Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. Is the LET inlet manifold the same as XE?
  2. Corsa Wiper Motor & Linkage on a Nova?
  3. Washer Jets Blocked
  4. nova 1.2i decat question??
  5. saab GM 3.0t engine?
  6. 1.2 corsa merit....very slow help!!
  7. Turbo Bits
  8. c20xe headgasket replacing
  9. Flushing engine with petrol?
  10. angel eye headlight wiring help plz
  11. Help with Idle Control Valve cleaning.
  12. Lambda on early Astra GSI
  13. Custom inlet manifold on x14xe
  14. Name that manifold
  15. xe ecu fault flash out codes plz
  16. Z20LEH with XE/LET head???
  17. C20XE Camshafts into a X20XEV
  18. Fan belt on a turbo ?
  19. Gearbox specialist south wales needed
  20. Fabrication
  21. autovaux lambda sensors
  22. C20LET / C20XE exhaust flange...
  23. HKS Turbo Dilemna
  24. boost
  25. v6 F23 Gearbox Lift Reverse?
  26. T34 turbo owners
  27. how to plumb up mvaux kit without amal valve
  28. astra gsi fuel computer??help
  29. problem with my c20xe
  30. f28 2wd kit
  31. Head Gasket
  32. f20 and shafts
  33. my engine has a big problem?
  34. f28 flywheel
  35. Vectra ecotec 2L 16v G/Box problems
  36. cav mk2 1.6 inner cv's part number?
  37. Coilover Camber Adjustment
  38. quaife atb lsd fitting
  39. Corsa Xe Manifold
  40. Cav Equal Length Driveshafts
  41. 'Gurgling' noise on turn of key (b4 engine starts)
  42. C20LET Pistons CNC can be used?
  43. x16xe/c16xe lower inlet size
  44. cally engine rebuild help please
  45. F28 2nd gear synchro supplier needed?
  46. Whats needed to turn F28 to hydraulic clutch
  47. mbe 976e mapping south wales or close
  48. clutch pedal help
  49. over fueling
  50. C14NZ rad hoses vs X16SZR..same size?
  51. F28 differential bearings
  52. CTS problem
  53. 1.3 inlet manifold
  54. Battery tension in Corsa C20XE
  55. Hydrolic clutch problem (vectra)
  56. EDS phase 3 question
  57. Comparing garrett turbos - Are the flanges the same?
  58. Tuning C20Xe?(Corsa)
  59. What can cause high Lambda readings on LET?
  60. Equal length shaft setup???
  61. wat size bolts for XE sump?
  62. MBE mapping in south east????
  63. Mystery gurgle, hope its not serious...?? (Astra X16SZR)
  64. what clutch to use
  65. Engine code required
  66. Corsa Sri 1.4 8v(MPI) Problem
  67. How hard to change clutch
  68. c20xe fault codes
  69. fitting 2.0 turbo into my corsa
  70. exhaust fitting on a mk4 astra 2004 vx sport
  71. C20LET error code 41. and how not to get it
  72. Aftermarket Engine Management System for C20let help needed
  73. corsa xe problem(weak spark)
  74. Exhaust fitment question
  75. Petrol engine swap on a diesel van??
  76. cams
  77. mk3 astra ecu diagnostic plug help
  78. XE/C20LET Alternator picture request
  79. f28 2wd quaiffe diff fitting
  80. does vectra c dti have same turbo as vectra b dti
  81. tps high voltage
  82. 1.4 single point injection cutting out
  83. c20let tuning, whats best to do next
  84. Avo coilovers, any good?
  85. Raspy C20Xe with 2.5in s/s
  86. Exhaust noise
  87. fitting 20SEH into 1.4 mk2 astra, engine mount advice needed.
  88. c20xe in a 5 door corsa?
  89. Removing EGR valve
  90. Tigra fuel pump cover
  91. z20let fuel rail/injectors?
  92. c20xe on f13 box?
  93. Red Top for Eco
  94. genuine stretch bolts for XE???
  95. Turbo experts look
  96. Unplesent gear change feeling!
  97. please help ecu light!!! c20xe
  98. redtop problems
  99. Does anyone now (Z20Let)
  100. Does anyone know
  101. x20xev aux belt diagram
  102. ICV pipe to inlet box on xe
  103. "HOW DO I" plug the exhaust cam when losing dizzy???
  104. petrol gauge sensor
  105. Misfiring after Head gasket Installed
  106. C18SEL?
  107. part number for C20LET knock sensor?
  108. LET turbo oil return question???
  109. LET recirculating valve problem
  110. Looking for fuel maps
  111. whats the 6spd fitted to the z20let?
  112. 2WD F28 and astra driveshafts.
  113. Gearbox problem""winning"
  114. Headwork
  115. Clunking Noise on C20xe near Driveshaft
  116. Frontera B 2.2 Manifold (EPC Request)
  117. f28 on c25xe in nova?
  118. z20let turbo to c20?
  119. Lowering Corsa Tie Rods
  120. X16XE Map
  121. xe/let. same inlet???
  122. power help
  123. Kent cam but risse punched
  124. Astra Mk5 Sri Diesel Engine In Astra Mk4
  125. ARP flywheel bolts gen!?0dders?
  126. ***injectors***
  127. 1.2 8v corsa b won't turn off!
  128. redtop problem in corsa B
  129. clutch help
  130. plz help r the air flow meters different between the early c20xe and the dis type?
  131. f28 into mk3 astra
  132. screaming sound from engine?
  133. Astra G Gsi (z20let) engine light on any ideas?
  134. F16 bell housing vs F20 bell housing
  135. c20let conversion probs
  136. help mvaux 350 kit manifold is not straight
  137. Fitting a starter motor to a calibra???
  138. So.. I weighed the F28
  139. what pipes does my mate need from the xe to v6 conversion in astra ?
  140. F25 out F20 in??
  141. Rwd,4wd,fwd?
  142. Fuel pipe setup for red top engine - experts required !!!!
  143. f13 on to redtop
  144. 200SX Manifold -WELDING
  145. Help needed in redtop conversion in corsa B
  146. Why do LET corsa'a have a speacial power steering bracket
  147. Anyone know how to get electronic speedo working in cav turbo?
  148. Tappets noisy after rebuild, and cams ?
  149. Cav red top or vectra 150?
  150. Which heads for my Corsa V6
  151. Corsa Xe shafts(Clunking noise & F20 gearbox)
  152. Removing Gearbox without engine
  153. Questions about F28 tranny conversion
  154. Making c20xe power cap !?!
  155. corsa xe shafts
  156. high voltage on tps
  157. What 1.8 16v had exist?
  158. Zafira 1.8 cutting out above 2.5k
  159. Cav gsi and Calibra 16v exhausts
  160. Rebuilding my LET (XE inlet cam? tricks/mods)
  161. f20 gearbox info
  162. Fuel gauge sender snapped !!!
  163. Exhaust sizes Astra mk3
  164. tps low voltage help asap
  165. building a turbo engine
  166. Performance manifold
  167. How nuch gearbox oil??
  168. nova xe hubs
  169. How do you know if a camshaft is worn?
  170. XE Conversion corsa guide!
  171. this is for c16xe/x14xe/x16xe owners who have either throttle bodies or an aftermarke
  172. ZLET Actuator
  173. corsa 2.5 v6
  174. Baileys Dump valve service kits?
  175. nickel seal liners
  176. New Block
  177. price for complete XE rebuild?
  178. a dummies guide to LET please
  179. Best Injectors
  180. gearbox help
  181. What plugs????? (Phase 2)
  182. 660cc injectors on Motronic ECU?!
  183. Cavalier 2.5L V6 Exhaust bore?
  184. Where is the egr valve on astra 2.0 diesel??
  185. corsa diesel shims how much do i grind off
  186. c20let +f28 mounting kits for corsa B
  187. let's running greddy emanage?
  188. corsa diesel 1.5 how do i find TDC
  189. headgasket??
  190. end of the f20?
  191. diy coil overs
  192. engine not pulling, at all!
  193. random flashing oil light on 1.2 corsa?
  194. Xe Running Weird..
  195. C20LET ECU designations
  196. 3 ecu codes coming up fssss
  197. F13 hybrid gearbox questions
  198. mvaux turbo kits is it all there
  199. Spark plugs sooting up?
  200. corsa sri egr valve
  201. Another fine C20LET ruined.
  202. are the c16xe and x16xe throttle body the same?
  203. Head gasket or oil cooler???
  204. Car xe problem update
  205. ?omega headlights? can anyone help?
  206. Looking for rear coilover kit for Astra Mk2
  207. tec info on amal valve needed
  208. Couple of LET related questions...
  209. F28 gearbox oil capacity, and other question...
  210. 3.0ltr v6
  211. carbs or injection
  212. air mass sensor is a 1.8gsi is it same as the c20xe one
  213. Xenon headlights point right
  214. Which head gasket for a C20XE running 220bhp?
  215. Just fitted an induction kit.
  216. Engine Loom Part Number
  217. Bottom pulley x16xe removal
  218. Re-routed XE throttle pic's needed
  219. HELP. Just blew my engine up.
  220. afm quick question
  221. nova lifters
  222. nova lifters
  223. xe/let head to z20let bottom
  224. c20let-which head gasket guys
  225. engine fault
  226. Noises under C20XE Calibra: advice please?
  227. zafira gsi engine loom same as mk4 turbo gsi/sri
  228. Headgasket or Condensation?
  229. x16xe cams better than x14xe cams?
  230. re-fitting timing belt to a x16xe (timing marks?)
  231. Can i use 8 valve filters on a 16 valve car?
  232. Corsa XE vs ?
  233. Ecoflex Service / Vauxhall Longlife Oil your feedback please
  234. fuel pump not coming in on project
  235. water pump on xe
  236. oil cooler pipes
  237. xe engine swop
  238. Bonnet release catch astra mk4
  239. Manual Gearbox
  240. Bypassing Fuel Pump Relay....
  241. gearboxs
  242. drive shaft and cv help
  243. xenon bulbs
  244. c20let compressions????? what is good and bad for these motors??
  245. How do you replace the shims on a corsa diesel
  246. which chip for c20let to give me around 300bhp??
  247. c20let calibra scrap engine
  248. Coscast head measurements
  249. c20 let starting problems
  250. mystery plug under mk3 astra air filter housing...
