- ECU Suggestions for Z20LET
- Bypassing Lambda on C20LET loom for fault finding?
- Are XE and C20LET oil pump the same
- What is an amal valve?
- Electric slimline fans on corsa let??
- New C20XE head problem
- What the hell is a high spec block?
- Repairing cracks in C20LET manifold, around wastegate / penny valve.
- C20LET with Z20LET gasket! Is it only the rivets that need drilling?
- Losing water and high pressure in header tank
- anyone Weber Alpha expert?
- Corsa conversion what I need? (1.0 to 1.6)
- What position do oil temp/pressure sensors have to be in too be effective?
- ap 5200 calipers
- Why wont my astra diesel select 5th gear?
- Astra Mk4 C20XE fuel pump wire?
- annoying em light
- astra diesel mk4 van X20XEV conversion.
- Camshafts and other bits ... from c20xe to c20let
- schematics
- what is going on here??petrol feed + return
- Occassional starting problem - Non Vaux
- Flow rate for stock XE injectors??
- snapped gear arm
- Should I flush radiator before using K-Seal on suspected head gasket?
- possible zorst prob with let...
- Did Vauxhall make a C20XEV engine?
- help
- help
- People with throttle bodies.
- Manifold and full system
- astra 1.7d wont start
- Standard cally turbo - missin
- astra 1.6 16v smokeing ???
- Engine light come on C20let, how do i check/turn off
- HELP Overheating!
- XE/LET into carlton
- Tigra overfueling
- Oil Cooler C20XE
- progress on c20let mk4 pics
- engine code
- c20let ecu pipe where does it go
- 1989 1.4 SR Nova cuts out.
- cavalier turbo please help!!!!(c20let)
- ERG fault code..
- Which Fuel Pump C20LET Phase 2
- c20xe loom plug what is it
- Corsa X20XEV Conversion
- head gasket gone?
- F20 Seized? Gear Selector I think
- How can i tell if diagnostic (octane) plug on c20xe is set to a or b?
- x16sz tuning
- Tigra C20XE swap - Parts
- c20let aml valve vac hose?
- fuel use
- high mileage ecotec worries?
- What would cause a rad top hose to split?
- Flywheel 1600 16v into 8v
- Flywheel 16v into 8v
- brake bleedin on corsa b hellpp mee
- Vacuum Gauges
- astra mk4 hydraulic clutch info please :)
- ICV on a corsa sport??
- would thisfit a cally?
- coil to dispack??
- Corsa C20LET project trouble
- sri 130 not firing
- Traction control light on
- ecu....c16 into an x16?
- cooling setup on c20let help
- Running Rich:
- quafie atb torque steer!
- c20let experts please look.
- C20XE oil pump removal
- quick o2 sensor question
- corsa c20let drive shafts
- Syncro Issues on F23 Gearbox
- LET running rich
- clutch
- C20LET exhaust system
- 2.5 V6 conversion problem??
- xe running rich
- top alternater bracket bushes
- VXR into a mk4 van???
- custom exhaust
- Wideband Question/Help
- is a let dizzy same as a xe??
- Can fuel fiters have the direction printed both ways?
- help with gearbox identifications
- Corsa Timing Chain?
- C20LET fuel pump
- astra chipped?
- gt2540r where from for good deal
- Are these Carbs or TB's
- Would a bigger I/C make that much difference?
- Please assist parts enquiry (CV Joint)
- Biggest intercoolr size for calibra? dimensions needed
- corsa timing 1.4sri
- Color of wires on amal valve into which port?
- Red top mk4
- Baffled sump ???
- gearbox out of calibra 8v
- engine mount on c20let
- Ideal coolant temperature ????
- Which carbs for SEH lump?
- calibra new clutch adjustment
- My head is doing my head in
- Fault code 16?
- ran out of diesel now wont start? mk3 astra
- external wastegate which pipes go where?
- Omega 2.5 TD Automatic
- Corsa B, Nova ecu problem???
- Corsa C20LET trouble
- c20xe running problems
- timing on a c14nz
- plugging exhaust cam
- vauxhall cavalier problem
- C20LET Misfire Problems. Advice on codes please!
- disadvantaged of fitting air flow meter on boost side
- tuned x16xe pistons?
- Honda Rear Brake Help
- xe help
- testing O2 Sensor
- help! need to get bottom pulley (crank) off!!!
- clutch differences
- Stripped sump plug threads
- gearbox for c20let help!!
- Redtop Conversion Help Me Before I GO INSANE
- differences between izuzu and vauxhall 1.7 td engines
- Phase 3 + Let, Bosch Reds but what Fuel pressure?
- C20XE Block - Core Plug Size
- c20let
- idle very rough
- Could i swap a 1.8 spi rad for a 1.7 TD Cav Rad
- Fitting Corsa Crankshaft Censor !
- 1.8 ECOTEC help!
- mk3 x25xe conversion
- size of scket needed for drive shafts..???
- gearbox ratios
- !HELP! Knocking !HELP!
- weird engine light problems
- what to change in an F18 to use 160mph clocks
- Help with C20XE corsa please
- corsa help
- Need Advice On Head Rebuild
- Ebay - OBD-II / Tech2
- reverse prob on f28 corsa
- Can a Supercharger have a dump valve?
- mk4+m-tech mount
- X22XE
- Air filter?
- corsa b engine swap
- Running issues - 1.2 16v SXI Corsa
- Turbo presure sensor and vaccum pipe setup???
- Core Plugs
- New plugs
- Rebulid C20LET Uprated
- turbo presure pipe vaccum pipe setup???
- Help - Overboost with manual boost controler
- C20LET Crankshaft Pulley Torque Setting??
- Nice Pistons :)
- F28 Nova Issues
- Help my shoddy idle!!!!
- polished engine bay
- x20xev mk4 astra driveshaft
- c16xe - formula for CC's
- Torque settings c20let with Z20LET Gasket
- What all's needed for 2.0 8v corsa b
- Engine swap
- how do the hydraulic tappets get their oil? 8v OHC engines
- engine cant hold stable revs ?
- EML on but no fault codes stored? Won't even flash a 'self check' code or anything...
- removing cylinder head
- Part numbers (this'll be a laugh!) obscure nova parts
- c20let problem help needed
- xe inlet mod on let?
- C20XE Exhaust cam removal
- LET head bolt size
- turbo vaccum pipes and crank shaft pulley
- turbo's smoking
- Urgent!!!! need to repair engine block by saturday
- F16 wr and cr
- std Vaux clutch on Phase 2 LET in Nova ?
- LET Corsa help
- help setting cable selector f23?vectra
- cavalier gsi nightmares!!!!
- XE driveshaft removal..
- major help overheating problem i think
- Dimensions of a corsa gsi rad?
- which cat
- Vectra DI pump Interchangeable
- 1995 astra 1.4 8 valve
- z20let hesitating
- phase 2 astra gsi wont start
- How do I wire a manual switch for my fan
- Fuel pump question...
- nova 1600 cam lift
- exhaust size for 300bhp LET?
- how much power? which clutch and gearbox?
- Nova 2Ltr Engine mount template ?
- nova c20xe R1 carbs !!!!
- Odd Idle/cut out problem
- Help - Help-help-help
- Oil Leak
- Daewoo Fo Astra Engine
- F28 oil capacity and oil spec
- how do i tell when my engine was made?
- remap ecu new rev limt is it safe?
- c20let cambelt cover (which one?)
- (c20xe) questions on butterfly position when idling
- is this right
- Exhaust pipe dia.
- Prob with clutch, Pic inside
- ANOTHER QUESTION!! omega and v8's
- turbo not startin
- Blue smoke
- corsa c20let cv joints???
- Vectra 2.0L DI fuel pump probs?? HELP
- Oil Cooler for Calibra V6
- 1.0 nova
- Megasquirt C16XE question
- Basic Transfer Box Questions.
- f28 astra g linkage
- C20LET into a mk3 Astra
- a few cavTD questions...
- 16 8v head gasket bottom pulley
- engine idle and wheel scraping, help!
- Corsa gearbox/speedo question
- 2.5v6 heater cooling problems
- c20let idleing at 1500, why?????? help!!!
- Crank pulley and vaccum pipes
- pourous xe head repair
- em light help asap
- z18xe Spec
- Corsa XE ----> LET whats needed, rough costs
- auto
- C20LET water pipe!
- LET flywheel choice
- LET skimmed head
- LET engine assembly
- corsa + f28 problem
- C20LET turbo oil feed pipe
- What electics to fit into a manta
- How much should a fuel pump relay be?
- Corsa Air Filters
- Exhaust
- let running temp ?
- Stalling Vectra
