- Big Bhp Sri
- Wiring. Im confused...
- Rroundered off Sparkplug Thread - C20XE Head
- Non Vaux question! Fiesta crank sensor...
- Should i remove exhaust centre box?
- Astra G GSI gearbox problem!?
- which headgasket?
- Possible imobiliser/ecu prob.
- bottom end?
- Oil on back of spark plugs... ??
- OIL LEAK!! Sump Gasket?
- Brass tube coming out of ECU
- c20xe power
- Petrol smell in car but no leaks, any clues?
- RWD Ecotec Exhaust Manifold?
- My Corsa Sri E16SE 1.6 8v died on me tonight
- C20LET What do i need ???
- power to astra 8v auto
- Can someone help me!! High emissions, low lambda readings.
- Ecotec vs Red Top
- mvaux turbo, any good?
- brembo brakes under speedllines
- MVAUX
- Can the C20XE be driven by other ECUs...?
- idle valve on let
- LET waterpump
- juddering. think its a misfire.
- 4x4 light, abs... connected?
- oil cooler differences
- Nova carb to injection engine
- intermittent xe tapping
- x12xe fuel pump on c20xe
- Air Flow Meter & Knock Sensor HELP!
- Daewoo Nexia X20XEV conversion
- fuel pump mounting
- Air leak? Strange problem.
- Megasquirt
- Calibra C20xe Coolant Hoses
- £500 to spend on a X14XE
- Tigra c20let diagnostic
- Turbo Recirc Disable Thingy
- Ignition wiring problem
- manta lsd!! help
- Fitting A Turbo
- Engine running VERY lean.
- boost problem
- quiaff diff for f28 2 & 4wd the same or different?
- ECU Number 16v GTE Astra
- corsa c engine transplant..
- 4 wires on calibre turbo gauges what are they
- How to clean block top???
- Need Help With My 3.0 V6!!!
- key and transponder...
- oil in a cav GSI RED TOP
- amal valve
- Which way to xe throttle body studs screw in?
- c20 let cylinder head bottom limit
- Crank bolt, pulley and woodruff key
- phantom grip LSD
- C20LET Haynes manual
- Was my intercooler sufficent?
- turbo oil feed/return leaking
- LET it run
- What exactly is a performance box...
- V6 brakes, will these fit ?
- gearbox info need
- sum kind of power steering fluid cooler on my corsa sport
- OK Plan B lol, lets talk turbo and not carbs...
- no compression c2.0 let
- E16se same as c16se
- Need a clutch for friday !!!!!!!!!
- calibre turbo gauges oil/volt meters
- driveshaft difference.
- Oil Cooler Qs
- IS the SBD 208 hp Kit noisy??
- c20xe engine conversion problem.
- c20let oil pressure
- 18xe & 18xe1
- Cav SRI 2.0 (Red Top)
- could a bad earth cause
- Apexi AVCR boost controller & APEXI SAFC FUEL COMPUTER
- differences between blue and cream injectors C20XE
- p0170 error code-changed lambda,spark plugs cant find leak now what help!
- 20SE and 20SEH pistons - are they the same?
- Supersprint Exhausts
- Late C20LET wiring loom on early engine
- Can I get 500ish bhp out of an XE or should I go cossie?
- X20XEV to Z20LET (in Brazil)
- Gearbox oil for c14se
- Z20LET Misfire - what could be causing it? *NOW FIXED!*
- Engine dress up bolts??
- how to wire in and test for fault codes let
- What oil would you recommend for an F28 gearbox?
- info
- HELP! EGR Probs!
- EPC request - 8v oil pump
- More power from my X16XEL
- Hard to get fifth gear now??
- c20let rebuild, help and ideas needed
- size of intercooler pipe off the pipe?
- 2.2 Airbox conversion for Z20let
- 1.8 head on 2.0 8v?
- X30xe in a calibra x25xe
- X30XE + Jenvey ITB question
- brake wear warning light now!
- OBD2 Interface.
- F28 electronic box in to cally 8v
- Plugs coked up
- SBD MT196 map
- c20let running badly?
- Rotten nuts
- nova 1.3 sr head on corsa 1.2 8v block?
- C20let into corsa b using c20xe kit
- CorsaB (AC model) rad Q's....
- Corsa Cams
- Will these cams be ok ???
- Diesel Engine
- What Astra engine is this, and will the camshaft fit mine??
- air filter on carb
- corsa let owners!
- throttle boddies
- msn
- Xe Lower Pulley Multi To V-belt
- EBC clutch kit
- OK head is off, breather full of mayo, Doh! lol (pics)
- xe head
- vectra st 6 speed conversion
- 240mm Clutch and LSD for F23
- fuel pressure reg on c20let
- Mantzel Style inlet box, induction pipe
- xe 2.0 dizzy or no dizzy
- what 550 or 600cc injectors can i get
- cams
- AFR lambda sensor colors???
- C20LET cutting out!
- rebuilding c20let
- vectra 1.6 16v top speed
- Recommended Megasquirt Dealer??
- F28 Gearbox Syncro Ring Question
- Astra auto gearbox problem...
- twin pacet fans. wiring help!
- f 17 gearbox i think!
- c20let engine question
- Uprating induction on Astra G
- Turbo rebuild
- Vectra 2.2 SRi 150 - car died
- 20XE Smoking under load
- xe running rich
- running diesel gearbox
- Oil Grade
- Aftermarket 'Chip'
- differences between late & early let's
- corsa c20xe help needed please
- 20NE Crank pulley bolts rounded off, HELP!!!
- Opinions or ITG Airfilters
- Corsa Sri E16SE 1.6 8v Not As Responsive ?
- Oil cooler sandwich plate thread size
- could this be a fuel pump issue??
- Corsa 1.2 engine problems
- XE or LET inlet cam part no.???
- oil level warning light has come on
- Which Clutch?
- Courtenay Stage 1 + Milltek?
- Apexi boost controller LET setup?
- best place to buy a fuel pump relay?
- xe flywheel
- F18/F16 Final Drive Swap - changing the pinion
- Which Oil For Corsa 1.0 Active 12v.
- Valve keepers - Refitting.
- Corsa Sri E16SE 1.6 8v Idle Adjustment ?
- Vivaro Clutch Help!
- Let high idling
- What the hell does this connect to??
- 20XE exhaust and header specs
- zafira gsi upgrades
- C20LET oil pump removal
- Oil coming through Dump Valve?
- what turbo to buy
- c20let chips in and cant feel a difference
- sensor under the thermostat c2.0 let
- need an Airflow meter for a c25xe or x25xe!!
- quafie straight cut gears with atb, oil????
- x20xev manifold
- fault code 94 on c20xe
- Clicking
- C20let strange smoking problem!!
- Veccy F23 box
- Red top engine what do i need ?
- Carb advice on a nova GTE!
- Corsa B 1.2 suspected fuel problems?
- I need lambda explaining please.
- Astra G 1.6 8V - Head Gasket
- Cracked head repair ?????????
- Coolant temp
- EM Light Frustration
- Anyone with Autronic knowledge?
- Coolant problems!!!
- Let into Mk2 Astra
- corsa C20XE conversion
- c20xe inlet manifold pipes
- 20xe throttle body
- Gearbox
- let cutting out occasionally
- Camshaft bolts, damaged and need to remove
- Exhaust Emmision Warning Light
- C20XE gaskets
- c29let engine man light
- F28 what year was change cable/elec driven
- Tigra Emissons
- Turbo
- Buying a53 plate astra with a newish engine -HELP!!!
- cruise control & flywheels
- Fuel consumption issue's??
- Crank damage - Would you re-use this?
- engine problem astra
- HELP! Crack in thermostat housing on c20xe how can i seal it??
- c20let idle problems?????
- How to install gearbox oil seal...
- Nova gearbox
- Help my exhaust emission light is on!
- uprated engine mounts/lightend flywheel
- Strange Noise From Astra Engine
- strange noise
- corsa sri 8v
- c20let parts at vaux dealer?
- Uprating a X20XEV
- injector testing
- C20xe/C20let throttle body
- All X20XEV's the same?
- Corsa B
- corsa 20xe only sparking on two cylinders???
- Manta 1.8 5 Speed Box
- c20xe manual adjust alternator
- engine conversionb 1.2-1.8 can anyone fit it for me?
- lambda sensor!?
- Anyone installed tuningbox 2.2Dti Vp44 Dual Plug
- All C20LET/XE, C20NE and Ecotec owners
- Switchable phase 2 eds
- Sard FPR gen needed
- C20LET ecu imobiliser??
- vxr injectors part no ie bosch no or who eva makes them
- Turbo boys, need help
- c20let z20let
- Ecotec missfire
- gearbox and axle oil
- c20let blowoff noise
- C25xe manifolds
- c20let cams?
- corsa sri help
- Z20LET oil capacity?
