Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. what engine will fit straight in
  2. bigger engine
  3. xe into nova - strengthening
  4. XE, Taper TBs, emerald ECU... 4krpm???
  5. Vectra diesel help
  6. nova gte lump into corsa b
  7. cavalier gsi c20xe
  8. Vernier pulleys
  9. egr help
  10. universal 02 sensors
  11. C20XE Grp.N ECU's..... Any gen?
  12. Ecotec Identification
  13. Supplying Own Cambelt Kit To Garage
  14. Standard Conrods
  15. fitting an apexi avcr
  16. converting to 5 stud & brakes
  17. Clutch Slip Question
  18. oil grade
  19. Universal intercoolers suitable for DIY turbo conversion
  20. Astra MK2 instrument panel pinout
  21. let turbo
  22. eps
  23. this clutch gonna be ok for 350bhp let??
  24. Xe Big Valve Head
  25. C18XEL bottom Pulley
  26. 1.4 engine build help (long shot)
  27. Spill pipes
  28. knock sensor + fuel tank vent valve
  29. v6 astra engine choice/combo/mod
  30. cav redtop engine problem
  31. blue injectors help!
  32. nova redtop fueling
  33. Red top Manifold
  34. corsa LET boost probs
  35. C20LET clutch reccomendations 292lb/ft +
  36. Reliable 230 bhp from an XE
  37. oil filter
  38. 1996 corsa gls auto engine number location
  39. Fuel leak and power loss?
  40. Sparks from exhaust - any ideas?
  41. Astra SRi poor performance, what should I check ?
  42. x16xe running prob
  43. Using braided (brake) hose for LET oil feed ?
  44. 2.5 V6 hesitation
  45. Drive to only one wheel!!
  46. R1 carbs on x20xev?
  47. Random overheating/head gasket?
  48. Exhaust manifold
  49. COLOSSAL Engine death at 7900 RPM
  50. Gear selection way too tight - clutch/flywheel wrong?
  51. what is a 3 pipe mod?
  52. kenlowe fans
  53. omega cams?
  54. LET 3.5 BAR Fuel press reg?
  55. 02 sensor
  56. Airfilter for LET
  57. 1.6 16v into Nova GSi?
  58. oil presure reading too high on let
  59. Webber carbs
  60. Where is the ECU located?
  61. kent 16xe cams-No sprocket locating pins?
  62. vxr injectors
  63. What Oil for a LET
  64. Enlarged v6 throttle body
  65. corsa c20let ARB problem
  66. skimmed and ported 1600 head.
  67. Corsa V6 conversion any 1
  68. Nova gearlever change
  69. Think it's fuel problem so ill post it here.
  70. help please!
  71. phase 1 boost trouble
  72. CORSA V NOVA = what exactly
  73. Is the C25XE odd fire?
  74. ..cardan..
  75. 3.8 bar fpr
  76. Whats this plug for??
  77. Which alternator for cavalier V6??
  78. whats the difference
  79. 1.4 8v tunning help?
  80. new clutch?
  81. vxr injecters and top hat? help plz
  82. C20XE Pictures High Res
  83. major lack of power (cav sri)
  84. cv joints keep blowing
  85. ICV, Knock Sensor and Tank Vent Valve issues, PLEASE HELP ITS URGENT lmao
  86. astra gsi mk3 fuel pump
  87. digital clock worry
  88. v6 into astra gsi quick few questions
  89. redtop into mk3 astra help!!!!!!
  90. What engine would i have?
  91. zafira problems HELP PLEASE.
  92. While the box is out...F28 hydraulic clutch release?
  93. 1.8 cavalier over reving help
  94. C20LET PJ ECU Help Please..
  95. C20LET Engine Wiring Loom Differences
  96. fuel pump advice
  97. c20let oil pump
  98. fuel filters, pumps,hoses,regs ect
  99. wierd engine problem.. HELP ;0)
  100. mk3 v6?
  101. CTS Connector the same on all 16v Vaux's?
  102. ecu tuning files
  103. The Big Discussion 20seh Vs C20xe
  104. accurate charge temp gauge/sensor
  105. LET into Astra, starting problems. No Spark
  106. some help with the gsi
  107. Corsa 2.0 Xe Just Finished And Disappointed
  108. Vectra 2.5 V6 tuning?
  109. injector o rings
  110. help Tuning the mighty 20seh?
  111. putting turbo engine into a mk3 astra
  112. LET help (EVO5)
  113. power goes at 5000 rpm on let (help needed)
  114. Quick Engine Q
  115. wiring a c16xe
  116. best clutch for 400bhp let
  117. c20xe valver corsa wont start
  118. Nova GTE Diagnostic Plug, WHERE!!!!
  119. Engine Additives
  120. mk3 LET more build probs..
  121. C14NZ Fault Codes - Constant Flashing?
  122. Unknown corsa look plug/part-Maybe g/box related
  123. tigra c20xe pipes urgent
  124. corsa c20xe connections
  125. zlet head gasket on a x20xev
  126. C25XE Breathers?????
  127. ford sierra dohc overfueling :(
  128. Engine swap.
  129. Fuel lines Ecotec, which is which?
  130. exhaust 3inch or not
  131. c20let-just been rebuilt and has alot of pressure in water system!
  132. C20Let Pipes Query
  133. Engine help needed
  134. What engine code?
  135. Fuel pressure relief valve
  136. 400bhp let, but what management?
  137. engine management problems
  138. Turbo probs
  139. Phase 2 injectors
  140. turn key...but nothing
  141. phase 2 boost - whats the deal here
  142. Which Air Filter?
  143. heater blank
  144. LET into a basic Mk3 Astra
  145. c20let chips
  146. lamba sensor
  147. MK3LET fitting probs-breathers
  148. engine problem at idle
  149. Temperature Gauge Not Working and Fan Running Constant
  150. GSI - Ecotec to Redtop
  151. phase 3 problems
  152. Quick shift on a mk3 astra
  153. mr2 , sorry
  154. Pug 306 boost gauge fitment
  155. Mapping, Fuel Pressure And Cam Timing
  156. 1.4-1.8 veccy engine in tigra?
  157. Coolant hose - Turbo to header on a C20 LET
  158. What size e-torx socket-16xe crank pully
  159. C16XE Head upgrades
  160. Let on cossie management
  161. F28 Rear Mount Help Needed Please
  162. F18 on an XE
  163. Turn up the boost............?
  164. F17 gearbox question
  165. f28 gearbox
  166. raid hp air filter on c20xe
  167. Question about F28
  168. speedo cable of28 in corsa
  169. how to move fuel filler cap on mk2 astra??
  170. Cav hard to start when hot
  171. Winding the turbo up, 1.7 Izuzu engine
  172. xe/let headbolt torque
  173. how do i get my speedo working?
  174. 1.6 8v to 2.0 8v
  175. porous head c2.0let
  176. thread size on XE/LET sump bolts?
  177. corsa 1.4 16v sport holding back when warm
  178. Timing belt covers & MOT?
  179. Inlet hose to AFM needs to be altered?
  180. Advanced Ignition on 20XE & NOS - HELP
  181. fault code 113 'turbo boost control boost pressure high/ out of range'
  182. astra mk3 piston and bore measurements needed
  183. Red top Manifold query?
  184. Which turbo should I use?
  185. c20xe coil pack people NEED UR HELP!!!!
  186. Turbo Diesels And Dump Valves
  187. 2.25" VS 2.5"
  188. convert my c20xe to a c20let
  189. doug kiddie crank
  190. Tuning a V6?
  191. no live feed at fuel pump
  192. Astra 16v sport misfiring
  193. carbed red top running problems!!!!!!!
  194. Crankshaft pulley
  195. f16 box on 16xe?
  196. o2 sensor plug wheres it plug in on seh, ne?
  197. anyone have access to a lathe ? small bit of machining wanted
  198. fuel pressure regulator
  199. F28 shaft problems.
  200. oil presure on let
  201. sensor trouble
  202. Preperation for RR session
  203. 1.4 sport power?
  204. identifying a coscast head
  205. LET conversion, immobaliser problem
  206. Traction control on V6 astra gsi
  207. Z28NET in my Lotus Elise
  208. Engine management light
  209. N/A exhaust
  210. extra wire in crank sensor on c20xe
  211. Who can help me get my car on the road? This is a proper plea!!
  212. what after market ecu for c20let
  213. problems
  214. C20Let Questions, running poorly
  215. Starting Problems
  216. Astra sxi 16v 52 reg Starting issues
  217. quick one 3.2 heads on 3.0 YES/NO
  218. 300 bhp from let?
  219. Hyd clutch kit fit a cable clutch box/engine?
  220. xe-let
  221. x20xev and c20let same oil level sender?
  222. swedish style intake manifold???
  223. NOVA PICTURE NEEDED ASAP! (Under car floor pan / exhaust system on car)
  224. carrying on this pug forum, differences between 1.4 and xsi?
  225. cav sri 130 c20 let conversion
  226. c20let water injection yes/no??
  227. can any1 help code 29 0n astra 1.8 16v eco?
  228. Bizarre Astra GSi cutting out problem
  229. Tigra C20let hot air
  230. xe or let?
  231. Pulsar inlet for LET
  232. FMIC pipeing
  233. Redtop Nova Running Prob, any ideas ?
  234. SEH into astra 1.4spi questions?
  235. F20 G/box fluid spec??
  236. C20LET Boost question,
  237. Intake Air Temperature Sensor?
  238. PK ecu
  239. mk3 astra c20let f28 which cv joints????
  240. nova gsi into corsa need help
  241. cavalier gsi repairs
  242. RR Result from my TB'd 1.6 16v
  243. Overfuelling, but only when the weathers cold?
  244. Wide band fuel/air guages.............
  245. 2.0 16v VTS Nova
  246. 2.5 v6 calibra missfire, cylinder 3+6
  247. Head Gasket ?? huge oil loss!!
  248. nova 1.2 - c20xe
  249. engine numbers
  250. Cally C20LET uprated engine mounts
