- Remove a/c from x14xe
- Zleh scooby noise (misfire) at 2k revs
- C20XE cam cover inner baffle plate
- let hesd 135.12mm has this been skimmed much
- best performance f28 clutch?
- c20let hunting
- coscast head valve steam seals?
- part number please! - C20XE cam cover mounting female/male fixer
- Vectra 2.6 missfire under load
- supercharged corsa b
- C20LET headgasket gone , pics .
- C20XEL?
- 8v oil squirters?
- Erratic idling
- Dbilas Flowmaster vs 1.9 cdti airbox od? which is better? z20let
- courtney tubular mani leh, any issues?
- f18, f20 clutches? same?
- Mk4 Astra intercooler options
- Corsa - C20XE With F20 - Damaged Gear Linkage
- missfire on half throttle
- engine torque damper
- Front seats Astra 2002
- clicking noise C20 xe and F20
- tx autosport c20xe crank pulley!
- c20xe ecu chipped ???
- z18xe head removal
- Power on a z20let engine
- mk4 astra 1.7td low blow
- 2.0 xe snapped fuel line to fuel rail screw in union....help
- Is a x20xev and c20xe fuel pump the same
- C20let misfiring,overfuelling & cutting out
- Corsa B 1.6 16V Wont Start....
- c20xe with f13 straight cut box ??
- ebay universal turbos
- c20let valve springs
- can i re-use arp head studs bolts ?
- Best engine oil to use?
- Corsa B 1.4 Sport Exhaust hanging too low!!
- c20let in vectra 2.2 150 estate help!!!!!
- Astra G 1.6 8v Misfire in Cylinder 1 - Cause?
- Corsa c20xe problems
- reusing 400 mile mains shells
- advice please c20xe
- Piper or Cat Cams, which to break 200hp in 1.8 vaux
- Gearbox Damage - only 3rd/4th work.
- steering rack vectra b 1.8
- x20xev no ecu feed?
- C20LET Corsa oil pressure
- How long for c20let head removal
- 1.7 dti (astra g estate) flat And hesitates until 2500rpm (turbo kicks in)
- X20xev no spark
- Refitting cambelt after it's snapped...... Finding TDC
- x18xe Cam Belt Failure
- Is water needed for X20XEV throttle body
- Z20let vacuum diagram
- Best spark plugs? Z20leh/z20let corsa turbo
- Head gasket change. . ? (poosibly on a C20XE Corsa, but I've not said.)
- Corsa 20XE/ F16. No drive
- xe corsa with mayo in water
- fuel pressure
- 2001 1.7td has poor accelleration.
- c20XE / C20Let Bolts
- Corsa c16xe low power after engine swap
- What is bend in air intake duct for?
- Corsa C20LET fuel pump feed wire getting hot.
- vectra cdti cambelt damaged idler melted
- 1998 Astra 1.6 8v Terrible running issues. Overfueling?
- sealing the end crank cap on an let
- c20xe miss fire?
- C16XE + Dbilas manifold - will X14XE lower inlet fit the head?
- x10xe head onto a z10xep block
- Astra mk4 Gsi clocks fit?
- mk4 astra 1.7td idle problem......
- z20let/leh stroker kit
- Cavalier/Calibra turbo locked transfer box advices needed
- 2.2 vectra problems starting ECU or CIM ?
- F20 parts on f28?
- can a duff OS affect boost? [C20LET]
- MK3 Astra Gsi phase to ecotec 2 litre replaced with 2.0xe what fuel pump is required?
- f20 box pot flywheel
- Ford Galaxy 2001 1.9 TDi DM flywheel type need to know
- physical differences between early coscast and later coscast head
- C20xe fault codes
- Does this gearbox look useable?
- Driveshalf help?
- Vivaro techshift gearbox
- isuzu 1.7 td conversion
- quick xe question
- c20xev
- x20xev mk3 astra gsi using oil and smokey???
- Z20let running strange
- Astra Vxr judders help??
- 04 zafira gsi problems
- Where does my door stop go ?
- corsa c20xe coolant pipes
- Coil pack XE poor running fault at idle/low revs
- c25xe oil cooler.
- oil cooler on C20LET?
- Astra 1.7cdti cambelt problems
- standard yellow injectors for c20let max BHP?
- c20let - refitted turbo now it wont run properly
- Need help on c20xe corsa conversion
- z20let help, white smoke at idle when hot head tested 3 times shows ok
- Need help!! Gti-r throttle bodies on a 20xe
- 1.8 Vectra timing belt guide
- Holley blue fuel pump
- vectra clutch
- mk4 x20 xev into mk3 astra
- Changing the clutch in a Corsa VXR. Best way to do it?
- Let & f16cr
- 20xe + kkk16 + motronic
- Forged rods and pistons for 500BHP+ LET
- vectra c 2.2 z22se engine question
- random question turbo charger
- Is this standard C20LET turbo scrap?
- Zafira gsi oil leak!
- shocks and hubs calibra 4x4
- Wiring help!?!
- f20 pot flywheel clutch
- astra mk4 c20let MOUNT
- Mk2 Cav sri gearbox
- Eds phase 3.5 and saab reds... What fuel pressure?
- what injectors are these?
- 2.016valve DIESEL conversion?
- CV and driveshaft data anyone?
- dual mass to solid vectra c dti
- Vectra B GSI Short Shift Kit.
- Corsa B GSI F15 gearbox short final drive
- X18XE1 Nova. Immobiliser trouble.
- nova redtop project again
- Friction Plate Thickness
- 95 astra 1.7td just turning, wont fire up.
- C20XE Rebuild
- The 2 year misfire :(
- who does custom inlets?
- can i put a c18xe bottom end on a c16xe head?
- Anyway of telling is an XE/LET idle control valve is working
- Auto choke
- X16xe into astra mk3 1.4 8 valve, is it easy?
- c20let corsa ph2 clutch
- what size tubing for let exhaust manifold
- 1.6 sport in to 1.2sxi corsa b
- tx rad into c20let corsa b = fail
- F20 clutch replacement
- C20LET Torque Rod Idea
- c20ne conversion
- c20xe bule injectors and fuel pressure regulator on a 20ne??
- T3 turbo and ECU with evo 5 chips
- Need help choosing new turbo
- Engine running in question
- paddle on standard cover? c20let
- Parts for KKK16 turbo?
- N/A Single TB stroked 1.8
- cav 1.6 cv joint, where from?
- Astra mk4 1.8 16v x18xe1
- Vectra c on a 52 plate 2.2 SRI - Rattle from chain?
- Vectra X17DT Turbo cleaning How?
- td05 updrade on a LET problems
- mk3 astra gsi engine mount question
- astra mk3 c20let mounts
- upgrade GTXXR to GTX2863R / GTX2867R
- z16xep WANTED
- c20xe cambelt roller bearing bolt part number please!
- mk2 cavalier wiring trouble
- zafira dti performance
- M32 gearbox differences?
- C20XE Which oil?
- i have one crazy car ( clutch help )
- help me choose the chips
- swirl pot ???
- Max BHP for cast Z20LET pistons.
- v6 throttle body?
- Help, advice and opinions needed...
- vauxhall astra 2001 sxi 1600 AGR Issues
- Novastien (just how does this car actually run)
- Engine transplant
- Engine conversion
- overboost problem > ECU CUTS BOOST FOR SPLIT SECOND
- c20let not starting
- zafria dti 16v
- x16xe bolts
- EML but no codes stored...
- omega plenums in vec b?
- GT28R
- f28 gearbox seals
- c30xei throttle body
- mk4 astra diesel immoboliser situation??
- Astra 1.4 8v hall sensor
- ebay hydraulic lifters
- help me to increase the mileage of opel astra 1.7td
- Vmax EVO310 chips problems
- curing problem with GM KS porous head.....
- paddle clutch refurb
- X20xev exhaust ports?
- easytronic bleeding
- FPR c20xe
- engine blocks??
- Nova GSI running problems
- whats the easiest way to find a air leak? on c20xe
- Emissions fail
- Omega v6 fit in vectra b
- 20xe rebuild parts
- MOT fail :(
- c20xe Plugs
- F13 and F18
- 20let + gt2860rs
- how to tell the difference between xe & let cams
- Corsa C 1.2 Twinport Common Faults
- Zafira 07. Engine management light coming on and pulling
- New thread!! C20XE late engine misfire! Stood for a year!!
- timing belt problems
- 120 16v cdti vectra
- astra coil pack gone?
- Slight coolant loss but emissions fine, and an autobox q...Astra-G
- C20NE Crank Shells
- Getting new head gasket and bolts .
- Corsa B C20xe AirBox
- f20 clutch pot type
- 2.0 8v into 1.2 carb nova ??? advice please......spark troubles
- x16xe flywheel change .
- GT30 z20let into corsa c
- c20xe corsa c
- C20LET Boost Pressure is baffling me
- c25xe into a coupe 2.2 51 reg info please.
- x20xer
- Vectra B Z22SE transmission range sensor
- C20xe corsa weird misfire.
- 16XE diagnostic questions
- 2.0 xe conversion what gearbox
- where is the ICV on a vectra C 2.2 petrol
- 02 Zafira 16V car stalls at traffic lights with clutch down
- c20xe wiring into 1.0l corsa
- tx vernier c20let
- How to Identify C20XE and 'Box?
- M32 gearbox question when mated to a Z20LET
- c14nz cutting out
- universal back box
- c20xe which lambda to use:-/
- Z20LEH Conversion
- Zlet in Mk4 van - No temp or fan?
- vectra exhausts
- f23 linkage cables
- Best mods on cdti (100ps)
- c20xe fuel problems
- C20LET injectors upgrade
- Engine for z10xep twinport
- C20xe fastroad cams | reprofile yes/no? | who does it?
- 2004 Astra 1.6 sport loss of power??
- paper clip test
- 2001 vectra engine probs
