi throttle bodies
  93. Tigra engine swap!
  94. spark strikeing
  95. exhaust help
  96. nova 1200 spi fuel lines
  97. custom made turbo manifold for c20let
  98. c20xe oil dissapearing then tapping
  99. c20let corsa kangarooing
  100. after market ignition coil???
  101. aux belt on a nova turbo
  102. Early xe waterpump !!!
  103. battery tray modification
  104. C20 XE help!!!
  105. better brakes on my astra x16xe
  106. Corsa Coilovers
  107. Which pug diesel uses a chargecooler ?
  108. hydraulic clutch conversion on a mk2 astra?
  109. Amal valve wires
  110. Astra diesel, cam belt gone..
  111. X18XE1 ECU position please
  112. C20XE Time finally
  113. 4x4 TX Box question
  114. fuel pump
  115. c20 let HELP
  116. Calibra Turbo cutting out
  117. Con Rods
  118. Sticking injectors
  119. Cavy sri, bent valve/s???
  120. c20xe question
  121. where is the ignition amp on 1.8 16v eco astra gsi
  122. FUEL
  123. LET held boost problem.
  124. getting more power from x16xe??
  125. Late C20LET ECU (PH type) - interchangeable with old type?
  126. redtop loom question
  127. Wanted 3 ltr v6 engine
  128. F28 transmission fluid
  129. powercap into corsa b.
  130. c20xe cambelt covers
  131. X20xev help needed !!
  132. double valve springs c20let
  133. Urgent Engine conversion wiring question
  134. Is this an xe downpipe????
  135. Cavalierr Turbo RAD same as Calibra?
  136. Which clutch?
  137. C20LET turbo oil feed?
  138. Frontera 2.3td injection problem
  139. anyone running 370 bhp on standard rods?
  140. XE Loom Grommit hole Size
  141. Ignition Coil's for a C20LET
  142. C20XE Corsa Strut Brace
  143. Are you meant to clean off carbon from piston heads?
  144. torque settings for c20let sump
  145. broken valve guide,lot of damage,help needed
  146. C20LET steel head gasket?
  147. what could of caused this (pic's)
  148. turbo question/problem
  149. corsa diesel starter motor
  150. Corsa Diesel Alternator prob!
  151. Tubular Manifolds - post ya pics here
  152. AUDI RS2 Injectors onto C20LET!
  153. How long for motronic to learn new injectors?
  154. Cleaning method for XE throttle body
  155. Anyone with Pics of Getrag F40 gearbox?
  156. LET Flange
  157. corsa 1.2 hesitating on pull off
  158. Flywheels
  159. sump leak advise needed
  160. Ignition system help on a LET
  161. Maximum power from STD LET Rods & bottom end
  162. anyone put a c20xe into a astra gsi 1.8
  163. astra x16xe
  164. z18xe options
  165. How do these pistons/valves/plugs look? Mis-fire - Help Please!
  166. drive shaft query
  167. dbilas throttle bodys for x20xev
  168. What would cause high idle when hot on a Phase 2 LET?
  169. c16xe turbo - pics anyone?
  170. Bosch Injectors
  171. vaux tigra - my old EGR valve - here have a look!
  172. oil pressure quicky
  173. over fuelling on 1 cyclinder vaux tigra - what's the best way to check this?
  174. Corsa B XE/LET with Cav/Calli Shafts??
  175. changing a backbox...
  176. Non Vaux question - Ford diesel engine transplant?
  177. low boost pressure
  178. Equal lenght driveshafts on corsa b/f15 gearbox
  179. Corsa LET Suspension
  180. No fuel coming thru injectors
  181. Equal lengthTurbo Exhaust Manifold?
  182. High idle/misfire C20LET, strange problem.
  183. LET management light.....
  184. is there a quaife diff for the f16/20?
  185. which cams in a let engine?
  186. astra mk1 1.8 8v - injector info please
  187. Needed pic of calibra turbo rear axle
  188. is calibra & cavalier fuel tanks the same?
  189. plz identify these gaskets/oil seals (pic)
  190. C20LET bottom pully
  191. 8v Bottom end for C20LET
  192. HELP car stalling!!!!
  193. astra gsi c18xe ecotech wiring
  194. nova wiring loom
  195. 2001 Veccy SRi 150...What engine??
  196. oil pressure sender: loctite or washer?
  197. rev limiter for coilpack/coil on plug systems?
  198. removing C20LET superchip question?
  199. Oil for a Nova Sri
  200. Is cat requirement based on engine year not car?
  201. diy porous head fix tube diameter
  202. What gearbox for GSI Z20LET lump?
  203. VXR injectors flow rate
  204. Corsa C20XE
  205. What gearbox for XE Nova?
  206. Urgent! Fuel pressure regulator gauge not working?
  207. X14XEV cambelt failure
  208. LET Nova Clutch Cable Snapping!
  209. corsa manifold heat shield
  210. corsa B 1.2 filter problems?
  211. bent throttle flaps
  212. engine management light
  213. Corsa GSI cat. back exhaust
  214. pj pk ecu whats the difference
  215. EM light.......C16xe
  216. Missing bolts or nuts
  217. Astra MK2 Gearbox oil
  218. engine problems
  219. fitting a lsd to f20/f28
  220. corsa c20let boost question.
  221. c20xe problem
  222. Early and late xe differences???
  223. Carlton 3.0 throttle body butteryfly
  224. corsa b c20let intercooler sizes
  225. z20let running problems.
  226. Views On This Turbo For C20XE Please ?
  227. SORRY...any one know how to fit a crank angle sensor on a evo 4 SORRY
  228. Priming oil pump after rebuild
  229. Homemade turbo setup
  230. coil pack xe help
  231. Help With My Timing Belt Please
  232. Help With My Timing Belt Please
  233. xe into a corsa
  234. Re Loacating the battery to the boot ? need help
  235. Reputable Exhaust Fabricators
  236. C20XE on carb power?
  237. Rebuild costs on 20xe
  238. how do i fit an external oil cooler to the V6
  239. vectra internal oil filter.
  240. Exhaust/Engine problem
  241. £3 for Magnatec oil at Woolworths!
  242. Fuel Hose
  243. FAO ford folks - cosworth clutch/flywheel diameters
  244. C20LET Code 38 (oxygen sensor low voltage)
  245. transfer boxes?
  246. what turbo? 3.5 let
  247. Removing head - c18xe - torx sizes
  248. Calibra heated seats loom?
  249. Smoking C20XE Help?
  250. injectors
