- C20NE starting problem
- Do Corsa GSI shafts need modifying for C20XE conv.?
- x20xev engine mount on c20let
- Need help asap c16xe sump plug
- How to increase stiffness in engine supports?
- X18XE1 Pistons/CR Question
- 200 sx manifold
- Astra DTi - TD conversion
- X20XEV Plug Lead Diagram
- i need more BHP.....
- Yet another engine question?
- Mrk 4 astravan conversion question?
- Wanted Cheap Turbo Engine
- **TURBO**
- Cally Radiators
- XE can question
- vectra dti is exahust manifold gasket metal
- turbo question
- LET running rich ??
- rose jointed linkage???
- Let'ing a Nova
- Weird LET/F28/TXB issue.
- Nova 6 speed linkage (f28)
- gear linkage bushes.
- Will this camshaft fit my MK3 Astra?
- Corsa Sri Simple Modifications?
- 1.4 engine swap
- 8v 2.0l engine BHP differences
- Corsa Cylinder Head
- non start ecotec
- ecotec tapping
- powerflow ?
- are astra mk3 20xe manifolds different/longer to the c20xe?
- loss of power
- Adjusting camber on mk3 Astra
- Astra 1.6 8v idle and kangarooing problems
- Head compatability
- Camshaft question
- vectra dti vauxhall wont sell me an egr valve
- Brake bias valves
- Corsa Sri suspension and modifications
- How do I get the driveshafts out...?
- Z20LET balancer shaft removal.
- z20let rebuild kit
- c20xe carbs
- AFPR Controller?
- whats a corsa gsi engine worth
- 1.2 sxi 2003 corsa
- X16XE - coil pack - how does it work?
- re-built c20let is a bit smokey, anyone might know the source?
- Rebuilt Engine Mis-fire!!! HELP!!!
- german info on rally C20let engine design
- do turbos have a small amount of play in the shaft
- f13 gearbox on a x14xe ?
- MK 1 astra wont start!! (2nd thread)
- 2nd chewed up cambelt HELP!!! (1st thread)
- Aerocatch Flush fitting bonnet pins - anyone have any fitted?
- linkage problem
- Could somebody explain this... 8v Engine not starting!
- cav 2.0 ecotec front mount.
- turbo convertion
- C20let Trouble Code Help Please
- old Tigra 1.6 - how do you remove distributer cap?!
- garrett t15 ang gt15 are these the same
- vectra let conversion
- X30XE in calibra
- Quick clutch question
- chipping my astra c20let
- 1.0 12v to a 2.0 8v ecotec conversion on a corsa
- c20xe corsa Gsi
- Astra GTE 8v - Dispac XE Wiring??
- help ive done a 1.8 astra gsi into a c20xe do i need to change the fuel pump to a 2l
- clutch change in a vectra 2.0gls 1996
- Fault code 116
- 6 speed gearbox on a 2.0 8v
- Phase 2 in LET?
- Inlet question
- Corsa B 1.4 sri gear linkage problem
- engine conversion trouble from x12xe to c20xe
- Fuel tank and swirl pot setup
- c20xe pistons in a c20let?
- calibra turbo calipers onto mk4 astra?
- egr valve leaking oil on vectra dti 2.0 wll it affect running
- c20xe cylinder honing
- 888 REMAP
- Mk3 Astra Gsi to C20Let Problems.. Help.
- old Tigra 1.6 - 3 clean plugs and 1 sooty 1!! any ideas?
- fitting lsd
- C20XE oil pressure sender voltage?
- poor top speed, c20xe corsa
- 2.2 & F28 into a Corsa B? (Newbieish)
- Can you buy rebuild kits for the KKK16 Turbo ?
- XE into Corsa B
- Z20let Into Corsa B?!
- 2.5 v6 into a astra mk4 1.8sri
- c20 let porous head
- C20XE Running Problems - Badly Overfueling
- still no joy in starting my xe
- Who can do my engine swap?
- zafira gsi exhaust manifold
- 1.8 8v tuning
- Fitting Evo5 Chips Wot Fuel And Boost Pressure???
- help astra gsi mk3 c20 let subframe issues
- Turbo blankets? any Gen?
- how do i know which gearbox i have? numbers,etc
- Engine swop troubles
- z20let 9lt Intercooler
- What Kind of Engine is this?
- Mr MSG, your engine
- Clutch Change on 2.2 Vectra
- v6 in a astra 1.8sri
- Bike carbs-Which to choose
- c20let nova running funny
- bonnet catch
- 2l cav felt like a 1.6???? massive power loss, but not misfiring!
- would a old fuel filter and pollen filter make a car run bad
- engine swop: 1.8SPI into nova
- Engine swap: 1.7 TD into Corsa
- Is the V6 Cav Manual Wiring Loom the same as an Automatic One?
- Is the x18xe1 oil pump used in other block?
- corsaLET help
- chip fitting
- 20seh modified engine
- ECOTEC 16v 1600 excessive oil consumption? Or have I entered a Vauxhall Twighlight Zo
- Mvaux & Zafira
- C20NE
- engine management & oil light keep flashing
- c20xe in to mk 3 astra
- Nova Gsi manifold
- F10/f13 gearbox?
- That damn oil light
- XE crank sensor problem...
- turbo smart dump valves???
- engine conversion?
- Reading Mk3 Astra Auto gearbox codes - what pins?
- x1.8xe ecotec with 2.0 pistons???
- Engine management light on Astra LET?
- Best filter for LET?
- Fuel Consumption for 1.9CDTi (150BHP) engine??
- 2.0l 16v Ecotec info please
- DSG gearbox.... in Meccano.
- Calibra volt/oil pressure gauges in mk4 astra
- 18xe .. runs but starts badly
- Blocking the OE dump valve with a spacer...?
- equal lenght driveshafts on corsa
- Weight of an XE head?
- x14xe EGR removel :P
- Intermittent rumbling noise on C20XE Calibra - possible courses?
- Petrol Smell
- Gapping rings for large boost/nitrous...
- xe starting problems
- f20 gear box on my astra problem??
- my dis c20xe should it have a cat on it? can i tell if it should or shouldn't?
- Fitting valve guides to a c16xe
- carbs
- what gearbox?
- calibra rear camber help!!!!!!!
- Shallow sumps / Manta Sumps
- C20XE Group N Cars
- Help with Astra exhaust... Pic required
- D.I.Y. Coilovers...Anyone attempted this?
- Tigra X14XE Crank Removal
- 1.6 16v into nova?
- tx box test
- X18XE1 Safe head
- astra gsi fuel computer??
- c20xe into astra sport 1.6 16v
- fitting c20xe corsa sump
- How 2 bike carbs
- Low vacuum X14XE
- CV and drive shaft questions
- chipping my let ecu
- starting problem on xe
- xe question
- Corsa Engine Help Please..
- Another Bigend Question
- F28 ATB Diff 4x4 or 2WD?
- Tell me all about transmission losses?
- Gearbox Help!!
- Astra Mk3/20Xe questions (plenty)
- eds stage 3 ecu
- Astra turbo deisel problems
- Help Needed Cam sensor Calibra X20XEV
- 2 ltr eco tech cam box cover
- will a x16xe cylinder head go straight onto a x16xel?
- X20XEV on Throttle Bodies - couple of questions.
- c14xe vs c16xe induction roar
- Avcr Info Wanted
- LET detonating in exhaust
- Worn Camshaft - Ok to use for now?
- Let & XE conrods!
- immobiliser - 16xe in a mini
- Losing gearbox oil in f20
- engine sounds like diesel from cold
- engine fault
- Corsa sri (x14xe) fan cut-in temperature?
- quick oil cap question
- no throttle cable how do you fit cruise control in vectra diesel 1999
- vectra dti 1999 engine management light on and 20 mpg
- Corsa loom to Nova GSi engine loom - Help pls!
- what exhaust
- head gasket problems
- remus exhaust?
- rear brake valve and lowering?
- vectra dti engine management light and 20/gallon
- Calibra Ecotec to Turbo
- Corsa with C20XE engine wont start
- corsa let oil light?
- how much does it cost t recon a turbo
- anyone know the location of the diagnostic port on an R reg fiesta
- fitting fmic in mk3 astra let
- How hard is it to swap a x14xe for a x18xe1
- Coscast or Not? (Help! urgent before sale completes)
- dump valve
- vauxhall nova 1.2i 8v gearbox
- Astra GTE + LET + F28
- Information Required for Z20LET conversion
- Electronic turbo's
- converting a mk3 astra gsi let into 4x4 whats involved?
- astra turbo/ zafira intercooler fitment???
- cali se 8 2.0 16v engines
- convert f20 to hydraulic clutch
- any one have a how to on chanding injector seals on a vectra dti 1999
- FAO Nova Turbo Guys - Advice needed
- 1st Gear boost Calibra turbo
- Corsa 1.2 Sxi Cambelt Change !
- Cam cover breather pipe size
- wiring c20 xe in to deisel
- turbo and boost
- corsa gear linkage
- c20let rebuild
- oil light
- My New Engine Concept to improve power & torque
- corsa c engine swap
- Oil Pressure Problem
- help what size are the water pipes to the heater matrix? c20xe
- help needed with cav 4x4 loom
- Sachs/luk Clutch For Evo 5 C20let???? Yes No?
- bike carbs
- c16xe wiring plugs?? (pic)
- urgent help!!! c20xe heat problems!!!
- power/0-60/topspeed of the following engines/cars?
- No 02 sensor on XE
- xe octane sensors
- Need help with leaking fluid from gearbox
- Gen me. 1.4 16v Tigra M plate - Can I adjust the clutch ?
- Exhaust Manifolds
- calibra turbo missing
- Fitting Oil Pressure guage
- can the 2.2 dti vectra turbo be used in the 2.0 vectra dti
