: Engines and Transmission
  1. z20let fitting mocal oil cooler
  2. car's misfiring.. any known common causes for this on a mk4 astra g 2.0 sri 2000?
  3. revs not dropping between gear changes. HELP
  4. Corsa B 20XE Inner CV popping out?
  5. Zafira 120 , maybe for you newer car folk on here .
  6. C20XE Clutch wont stay attached to flywheel
  7. Z20let combustion chamber volume
  8. Z20LET Jumps out of 1st gear
  9. T turbo charger in c20let
  10. z let oil pump
  11. Uprated hydrofollowers, is it worth it?
  12. Astra mk3 cabrio with cav GSi front struts problem
  13. Y20DTH vacuum pump pressure
  14. are these any good
  15. Corsa B 20XE Gear Linkages
  16. corsa b engine conversion
  17. stripped threads on the hole for the cam belt tensioner x14xe
  18. Need to find the history of an engine with just the engine number
  19. x14xe flywheel change for lighter???
  20. Astra Mk4 1.8 16v torque settings/sequence
  21. Corsa 1.4 Thermostat
  22. Kkk k16 safe boost to run?
  23. C14SE Camshaft Inlet Duration?
  24. c20let porting ??
  25. Corsa c20ne rattlin noises
  26. c20let engine help
  27. anyone make steel inlet manifold flanges ?? c20xe
  28. 54 plate Agila not running quiet right
  29. x20xev turbo
  30. X14XE crankshaft pulley
  31. Z12XE low oil pressure
  32. C20LET Compression Problem
  33. c20xe into a corsa d?
  34. 2.2 diesel tining chain/diesel pump
  35. seh head bolt socket
  36. compression reading
  37. F20, how do I set up the gear linkage?
  38. steveboyslim empty the pm box please
  39. sbd nylon relief valve kit
  40. 1300 sri nova
  41. Which engine is better z20let or z20leh
  42. No spark, after moving coil
  43. mounts and other stuff f23 gearbox?
  44. mk4 astra estate 1.7td envoy engine replacement/upgrade
  45. c20 xe spluttering under load
  46. i need my b204l ecu mapping
  47. Engine Control Indicator comes on when drive over 70mph
  48. Anyone know how to remove the aux belt tensioner on a 1.0 corsa b?
  49. HELP astra mk4 redtop engine
  50. f23 into corsa b?
  51. good c20xe exhaust manifold
  52. Noisey 1.7 CDTi
  53. turbo help t28 differences
  54. HELP my vauhall astra mk4 redtop
  55. Astra Sport Hatch 07 1.7cdti 100 wont turn over, clicks twice
  56. saab flywheels????
  57. help wanted 20seh wont start.
  58. C20xe won't start, ideas please
  59. clutch to bed in, how long
  60. xe engine oil
  61. msd streetfire with R1 carbs
  62. f28 gearbox help
  63. C20LET wastegate stiff
  64. C20XE exhaust valves not seating
  65. c20xe problems
  66. after a c20xe to fit in nova
  67. Z20let block against the c20 let
  68. Diesel tunning
  69. Clutch differences: LET
  70. aux belt on c20let into nova
  71. c14nz cutting out problem
  72. corsa b 1.0 12v eco tec making a whining noise any 1 know what this might be ?
  73. Carlton r25 Gearbox serious help and Advice needed please
  74. zafira gsi oil leaking from new turbo
  75. saab b204 engine
  76. Another non-starter problem!
  77. rose bush removal tool
  78. C-LET Stalling Occasionally
  79. cossie fuel reg
  80. clutch setup
  81. VW 1.2 12v
  82. c20let heads
  83. x16xe performance !
  84. c20let/c20xe piston and bor size
  85. X20XEV Camshaft postion sensor problem
  86. advice needed..c20let or z20let conversion to a 1.8 astra
  87. corsa coolant issue
  88. Corsa C & Corsa D Inlet Manifolds
  89. Engine making ticking sound when oil cap removed
  90. Fuel pump feed pipe advice
  91. Injector seal replacement
  92. Identifying Corsa C20XE Conversion Parts
  93. are x18xe and x18xe1 heads the same?
  94. C20let revving on its own
  95. Astra 1.9CDTi slave cylinder bleeding.
  96. Driveshaft Angles
  97. tx autosport crank pully
  98. Corsa 1.0 3 cylinder 1999 Engine cutting out - not restarting for 5 minutes
  99. Serious problem with the coolant/overheating
  100. Cam shaft question who an help?
  101. Possible cracked 14xe help please
  102. can any one tell me if this ai autosport is still open
  103. What does knock single circuit mean?
  104. Heavy clutch action? Thoughts?
  105. X25XE in to small block mk3 astra
  106. 2.0 xe is there any need for the oil cooler to be fitted or not?
  107. X16xe breather modification
  108. 1.0 12v to 1.6 16v wireing and installation
  109. Corsa b 2000 1.0 - Starting issue
  110. Bolts/Thread Size To Mount a LET to Engine Stand
  111. Late Type C20LET Engine Timing
  112. M32 release bearing
  113. fuel pressure regulator
  114. C20LET Turning over slowly but not really slow
  115. z2olet turns over but wont start?
  116. C20LET not starting, could this be the problem, look at image
  117. C20let boosting problem: Hardly any boost yet EBC showing 1.65bar
  118. starting trouble !
  119. corsa gsi ecu chip
  120. 1.4 8v sr engine
  121. blow through carbs?? anyone knowmuch about them?
  122. Corsa GSI engine.
  123. Apexi Avc-R - Boost issues
  124. Corsa 1.0 to 1.6
  125. C20xe redline's early sometimes? Arghhhh HELP
  126. Need help on Corsa GSI project, any mechanics out there wanna make some x-mas cash?
  127. C20xe starter
  128. corsa b 1.2 sxi where is the IAT sensor
  129. Vectra F23 Astra F23 Gearbox Any Differences??
  130. c20let crank why does it have an extra spacer
  131. 3" corsa exhaust?
  132. C20LET coil ?
  133. C20let lost oil
  134. 1.7CDTi Astra Niggles/Advice...
  135. C20let & Z20let clutches?
  136. Vauxhall corsa c 1.2 rocker cover help...
  137. nova redtop project
  138. can a f23 gearbox fit my c20let corsa b?
  139. Mk4 astra gsi losing coolant
  140. AP RACING CLUTCH c20let f20
  141. tell me about idle control valves chevrolet /daewoo engines
  142. limp mode
  143. z22se to z18xe vectra
  144. rev counter signal mk3 astra
  145. Renault Megane 1.6 8v Engine Problem
  146. Corsa C, no throttle response
  147. z20let smoking?
  148. oil pressure gauge what is the normal pressure under load?
  149. C20xe Camshaft timing
  150. corsa b lamba sensor faulty or air flow meter
  151. corsa b 1.2 2000 how many lamba sensors
  152. Vauxhall Oil ok to use on VW Diesel engine ?
  153. needing help if anyone can help with an engine spacer kit ?
  154. c20xe, c16xe, or 20seh?
  155. Mk4 Astra ECU Problem
  156. Zafira anti roll bar link
  157. 20ne turbo cosmetic headgasket
  158. X20XEV Driveshafts Upgrade
  159. X18XE1/Z18XE Nova.
  160. quick question about tappets (c20xe)
  161. Corsa C engine change... Not firing
  162. c16xe ignition options
  163. z20let/leh Vacuums to fuel reg and vac box/solenoids
  164. coscast head can brnze guides be pushed out and then back in
  165. Differences between c20let and z20let pistons?
  166. 1.7CDTI Astra H Cam belt help
  167. astra mk4 1.7 diesel turbo problem
  168. Transplanting an LPG system from one car to another... advice please!
  169. mk3 astra 1.7tds isuzu
  170. Oil leak(loss), help needed
  171. vauxhall 1.4 or 1.6 8v engine wanted
  172. caustic truck wash as an engine degreaser
  173. 20ne Crank
  174. saab engine into astra mk4? how hard?
  175. fmic on mk3 astra van c20let pics
  176. Splitting an XE oil cooler thermostat
  177. corsa 2.5 v6 transplant
  178. Little confused with my eds phase 4 ecu
  179. recommended vauxhall spcialist
  180. walbro fuel pump c20let spluttering
  181. C20LET timing cover issues
  182. Lift pump before a swirl pot
  183. EDS phase 2 chips activation switch
  184. Z20LET/VXR turbo vac hoses... what goes where...??? New turbo fitted....
  185. MK4 astra z18xe starter motor?!
  186. X18xe1 pedal box and wiring loom
  187. Which injector seals do i use?
  188. FCP engeneering any one knows?
  189. Too much white smoke on C20LET Corsa
  190. c20let idle problem
  191. corsa b 1.0 12 v
  192. 0300 code wtf??
  193. clutch bite on the floor??
  194. gutted! what box is best to use now
  195. Astra cdti 150 sri will not start when its cold
  196. Astra vxr gearbox in zafira
  197. rwd c20xe do i remove the baffle?
  198. which is the better GM clutch, clet or zlet
  199. Zafira 2.0 dti gearbox conversion to 6 speed
  200. Zafira DTI clutch
  201. which oil for my c20let
  202. z18xe oil pressure problems
  203. corsa rear noise
  204. mk3 astra 1.7td boost problem
  205. what do i need
  206. Boost solenoid connections??
  207. X20XEV or Z22SE ?
  208. F20 Gearbox
  209. My new custom billet 1st gear
  210. Vectra sri150 internal water leak
  211. Corsa 1.4 8v -Engine swap possibilities
  212. z14xep manifold size compared to z16se
  213. For those who have fitted a c20let/xe to a Corsa/Combo C....
  214. calibra turbo clutch f23??
  215. starter motor just clicking when i try start the car? bumps starts okay!
  216. Audi DSG Auto clutch-any disadvantages?
  217. Driveshaft lengths
  218. auto box question
  219. Engine mounts and F17 box
  220. astra gsi what mounts
  221. Tell me a little about flywheels
  222. Will this set-up be ok on a let
  223. 4.5 litres in 2.4 litre m32 box..... leak spilling breather??
  224. astra SRi turbo missfire/loss of power/ holding back
  225. Problem with my phase 4 power wheel
  226. corsa c16se on twin 40's setting up
  227. calling all mk3 astra 4x4 owners
  228. gt3071 changing from internal to external wastegate
  229. c20let into corsa c?
  230. 1.8 is dead .... replacement .....
  231. vectra A 1992 i need a floater and a needle for my Pierburg carb
  232. Cold air feed advice please
  233. Corsa 1.3cdti starting problems
  234. C20LET - Coolant Temp Sensor Colour
  235. engine removal ?
  236. A few useful C20LET / C20XE diagrams - save them to your PC
  237. Boost problem C20LET Corsa
  238. Tigra c20xe
  239. 1.7 CDTi fault codes...
  240. 1.4 SRI Corsa D EML is on
  241. Help with engine oil please...? Valvoline Turbo V SAE 10W40
  242. zafira 1.8 in limp mode no faults on diagnostic tool
  243. Is there a multiplier on the wideband/afr on A20dth, Astra J/insignia etc.
  244. advice on zlet clutch, boy i am confused
  245. C20NE turbo conversion engine management ideas?
  246. Saab turbo + equal length shafts..
  247. Help need Cylinder Compression readings for C20NE Cavalier
  248. looking at corsab zlet forsale.. a few gearbox answers needed please!
  249. Z20let boost problem
  250. will this fit a zlet
