- Removing Oil Gallery Grub screw
- F20 4x4 box into 2wd help
- Astra 1.7 DTL Feul pump Exploded diagram needed
- C20Let Calibra EVO5 boost problem
- c20xe wont spark after engine conversion
- c20let wiring diagram
- Spark Plug Gap for GSi2000
- x14xe troubles!!
- Dizzy assistance
- engine conversion
- c20xe mounts - for anglia 105e
- c20xe wont start
- dropped valve
- kent cams
- Looking for Trhottle video
- 1.5 TD ponderings
- Can I Do Paper Clip Test On My Car With Imobiliser Armed???
- cavalier transponer rewiring help please
- bad fuelling. over fuelling
- let wiring
- custom exhaust places nr sheff or that area
- engine loom
- 20se conversion into corsa b.
- How many stages in headstud torqueing??
- MBE 967 mapping query
- nova diesel
- mk4 xe/f23
- X20XEV onto a F15
- gearbox noise?
- let engine loom
- Understanding Cams
- let conversion gear mount question?
- X16XE Fuel vapour pipes, two vaccum pipes left over?
- Coolant Temperature Sensor
- oil spray jets c20let
- Kit Turbo In My Tigra
- best head gasket for c20let
- Z20LET idling fault?
- 2.2 Petrol Headbolt Torque Settings
- Ecotec engine number
- oil light wiring
- Gear Selector
- let 6 speed
- Astra Twin Port stalling and rough idle
- gearbox in opel tigra
- Tigra Immobiliser Problem
- Calibre Turbo Injectors
- C20LET F28 first gear sensor??
- Car will not start
- alternator bracket
- X30XE induction.
- c20let cutting out
- Starting problem.......
- happened to anyone else??
- rounded water pump bolt
- kkk flange?
- Where is the coolant going?
- Transponder and chip on the key?
- LET cambelt cover
- Redtop Radiators
- spark on mbe c20let running dispac
- My astravan wont start :(
- is it a oil sensor? xe
- SAGUM dispac - firing order????sbd tb kit boys help
- Running on 2 cyls SBD TP208
- Distribuitor For 1600 GSI
- help cavalier ecotec problems
- converting a 4x4 to RWD?
- Fitting Valve Guides.......
- Baggy Sloppy Gearbox
- antifreeze
- astra gte ecu loom question
- How do i fit dump valve to cali turbo
- Gearbox Or Gearbox????
- How to repair this two fault codes of C20XE---> 57 & 94
- what are these plugs on a c20let loom?pics
- Half omega half vectra engine HELP
- ignition outputs
- Independent rear suspension onto astra
- X20XEV Ph2 GSI Cutting out HELP!!!
- nova gte/gsi engine into 1.2 corsa?
- engine parts
- xe coil pack p/n
- do i need this wire
- Nova C20LET on Evo 5 ... misfiring when on boost...
- nova c20xe exhaust
- Calibra Turbo Clutch Replacement
- Fitting Vxr Gear Lever
- V6 into MK3 Astra?
- Cylinder Head - NOva GTE
- need to know 4.18FD speed vs gear ratio
- let into astra expansion tank question
- how to change a WATERPUMP
- valve springs - xe/let
- corsa BHP
- Fuel pressure on XE Redtop
- differences between vecra engines?
- SBD TP208 air filter back plate
- pj ecu
- my nackerd waterpump
- where can i get this fitting(mvaux waistegate????
- Twin 40s, To be or not to be???
- Difference between C16NZ, E16SE & C16SE
- C20let matrix product codes EPC CD?
- high Co/HC cat or Lambda.??
- Ecotec - engine fault Help please
- Good spec Bottom end for a XE?
- engine warning light
- How much oil for the f28 gearbox??? ASAP!!!
- Does the paper clip ECU FAULT CODE reading work on DIESELS?
- mk2 gte turbo
- astra mk3 gsi c20xe smoking round corners
- removing inlet manifold c20let
- corsa MOT emissions failure HELP! ASAP!!
- ARP con-rod bolts
- change engine
- c20let smoking??
- can you over throttle? as in too much
- vectra 1.8 16v revin at 4000rpm
- bike carb ma xe
- Simtec 56.5 ECU immobiliser wiring
- c20xe ht leads
- C20LET spark plug pictures, standard, uprated, high boost
- C20LET engine number?
- Corsa B: F20 removal, input shaft
- Will this fit a 1994 Corsa GSI ????
- Lowering Mk 4 Astra Turbo
- C20LET dizzy help
- Quick XE/LET Nova water hose question!
- Idle problems with X18XE1 Astra Coupe
- Z20LEH Crank pulley pic
- astra coupe engine help ?
- Forgive my stupididty (Loosing Water Again)
- is throttle postition sensor same as omega
- why v6 cuts out on full throttle??
- c20let boost hoses, 51mm?
- corsa gsi engine into sri shell
- Cally Turbo Smell of Oil
- What goes wrong?
- MK3 Astra GSI
- C20XE cutting out
- running a let oil cooler with no stat
- c20let core plug size
- 3.0 v6 omega full throttle cut??
- Flippin' stem seals
- 6speed linkage on let corsa gsi
- will this cam fit
- After some engine/head help
- corsa gsi lump into sri shell???????
- Fuel Swirl Pot ?
- standard dv pipe ?
- exhaust smoking and lack of power
- mk4 c20let
- corsa xe driveshafts/hubs
- equal length driveshafts
- sri 130 2ltr 8v
- oil light flashing on and off?
- Harmonic Balancer?
- Powerchips from collins performance
- gear cluster swap f10 to f13
- *URGENT* Timing Belt on Astra 1.4 8v
- differences between XE and LET
- dump valve
- 20xe / 20xej?
- headbolt socket size c20et
- Vernier Pulleys
- V6 clutch gone
- Slightly random - does anyone have a C20XE on an engine stand in Staffordshire ??
- Think i've acquired a turbo! Exhaust probs....
- f28, strip down to check condition? is it worth it?
- Z20LET Misfire
- ARE ECU's same IN manual or auto's
- 3.0 v6 omega ECU FAULT HELP no bhp
- Engine Mounts/brackets
- fitting sard fuel reg????pipe confusion?
- fuel regulator pipe
- gaskets c20xe
- starting problems
- c20let cracked bore
- c20let oil presure question!?
- Which cams, XE or LET??
- Big injectors,9:1 AFR,misfire
- Broke my Ford!!!
- Nova F28 Linkage
- Ebay Tappets..dodgey Or Not??
- Small hair line crack in turbo
- Tuning 2.0 DTI
- Removing Fuel tank vent valve
- injector size for upto 250bhp
- z20let exhaust manifold cracked
- Fitting Evo5 chip to ecu
- connecting laptop to mbe 967e ecu
- Anyone got pics of an early XE crank compared to a late one?
- F28 Flywheel Question
- induction roar
- z20let Turbo Oil Feed gasket
- Rough running XE
- XE Inlet manifold for Weber Alpha TBs.....
- astra mk4 egr valves & fault codes
- Astra Mk4 Barometric Pressure (BARO) Sensor Location?
- broken down spark plugs
- List of parts to convert C20XE to C20LET
- z20let astra engine management light on ?
- oe dump valve pipe query!
- X20XEV Possible Cambelt Snap at 60mph *ish*
- c20let actuator bracket, when changing away from a standard unit!!
- Corsa xe box removal
- 20XE C20XE X20XEV big block Daewoo nexia mounts
- Need advice on Traction control fault
- is this a head gasket problem c20let
- Pierburg c20xe
- Starter Motor Wiring - E16SE
- headgasket
- C20LET oil cooler
- Splitting an F28
- Omega Auto High rev Stutter
- 3.0v6 help on oil pressure!!!!!
- LET ECU pic needed
- Dbilas throttle bodied E16SE nova
- Performance Cams Z20LET Phase 3.5
- Port and Polishing... Mainly polishing C20XE
- Intercooler cooling??
- Cav Turbo steering rack
- Broken engine mount
- My rolling Road yesterday
- altanator differences
- fitting FSE fpr to 20XE
- Vectra v6, lots of mayo in water bottle
- X18XE1 Manifold
- C20LET mulit groove belt into Corsa B
- Can i clean under the rocker cover with contact cleaner?
- corsa let water hoses
- Chip an Astra 1.6 auto? will any one do it
- How to top up an f16 box
- XE Bottom Pulley Bolts - what size?
- Z20LET + Nova
- F20 4x4 gearbox will it work on 2wd
- 1.8 8v engine codes
- plate between sump and block
- wastegate Chatter is it ok....?
- C20LET ECU, Immoboliser type or not
- 20XE Engine pic/design
- Killed thread in bottom end....
- EGR Valve
- corsa v6
- LET cam cap torque
- diesel astra 1999 1.7dti wont start?
- Light flywheel/uprated clutch - Courtenay
- Big Bhp Sri
