: Engines and Transmission
  1. Turbo Smoking on Idle
  2. GSI 2000
  3. Removing v6
  4. Mk4 Astra Z20LET conversion
  5. Clutch / ECU Question
  6. knocking banging top end crank pulley?
  7. new clutch dead
  8. vectra 2.5 v6 engine manigment light
  9. x16xel into corsa sport problem
  10. spacer with f28 2wd conversion kit
  11. throttle body sizes ???
  12. 1.6 8v rebuilding
  13. twin 45's
  14. 3.2 V6 Chip
  15. car wont start after engine bay wash
  16. C-LET missfire at high revs
  17. actuator problem!
  18. vecra b clutch problem
  19. Is this a bodge or not?
  20. Nova engine mounts
  21. f28 into a nova
  22. gsi2000 how can i tell if my injectors are working
  23. 2.5 v6 cavalier engine coil pack wireing order
  24. HT Leads To Cap, Which Goes Where
  25. x20xev simple swap ideas?
  26. x18xe wiring loom.. help wanted pls
  27. four branch
  28. Corsa B 1.2 8v Conversion - Help !
  29. 20xe nitrous kit questions
  30. F28 in mk3 astra gsi speedo reading incorrectly
  31. corsa b mods
  32. ARP rod bolts
  33. 2l REDTOP, GEARBOX, AND BRAKE DISK (BACK)
  34. Z20LET Boost Problem
  35. 2.0 8v power
  36. will a f20 gearbox fit a 1.6 16v engine?
  37. The "please MSG, service your Calibra" thread
  38. gte16v camshaft sensor
  39. whos done a z20let conversion in corsa c
  40. astra 1.6 club vibration
  41. What Gearbox on GM 1.7TD Astra Mk3
  42. c20let idling high when warm!!
  43. z20let ecu help
  44. XE Inlet cam gains???
  45. Corsa b clocks
  46. My turbo is goosed!!
  47. Heat is melting the Spal
  48. 2.0 8v tuning
  49. got no fuel to rail
  50. c20let oil light flicker????
  51. Buggered ignition coil?
  52. cts wiring
  53. Electric speedo problem
  54. LET Injector valve 1 fault code?
  55. V6 Water in oil, lots of water in oil!!
  56. zafira cold start problem
  57. F28 question
  58. need help with gearbox!! :(
  59. crank movement ?
  60. nova seh fuel pump not priming
  61. redtop corsa speedo?
  62. astra g 2.0 xe conversion stuck on cooling piccies to show
  63. no spark
  64. cav v6 ecu light
  65. Help!!!!!!!!!!!
  66. c20xe problem (juddering)
  67. DRIVESHAFT GURU'S help needed
  68. anybody no the size bolts needed
  69. z20let in corsa c
  70. cam Info needed?
  71. cylinder head skimming
  72. Driveshaft wont go all the way in???
  73. Injector guru's
  74. X12XE--problems
  75. missfire with rattle
  76. Who Can guess what was wrong?
  77. xe engine noise
  78. weak spark
  79. calibra v6 wiring
  80. small block weight??
  81. question about injectors
  82. Gearbox Help
  83. Any differences between the Ecotec from a Cav and one from a Vectra?
  84. exahust downpipe dilema :(
  85. Where to buy parts from for ZLET/ZLER?
  86. inlet manifold , dizzy.
  87. C20LET-engine .some questions
  88. astra fueling problems
  89. car reg for ordering parts c20xe
  90. Igntion Timing On Gotech Managment
  91. help with my 8v calibra
  92. supercharge? 323 engine, lower compresion?
  93. Twin Turbo???
  94. which end is fuel in!!
  95. corsa 12v problem
  96. C16XE No power on full throttle
  97. C20XE distributor slot or peg drive?!?!?!
  98. Nortech Performance
  99. gt3582R 0.63 a/r vs 0.82 a/r
  100. ex wastegate plumbing
  101. c20let head gasket
  102. How to tell F13CR from F13WR
  103. corsa engine
  104. Urgent help with first Vauxhall. 1.7td Astra van
  105. Urgent help with first Vauxhall. 1.7td Astra van
  106. anyone thats fitted a XE manifold to the XEV?
  107. what size do i get block bored out to??
  108. power steering problem on corsa redtop help plz
  109. sfi bolts
  110. sr 1300
  111. Help fan didnt go on!
  112. c20xe tigra missfire
  113. Saxo VTR - Same engine through out production?
  114. HELP! think ive blown my turbo!
  115. Supercharging
  116. syphoning a vivaro tank
  117. misfire zetec engine
  118. helix organic group N
  119. which fuel pump to use on let conversion ?
  120. Best place to get a C20LET set up?
  121. Anyone fitted a LET to a 2WD Calibra?
  122. popping banging and hot corsa c
  123. corsa let radiator
  124. xe overheating
  125. corsa gsi lamda problem
  126. turbo kits from america.....
  127. astra g 20.16v eco putting a 2.0 ex redtop in the cooling system how do i wire up..
  128. Weird engine prob
  129. hi does anyone know.....
  130. z20let in2 a corsa c!!!!
  131. Gearbox and Pulley Help
  132. Fse Boost valve
  133. problems with heating
  134. black spark plugs = too rich?
  135. 2.0 8v regulator
  136. Ashley backbox
  137. F18 bellhousing seems different to F28
  138. cav gsi v6 whats needed to fit f20
  139. Inlet manifolds
  140. vec b and astra 4 pannel filter the same?
  141. ecu chips original and aftermarket
  142. ST170 engine with F28 gearbox
  143. cam cap torque settings
  144. i have a churning noise
  145. Astra G 1.6 twin port head gasket
  146. evo5 chips (beardie)
  147. Corsa engine management light
  148. x16xel cambelt not fitting
  149. V6 engine not working, end of my teather HELP
  150. calibra exhaust on a cav???
  151. fitting 2l 8v steel sump on c20let
  152. bike carbs and megasquirt fitting
  153. 20xe Coil Question
  154. f20 to c25xe
  155. fuel pressure regulator settings
  156. lexmaul 4 branch
  157. astra mk 4 sri 2.o
  158. Upgraded Engine Mounts For C16XE
  159. idle control valve
  160. will this work as fpr for c20let ...
  161. Odd boosting problem
  162. Cone Filter - Jerky Ride
  163. help with decision of gearbox
  164. Vectra Eco XEV to C20XE or C20LET...
  165. how to convert xe to let
  166. XE poor running
  167. c20let sump
  168. C20xe to Type 9 box problems
  169. Smell of petrol coming from rocker cover breather pipe
  170. c20let rebuild/tuning advice
  171. c20let wont start!!
  172. astra mrk 3 v6 engine mount
  173. Equil drive shalf bearing cracked
  174. F28 speedo problems!!!!
  175. anyone got any pic of how to fit power steering on a corsa redtop
  176. astra mk 4 sri 2.o
  177. C20let from corsa into mk3 van ???
  178. c20xe running problems
  179. redtop into corsa b
  180. Diesel Vectra
  181. Hi Revving XE - what oil?
  182. cav x20xev crank sensor wiring help
  183. X20XER into a 1.2 Corsa C?
  184. HEHE here i go again! 1.4 Astra Engine
  185. 1.9 CDTi Help
  186. let ph3 quiries
  187. Air Flow Meter problems
  188. xe on carbs,ignition wire?????
  189. timing belt
  190. astra mk 4 sri tapping
  191. High idle
  192. c20let oil pump removal?
  193. Corsa 1.4 16v problems, needs solving asap
  194. clet tensioner help neeeded!!!!
  195. EGR Valve problem
  196. rad fan on a cavalier sri
  197. Can timing on verniers LET xe inlet cam
  198. engine running at 100+ degress
  199. c20let rebuild, recomended places
  200. rev limit problem plz help
  201. c20let high emissions
  202. R25 gearbox to XE
  203. could someone give me some info on sbd manifolds
  204. wheel bearing replacement
  205. are these manifolds any good
  206. consentric top mounts chris astley
  207. dizzy blanking plate seal
  208. 6 Speed box?
  209. Just want to say thanks to the lads especially msg best forum by miles
  210. H&H ignition
  211. vectra shifter problem, i broke it!
  212. Lost key - reprogramming help please
  213. Dump Valve Issue
  214. xe oil pump
  215. Diesel fuel pump foam cover!
  216. C20xe or C20xe-LN
  217. Silkolene Silktran G/box oil (lsd)
  218. C20LET
  219. crank seal
  220. why is oil appearing here!!! GRRRR!...
  221. Useful info on gear ratio's
  222. Additional water temp sender
  223. redtop crank
  224. Ignition Map c20let
  225. Shaft has play on reconditioned turbo
  226. v6 on f17??
  227. Ticky Corsa
  228. driveshaft nut size?
  229. Which dump valve / BOV should I buy
  230. c20xe-changed tappets now car wont run
  231. XE clutch/flywheel question
  232. What radiator for V6 Corsa B?
  233. trans x lsd in a nova let???
  234. Screamer pipe
  235. Issue with over heating cali turbo
  236. Help needed, c20xe ecu+wiring
  237. V6 Calibra gearbox dead -help!
  238. nova driveshaft question
  239. maf
  240. turbo question
  241. XE Questions
  242. What is the best chips to use for c20let
  243. Rev counter jumping about
  244. air box mods
  245. lightened flywheel pros and cons please
  246. choosing big injector
  247. Crankshaft sensor
  248. Tensile strenght of bolts
  249. x20xev turbo conversion
  250. Piston choises for C20LET????
