- c20.let bottom crank shaft bolt
- Engine Management Light
- First engine conversion
- Gearbox compatiabilty
- Coscast C20XE Heads
- Corsa 20xe Exhausts
- Early C20XE water pumps with metal impellers
- Antifreeze - where from for larger amount?
- QED Q38H cams
- mpg calculations
- Reverting back from a Regal Phase 1!
- exhaust wrap..
- Mk4 astra fault codes list
- Kadett C20let
- will a smallblock speedo ring fit in an f20?
- Oil feed / return Banjo bolt size
- turbo refurb kits
- machined c16xe pistons,help/pics needed
- nova gsi wiring
- Vehicle Speed Sensor Location???????????
- LET flywheels
- Don't you just hate it when your 2.0dti goes POP
- "COSCAST xe" ON A "LET"????????????
- Vectra v6 missfiring HELP please.
- C20let Core Plugs!!!!
- Oil Cooler
- What wires do I keep after TB conversion on xe corsa??
- z20let gasket 0n c20let
- Zafira running probs!
- Ecotec error issues...
- Cutting out/ Erractic Revs Tigra 1.6
- Ecotec pipe on XE more power???
- Leakdown Test Results...
- C20LET Exhaust Maifold Gasket
- differance in radiators?
- nova gsi engine on corsa 1.2 box?
- c2.0let fuel rail and injectors
- Ignition Unit Help!!!
- Astra 1.7TD - Alarm problem
- c20xe clutch
- Astra XE GSi Intermittant starting fault, Help REQ!!!
- does anyone know how to change nos jets?
- Helicoils........where???
- nova turbo fuel pump?
- c16xe - code 44, not idling properly
- z20let astra coupe to vxr engined coupe
- middle section exhaust
- removing the egr valve from a corse gsi 16v
- c2.0let coolant diagram
- Astra G gsi exhaust onto 1.6 sxi?
- c20xe self revving
- Pics of my engine bay, arrows to my ICV much appreciated
- Diesel engine problems
- Vectra DI engine questions
- no spark c16xe
- C20LET Flange (downpipe to turbo elbow)
- bottom pulley bolt - help?
- fault code 13 and 47 on corsa GSi
- No spark or Fuel to rail
- is my y17dt OBD2 compliant?
- C20Xe Corsa driveshafts
- Camshaft Degreenin V6
- 98 they do RON RON RON they do RON RON
- C20xe Lamda Sensor
- Samco hose kit for C20XE CORSA
- Xe wiring help
- Best head gasket ??
- everything i need
- bottom pulley bolts
- exhaust bore question
- 450bhp 4x4 Tigra Project,, 4x4'ing info
- info on c20ne please
- k16 turbo/downpipe zorst flange
- oil cooler
- c20xe summer problem
- Seh Nova, What Box????
- coolant calibra turbo engine
- turbocharging a c20ne???
- Error 69 (ATS) - Air Temp Sensor
- c20let fault code advice
- Recon engine and gearboxes
- XE enlarged throttle body
- C0244 Actual Engine Torq Malfunction
- Suitable replacement alternator?
- astra gte mk 1
- help please urgent ecu and sensors
- Engine Coolant Temperature (ECT) Sensor Issue's
- can anyone suggest to me a decent place for a recon turbo???
- Corsa paperclip test
- Oil Catch Tank?
- chip and ecu re-map
- C20let wiring
- 20.16v redtop in a calibra now it sounds like its running on 3
- crank sensor q
- crank sensor and lamdba q's
- Adjustable Weber fpr? *pics*
- Astra F: Where to connect pipe
- Hall Effect Switch (Low Voltage)
- c20xe multiple misfire
- Equal lengh shaft CV same as standard shaft?
- C16XE / X16XE Transplant into 1.4 SPi astra
- Z20 LET Smoking when hot
- corsa gsi wont idle
- quafe atb
- Nova 88..redtop conversion
- XE ECU opening and installing chips??
- 4x4 info please
- Oilsquirters from Isuzu 1.7 diesel turbo?
- ARP rod bolts
- astra mk3 gsi turbo brake upgrade
- Big end bearings
- which engine?
- corsa xe V belt conversion, alternator gen
- LET turbo oil feed and return
- custom driveshafts
- fuel pump
- xe and let loom
- Increase Traction ?!?!
- astra g X14XE radiator needed
- Why LET making alot of Oil pressure?
- XE FPR quick question
- gear adjustment
- Inlet Manifolds?
- GT4 Gearbox
- Innovate DB Gauge & LC-1 Kit
- 1.3 sr turbo?
- just wondering on any info
- Ecotec to XE
- removing mesh in afm?
- vauxhall cavalier gsi c20xe red top
- Z12XE - Does it have a precat?
- Camshaft swapping?
- Calibra V6-LET
- URGENT! Mbe help needed for MOT! Anyone got a map I can borrow!?
- F28 gearbox
- 16xe powerbox mods without remap - experiences
- Panel Filter vs. induction kit?
- In-car Fpr gauges....
- A question on exhaust heatwrapping...
- Throttle Position Sensor
- 1993 cav
- astra Turbo 99 fuel filter location ??
- marks on pistons
- R1 Carbs Help!!!
- Error 19 - Top or bottom sensor
- c16xe
- Inlet Size - V6
- xe or let ?
- c20seh into nova?
- C20LET injectors?
- c20xe throttle bodies
- Will a C16XE headgasket set fit a X16XEL?
- c20xe ecu wiring diagram
- Distributor part number for Astra C14NZ
- no spark
- mk3 astra gsi idle
- C16XE belts
- AFM and MAP testing.??
- redtop turbo problem
- Corsa x14xe please help
- fitting c20let loom in corsa b?
- which crank?
- Fram filters
- X20XEV induction system upgrade???
- is a c20ne bottom end casting same as c20xe/c20let
- nova f28 g/box mount
- Power Streeing PLEASE HELP
- clutch!!!
- Oil leak from camshaft seal.
- co emmisions
- calibra drive shaft removal
- Let boost problem
- XE to LET Information
- Fault code
- c2.0let cooling
- Best place to buy a 'performance' panel filter.
- f28 gear oil is this right?
- Fuel consumption report
- Corsa C20let uprated fuel pump....WHERE?
- loss of power due to exhuast?
- can i test my crank sensor with a volt meter
- X18XEV head swap
- clutch kits
- C16xe alternative flywheel/clutch
- Very noisy
- Corsa redtop conversions
- Clutch cable change on a Td cavalier
- Nova C20 let keeps dying
- Melted or shattered valve?
- ZLET Oil Pump changing?
- Can anybody help?
- tb for less than a grand??
- C20 LET part no. request
- Megajolt - C20XE
- 20xe Injectors
- carbon cannister
- 2.0 8v tuning plz help
- corsa let+f28
- Evo 5 LET Nova Problems again...
- LET Cam Specs
- Wiring Loom
- What is a Screamer Pipe?
- Engine code query?
- 17 td lack of power and noisey engine
- what gearing
- F13 Gearbox
- Final silencer c20xe differences
- v6 engine into astra gsi
- Anyone bought a tech2 interface from Ebay?
- why are these so cheap?
- Crankshaft sensor from a cavalier V6, and a 3.0 omega v6, the same?
- what is the poly v belt
- fixed alternator and poly v belt
- Corsa LET belt sizes
- Broke my ford again :-D
- corsa xe pulleys
- nova let intercooler problem
- Powerflow exhaust questions
- vauxhall senator 3.0 24v 94
- Dizzy Engine into Dizzy-less Calibra
- 3.0 omega starting problem
- astra mk3 throttle postion sensor
- c2.0let cooling diagram
- exhaust differences mk4 astra turbo and non turbo
- Where is my charge relay?
- c20let valve guides
- Evo 5 chips top and bottom.......HELP!!
- E-Ram Superchargers
- serious help needed!!! fault codes on ecotec
- c2olet pk ecu
- methods of testing an EGR valve - X16XEL..
- Calibra Turbo clutch
- peugeot 106 gearbox and drive shaft identification
- head bolts on a LET
- Wiring an LET loom into a Nova
- ultimate C20LET
- 1600 16v ecotech - starts then dies
- let misfire at high revs only
- 2L cam into a 1.8
- C20XE Inlet Circumference ??
- Let elbow removal
- C20LET error code
- where can i get......
- turbocharging and modifying a 20SEH/C20NE??
- c20let question?
- c2.0let coolant diagram,
- o2 sensor wire
- c2.0let high idle
- f28 problems
- gm head mod
