- help wanted xe throttle bodies
- c20xe help
- lower compression pistons for z18xe (corsa c sri)
- Is There A Definitive Guide On Here For A Turbo Conversion
- sump on mini xe
- Some photos of factory 2.0 8V Turbo
- final drive ratio with 71 teeth on crown wheel - F20 Box
- zlet low comps?
- LET actuator mod.
- has anyone fitted a F17 box to a redtop?
- f28 - electric speedo to cable speedo - easily done :)
- corsa LET - fuel pump?
- Phase III Fuel Question!
- Z20 Let Oil Pressure Gauge
- how do i test a ignition amp on a dis c20xe engine
- Fuelling for C20LET with Evo 5 and Saab reds
- too any who know nova let frnt suspension
- Phase 2 Bulb Fitment
- Engine Rebuild (but wich engine)
- Tran-x LSD ? id required
- Urgent - C20LET MAP/MAF Voltages
- Xe fuel reg? what pressure?
- help on turbo
- Oil change and coolant change on 2.2 Vectra C Z22SE?
- Turbo air restrictor
- xe bottom pulley
- Engine running-in/breaking-in procedure
- How much bhp can a redtop handle?
- bias pedal boxes
- turbo brakes and rear beam on corsa b need bigger master cylinder?
- c20let cutting out when held flat out for a long time, help need please????????
- c20xe questions
- C16xe Lexmaul inlet question
- External pump MK3 Astra LET?
- anyone know how to test a coil pack of wiring plug on a dis c20xe
- Z20 LET Oil Pressure Gauge
- C20XE, how is it ment to sound on full throttle ??
- EDS intercooler on my LET Corsa
- New Transfer Box Help
- nova turbo engine mount
- 20SEH with carbs
- C20LET showing 8K RPM but wont start!?
- ecu reseting on diesel
- Astra GSi 1.8/XE exhaust queries...
- Exhaust size Calibra Turbo???
- XE AFM
- let cutting out at high revs
- What thickness for LET exhaust flange?
- Ecotec Cams
- g13b map conversion
- C20LET vs Z20LET?
- does anyone know if the cranksensor from the old c20xe will fit the newer dis c20xe
- Cometic head gaskets?
- fitting intercooler
- Changing a clutch on a 1997 Calibra 16v HELP PLEASE
- can i use uprated xe cams on the c20let
- who can replace chips in my ecu
- advantage of xe inlet cam on c20let
- waterpump 4 Cav best place to get CHEAP
- C20XE into corsa, engine mount help.
- 8 valve cav sri into corsa b
- hesitation with new spark plugs (Z20LET)
- z20let surging problems
- What oil / grade would you recommend ?
- Plug gaps on early XE, anyone know them?
- Throttle Bodies, and Winter?!?
- Dump valve broken ?
- Carbs or Throttle Bodies?
- Will an F23 bolt into my cav turbo?
- Which Strut Brace For XE Corsa?
- nova fuel cap?
- turbo m*o*u*n*t*
- 2.5 v6 onto a f20 box im have trouble
- can you get new chips and transponders
- 2.0ltr corsa-b N/S engine mount
- Camshaft sensor Help
- pas corsa belt
- power cap
- C20 LET Flat spot
- xe uprated headgasket
- Which intercooler
- calibra camber/which bushes?
- 1.4 single point corsa running problem
- Coilpack/plugs help
- Cheapo clutch sellers in South West
- 8v head
- How few ECU loom questions.
- F28 / F20 4x4 Conversion Question
- Engine Number Q
- f28 speedo info
- Engine mounts 2L 8V
- temp gauge - 2.0 8 valve sri cav
- 2.5 td tuned chip, any good?
- X14XE and X16XE emissions standards...
- F28 Gearbox Problem help please.
- X20Xev problems !!!
- Sickly C16XE
- astra mk3 1.4 8v HELP!!!!!!!!!
- Corsa c20xe Question ??
- V6 Cam Question
- Black wire near ECU on Caqv Turbo
- cam for a 20L 8v
- frontera 2.2 bottom end on xe
- engine conversion
- X20XEV head vs X18XEV
- Tried to fit Phase 2 to my Cav today... Oops!!!
- Pistons??
- c20xe crank sensor problem please help!!!!
- c16xe exhaust popping
- Corsa V6 Conversion,Advice Needed
- Best V6 inlet system?
- what radiator
- Waterproof Air filters
- xe conversion gear linkage.
- Ecotec and xe manifolds
- Let + mvaux = intercooler pipes?
- 20Xe throttle bodies
- Interesting article on interpreting compressor maps
- **gear Box Linkage!!**
- What gearbox will give me a longer 5th gear on a 20XE?
- 18E cams. degree
- Cam shaft part no. XE or LET.
- X20XEV Crank Sensor V's XE/LET?
- X20XEV
- i think i knackered my LET..
- omega jammed ignition barrel
- C20 LET corsa almost overheating
- not staying in 5th gear
- Standard throttle bodies or tapered???
- LET crank trigger disc
- x16xe service
- carbon fibre boost pipes
- turbo gsi problem.......
- XE Induction options...
- A few XE Questions....
- nova speedo with f28
- any 1 got a sport head for sale
- Vectra shaft on a cavvy x20xev
- 1400 16v engine
- nova xe
- Bike carbs on a x16xe
- Crankcase ventilation, 2 ports.........?
- spark map
- c20xe?????
- V6 B*r*a*k*e*s!!
- puting 4x4 on a astra mk3 shell
- N/S Inner Driveshaft Boot
- Smeggedy smeg smeg smeg (cross threaded spark plug)
- Astra MK4 van C20xe
- astra 3 5 stud conversion
- Is there a 1.6 engine in a corsa C?
- conversion kit - hubs and driveshafts
- carbon fibre sheeting
- can i use a paddle clutch with a standard pressure plate
- 2.0l engines into Astra mk3?
- C20let Plugs And Leads
- xe pullt bolts sized help (suprise)
- F28
- OH NO!!! smoke coming out of air filter
- EBC or LUK clutch for F28?
- cosworth t34 on a c20let
- C20LET - Turbo keeps boosting with no control...
- X20XEV Engine Broken?
- Engine Cutting out Intermittently
- starter motor...
- corsa c20let ribbed belts....wot have people done?
- corsa swapp to c20xe or c20let - same way??
- strongest vauxhall rwd gearbox
- Best clutch to run big power on a nova?
- injector flow rate again !!
- corsa xe problems...
- possible reasons to cause random over fuelling
- How much can I skimmed my c20xe head?
- c16xe/x16xe
- X20XEV balance shafts
- Help tightning a fan belt....
- universal intercooler
- 6 layer head gasket
- URGENT HELP!!!! poorly c20xe
- Uprated front Gearbox mount, Where from???
- Equal Length Driveshafts Question
- Corsa C sri - 4 or 5 stud?
- Cavalier turbo clutch??
- Xe Water Pump Help
- Fuel Flow Damper ?
- were,s a nova 1.4sr pick it rev counter pulse up from????
- Headlamp surround for Astra GSI '97
- cheap exhausts?
- which performance manifold do i need?
- f28 fwd kit, hubs and shafts?
- Latest, car wont start
- head question?
- c20xe not starting?? plz help!!!!!
- Nova 1.3 Running Problems
- gsi fuel comp
- Corsa C needs new engine, but which would fit??
- c20let fault code 19 incorrect rpm signal (help)
- help please 2.0xe in corsa gsi
- can someone confirm..
- eml light on at 6k revs help please!!!
- Mk2 1988 Astra non starter :(
- Bleeding a cooling system on a C14SE
- Corsa sport 1.4 16v, wont blow hot air!
- f28?
- induction kit for 2litre ecotec!!!
- c20let howe to mesure compression
- astra coupe turbo brake advice
- 2.8 V6 with LET Pistons?
- c20let good sparkplugs
- Power Steering Leak - Turbo - accumulator block
- F16 in a turbo?
- Engine Oil!
- Hubs and driveshafts question - urgent
- code 31 20xe engine
- C20XE Flatspots??
- XE Inlet Cam on LET
- Blue smoke on idle (zlet)
- f28 gearbox
- Astra mk3 engine cutting out unsure why
- Corsa XE Manifold / System
- 2.0Ltr turbo corsa
- What 1.6 16v do Mk4 astras have?
- Mk3 Cav sri 8 valve
- code 61 fuel tank vent valve
- Can i flush my transfer box out with normal oil?
- Fitted chipped ECU, EML light now on????
- Any1 Done A V6 Into A CORSA?
- Oil pressure light
- phase 1 what psi.
- putting turbo on eco 2 litre???
- Engine Wiring Loom Question Mk4
- Z20let Manifold options
- Tigra c20xe No power!
- cams on c16xe
- Oil and battery q's!
- Annoying little problem... Engine Cutting out!
- Throttle bodies on x18xe1
- gauges C20XE in corsa
- oh dear think my clutch is dead
- Wossner pistons in an LET
- How to get big bhp out of the c16se
- Corsa LET Fuel Pump?? ASAP
- how to choose an early xe crank
- C20XE Corsa....Poss V6 Mount Help???
- are the xe and let conrod shells and big end shells the same
- Turbo needs to be mounted above sump height?
- early xe crank vs c20let crank
- engine managment light codes
- Engine Management Light Staying On Help
