Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. Xe To Let Loom
  2. Where to get big end bearing shells from
  3. C20LET nova exhaust on a C20LET corsa
  4. Crankshaft pulley removal.
  5. f20 gbox and clutch on a let
  6. Xe Exh Manifolds
  7. Reading Oil Pressure On Lcd Dash
  8. XE oil pressure concern.
  9. turbo nova hubs
  10. identify this part and a couple of questions 1300sr (carbs)
  11. let idle to hi
  12. Astra 16V Ecotec Temp sensor
  13. best place to buy turbo rebuild kits from???
  14. Cam belt type
  15. help weird noise
  16. Corsa 1400 sport
  17. [03] Vectra 2.2 SRi Petrol tapping when cold
  18. c20let astra radiator! help!
  19. Half Shaft, Same or not?
  20. Coupe Turbo manifold blowing
  21. c20let guru's please help!!!!
  22. Best way to clean the cooling system out?
  23. 2.0 cav
  24. **turbo Advice**
  25. Stalling!!!
  26. Vectra V6 knock sensor
  27. Nova+LET+F28=Undrivable Toruqe Steer?
  28. Lumpy corsa
  29. rich/lean indicator
  30. C20XE CLUTCH (early flat type flywheel)
  31. C20 Let Sensor characteristics
  32. F28 Gear Linkage...
  33. C20LET which is best
  34. bringing a high-miler back to life?
  35. actuator problems
  36. help with a mk4 astra 1.7 td .
  37. mk3 astra airboxes. All petrols the same??
  38. Nova radiator outlet size?
  39. C20LET head bolt torque
  40. valves
  41. help on fitting this 1300 to my corsa
  42. Any reason Xe would snap a rod????
  43. Stage 2 RS Turbo T3, Good for an LET ??
  44. porting and grinding standard head and manifolds
  45. c20xe tuning and torque figures
  46. Rear Driveshafts Cavalier Turbo
  47. 20NE cylinder head help
  48. Yet more problems with my 20NE!!
  49. xe and let cam difference?
  50. 2.0 rear quaife ATB
  51. Fuel Pressure Regulator
  52. Head gasket/valve stem seal change - DIY?
  53. Removal of crank pulley
  54. corsa c20let intercooler problems!!!!!!!
  55. F18 in M Reg astra GSi
  56. Clutch slip - Nova LET
  57. vacuum gauge?
  58. help please!!
  59. Engine numbers on my C18NZ (i think) and could i swap spi for mpi
  60. C20let Problem
  61. 8v Cylinder Head
  62. canshaft cap.. tightening sequence
  63. speedo sensor
  64. LET Turbo info needed!
  65. c16xe or x16xe
  66. 4x4 light on but propshaft turning?
  67. oil for rebuilt xe
  68. part number for corsa ecu 17dtl engine?
  69. C20XE throttle bodies - late Vs early
  70. vectra v6, oil cooler fixed, now got a knocking noise at 2000rpm!!??
  71. Washer sizes for oil cooler to banjo fittings...
  72. Coupe Turbo Gearbox
  73. engine probs
  74. Balancer Shaft Removal – Girdle Question
  75. 1.2 corsa hesitating at full throttle
  76. quick fuel question
  77. fuel rail sizes as in -8.-10 areoquip
  78. clutch for a nova let
  79. cav gsi exhaust
  80. Corsa gearbox conversion
  81. a call for some inteligent engine tuners please. 1.4 tuning
  82. MBE Base Map
  83. None vaux question - fiat punto 75 running crap
  84. c2.0let oilseal
  85. help needed with c20let water pump's
  86. smokey let
  87. XE/LET paper oil pump gaskets?
  88. coil for c20xe conversion
  89. 20NE Ignition problem........PLEASE HELP!!!
  90. C20let leaking oil still
  91. C20LET gudgeon pin clips
  92. WEBER 36 DCNVH on small block?
  93. nova sr engine running rough? Please help!
  94. Best way to fit 16xe downpipe to nova system
  95. vauxhall 1.8 or 2.08v in to corsa
  96. Combustion chamber advice needed please.
  97. cavalier 1.8 8v running rough
  98. removing the sfi studs from the throttlebody
  99. corsa running problems (2.0l 8v 130)
  100. Forged Piston for 1300 8v
  101. x25xe oil cooler
  102. engine mount change will it work????
  103. the turbo'd astra's dead!
  104. C20XE / 20XE ECU Different?
  105. Astra MK3 V6 conversion.
  106. Off Topic - but needs to be said
  107. gsi 1.8 info please
  108. Emissions Problem
  109. Upgrading to VXR turbo
  110. please look (power steering on clet corsa)
  111. Breathing problem
  112. New Oil Pump fitted
  113. c16xe - wheres engine number?
  114. XE inlet side piccy needed
  115. xe inlet manifold
  116. 2.0 8v (SEH) Exhaust manifold temps, any ideas??
  117. c20let valves
  118. any1 no this answer
  119. Zafira GSi using lots of oil
  120. help with cams and lifters
  121. Engine Flooded
  122. Engine bay welding?
  123. air flow meter
  124. c20let problem
  125. Have I timed up my xe properly?? with dta
  126. c20xe bent valves
  127. Turbo or courtney conversion?????
  128. white smoke from corsa sport
  129. Oil pressure of a standard XE
  130. 1.4 16v Cambelt change - DIY?
  131. 20XE head and block weight?
  132. 1.2 injection corsa (cambelt broken)
  133. 1.4 16v Ecotec - Acceleration hesitation.
  134. Throttle body pics
  135. can i use cally 8v fuel pump on redtop?
  136. manifold polishing
  137. regal shafts on corsa c20let
  138. Redtop Turbo Into Vectra??????????
  139. nova f20 box help
  140. pistons
  141. lots of problems..?
  142. Mk3 Let intercooler
  143. cam problem
  144. Why use xe inlet cam on C20let??
  145. HELP fiting a charge cooler
  146. em light is on
  147. C20LET Help?
  148. Astra 1.7 dti turbo problem please help
  149. oil pump c20let
  150. Astra F Diesel, Clutch release bearing problem
  151. c20xe corsa speedo cable
  152. Mk4 Astra, Engine Blown out?
  153. pullys
  154. Anyone know about citroen diesel van fuel prime pump?
  155. c20xe cylinder head question with pics
  156. Oil Pump Removal
  157. regal EDS phrase 3 chip
  158. Vectra 2.2 overfueling
  159. Spark timing on 2.0 8V
  160. corsa 1.4i auto box probs
  161. spray bar
  162. corsa engine conversion question
  163. nova engine mount question
  164. can u get uprated shells for c20let?
  165. brainfart of the night-throttlebodies on standard management
  166. Auto Astra 1.6 gearbox prob
  167. tigra C20xe) will not start
  168. Locking A Tx Box
  169. !!HELP! nova c20xe running f13
  170. C20XE Head studs
  171. how do i
  172. tps help
  173. Misfire on my cav turbo
  174. HELP EDS phase 3 error easy but tricky
  175. Turboing an X20XEV
  176. what would this make my compression ?
  177. Help! How to split prop shaft from rear diff??
  178. silicone vacum hose c20let
  179. Idle Stepper Motor promblems WTF! please somebaody HELP!
  180. Z20LET head gasket on 20XE
  181. vectra 1.6 16v into corsa
  182. just changed glow plugs now car wount start!
  183. Belt
  184. what the torque settings for c20let
  185. head bolt tightening on c20let
  186. help
  187. manifolds for astra gsi
  188. low voltage stabiliser
  189. Advice on Clutch Fitting
  190. does anyone know about diffrent nos jet types?
  191. nova engine mounts?
  192. let corsa power steering question
  193. quick Q?
  194. astra van problems
  195. hybrid turbo?
  196. late and early x20xev
  197. c20xe paperclip test
  198. C20LET bottom pulley and cambelt drive
  199. fitting Nos
  200. quick mk3 gsi fuel tank question
  201. z20let head gasket tightening torques
  202. C20LET/Z20LET Pistons and Rods
  203. XE/LET Pot type Flwheels
  204. Nova GTE/GSi Gearbox
  205. vernier pullys ??
  206. chips / ecu remap
  207. welding up a diff
  208. z20let servicing?
  209. Gauges. Which ones?
  210. Oil Pressure Light
  211. Nova alternators
  212. C20let Fuel pump relay
  213. Actuator replacement
  214. c16xe missfiring
  215. 1.4 manifold
  216. Clutch Problems Nova F28
  217. fault code on c20xe
  218. Helper spring
  219. vxr injectors
  220. are 3.0 cams all G numbered or just inlets
  221. c20let, ph4? what kind of engine spec would be needed?
  222. Vectra Redtop
  223. vectra gearbox change
  224. 1.4XE 16V
  225. racing chip
  226. XE running problems
  227. DTA E48 and Innovate LC-1
  228. Quick Daft Question
  229. LET into a 1.4 MK3 Astra
  230. Wanted Urgent Xe Wiring Loom Can You Help?
  231. pic request 1.6 16v Nova
  232. oil pressure and digi dash
  233. x20xev cambelt
  234. help needed
  235. Knackered EDS Phase 2 chip / Switch ???
  236. C20xe Exhaust Popping!
  237. do i need to bleed my fuel system?xe
  238. water in inlet
  239. where can i get a large bearing for quaife diff into f28
  240. TB / Injector question
  241. Why is XE/LET king lead excessively long?
  242. Ignition Unit Prblems
  243. Uprated Cams
  244. C20LET ECU Chipping Question?
  245. Oil Breather
  246. C20xe idle problems
  247. oil in boost pipe on c20let
  248. Oil flowing from the filler cap
  249. smoky turbo
  250. Getting past the Anti-Syphon
