- Astra 1.7 dti oil pressure switch
- Corsa VXR Engine Into Mk4 Astra Van
- engine swop
- Performance cam for c20xe
- Re: 3.0 v6 cams
- vectra gsi losing coolant
- Help needed urgent clutch/gear box trouble
- coolant pipe from inlet on seh
- f28 box on c20xe with flat flywheel.
- c20xe misses and eml light shows???
- isuzu diesel over heating but why,
- Best place to feed screamer pipe.
- c20xe on omex throttle bodies fule problem
- saab 9000 timing chain change
- powerflex bushing
- C16XE valve guide Damage from Porting work
- Exhaust Size Advise.
- C20XE "tttttttrrrrrrr"
- dizzy coil wiring
- C20XE, flat spot between gears.
- Concentric Slave Cylinder
- Nova 1.3 twin 40s
- 2l 16v redtop conversion
- How to estimate engine's volumetric efficiency?
- dti injector seals anyone changed?
- engine swap
- eco tec x20xev TC problems
- 17td into corsa
- ecu colours
- lexmaul inlets
- track car keep shearing hub
- alternator belt
- driveshaft of 1.6 corsa sport
- EML flashing randomly the last couple of days wtf???
- airbox or cone filter?
- how do i top the gearbox op on my vectra v6
- Garrett T3 on C20LET
- f15 electric to manual speedo? ? ?
- x20xev, are they worth tuning?
- 3.0 heads on a 2.5 block - problems?
- cutting down equal length for corsa
- f16 not staying in 5th
- engine mapping?
- Is the c20xe that good of a motor
- Ford Transit Diesel Van - 2.4L glow plug question
- what engine mount on a mk3 astra with a 2.5 v6 ?
- je piston slapping
- equal length driveshafts wanted
- Turbo charger t3/t4 to4e a/r.50
- C20XE Sump Gasket
- c18xe turbo??
- car wont start but back fires
- Widebands .
- mk4 astra van 1.7td feels flat.........help please.
- 20xe core plugs on ebay
- c25xe dipstick seal
- are c20let big end shells the same as c20xe?
- Rusty bottom end :eek:
- oil preasure relief valve
- X16xel Problem Smoke
- flat spot x16xe
- corsa vxr
- z20let head on xe block
- 1.6 corsa sport 1998 Cutting Out
- V6 engine running problem!!
- Why wont it start (Cav SRi c20xe)
- 2.0l 8v Corsa Conversion Kits! HELP!!
- drive shaft lengths
- mahl forged pistons?
- Odd (or maybe not) fault..
- problem with clutch - astra cdti
- Looking for a t3 tubular manifold for z20let
- Which engine to use?
- Advice needed on my clutch problem
- actuators
- would a c20xe cav loom fit a gsi astra ?
- will a z20let lightened flywheel fit v6??????
- throttle bodies
- will my turbo be in danger?
- corsa vxr
- cossie 34 actuator for c20let?
- C20ne, 20seh head....ect
- parts list needed to fit f28 in my corsa let
- XE Stainless manifold flange?
- Remote turbos
- V6 into mk3 Astra - what hardware?
- throttle bodies
- faults x20xev ecu
- c20xe ticking like fook on start up (cold)
- 4500rpm at idle?
- f28 and 2.5 v6 in gte astra 16v
- Max boost
- megajolt trigger wheel ideas?
- c20let starts up but with problems
- running problem
- Bad oil leak C20xe Race engine
- reusing shells
- V6 Flywheel - any advice?
- Vectra V6 Clutch...
- Turbo Part Number??
- 1.2 sxi in 1.2 corsa b
- Help PLEASE
- Who sells these oil pump parts ?
- z20let pump on c20let ?
- Can anyone tell me the weight of an XE
- what pistons are these
- wierd oil leak
- corsa redtop conversion
- What coil pack?
- T3 Conversion Help
- astra mk3 c20let tuning , problems,and advice
- 3.0 litre vec gsi conversion ideas pls
- astra mk3 gsi phase 1 speedo cable
- corsa v6
- on phase 2, do i need an upgrade?
- C20LET, Corsa B, 20psi, Questionnare.
- May never happen but just want opinions...
- Clutch making noise on tick over
- corsa c20xe conversion - fuel lines.
- engine smokeing very bad PLEASE HELP ????
- Calibra V6 into Cavalier mk3
- diff nut remove
- Corsa redtop Flatspots
- astra c20xe air flow meter problems
- red top
- Question for Someone Slightly More Knowledgable
- c20let turbo
- Help with wiring a 2ltr seh in my nova
- Fresh build, engine wont stay running?
- advantages of an mbc
- Adjustable FPRs that fit straight onto an XE/LET fuel rail
- astra h 1.4 16v engine probs
- XE on tb's, talk to me about breather set ups
- which is better t38 or a gt30
- vectra 1.8 help ASAP
- VXR turbo on c20let?
- coil pack
- diy driveshaft modifications???
- what gearbox for c20xe??
- f23 on a c20let starter motor?
- Belt tensioner rollers Late XE size?
- turbo surge
- let cam pulleys usable on xe
- where can i buy chip for c20xe
- diameter of c20let dowpipe.
- astra g z16xe/x16exl engine transplant
- AMM fault code after cleaning
- Bowyer Throttle Cable ITB Thingy
- turbo help
- aftermarket actuator and bracket on standard k16
- head gasket changed
- Power Steering issue.
- Cav 2.5 V6 Torque setting help????
- TDC Marks
- astra g 2.0 8v conversion
- Any1 know what year R1 carbs to get?
- f20 on a let
- c20let vac pipes
- Gearbox for C20XE on TB's
- mark 3 astra phase 1 gsi , fuel pump internal or external ?
- problem !! help? (C20LET)
- keeping pas on convo
- M32 Gearbox
- c20let phase 3 chips help needed
- nova blowing out black smoke!!
- timing belt snapped, help!
- does this gearbox fit?
- Astra OPC 6 speed gearbox in corsa b PLEASE HELP
- How to fit a Quaife ATB in a F20.
- Vectra B2 X16XEL annoying gas response hesitation
- Astra Coupe Turbo Z20LET De CAT Question
- Not Vaux but need opinion
- Are corsa diesel shafts the same as gsi?
- F16 Diff fit a F18?
- ser 8v turbo
- c25xe chip into x25e ecu
- cav mk2 1.6 inner cv part number
- Drive shaft popped out whilst towing???
- Tranfer box neeeds help
- Fierce over-run on Nova LET
- F28 Helix clutch adjustment
- a little advice please
- Blank the EGR Valve
- Hiya all (< I need help car wont start!
- Astra Engine Into Corsa B
- red top
- will a 3.0 cdti run on biofuel
- vectra cdti
- Tubular manifolds for clet LOOK!
- FSE fuel pressure regulators
- C20let into corsa gsi. wiring tips needed
- C20let Fuel Pump Problem
- Nova engine transplant question
- x14xe Rocker Cover Gasket Needs Replacing AGAIN! HELP
- C20XE Corsa Inner Cv Boot Trouble?
- inlet manifolds... corsas
- Z20let oil return feed?
- c20xe ecu numbers ???
- best cam for 2.0 8v?
- Gearbox Question!!
- my corsa
- Re-Using Bolts - C20LET
- Anti-rollbar blocks for c20let corsa conversion?
- Mk3 astra gsi 2.0 8v
- 2.1 piston size
- Best way to do xe rocker cover
- ERST turning but not firing?
- 512 bhp redtop turbo
- corsa 1.2 / 2.0 cav
- which ecu to use
- Are any kkk's Hybrid as std..
- how much to map an omex ecu
- How do i get the bottom bolt out of the alternator??
- astra mk4 engine conversion, f23 Clutch problems
- astra gsi redtop to cav v6!!
- turbo upgrade guide...1st bit
- gearbox and block quicky
- what gearboxes cames on the x18xe?
- gearbox ratios
- xe inlet cam in let need advise asap
- tigra headgaskets
- help on bottom end rebuild
- quick carby ignition question
- bosch 044
- Astra Coupe Turbo Blow off,Dump Valve or Diverter Valve.
- anyone have a map for the omex running gt30 turbo
- z20let price ? ? ?
- running problem
- hybrid t3 . what power?
- idle control valve
- eml light
- diffs will it fit will it not?????
- XE PULLY
- c20xe conversion HELP!!!
- z20let collateral damage with broken turbo
- Loss of torque
- Transfer box
- Where is the EGR Valve on an X16XEL?
- vw fault
- Exhausts, manifolds etc
- Dished low comp pistons . . . .
- Dual mass flywheel to solid, conversion
- what ignition system/fuel pump do i use with carbs?
- cav turbo rear diff
- valve stem seals
- cam belt tenison pully question
- c16xe idle control valve
- Redtop Ushall Help
- Gearbox f16/f20 Q?
