- 2ltr 16v engine wanted
- c20let engine troubles in a nova cutting out round right hand bends
- would a lightweight flywhell be less stress on the clutch
- corsa ecotech
- wht cr to go for with wht turbo
- Which clutch?
- wots needed to wire up a air/fuel meter
- exhaust manifold to turbo gasket
- Headlight level
- smoke on start up for 5 mins??? c20LET
- diagnostic plug
- Let / Xe Flywheel
- corsa z20let
- 20xe Big problem
- Throttle bodies
- Isuzu 1.7D alternator/vacuum pump
- c20xe crankshaft (what is this with row)?
- Transfer Box Check?????
- shells c20xe
- gearboxes
- code 49 voltage high.astra 1.6 16v
- Heat Shield question (Z20LET)
- does any have or know of a step by step guide to wiring c20let into mk3 astra gsi
- 1.7 TD suzy diesel rad..
- Nova XE Gearbox Questions...
- Equal length drive shafts
- What gearbox can i run on a c20xe engined corsa Gsi?
- C20 LET help
- 8v engine woes
- Gearboxes...
- got my engine out
- How much for a new coil?
- Oil Sump sealant with a rubber gasket?
- im after an engine picture.
- Help needed (LET Single Speed fan)
- fuel pressure query.
- fitting c20xe into nova
- help needed with c20let wiring
- 20ne/C20XE mounts help.
- C20 XE into Vectra gls?!
- Oil pressure light testing the wiring.
- Timeing Belt Snapped
- zlet cam cover unique?
- Just changed my CTS on the Vectra and ....
- c20xe just wont start
- how would these go for? c16 bits
- Corsa utility C20let mod
- Advice in Quaife Diff fitting
- gear linkage on XE corsa with F20 box
- size of frontera intercooler please
- Pic needed of the back of a C/X16xe
- do DCOE manifolds exist for the XE?
- rebuilding c20let for at least 400 bhp
- grooves in the head
- help gearbox
- C20let Eml On At High Revs/ Boost
- what vauxhall has 85mm pistons?
- Ecotec cooling issues on track
- how do you split the c20let ecu
- problem with wireing loom {burnt wires}
- Quick Q - C16xe - how much bhp on std clutch?
- head gasket yes or no??
- mix & match chips?
- Removing Lamdba sensor
- Where to get oil sqirters for let engine?
- f28 into mk4 astra
- urgent info needed for vxr injectors on c20let
- Nova XE Coversion Q
- morning,1.4 corsa sport engine question
- coscast question
- Removal of LSD
- C20xe Quesiton
- Is this turbo ok for this engine? (help!)
- grounding lamba on 2ltr ecotec??
- quick gearbox question
- exhaust
- c20let boost problems ???
- 1.4 corsa induction kit on a 1.4 astra??
- 1993 1.4 astra bhp??
- Clutch Quesion , Help please.
- C20LET running probs
- gearbox trouble
- X20xev parts on C18xe ?
- Engine loom help
- fuel problem or ignition problem/ help please!
- 1.2spi corsa pump with c16se engine
- Riming belt help needed (cam prob - part no check)
- X16XE Corsa sport engine into an X12XE Corsa sxi?
- head skimming
- Twin 40's on C20xe - are they ok?
- Astra Mk2 Bulkhead stiffening
- Phase 4
- c20xe missfire????
- MAX PSi to be used on a 'SE' engine?
- How much boost?
- leaky sump but not the usual
- LET oil temperature
- Long shot here...Anyone know the standard height of an R5GTT head?
- Radiator fan switch triggering temperature
- C20 Let Fan / Switch
- Help needed with head gasket? problems.
- water leak on xe
- Modification to f28
- XE Nova engine mount issues
- zlet engine covers????
- help urgant timing on doc ecotec engine for vectra 1.8
- will it leak compression?
- c20let ebay gasket sets
- which flywheel?
- Injector Valve...
- XE corsa conversion (pullys)
- bored c20xe
- Rod dimensions?
- missing v6!!!help
- standard fuel pressure
- FAO anyone with a working XE dizzy setup...
- boost valve on 2ltr ecotec
- Please Help 99% Finished C20xe Con But Won't Start
- Exhaust Manifolds
- Calibra clutch pedal
- Modification Advice Needed
- valve stem oil seals c20let
- valve stem oil seals on c20let
- Dump valve not dumping??
- Is it possible to 'straighten' a manifold?
- Loosing oil cap whilst driving ..... what does this mean??
- 2.5 v6 nitrous oxide
- 2.0 Ecotec
- Overfueling *** HELP ***
- C20let flange?
- corsa c20let f20 - f28
- HELP!!!!! finished conversion but wont start
- whose running a t35 turbo on a phase 3 let
- WTF have i bought? clutch for c20let rated 350bhp hmmmm...
- Corsa Turbo Q ? - Speedo Help ?
- De cat Z20 LET?
- C20LET T3 manifold and more
- regal?
- xe head
- what fuel pressure for c20let
- XE / LET
- Reprogramming ECUs
- 1.4 to 1.6 xe
- C20LET torque settings ASAP
- Running my Walbro pump inline with existing in-tank
- C20LET Cambelt
- where can i get a tubular turbo manifold made?
- Oil cooler fittings
- Ecu wiring diagram for Astra G Z16XE
- is it difficult to change a rear wheel bearing on corsa diesel l reg 1994
- inlet bolts on 2.5 v6
- C20XE ICV Bosch Part No.
- gsi xe power cap quicky!!
- Hybrid Turbo's and oil cooler
- 1.8 cav, to a 20xe?
- xe conversion
- 288mm/308mm Caliper Identification
- xe or let
- gt28/40r turbo
- How to test EGR valve and injectors?
- is my turbo seals going
- C20LET/Transmission info.
- 1.8 16v engine problems
- Earths on a C20LET
- Nova 1.6 Weber Jetting - Any Suggestions?
- F28 Mechanical speedo conversion
- Omega 2.5 V6 cambelt question?
- f23 diesal gearbox
- 2.0 ecotec sri cams ??
- Anyone know what cc astra vxr injectors are?
- C20LET running lean, changed loads of stuff, any suggestions?
- 125 bhp 1.8 or 140 bhp 1.8?? Which is best?
- sard fuel pressure regulator how do you set one up to the right pressure
- c20let stuttering between 3000rpm and 500rpm any ideas
- c20let crank
- x20xev engine trouble (calibra)
- F28 six speed in mk3 astra help needed
- c20let dizzy
- c20let standard pistons
- Downpipe heat shield removal
- Early XE crank shaft? Enigne years?
- who does turbo seals
- Just Bought An Astra 1.6 SXi - What Goes Wrong With Them?
- What injectors for c20xe?
- C20xe/C20let std valves
- replacing fanbelt tensioner on 1.6 8v astra
- corsa XE wiring
- help!! overfuelling and misfireing
- How can I find The Camshaft Details
- C20let Chip Help Please
- 20xej Help Please
- Underpowered C20XE...
- Vxr Injectors On A C20let??
- c20let distriutor
- Power cap ecotech pipe for a XE
- can some one post dyno graph for phase 2 c20let
- Can the ecu correct fueling if I increase line pressure?
- Oil cooler location
- f28 nova people
- 3ltr fuel pump on xe
- omega v6 , fuel gauge not working
- quaife ATB LSD
- 2.5 V6 Vectra losing power
- 1600 16v Rods and Piston in 1600 8v
- Oil shocks question
- mk2 nova clutch cable hole different to mk1?
- Wheres me chip???
- Corsa XE Help! - Whats the best radiator to use?
- brakes
- brakes
- Oil Pump Problem
- LET high idle/msifire/overfuelling
- Turbo dump/screamer pipes - will they pass an MOT?
- got 2.0 16v ecotec in gsi where do i start?
- Corsa c20xe Vs VTs 1.6 16v :P
- C20XE X20XEV ECUs
- cossie management in LET
- 2.0 redtop underpower
- eds phase 4 fuel pressure
- Help needed......3.0 cams number?????
- what block for c16xe?
- diesel engine cutting out randomly
- c20let, no spark
- nova let suspension
- Engine balancing n lightening
- will astra gsi back box fit 1.6 16v astra sport
- vectra B with X25XE help
- C20let no oilpressure
- Cams in the vectra V6? GSi better?
- c20 let dizzy
- oil leak calibra
- Calibra Turbo rear engine mount pic needed
- what do i need to do to get more bhp on c20let
- calibra turbo clutch
- X16xe revving like mad at idle and whilst driving . . .
- C20LET not starting !!!HELP!!!
- piston ring gap??
- c20xe oil getting in to throttle body
- How to test a cam sensor?
- urgent help!! fuel pressure regulator
- Corsa XE Build
- mk4 asrtra van standard headunit removal
- c20 let compression ratio
- which head gasket for c20let
- starter motor fecked?
- Convering a Dizzy head to dizzyless?
- wot clutch for phase 2 let?????
- high powered x16xe...what gearbox spec to go for?
- Would any Vauxhall 6 speed fit my Z16XE
