Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. Engine knowledge 1.8
  2. Rocker gaskets???Where from??
  3. Car wont start
  4. clutch slip
  5. volt /oil meter clocks
  6. cambelt..........
  7. nova intercooler
  8. Temperature Sender on 1.4 Corsa SRi?
  9. astra mk2 / cav fuel tank question
  10. Removing An engine
  11. dynamic headlight beam control
  12. c20 let rebuild
  13. Corsa C brakes and sump plug.
  14. Astra VXR injectors
  15. Corsa driveshafts
  16. Mk1 astra and mk2 astra manifolds
  17. Engine management light
  18. what can stock x16xe con rod's handle
  19. c20let sump gasket
  20. Should tappits on redtop be replaced?
  21. Engine swap Cally 2.0 8V help advice welcome
  22. FAO C20XE Corsa owners
  23. xe cams which ones?
  24. Have I blown my 4x4 circuit?
  25. head tech talk
  26. Transferable parts from the 20xev to c18xe
  27. F****D XE
  28. Nova sri-c16xe wiring Q
  29. cav turbo wheel bearings
  30. Symptons of fuel Pump Failure ?
  31. Help needed with gearbox....
  32. proper video of problem with my xe see what you think please
  33. info on XE's running bike carbs
  34. Bike carbs on an xe!! What distributer etc??
  35. oil/volt meter
  36. Driveshaft popped out not under warranty????
  37. X25XE / C25XE question ASAP
  38. v6 nova help!!!
  39. AAAAAA HELP i have daylight seeking conrods on my 20xe
  40. autosprint cams
  41. interference engine?
  42. recommended spark plug for C20LET
  43. rwd props and axles???????
  44. Vacuum pipe missing on a sensor. and only getting 12psi on P4
  45. Key Reprogramming
  46. Cam dialing
  47. fitting a mantzell powerbox
  48. 16xe inlet manifolds .. different types (pic)
  49. c16xe nova
  50. Nova xe suspension on a budget ?
  51. Cams and Verniers
  52. reg plug
  53. x16xel water pump and cambelt gone is the engine non iterference
  54. X14XE fault code
  55. Changed the dump valve on my LET, now runs lumpy.....
  56. Motronic 2.8 reader?
  57. Afr Gauge C20let
  58. whos got phase 3.5
  59. Corsa C20xe project
  60. what is the best colour for an intercooler?
  61. pistons for c20let
  62. Rev limit on LET, standard and Evo 5
  63. Astra Coupe Coilovers
  64. renewed c20let engine !!! Ask...
  65. LET & XE Cam Part Numbers Needed
  66. What fuel pressure with vmax evo 5?
  67. Amal valve wiring
  68. driveshaft condition
  69. xe starter motor
  70. vectra engine numbers
  71. Does anyone remap SPi ECU's?
  72. what gearbox from cesaro
  73. getting behind the inlet on a 2.0 16v corsa
  74. c20let in to vectra
  75. help! quick question
  76. Astra 2000 w reg. engine died Help.
  77. V6's and Redtops into Isuzu engined Astras
  78. c20let f28
  79. corsa c bulkhead leak
  80. problem with oil leaking
  81. c20xe noise
  82. c20xe corsa mounts
  83. corsa let temp gauge queiry.
  84. Nova GSi engine identification! Help!
  85. Tigra 1.6 headlight bulb change
  86. Reconditioned X14XE. Prices?
  87. Where to get Coilover spring seats ???
  88. Would a worn camshaft...
  89. has anyone got a guide to taking out an x16xe ?
  90. mk3 astra induction kit.
  91. 6 speed gear box
  92. 2.5 gsi cams
  93. Corsa engine management light
  94. arp bolts???
  95. gearbox
  96. Vectra MK2 HID Headlights
  97. Lambda and non-lambda 20XEs
  98. Engine rebuild
  99. corsa diesel leaking injector
  100. C20let clutch which make??
  101. Weight of an F28 gearbox?
  102. just fitted bi-xenon kit
  103. urgent help clutch problems
  104. remap
  105. C20XE clutch advice
  106. z20let oil leak
  107. Omega Engine Removal
  108. C20let amal valve location
  109. Shell - V Power
  110. TPS Adujstment
  111. My car idles at 4krpm and stay there (C20XE
  112. reprogramming astra gsi fuel computer/mfd for C20LET ??
  113. 1.6 Astra engine change (X20XEV)
  114. are the driveshafts on my nova 22 spline
  115. driveshaft trouble
  116. running in
  117. Radiator Problem . .
  118. C16xe Loads of fault codes!
  119. LET/XE Exhaust Manifold Gaskets
  120. new steel head gasket torque figures
  121. Quick question about valve springs?
  122. V6 novaaux belt? anyone found one yet?
  123. oil changes/serviving???
  124. tune up c14se or c16se
  125. Compression Ratio on Accralite Pistons
  126. nova sr cambers and angles
  127. C2olet Pipe?
  128. Powerboxes (dbilas/mantzel)
  129. c20let exhaust manifold
  130. help removing c20let and 6speed g/box
  131. ecotec idle problems
  132. what gearbox came on the astra coupe turbo
  133. C20XE stuttering under load at low revs
  134. x16xe, what 4 brancher should i use??????
  135. C20LET hesitation on LET under high load/ high gear
  136. How would this help a let with kkk16?
  137. C20LET Fuel pressure issues
  138. clutch?
  139. C20XE head on X20XEV
  140. Coolant boiling over LET
  141. Nova TD (ISUZU) wont start..odd
  142. c20let modified downpipe similar to DSOP anything considered pics please
  143. Corsa diesel cambelt change
  144. Can a smallblock be fitted to a nova with tiebars in place?
  145. help needed about xe inlet cam
  146. Help needed, 1.4 16v bore and stroke figures needed!
  147. Phase 2 chips fitted correctly ??
  148. let into a corsa
  149. Wot Radiator For Mk2 Gte Turbo???
  150. Idle pulley mount late c20xe!
  151. calibra turbo - worn driveshafts??
  152. Shortening cav shafts for xe nova !?!
  153. Would an overbore affect fueling on a phase 2 LET?
  154. phase 3.5 wires
  155. Whats an evap canistor purge valve and how do i test it?
  156. XE into mk3 diesel van? C20LET mini?
  157. Vauxhall Vectra/signum F40 6 Speed Gearbox Manual
  158. Running amal valve/MBC on aftermarket turbo
  159. Exaust and Air filter
  160. STRANGE CHIPS LET is anyone familiar with these
  161. C20LET Crank pulley Torqx socket size?
  162. wiring c20xe in nova
  163. Aftermarket injector loom
  164. C20LET Tapping/Knocking (only bought 3weeks ago)
  165. f28 clutch, look at the pics and see if you can help!
  166. Turbo questions
  167. c20xe conversion problem in my corsa B
  168. uprated in tank pump for c20let corsa b?
  169. "c20xe" sfi in nova
  170. xe running problem help...
  171. oil pump-signs on gear wheels
  172. which carbs
  173. Oil PRV operation.
  174. If i was to turbo my XE....
  175. injectors help
  176. Custom ex. manifold & rack
  177. Clutch for a TD Cavalier
  178. dumb question: how to tell a 2 part sump...
  179. best plugs for a c20xe dissy type??
  180. frontera intercooler on mk3 gsi
  181. Help, fuel problem?
  182. c25xe conversion into mk4 astra coupe 1.8 16v
  183. corsa c engine swap
  184. F28 with electric drive, changing to mechanical.
  185. Is it safe to weld a precat?
  186. xev into nova from corsa
  187. New girl needs help!!!
  188. comma oils
  189. corsa diesel struggles to start in the morning
  190. X22XE Pistons
  191. why not turbo a 2.5 V6
  192. Replacing a head on a R Reg Vectra
  193. LET coolant temp sensor
  194. pug 306td changing fuel filter
  195. C14SE to C16SE (is it possible?)
  196. LET performance observation
  197. twin carbs and tickover
  198. c16se turbo ?
  199. Astra Gsi Power?
  200. what oil do i use at first, in a rebuilt engine?
  201. Drive shafts??
  202. Turbo & Supercharger??
  203. engine swap
  204. what can i replace the amal valve with (c20let)
  205. f28 in a nova
  206. losing oil?
  207. xe fuel pump relay
  208. AFM HELP
  209. Auto to Manual X20XEV
  210. What is this??
  211. Cav Turbo 4x4 Transfer box advise please !!
  212. Accusump Install Question
  213. What size cold air feed C20XE Viper Induction kit
  214. looking for a rebuild
  215. Pot type c20xe flywheel
  216. C20let clutch question
  217. Head Gasket on Corsa C
  218. Mass Air Sensor? engine cuts out.
  219. Calibra Turbo Front shocks
  220. DIY Cam Fun - Is It Possible ??
  221. Gearbox on C14SE
  222. What Intercooler is This???
  223. is astra 1.7 diesel turbo rad same as calibra turbo rad
  224. 1.2 Corsa into 1.4 SRi Corsa
  225. x20xev to z20let whats in volved
  226. imoberliser question!! c16se astra f
  227. Driveshaft hubnut to what torque?
  228. where can i get the cheapest clutch 20xe???
  229. HELP vxr injectors what fuel pressure
  230. sfi to tb gasket part number?
  231. picture and dimensions on a calibra turbo air fliter box please
  232. urgent help needed gear box change c20xe astra gsi
  233. Cavalier F25 into Vectra?
  234. Headlights always on even with ignition off
  235. [FAO 2.0 corsa owners] before lsd and after ?
  236. Ecotec key code question???????
  237. Calibra SE2 Cat/Exhaust
  238. Fuel computer from Cav GSi
  239. fiesta 1.25 tuning help please
  240. c20let ecu in a cav gsi question!
  241. Corsa block in a Nova
  242. Power Steering Fluid - Bleeding 4x4
  243. WTF is this engine? Redtop or Ecotec?
  244. 92 Opel Monza 1.6 Gsi gearbox question
  245. Late XE dis pack ignition question
  246. x16xe
  247. Peugot 106 1.1 headgasket
  248. corsa b. m-tech front engine mount
  249. corsa xe help
  250. Unknown Head
