Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. C20LET Uprated HeadGasket
  2. Do U Need To Change The Driveshafts On A C20xe Corsa When Fotting A C20let
  3. Oil problem
  4. rebuilding a let
  5. low oil pressure c20let
  6. SEAT problem after oil change
  7. z18xe starting problems
  8. wire loom wanted
  9. Can a cambelt slipping damage the crank?
  10. Flywheel weight of standard nova wheel (F10 box)
  11. corsa 1.2 16v paper clip test?
  12. let boosting probs!
  13. astra let electric speedo help desperately needed
  14. corsa xe help
  15. 1.2 to 1.6
  16. c25xe coded key
  17. keeping air con xe into arctic2 1.6 16v
  18. fuel pump voltage rating????
  19. red top with flat spots
  20. C20 Xe Ticking on Cold Start
  21. Calibra 16v SE2 Clutch & Accelerator.......Help
  22. urgent help needed c20xe conversion
  23. MK3 1.8 Carb Cavalier distributor, coil etc. Is a rev limit built in to the module?
  24. tappets
  25. anywhere in somerset to get upgrades for ecotec engine
  26. is it possible
  27. intercooler and gearbox
  28. lamba sensor
  29. mk3 astra gsi clutch cable ?
  30. Question about final drive gear
  31. c20xe throttle positon switch
  32. LUK clutches. Any good for stock calibra turbo?
  33. Oil spray jets
  34. C20xe into a C20LET Calibra
  35. Cally ecotec driveshafts
  36. F20 driveshafts from MK2 GTE into Mk3 GSI
  37. what should a standard kkk boost to ?
  38. c20let fault codes read-results!
  39. fitted kent cam now car wont idle (c14se)
  40. engine code for 1993/4 1.2 corsa?
  41. corsa 1.4 c14xe overheating
  42. mods required for bhp increase 20let
  43. Z20LET on a C20LET
  44. gte16v fuel plug?
  45. cavalier sri bhp ?
  46. Corsa XE conversion, multi v pully setup?
  47. Does thicker oil..
  48. what type of oil for a 1.2 8v?
  49. hydraulic clutch pump, question
  50. Astra mk4 - Z20LET transplant
  51. X20XE from Omega to a Vectra - problems
  52. c20let fuel problems update
  53. Power problems
  54. the ultimate C20XE guide?
  55. oil on 1 glow plug?
  56. let evo5 chips.+lots more/what next
  57. calibra turbo won't idle properly
  58. best radiator for a nova?
  59. f25 gearbox
  60. need help with a xe cally non starter ??
  61. Ebay Hydraulic Lifters.. Any good?
  62. Astra 1.4 Cambelt Change
  63. dump valve causing probs
  64. corsa turbo - probs? - soon as boost comes in fuel cuts ?
  65. help i have no fan!!! on my c20xe conversion
  66. nova with tigra engine?
  67. 1.6 16v Breathin like a goodun
  68. c20xe corsa driveshaft query
  69. how to bleed the water system c20xe???
  70. fuel at the fuel rail????
  71. gear linkage experts!
  72. matzel style inlet question?
  73. calibra turbo calipers on to nova
  74. E16se injector numbers
  75. manta coil
  76. f28 into let nova
  77. Flywheel type for LET with f28 box...
  78. Astra SRi 2 litre 8 valve 0 261 200 538?
  79. p2 chips fitting threads.
  80. What is the top speed of a f16 cr g/box
  81. how much £££ to make my let 300bhp?
  82. engine not gettin fuel
  83. XE Not firing right...
  84. Calibra engine swap
  85. 20XE Nova and GTE shafts - How strong and Anybody snapped one?
  86. C20let with f20 fitted...
  87. emissions on 20xe corsa
  88. C20XE installation
  89. c20xe corsa conversion
  90. Woohoo! Another XE fitted, I'm back on the road!
  91. c20xe corsa driveshaft/CV help
  92. C20XE nova experts?
  93. 2 Post Car lifts - Single phase, and 3 phase differences?
  94. smoke and sparks from 20SEH
  95. Smell of burning oil at high revs.
  96. Tourqin up the head in a 16xe
  97. driveshaft question
  98. C20LET on Evo 5 chips. What plugs / oil to use?
  99. Help identifiying xe wiring colours please
  100. Hoping you can help... Corsa 1.0 ECU/EMO
  101. c20xe to c20let
  102. Head gasket or oil/waterway crack?
  103. c20let pistons
  104. vectra c inlet pipe???
  105. valve stem seals. c20xe
  106. F20 or F16??
  107. how much does f23 gearbox weigh
  108. C20xe Power Delivery Problems
  109. Gearbox oil, how much?
  110. C20XE k&N induction kit onto a Z20LET?????
  111. xe/turbo exhaust question
  112. nova xe-let
  113. pics of peoples tubular manifolds on there c20lets please
  114. c20let corsa problem
  115. Oil breather smells .
  116. where to buy a turbo from
  117. Whoosh noise when removing plug lead LET
  118. Sandwich plate for oil gauges
  119. low voltage @ tps any ideas why......
  120. Cylinder head
  121. XE Conversion astra MK2
  122. calibra turbo
  123. x25xe tecnical info
  124. do i need a new ecu to go with new head
  125. kkk16 turbo vs t3 cossie turbo! how much better are they?
  126. Tuning the 1.7 dti y17dt engine what can be done?
  127. can you help with my xe problem?? vauxhall cant!
  128. Corsa misfire 16xe..
  129. c20let and 20xe wotparts are shared?
  130. Omega/Manta Gearbox
  131. Saab red injector number
  132. ignition coils
  133. redtop new headfitted now fault 93 help
  134. C16xe Tappets
  135. 1.2 8v camshaft swap
  136. can i automatic a red top
  137. red light cameras ??????
  138. Nova fuel leakage and tank Q....
  139. sump fitment
  140. zlet turbo prices?
  141. where can i get a manifold welded to a let flange?
  142. Which chip for a redtop engine
  143. TPS for Weber Twin 45s
  144. Drive Shafts
  145. omega leak off pipes + torq head size
  146. sticky valve
  147. injectors
  148. anyone here good at head? in swindon?
  149. only runs on full throttle
  150. xe in to diesil corsa combo
  151. x14xe help
  152. corsa gearbox mount
  153. throttle position sensor/potentiometer sensor
  154. A bit of advise needed (astra mk3 clutch problem)
  155. corsa 1996 1.2 problem
  156. 1.4 16v engine- What sort of realistic power output
  157. Mk3 engine swap
  158. Fuel Gauge Resistor Value
  159. few probs with ecotec cally, need guidance
  160. OK got spark, and does not start...
  161. speedo cable removel f20 gearbox
  162. No engine managment on Corsa 1.4
  163. Building a Ph2 Nova Turbo
  164. HELP, with coolent pipes or corsa c20let
  165. clutch removal tips eco calibra
  166. Astra 1.4 few niggly bits
  167. Ecotec specs? Bore x stroke? CR?
  168. what de cat pipe fits calibra turbo?
  169. very sick 2.0 sri 140
  170. Query running aftermarket + two pumps + gt28rs...
  171. £1700 to spend on my nova, what should i get?
  172. Does the Spark plug spark if the crank sensor has gone?
  173. ECU Fault Codes Plug location on corsa B
  174. Ecotec S And The Z20let Motor Differences
  175. x14xe Questions
  176. Diblas Z20let flowmaster kit - Any good?
  177. A catalogue of errors
  178. Nova xe, cav hub modding !?!
  179. Arcing Across Leads and to Cam Cover - Rotor Arm Resistance?
  180. xe corsa equal length driveshafts?
  181. exhaust
  182. 1.4 8v tuning
  183. How much bhp would I gain?
  184. Fuel hose
  185. c20xe corsa wont spark
  186. xe loom help!
  187. c20let uprated internal parts
  188. Isuzu turbo diesel tuning guide
  189. Bonnet Lifters Gte
  190. Aftermarket managment question
  191. c20let overfuelling and missfire occurance
  192. veccy 2.5 v6 engine differences
  193. AirBox on C20 XE Corsa
  194. Astra Mk3/F gear linkage
  195. X18XE1 Block
  196. nova 16v fuel pump
  197. Advice needed on my Vectra engine block
  198. let ecu questions
  199. Corsa 1.4 16v Sport.....gearbox problems??
  200. whar are the dimensions of the frontera intercooler
  201. Very Poor Headlights
  202. stupid black box nr ecu
  203. ecotec to c20xe question
  204. crank senser on X20XEV ??
  205. new head on the xe and it wont run
  206. 16 8v MPI into a corsa, 1.2 8v SPI
  207. Tuned X16XEL only gets 140bhp
  208. C20XE Over heating And Weird idleing
  209. what timing does a standard let have?
  210. Whats Best for Bodging a rusty Fuel tank?
  211. Removing Lip off on LET/XE RockerCovers....
  212. What's the better in-tank fuel pump for a corsa?
  213. serpentene belt
  214. SBD Valve springs and caps
  215. 1997 vectra v6 front headlight bulbs blow and dash lights flash? what is it?
  216. nova turbo owners, intercooler/rad question
  217. 20xe Engines dizzie or dis module... what do you prefer
  218. spi nova/mpi engine what needs to be done?
  219. Custom turbo oil feed - advice needed.
  220. Corsa XE inner cv's?
  221. Lumpy idle on 1.8i
  222. Oil Filter problem!
  223. 1.4 8v cam followers advice needed????
  224. Anyone got any pictures of how an XE/LET ECU mounts into a Mk2 Astra footwell?
  225. Rs turbo maniford on c20let?
  226. X20XEV Ecotec Simtec 56.0 Wiring Diagrams?
  227. What inlet manifold do I need fo TB's???
  228. Do Z20 LET's have an ICV?
  229. coil
  230. How to fit oil pressure/tempreture gauges on a XE?
  231. whats needed to put an xe in place of the ecotec?
  232. timing belt advice??
  233. astra gsi c20 let
  234. Clutch Problems
  235. X25xe Timing Belt Problems...help!!
  236. Strong petrol smell from my corsa
  237. induction kit help needed
  238. omega spark plug, missing centre electrode
  239. zlet Dump Valve Help
  240. c20let removal from a calibra turbo 4x4
  241. Clutch retrofit..
  242. LET turbo smoke
  243. mk4 astra exhausts.... quiet one please
  244. fitting a clutch
  245. coil
  246. chipping my let! havings problems
  247. "chipping" a GSI Turbo?
  248. 1600 8v 4-2-1 Exhaust Manifold
  249. Fuel Gauge
  250. Tuned 1.4 or tuned 1.8
