- nova drive shafts
- repairing crankshaft on x16xe
- c22xe(c23xe) project it not seems so bad
- Calibra 4x4 questions
- mk2 turbo idle probs
- C20LET smoking loads
- Manifold
- Engine runs very cold is this normal?
- can anyone help with cams
- will de cat pipe of 16v eco fit 92 turbo
- chipped ecu
- vectra gearbox
- induction kits & exhausts
- the slippery slope, first engine mod done to the astra
- will an 8v calibra coil be the same as a red top one?
- Techie questions: Vauxhall ECU overrun fuel cut off rpm (Z16SE) / manifold adjustment
- what parts would you suggest i replace before putting the xe in ?
- enlarged throttle body on x20xev
- what bar should my zlet be running at
- Violent missfire and popping on boost..(let)
- difference between X16XE and X16XEL ECUs
- When re-fitting hydraulic lifters..
- i heard about R1 carbs on a vx engine
- alternator-how cam i test it when its not on car?
- twin carb set up guide
- Fuel filter clips on a Mk4?
- Where can i buy a Re-conditioned F28 Gearbox?
- X16xe Head Studs
- pistons for 20xe question
- arp bolts or not?
- fuel relay plz help
- clutch query
- nova c20let info
- let fuel trouble
- For People Not Wanting To Use The Original 4x4 Set Up
- FSE power boost valve
- still getting tps fault code
- x16xe wire help ( again )
- c16xe decatted
- f13 oil filling
- Astra mk3 dash oil temp and rear heated screen problem!
- Normal Compression Test Readings for ZLET
- Vectra 4x4 conversion
- C16xe Corsa head Bolt question
- C20Let oil feed question?
- Is my turbo a hybrid?
- XE Bosch AFM setup?
- Corsa c20xe Wiring Loom Question????
- people who got a SARD fpr from RHDJapan please read!
- Nova Sport engine identification
- cheapest place to get bits for me mk3?? ecotec
- I'm not understanding the Valve clearance 're'shimming' proceedure on my Cav TD :-(
- C20LET corsa!!!
- GT2871R or GT3071R on Z20LET?
- Nova Cam
- C20let astra 4 wont spark
- Alarm problem on Astra Coupe Turbo
- cav turbo fan (amp)
- long ignition leads for late 20XE
- Why not re-locate the cone filter to here ?! C20XE
- late XE AFM's again any others the same
- How much Oil: Astra Club
- Forge DV for Z20LET
- Head bolt measurement needed!
- Help Increase Power On X16XE Please
- corsa let-which f28 shud i use? cable or electric?
- Aquamist
- How can I change Oil ? 4x4 TURBO Transferbox
- Nova driveshafts, very confused what i have...
- Air Recirculating on a turbo?
- corsa driveshafts
- 2.0 xe breaks
- x18xe ECU error code - 34 -
- c20xe alternator
- corsa b 1.2spi
- C12NZ EGR Valve Removal
- Kenlow Engine preheater?
- very quick ecu/chip question
- more power x20xev
- I need to change the ECU on my X16XEL
- help to fit turbo timer on astra gsi 03
- de-cat- is it worth it?
- c20xe powercap help!
- c20xe wiring help
- let running bad after clutch change
- c20let which spark plugs and where from?
- wheres the fuel pump relay on a mk4 astra?
- C20XE Head gasket
- tuning c20xe engine
- CALİBRA tURBO 4X4 transmissionbox is broken
- code 0170 on simtec x16xel
- Gear cluster interchangeability (yes, I made that word up)
- Did someone say Supercharger??
- 4 branch manifold on 1.6 8V Mpi
- Nova LET intercoolers
- Trip Computer Loom
- engine management/best gear box for a 2lt nova
- Dump valve problem...
- c20xe AFM's any difference
- cav 4x4 camber problems
- Astra F 1.6 8v problem
- cav gsi 4x4 M5
- coil and amp
- need info on Quaife ATB (QDF2B)
- matheus turbo or red top transplant?
- LET - At What Kind of Power Should I be Using Head Studs Instead of Bolts?
- c20xe needs tappets
- C20Xe High idle!
- Nova GTE Gearbox
- C16xe running on 2 cylinders
- Z20LET Exhaust Manifold Studs
- EXHAUST - recommend me a Custom company
- v6 4x4 please help
- Corsa C20XE Missfiring
- fse power boost
- Tappets and followers advice please..
- 1.4SR cam into a C12NZ????
- Mayo on Oil cap
- corsa gsi re-map
- X10XE Box on C16XE
- xe corsa drive shafts
- Remoing The Wires In My Engine Bay (xe)
- best exhaust and filter for bhp gains on 2ltr ecotec
- nova gsi c20xe coil pack loom HELP!!!
- tubo a 2lxev, what do i need
- zlet feels slugish what is the prob any clues
- Full service Vetra Turbo Diesel, Any special tools needed?
- Recommend a clutch for 300bhp
- C20XE Low Compression
- cally phase 2 chip
- C/X16xe Pully picture required URGENT
- what driveshafts for mk3 astra with f28?
- Nova: Changing xe to let???
- cams for c20let
- 16 bent valves, 4 shafted pistons (pics)
- just bought red top calibra!! for transplant
- can anyone confirm these are c20let pistons?
- Oil cooler pipes
- Starter on a 1.7TD isuzu
- Cavalier turbo block removal?
- 3.0 V6 Cam Followers?
- xe missfire, any ideas?
- corsa sport 1.4 engine
- Haynes x20xev manual
- lambda sensor
- Astra 1.4 fast idle
- c20let engine warning light
- 2.0 Turbo Lump. (Coupe)
- throttle bodys x20xev
- Relaying/Wiring up headlights question....
- C20let lightened flywheel
- C20Let corsa question.....ribbed belt??
- GT28RS exhaust elbow? Any gen?
- Knocking Noise from rear and indicator/beam fault?
- manifold
- Best place to buy new 20xe parts?
- Quick questions regarding 20XE into MK4 astra FAO Dan/jamie F you have done one :)
- C20XE cold morning starting.
- C20XE ECU Fault
- tubular manifolds??????
- for when i xe the corsa...
- vectra ecu location?
- cavy turbo or vectra v6 pads
- corsa let bore exhaust???
- Coupe headlights
- possible crack manifold...
- Hydraulic valves
- exhaust on corsa c20xe
- pinking and power lack on 3.2 v6?
- how to get more bhp out of me ecotec!!
- anyone know anythin about audi gearboxes?
- nova redTop
- TPS sensor
- Ecotec ECU question
- GM Part number timming belt?
- injectors
- Oil cooler sandwich plate? Thread too small
- mk3 astra sport 1.8-big block???
- Redtop Hessitation Problems
- Water Injection On A C20let Yes?? No???
- cam question
- What angle inlet manifold for TB's in corsa??
- f28 gearset will not fit in f20 casing correct???
- 4wd Redtop Corsa...... HOW ???????????
- IC for Z20LET (big enough?)
- 1993 Astra GSi - no fuel pressure
- the zleh oil spray jets can i fit to a c20let help??????
- Vectra Gsi Msd Model??????
- HELP Astra 1.7td 1995 engine probs
- Bigger butterfly for c20let T/b
- 1st and reverse gear recognition?
- What oil for f28?
- Installing New Head Unit, Help With Old 1!
- X16xe ecotec vs. A16dms e-tec II
- F20 gearbox on C20LET (Mk3 Astra GSI conversion)?
- removing cat on 1992 xe engine
- red top conversion
- calibra clutch
- silicone hose kit for vectra x20xev ???
- difference between c20let cav an calibra pj ecu?
- Need major help with my F28 gearbox, can't line gears up!
- brake conversion???
- Manifold for astra mk3
- Z20lt Running Probs Help Me Plz
- Astra GTE Rad+Fan Fitting on Nova XE
- k16- any potential???
- The EGR and SAI blocked?
- LET, V-Max EVO 4 or EDS Phase 2, What to buy ?
- xe not sparking??? dis type!!!plz help.....
- Cavalier Ecotec, error code 93? running rough
- Hole size for c20let oil sandwich plate
- Do Vauxhall still sell reconned or newly built XE or LET engines?
- big c20let engine rebuild advise and help needed
- driveshaft problems for corsa b conversion
- Nova XE Throttle cable
- advise on oil spray jets
- are there any mk4 astras with big block 4 stud hubs?
- F20 - does input shaft need releasing before cluster comes out ?
- Gear Box Problem
- corsa clutch cable
- gsxr 1000 throttle bodies
- manifold flow/ nitrous input?
- silicone hoses for xe nova???
- Where to buy? Bosch 909 + ARP Conrods bolts
- damaged XE head repairable (pics)?
- Vauxhall Nova 1.4SR
- Green Wire on C20XE
- would you ppl use this setup for 400bhp
- Fuel Pump Wire ?
- 3.0 cams in my 2.5 veccy
- I want to supercharge my XE.
- How can i get a speed signal on my cav turbo?
- c20let wont start all the time
- Cambelt tensioner 24426500
- ****oil cooler pipe****
- Throttle posotion sensor *** HELP ***
- what alternator on redtop conversion in nova
- fk coilovers or eibach and konis on a vec gsi?
- help, any of you guys based in cambridgeshire?
- what driveshaft is this?
- Programming central locking fob
- Coolant Temp Sensor, how hard to change one on a Z20 LET?
- corsa air filter
- F28 Quaife ATB-LSD
- possible gear linkage issues
- corsa power-loss quiz
- C20LET oil pipe help please...
- b&S PH3 chips
- Which gearbox oil for my F28? and how much?
