- C20 Let Pistons
- 2000 astra sri xev power loss when hot?
- Which HT leads...........?
- what parts are needed????
- corsa sri
- Engine number for nova GSi and GTE
- Corsa Xe Pas Pipes
- Engine Transfer
- gsi lacking/lost power
- Anyone ever fitted an oil pressure sender to a 2.5 V6 Vectra?
- xe cam into a let
- 16xe cams-Which is inlet, exhaust,lol
- 1.6 16v TB'd Engine... more powere required!
- turbo service
- MBE with TP208 chip file required
- Mk4 Astra Sxi engine conversion
- cat cams
- blew an inner cv joint
- Problem With Mk4 Astra X20XEV Car Idling
- Diesel vs Red Diesel
- SEH engine rebuild advice
- C20XE - ottom pulley bolts
- corsa let not charging
- Car booked now in for r/r session (do i need an adjustable FPR ??????)
- Corsa differences
- help cambelt c20let (early) astra
- oil pump ???
- gsi shafts?
- gearbox and clutch fitting
- rotary air control valve on c20 xe
- X20XEV (C20XE ?) lower power steering pump mounting bracket
- c20xe crank sensor
- Radiator Fan control?!?
- 1.9 cdti jerkyness
- C20XE Oil Sandwich Plate GTE/Gsi Same or Different?
- Nova oil pressure gauge...
- ecu
- let wont start
- Z16XE Owners please read!!!
- Part Numbers
- Removing EGR and SAI from x16xe(1.6 16v)
- f28 speedo conversion
- C20let Gearboxes Wich Is Best?
- Have a leak + Pics included
- Mk3 Astra Sport xe conversion
- c20let rebuild info
- can you help me start my gsi?
- how much will i recieve to break....
- Let trouble....any ideas
- let ignition timing
- V6 Mk4 Astra
- Clatter when going in reverse
- E.M light on!?
- Alternator size?
- Infomation on the managment system on the z16 xep 1600 astra
- standard recirculation DV location on Mk4 Astra GSi
- cav 2.0 8v manifold and down pipe fit as astra mk3 with 2.0 8v engine
- c20let in to vectra p reg
- I am a d*ckhead, 2.0 eco into corsa HELP
- converting from SPI to MPI?
- fitting 40's to a 8v
- 2.5 V6 power
- Veccy 2.5 V6 pic
- V6 project gone wrong - I think!!
- z20let under power
- hi everyone im new here
- c20let vacum
- round multipin plug calibra whats it for?
- Purple injectors?
- Wanted........A Picture of>
- DIY cambelt change problems - Help required ASAP.
- vmax evo 5
- Corsa X20XEV gear linkage
- Crank speed sensor 20XE ????
- crank seals
- vacuum pipe on 20XE
- C20xe timing kits.
- Another turbo gone?!
- help with omega exhaust
- cavalier fuel tanks
- oil pressure high!
- difference in ecu?
- wiring diagram for c20let loom needed
- dip in torque curve
- 1ltr > 2ltr 8v wiring issues?
- nova let 300 atw
- Hot starting problem on a 20NE?
- Corsa sport 1.4 . 1.6???
- cambelt
- z20let(dump valve)
- F17 Gearbox
- vectra problems
- cossie inlet manifold for c20let
- F28 into my Cav V6
- F28 Clutch fitting
- Calibra XE coolant hose
- fitting a c20let into a corsa
- emission test problems
- 10psi let starts spluttering
- Gear linkage?
- Astra GTE 8v running issues
- tapping XE
- Effect of adjusting the idle CO potentiometer screw
- Difference between Astra GTE 8v and 16v injectors?
- corsa b lambda sensor
- Oil on the top side of the plugs
- CorsaB 1.4 16v Erratic idle
- 1st Gear Switch on LET Loom into a corsa
- Lotus Carlton Transmission
- egr????
- key coding!
- My MV6 engine idling high
- frontera intercooler
- advice needed. engine problem redtop
- Urgent help needed ! Cam timing!
- F28 6 speed strip down! documents/manuals??
- c16xe wiring
- C20LET calibra Fuel pump phase 3 (evo5 -vmax310)upgrade
- Nova Plating Kit
- frontera red top ?
- loss of power in corsa sport
- more power
- Oil Capacity on a 20NE?
- New project help needed
- Changing Coil Pack on a V6 Cavalier
- Aftermarket cams for x25xe?
- X25XE Tubular manifolds
- couple of c14se q's
- increasing power on a c20let
- Pictures of Late setup for C20LET needed please?
- fault code 22 and engine warning light on
- Dbilas or home made?
- C16XE fault code help
- Astra not starting right. Any ideas
- Battery warning light.
- Ashley Manifold Exhausts
- cambelt play
- Whats the partnumber of an XE bottom pulley?
- The engine & airbag light come on when the car is first started but......
- looking for a cheap OBD1 reader any ideas?
- c20XE-LN help wanted please
- cryogenics??
- Cooling on kkk16 turbo
- supercharger c20xe
- someone make me a shopping list for 400bhp let.
- astra mk3 with let & f28 - but which linkage??
- Help!! Sheared Sump Bolt
- engine noise
- LET Rocker Cover Gasket
- emissions ?MOT
- injectors
- air pump
- Corsa Air Box's Different?
- Pot fw+LET pres.plate VS flat fw+XE pres.plate
- Engine mount bolts
- T40d 1.4 8v misfiring-Urgent help
- fuel injectors
- calling all turbo owners - help needed!!!
- Conversion kits
- whos using vxr injectors on a c20let
- boost
- F28/6 Speed Gearbox in a X20XEV/Ecotec
- c20let smoking
- 4x4 fault
- faulty fuel flow damper
- 3.0v6 into mk3 astra? what ecu/loom etc?
- Engine Code and cutting out
- flat spot on c20let
- Tunability of the ecotec engine
- Remote oil filter ??
- 1600i Astra 16v - 2003 model - timing problem?
- EDS Phase3/3.5 ????
- help vectrasxi doing half the miles it did
- egr fault
- Oil Pressure on 16v Calibra
- tubular c20let manifolds
- Traction control on mk3 LET
- Help, Need a new turbo!!!!
- ECU NO. for a V6 cav ?
- Standard Cams on C16SE?
- F28 vs F20?
- SBD Exhaust manifolds
- Where is engine number
- Misfire 2.2 Astra Coupe
- bleeding/termostat
- Cleaning A Piper X Air Filter
- XE Exhaust cam oil way...
- RWD 2.0 xe nova drift car?
- is this important? (F20 gearbox related - pic inside)
- Bottom end rebuild
- V6 Secondary Water Pump
- XE Crank V xev Crank
- DtaWin Software for DTA E48 ECU wanted
- 8 valve vauxhall engines
- picking the correct radiator
- wot plugs.......approx 280bhp let
- help with c20let head
- 1.8 ecotec astra gsi none start
- what vaux has the 3.8 bar reg???
- Noisy tappets / oil choice?
- Meriva Clutch
- c20let-fault code 114?
- xe conversion into a mk1 astra GTE
- corsa speedo not working
- X16XE into K-reg Nova-Required cat, yay or nay?
- Trouble shooting experts??? Sorry not a performance Vauxhall....
- V6 pistons
- gearbox spins backwards when in 3rd or 4th
- nova 22 spline shafts??
- c20let exhaust manifold studs
- Please help astra coupe 1.8 g
- Swaping late pot type flywheel for early type
- standart c20xe conrods.
- What engine code for a astra 14 16v wreg
- digi dash in a nova
- Anyone got/know about the Omega V6's?
- cam duration exhaust or inlet
- how do you calculate cc
- Removing clutch leaver on an F20
- Has anyone got....
- To replace, or not to replace. That is the question (cambelt rollers)
- c20let charging/voltage low problem
- advice on x30xe intake.
- Performance Increase
- corsa 20seh help
- nova f28 gbox mount question
- ecu
- which ht leads for early let
- astra mk3 fails emissions yet again
- Engine managment light flashing
- odd noises and tap
- 20NE oil pressure problems
- corsa c
- mk3 cavalier fuel pump
- Mk3 Gsi speedo
- Mk3 cavalier non starter
- Ebay Item
- Astra Exhausts
- increasing cylinder size of an c20xe?
- crankshaft bolt c2.0let
- c25xe and immobilisor key question
- Head stud problem.
- Tell Me About NOS C20LET
- What Pistons Are These?
- Reverse gear crunching (corsa b)
- Erratic revs
- Vectra Sri V6 Clutch Prob
- what clutch does people recomend for my mk3 astra gsi turbo - let/f28
