Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. Howto for TXB removal/replacemet?
  2. omega gearbox
  3. C20LET Problem!
  4. lightened flywheel - omega v6
  5. Need Information In Detail On C20let Conversion Into Corsa
  6. astra gsi head rests do they go all the way down?
  7. Read this if you are fitting Kent COR1612 into C16XE head
  8. Both sides flashing when I put my Indicators on
  9. anyone know what the tracking and the camber should be set at on corsa gsi?
  10. regal valve shims
  11. petrol tank sender unit
  12. C20XE
  13. intercooler any good?
  14. Removing nearside driveshaft from TXB, how?
  15. possible duff HT lead on x16xe? have a look at pics...
  16. let ecu
  17. C20let valve stem sizes???? help please!!
  18. Sensor on F20 gearbox ???
  19. evo5 chips - but now car wont start
  20. Carbs on a Corsa?
  21. oil for a f28
  22. Wireing up the avc-r to a c20let ??
  23. X20XEV camshaft sensor lead
  24. c20let fpr info needed
  25. c20let afm position
  26. FAO All nova c16xe owners - matrix pipes??????
  27. vectra dti oil in intercooler to manifold pipe is it ok
  28. Corsa Engine Change From 1.4 16v to 1.6 16v question
  29. Astra gsi c20xe not starting (the way it should!)
  30. fitting a f28 in a vectra b
  31. KKK16 hose sizes
  32. What C20LET Chips Are These?
  33. towing a 4x4 cav turbo
  34. XE Tigra Conversion
  35. Changing Ratios in a VX Gearbox...
  36. standard pipe from turbo to I/C
  37. 1.4 16v corsa keeps cutting out
  38. HELP- Corsa Clutch Cable Sizes
  39. vxr injectors?????
  40. astra coupe turbo gone????
  41. xe conversion hoses
  42. Turbo
  43. C14NZ performance air filter bolt on or induction kit
  44. cleaning out an intercooler ?
  45. Kangaroo Petrol!
  46. j reg astra 1.4 petrol ignition problems. help!
  47. Turbo D cav
  48. 8v AFM
  49. Turbo's
  50. C20LET internals
  51. QED Cams
  52. XE fault code
  53. Helicoiling spark plugs - question
  54. Corsa XE Conversion - Bottom Pulley help?
  55. X16XE High idle
  56. Photo guide: Freeing oil pressure relief valve on aircon Calibra Turbo
  57. 306 head bolt torque figures
  58. whats the best aftermarket ecu for a c20xe
  59. c20xe running Multipoint LPG
  60. 2l engine identification?
  61. wiring a turbo timer
  62. Gear box rebuild
  63. Early-late xe cams?
  64. Best FMIC
  65. burning oil help?
  66. Z20LET fitting to corsa
  67. how do i fit a k&n on an 8 valve cally
  68. How does common rail diesel work?
  69. Tigra oil leaks
  70. cam belt snapped,help needed with engine
  71. Testing an oil pump - ZLET
  72. c14se turbo
  73. How important is matching inlet ports to head?
  74. Is an F20 with an LSD fitted more reliable when attached to a LET than a standard F20
  75. Z20let 350Bhp
  76. custom fuel rail, who has one ??
  77. Corsa 1.2 Fuel gauge reading full when car is running
  78. Differences of x20xev engines
  79. CBR 900 throttle bodies on c20xe
  80. c20let inlet manifold vs c20xe inlet manifold
  81. 1.6 Spi Head Gasket / cooling system bits replacement advice thread '07
  82. engine swap
  83. uprating engine mounts
  84. C14NZ uprated cams
  85. Reason for not using XE dizzyless setup on a LET?
  86. engine (x16xe) troubles
  87. 4x4 nova project
  88. Best Oil for 20xe
  89. Injector and fpr help please
  90. Will EDS Phase 2 chips from a PK ECU work in a PJ ECU ?
  91. has my turbo had it /???
  92. corsa 1.4 8v
  93. C20LET water pipes in a Nova
  94. Creaky Coilovers...?
  95. Corsa 1.6 16v help
  96. Z20LET Engine into a Corsa B - Anyone?
  97. Let engine with s14 manifold
  98. 2.5 v6 head fitting parts needed?
  99. astra g turbo owners
  100. anyone got a pic of the oil catch tank setup on the breather on an ecotec?
  101. rebuilding and modifying C20NE engine- help please!
  102. fuel pump on 20xe conversion
  103. No Voltage to Crank Sensor......
  104. C20LET - Lost power to pins at ECU
  105. Bailey Or Forge
  106. Section cut C20XE-C20LET head pictures?
  107. c20xe to let
  108. Twin Tank Fuel System, Plumbing up
  109. 1 off x16xe injector overfuelling - where to start/what can i do?
  110. Vauxhall Astra X17 DTL Cylinder head problems
  111. which engine into corsa sri?
  112. Astra SRi misfire/srarting problem
  113. Broken z20let
  114. radiator fan motor switch
  115. engine conversion guide needed guys
  116. omega aux drive belt route x20xev
  117. New brake lines and fuel lines?
  118. Group buy NOVA custom equal length driveshafts
  119. turbo conversion
  120. c20ne tuning
  121. Engine in boot?
  122. omega 2 ltr oil level switch problems
  123. LATE Let Transponder key info?
  124. differences between c20xe - c20let
  125. Genuine EDS chips for LET
  126. how NOT to fit nitrous to a cav.....
  127. 1.4 16v sport
  128. Oil advice (TB'd C16XE)
  129. Xe tapping all the goddamn time!
  130. engine swop
  131. gearbox oil
  132. Putting a Diesel lump in an originally petrol car?
  133. isuzu engine loom wiring help needed
  134. Astra Isuzu Convert To Gm None Turbo
  135. What oil pressure
  136. x25xe engine mods
  137. where do i buy red top valves from?
  138. whats the firing order for a 20xe? starting issue after instalation into manta
  139. Difference between a X18 and a Z18?
  140. Big Brakes!
  141. Cavalier GSI Fueling Problem - Help Please.
  142. c20let conversion in to corsa
  143. vectra 2.0 diesel engine problem (2002)
  144. redtop inlet manifold question
  145. red top head to ecotec block?
  146. corsa valver conversion
  147. ticking then oil out the bottom ..bang
  148. Gearbox selector
  149. Turbo fuel pump for Corsa Sport? Help
  150. Springs for a nova let.
  151. clutch size
  152. Boost Controller, Z20let?
  153. LET not starting
  154. C20SEH code flashing
  155. C20let Engine Rebuild
  156. let to xe inlet cam, good idea?
  157. fitting turbo to an xe
  158. Can anyone help diagnose a problem on a c20xe calibra?
  159. c20xe head
  160. corsa van when should cam belt be done?
  161. Which chip and where from
  162. your views and knowledge on megasquirt?
  163. Coilovers for mk3 Astra
  164. xe inlet cam on c20let
  165. C20XE sandwich plate bolt
  166. hydraulic lifters where to buy
  167. Astra 1.7DTI - Best Mods For Engine??
  168. ecotec or sfi
  169. Exhaust heat wrap? any recomendations?
  170. Coil packer xe wiring
  171. 2.0 let turbo question
  172. -6 to fuel pipe sizes
  173. head torque settings?
  174. coilovers
  175. Wanted: 2.5 v6 Ecotec wiring diagram
  176. Fast 1400 Engine!!!!!!
  177. gearing
  178. Engine Tunning
  179. cams
  180. Are all 1.6 SPi manifolds the same?
  181. Compression test - C20LET
  182. Part No For A C20xe Ignition Control Unit
  183. Symptons for vectra disel pump failure
  184. c14se turbo????
  185. 4x4
  186. satin red cav turbo
  187. Xe timing marks
  188. Chipped UK Remaps
  189. Ecotec & redtop shafts - are they the same ???
  190. Diesel rev counter ???
  191. F16/F18 Gearbox
  192. Will Astra Mk2/3 suspension fit a Calibra Turbo?
  193. intercooler question
  194. Which if any Alternator belt fits
  195. Diesel tuning chips helllllllppppppppppp!!!!!
  196. corsa 1.4i
  197. corsa xe manifold
  198. Bigger fuel pump...
  199. LET flywheel bolt torque setting
  200. Petrol Tank Pipes- Nova
  201. Oil to use on Vectra 2.0 TDI Engine
  202. X14XE Weight
  203. Astra LET running rough
  204. vectra B BIG turbo
  205. saab red injectors part number
  206. what charging and starter loom do i need
  207. Fuel pipe threaded unions?
  208. Astra Mk3 LET PAS line help, urgently req! Odders, Jamie F ?....
  209. gear linkage
  210. What flywheel/clutch?
  211. Clutch ???
  212. Valver corsa help ?
  213. Help please! clutch or driveshaft problem?
  214. Would a hole in the exhaust cause a misfire?
  215. astra 1.6 16v?
  216. xe clutch
  217. f16cr with atb lsd
  218. Ecotec engine number location
  219. corsa xe'd
  220. Any issues for TXB with front only lift?
  221. XE sump gasket,wots the difference?
  222. Astra sensor locations
  223. Nova GTE gear linkage? rubbish explanation sorry.
  224. Injector pump woes...
  225. gear box spacer corsa b
  226. F20 power ratings
  227. C16, X16 heads
  228. gear shift problem - corsa 1.4 y reg
  229. C20let engine build manual
  230. will cav turbo rims fit 1.4 tigra?
  231. cts sensor and odd speedo problem
  232. Air con - c20xe.
  233. Corsa sport driveshafts
  234. how can you tell what wiring loom you have
  235. Superchips Customer Key Question
  236. gsi oil light
  237. Petrol Tank
  238. What radiator in a C20XE Corsa?
  239. removing pas belt
  240. Frankensteins engine? (relative newbie, still learning)
  241. X20XER info and tech spec anyone??
  242. Vecta B running problem (ecotec)
  243. help with engine running at a very high temp!
  244. Limp home question
  245. crank sensor on Omega
  246. q's about F28's
  247. XE nova- need more power!
  248. C20XE TB - Engine probs, stripped, pics
  249. C20let Porous Head
  250. C20NE starting problem
