- corsa xe linkage
- 16v pistons
- c20let adptor plate for fuel rail
- xe and let crank sensors the same????
- Astra 1.7 dti
- Need some info asap please
- scaning mk4 astra ecu
- Can you blow boost through....
- Vectra MK2 C20LET Wiring
- Fault Code 61
- oil in my pipework after turbo. very bad?
- Trying to identify a loom wire
- Autronic XE Base Map required
- K&N Induction kit - noise
- another idling question!!
- cavalier turbo please help!!!!(c20let) part 2
- perculiar let prob!
- Switching Gearboxes
- 1.8 16v exhaust manifold
- fuel pump corsa b
- ecu's
- X20XEV into Daewoo Nexia
- PK vs PJ LET ECU's
- VXR Turbo Actuator Setting
- did this today....
- c20let would you please look this picture
- ECU Problem
- All corsa drums the same?? Shotblasting powder/coating??
- crankshaft sensor part #
- which oil 4 petrol turbo astra?
- astra g c20let/xe pics
- Cavalier Adjustable ECU Module +45 BHP !!!!
- Poor performace, hestitation. Petrol Contamination my problem?
- Help Needed Asap!!!!!!!!
- Corsa B Hesitating
- xe manifold
- failed mot emissions help....
- pistons & rods
- Rubber Sumpgasket 20xe
- Changing the sump (ZLET)
- Astra 8v to C20let wiring
- HELP!! Just changed powercap back to sfi box and im getting some fault codes
- vectra engine swap
- X14XE C14E gearbox compatibility
- Can anyone help me with.....................
- F28 and f20
- Tapping F28 from Mk2 Astra rear gearbox mount?
- chevette hsr replica
- exhaust size
- C20xe wiring in c20let
- oil pressure
- Fuel pump Positive/Negative
- what ht leads do i need
- testing injector flow rate
- 90degree breather pipe in rocker cover
- Astra GTE 8v 16V Conversion not running
- Corsa sport driveshafts
- 20xe seized?
- LET ecu
- do i need to run my new turbo in
- clutch kits
- f20 linkage
- Astra coupe Turbo mods?
- ECU
- perfomance parts for XE
- Help Me Please???
- Tapping/ thumping noise when driving
- c20let dump valves
- F20 onto C16 XE engine
- Oil leaking from end of exhaust cam, gen me up!
- lsd oil
- big bore manifold?
- C20XE Oil Leaks *appears to be above sump*
- cosworth actuator
- How would you wire this up...
- Urgent Help Required please!
- calibra oil switch and sensor
- F23 from Mk4 Astra 2.0 DTi Flywheel height
- 20xe water pumps
- C20LET with K16/K26 Turbo Setup
- Dizzyless Cams XE ???
- paddle clutches
- Corsa C Manifold
- XE and LET rings?
- C20LET Not starting after rebuild, no spark??
- astra gsi fuelling problem
- C20LET.. your opinion wanted!!!
- LET intermittent starting problem
- manifold pipes on xe
- Engine Swap!
- Underpowered (lol) Isuzu TD
- performance exhaust for coupe turbo
- mk4 astra problem
- best 200sx manifold to get for z20let
- Help with C20xe wiring
- which camshaft is which?
- best engine for a nova???
- transfer box/temp sensor
- gt28 turbo gasket
- xe idles too high
- Poor comsumption - Need help locating these:
- broken rad
- Gen on this clutch set up (piccies)
- urgent info required to help lil old lady with astra
- manual boost controller do they work?
- astra coupe ticking problem
- c20let engine's
- Crankcase Breather valve
- scorpion centre section
- starting probs
- c20let - vxr 475cc injectors
- Engine power
- whats this, and where does it go? (pic)
- astra g kicking
- help urgent! 2.0 corsa gear linkage.
- Mk4 Gsi turbo engine
- help on mk3 1.4 8v swap 2 a ecotec 1.8 16v
- F28 Speedo cable
- calibra turbo - oil presure gauge sender - low oil level light sender
- Raspy XE?
- C20LET immob / ecu q's
- Stock XE Dyno Graphs WANTED
- Help! Driving me mad
- xe with out dizzy??
- ahhhhhhhhhh not again
- Starter Motor on a Cav td (izusu)
- holding crank still to do up pulley bolt
- X20XEV Help -0340,0351,0352
- Had a pop at polishing some engine bits and bobs.....
- Is this a Flat or POT XE flywheel?
- Corsa B C20LET Ecu / immobiliser issue
- 2.0 8v in mk2 van?
- starting problem
- c20let-when on boost its like its hitting a brick wall!!!!
- Early xe cambelt gm number
- Nova 1600 Wiring - Starter Motor & Alternator
- c20xe icv
- 89 Nova 14SR cutting out
- Standard or uprated headgasket???
- C20LET general info
- C20 LET gearbox swap F20-F28
- c20let in to mk4
- can you run redtop without
- Spark plugs and leads
- 2.0 Cav Drive Shafts
- Quick help needed
- quick help needed
- injectors for redtop
- List of engine codes
- Corsa 1.5TD tuneing...... breathing
- c20xe running problems (rundown)
- v6 fly wheels?
- GM sensor question
- corsa B body stronger..
- keeping the let cool?
- v6 into mk2 astra gte 8valve.
- sport webers on corsa sri 8v
- Megasquirt on V6
- Cav turbo exhaust
- what clutch for a nova let
- mbc affecting afr????
- nova 16xe coolant hoses
- Parts needed to fit F28 box
- Help Please Gearbox Issue On A 2.0l Redtop
- c20xe throttle bodys
- Help with 2.5 td Omega Superchip
- crank shaft, timing pulley, calibra turbo
- r1 carb conversion
- C20xe + megasquirt tacho wiring
- c20let xe inlet cam how much power?
- quick c20xe question
- quick quest f20 box
- XE RWD dizzy fitting
- ecu
- 20XE Single Alloy bottom pulley
- whats needed to run seh on a dizzy?
- bike carbs vs throttle bodies
- Injector cleaning
- What lambda for dta loom??
- After market cams for a X14XE
- Overheating Cally Turbo - Fan Issue
- Rodgerq vision; Leesturbo creation. valve spring compressor
- removing the cats??????????bhp= + or -
- site scooby slayer
- can a faulty lambda sensor...
- Problems with F20
- 20SEH in Astra G
- mk3 astra X20XEV into vectra B?
- 1.4 head with a 1.6bottom end
- corsa 3 pot
- nova turbo eml wiring! help
- 20SEH (SRi 130) Engine Water Hose pics please
- does this block and head fit?
- corsa let drive shafts
- Mk 3 Astra missing
- HELP OMEGA VECTRA Hybrid
- c20xe and 20xe ecu help
- c20let tps full throtle resistance can someone please check for
- Fuel Pressure Reg And Throttle Bodies
- Is this just the injectors ticking?
- Astra 1.7 T.D not starting,not driven for 2 months.
- where can i get this pipe from?
- GT28RS or GT3071R (Again)
- Another crazy idea - Electric Supercharging ?!
- Corsa 1.4 sri E16SE problem
- what flywheel bolts for my fidanza alloy flywheel on c20let
- XE Corsa Starting Problem
- tappets wont settle
- x14xe and x16xe head differnace's
- Coil Pack Replaced.
- benefit of low comp pistons
- bigger injectors? whats with the colours?
- New Corsa 1.o Litre Active 12v
- help needed asap on wiring
- Need help with VAG TDI engine problem
- corsa with late xe engine
- megasquirt management.(Any good?C20LET)
- serious o2 sensor problems pls healp fast
- steam from rad
- PAS pump pully removal?
- LET Fault Codes
- Uprated Astra mk2 GTE 16V gear linkage?
- what pistons fit?
- DTA S60pro users! have a look here please
- feed and return?c20xe
- fse boost valves
- 20XEV cams duration?
- identifying arp rod bolts
- Supercharging a C20XE?
- corsa let water hoses
- Zafira 2.2 tuning
- pistons or valve stems
- 1.6 head on 1.4 astra g..????????
- hands on electical help in leicester please on astra 2.5
- Astra dti to c20xe
- LSD for Carlton 2,0
- c20let missing help
- z18xe inlet manifold?
- xe wiring into nova 1.2
- whats a hall sensor/ whats it do? c20let
- vectra gsi-f28 wots needed
- engine swap 1.4 8v mk2 to a 1.8 8v from a cav
- Best Petrol to run an XE on?
- Diesel problems HELP PLEASE
- turbocharging X20XEV?
- c20let into a mk3 astra gsi
- F10, F13, F15 - Which bits to use??
- Cav/Calibra Turbo 4x4 solenoid
- F16, F18 and F20 Final Drive Ratios.....
- Changing shafts and F28 oil
