- Corsa exhaust problem
- cranks, pistions..
- 80mm Dia. Silicone Hose Connecting Pipe?
- seh injectors on xe?
- X14/X16XE Part - What is this?!
- Leaking RHD Japan supplied Sard regulator on C20LET...
- piper cam info
- Snapped cambelt astra mk4, please help
- corsa fuel tank in a nova???????
- v6 swap
- removing a c20let from a corsa gsi
- Cav sri ecu light stays on a few seconds after startup
- XE Dizzy to Coil Pack
- which cars/gearboxes had a 4.18 Final drive?
- arse end drive mk 3 cavy..????
- c20let corsa coolant hoses/diagram
- XE'ing a Vauxhall Viva
- c20let clutch
- wont rev ????
- i really need sum help
- maybe headgasket gone?
- any1 no whos this is ?
- Engine management light
- astra engine type?
- crank pully on small 8v
- nova 1.0 engine
- Tubular manifolds??
- Mk4 astra diesel. No fuel out of pump. HELP!!!
- engine number identification
- xe to single pully
- uprated cams.
- c20let earth points
- Bike carbs on a 20ne engine, spark related.
- 3.0 v6 performace mods?????????
- Strange noise and Bumping
- F28 weakness
- Nova exhaust on to a corsa?
- 1400 16V Engine Code and Tuning?
- corsa b extra bhp?
- cav v6 won't start......
- Bottom end mods
- Whirling "dog whistle like" squeak!?!?!?!
- 2.2 Sri 150, missfire
- 1.6 16v Oil Catch tank filling up quickly (with pic!)
- Camshaft on a c14se
- Replacing F28 rear mount?
- Bleurgh, car is trying to gas me...
- Mantzel powerbox throttle to airbox pipe
- Bioethanol
- does the vectra dti and di 2.0 have same inlet manifolds
- cav t won`t run
- ASTRA GSI electrical problem
- c20xe how can i make it faster
- stupid clucking noise from cally?
- Vacuum pipes on a C20LET / Dump Valve
- please update me
- c20let fault!
- wiring loom
- c20xe probs
- obd II software/kit
- need help quick please (c20let)
- Phase 4 Z20LET
- 1.7td vauxhall engine tuneable?
- Engine Management On All The Time (c20xe Corsa)
- C20XE ECU wiring Diagram
- code reader
- Identifying 1600 8v's
- please help!!
- carb re- jetting
- grrr this damn engine!?
- coscast head info
- Xe inlet cam on eds phase 2
- 20SEH cam into 20NE??
- c20ne rebuild - tuning, and which parts/gearboxs?
- turbo conversion 16SE
- Dump valve problems
- any 1 have pics of mk4 c20let engine mount
- Misfire on cavalier redtop
- dump valve problems
- Any gen experienced on ECU immobilisers.
- which gearbox? how to identify?
- where can a buy
- turbosmart
- X20XEV Secondary Air Injection System
- Nova Let Alternater
- Starter Motor Fitting Problem.
- This sodding engine again!
- Calibra Turbo Oil Pressure problem
- 440cc injector question...
- astra van blower
- Engine Code?
- XE block bored to 2.3???????
- cav gear stick in to mk2 astra
- What Cav is this ECU from?
- Astra 1.7td performance figures
- C20LET Coil probs which part broke???
- Engine numbers
- strange problem with c20let!
- Heavy Clutch on Pug 306
- engine mount mk4 to c20let
- Fault Code 72 on XE
- what gearbox will a v6 r reg vectra sri have ?
- cav 1.7TD exhaust
- mvaux manifold and turbo setup - would u???
- Corsa Starting Problems
- saab red injector part number for c20let...
- ECU light on with VMAX 5 chip
- vxr injector's
- Engine change
- boost gauge fitting
- 1.0 to XE speedo transducer
- Corsa topmount with coilovers
- c20let corsa C
- Changing timing belt on astra gte 8v
- 3.0 V6..where to find?
- Mayonaise in filler neck!!
- X20XEV or X20XEV1
- Wiring Diagram
- 1.6 cav's power differences.
- 2.2 astra sri
- C20let crank sensor
- c20xe engine mount problems PLEASE HELP!
- anyone tried one of those fault code readers?
- Cav or cally gear selector into nova
- F28 with flat fly...
- Fuel pump issue
- vxr injectors with c20let motronic yes/no?
- Fitting F15 box to a XEV(2L eco)
- gear linkage c20let corsa
- Group A rally engine?
- Cally turbo ARB bush compression?
- Exhaust Heat Wrap
- high consuption on omega 2.0l 16v
- C20let Exhaust elbow flange
- vectra sri engine swap
- C20let question/help
- does vectra dti use its glow plugs at 3 degrees c
- corsa b gerlinkage (conversion)
- c20xe running probs
- xe and 8v
- where can i buy oil spray jets for c20let
- C16xe Oil Pump/pressure gauge question
- Two temerature senders on my LET rad?
- Wiring in a diagnostic plug
- oil cooler??
- f28 tight going into gear
- sri head on 1300 bottom end
- Corsa engine mounts?
- Gaskets and rings C16XE
- Manta Gearbox Mounting
- Mante Gearbox Mounting
- fitting the knock sensor
- How do i change the glow plugs on a cav td?
- c20let crank sensor.
- 1600 into 1200 Corsa B?
- Cavalier Td Problem.
- Turbo Timer
- c20xe lifting point?
- Problem: Astra GSi 16v
- Why's my 1.7td so slow?
- Z22SE (Ecotec 2.2) Turbo Kits
- Z20 LET engine
- spring rates for let corsa
- Astra Mrk4 2.0td turbo problem
- Fuel Tank
- Gear Box Removal On Vectra 1.8
- corsa coilovers (ebay) any good?
- astra mk4 air box? quick help
- Starter motor wrong right for LET/XE Flywheel
- Nova GSi - Hose Help!
- Diesel turns over for ages ...
- Can EGR vauchall egr valves be cleaned effectively?
- LET oil cooler thread size?
- TPS sensor on Carbs
- should genuine beru leads be named?
- it seriously needs help! whats going on!!
- Turbo vacuum connections???
- C20LET Cam Pulleys
- f20 in to astra mk4
- XE Cylinder Head Torque Settings
- Engine Gone Bang!!
- Standard Turbo PIPES
- Lambda sensor removed
- XE/LET Nova front Coilover length and poundage.
- X20XEV Help
- how to time up an xe
- eps problem on xe corsa
- fitting adjustable fuel regulator
- Just finished stripping the engine down
- do i have to bin the aircon when fitting an aftermarket fmic??
- Someone to fix pourous head in Kent
- chip tuned corsa c16xe??
- How hard is it to remove the cast manifold off a VXR turbo?
- corsa let gearboxs
- no fuel after box change
- FWD Redtop to RWD
- cambelt timing does this look on to you?pics!!
- engine transplant
- Uprated single throttle body for XE
- C20XE funny starting problem
- XE Nova Starting for first time
- LET and XE eng. block differences?!
- c16xe smoking breather
- Starting Problems
- Coscast/GM Head's
- can you get induction noise from a XE
- 210quid for +20bhp any advice
- raising fuel pressure on an xe
- adjusting timeing
- ron plug
- Head bolts with thinner washers?
- 12 ohm 600cc injectors and Motronic 2.7 ?!
- C20let bearings & rings
- Opinions on PC based ECU / Fault code readers (non PC-based opinion welcome)
- oil cooler
- c16xe into 1.4 8v sri ??
- F28 synchros...
- c20let loom
- fuel pump prob maybe?
- Rosejointing gearbox
- My Corsa 1.6 16v
- Gm Bosh diesel pump - where is the solinoid?
- is there different widths of cambelts on the xe
- corsa diesel help
- Tapping Mk3 Astra 1.68V auto does my daughter's head in!
- what box on a x20xev
- Cav turbo coil and module
- LET help needed! (again)
- c20xe on r1 bike carbs
- z20let oil pump on c20let
- Lowering LET Nova OS Mount
- forged pistons damaged but how????
- vxr upgrade on zlet quick question
- calibra warning lights, which ones are they?
- c20xe ecu wanted
- c20xe idle problem help anyone
- 1.4 8V head torque settings
- r1 carbs on c20xe
- which oil?
- Is my cat knackered?
- Advice in fitting Quaife diff
- 1.8 engine into a 1.6 vectra
- Frontera Oil Pressure Problem / Vibration
- will a 2.0 8v alternater fi xe
- c20xe tuning
- dizzy blanking plate questions
