- astra driveshafts
- Webcon Alpha Wiring Harness ECU Pinout
- 8v Turbo's - Please discuss here.
- Flywheel
- Buying Oil, Some Basic Advice From Opie Oils
- Boost Advice Need,
- Porous Head????
- bearings
- Why does a TB have a coolant gallery/connection?
- Shell V-Power
- corsa 2.0 driveshafts
- xe running problem
- XE Weight...
- Just had to be towed off the motorway!
- New Tappets but still noisy - V6
- c20let - xe inlet cam???
- Corsa XE rear mount.
- C20let Icv
- Bosch Platinum PLug on LET
- c20let/c20xe bottom ends
- Failed emissions, Running rich
- corsa sri speeds
- Question?
- 1.4 8v head torque settings
- hybrid kkk turbo??
- High Lift Cams??
- 1.6 16v Tb'd Death... some pictures may cause offence!
- c25xe sump
- tps/icv same as......
- MK3 astra saloon exhaust
- Decent clutch for FLAT type flywheel on a LET??
- V6 Oil/water mixing problems
- what is a fuel tank sensor?
- 2.0 corsa
- small missfire?
- c20let annoying me now... code 15
- redtop conversion into astra mk3 ( wiring help )
- c20let into 2wd cav gsi
- Throttle body x14xe
- problem!!!!cutting out
- 2.0 8v wiring help
- Oil Light On Dash
- Corsa B F28 vibration
- help with fuel pressure on c20let
- F28 help (speedo drive)
- crank sensor looks too short!
- blown head gaskets on omega b v6
- EML light at high speeds
- c20let idle oil pressure
- gte 2.0l 8v conversion
- Let/xe Fse Take Off Plate Anyone No Thread Size?
- strange fueling problem
- Which intercooler CORSA LET
- OMEGA X30XE Gearbox - Safe Mode... Help
- F23 and F25 diffs...
- staling calibra
- Noisy Rollers
- help with engine identification
- cams? whats the score? help!!!!!
- gearbox probs
- is this an ecu?
- norris desgines evo 9 gt short base car???
- Corsa 2.0 Bulk Head
- Amal and external wastegate
- nova or corsa 20XE???
- Oil breather pipe smoking
- How to make my engine sound less like a sewing machine and more like a real engine?
- cavalier turbo, not starting new gm starter fitted
- Help me ID my cylinder head
- Engine Model
- 1.7 turbo diesel isuzu swap guide for corsa/nova
- 1.6 8v astra running off cylinder
- oil sandwich plate
- Faulty Amal valve???
- Corsa 1.7D to Convert to 1.7TD
- corsa 1.7D pig to start from cold
- What's the port spacing, or distance between ports, on the c20xe head?
- c20xe van conversion
- engine managment light on.....help!!!!
- Lifters
- Help for a frustrated female please
- C20XE Alternator adjustor bracket
- Gearbox knocking
- Who is running e-manage on C20LET/Z20LET
- 2x dump valves? why
- EDS PH 3.5+ (orig.) vs copy/paste eeproms
- 1.0 3 cylinder ecotech engine swap please help!!
- Very LOUD rattle from gear shifter
- Astra 1.4 8v To 2.0l 16v Redtop
- Best Gearbox Oil for F28???
- twin 40 webbers onto 1.8 8v
- C14NZ idles at 1500RPM Any ideas?
- c20let crank cap
- c16xe - eml light, missing!?
- 1.9 cdti (150) probs
- C20let Dumpvalve??
- Engine not starting
- small advice for C20LET owners
- vectra gsi 3ltr v6 / 2.5v6 engines
- Big Bang??
- let/xe heads-will the vavles from a gm head fit a coscast head?
- oil in 1.4 sri
- Fuel pressure sensor
- To do a sump gasket on a Ecotec, does exhaust need to come off?!
- arp bolt settings
- coil for a XE
- What radiator to use with 20XE in mk3 astra
- Frontera
- cavvie 1.7 td parts...
- engine mod ecu problem
- Best oil for my Mk4 Astra Coupe 1.8 16v
- 1.4 spi to carb
- strengthening a transfer box
- XE fitting Help
- corsa gsi gearbox
- URGENT - oil pressure light on! (pics of damage)
- What do you lot think about this actuator mod?
- why would a car jerk when wet/damp weather
- c20let torque settings??
- Hissing Calibra
- f20+c20xe converting to f28+c20let
- mk4 c20let wont fire, dash dies
- E16se engine fault codes
- sr induction systeams
- loud rattling?????
- X16XE bike throttlebodies and Gotech management
- Corsa conversion
- disconnecting a non factory immobiliser!!
- astra 1.6 8v missfire
- Astra Mk3 1.4i snapped cambelt. Quick question...
- Which gear oil for F28?
- Z20LET Dumpvalve query?
- c20let sensor hassle
- Cosworth style LET inlet manifold on ebay
- timing on a c20xe
- 1.6 ecu runnin on a 1.4
- Corsa 1.2sxi engine swap
- oil catch tank.
- LET crank sensor wiring question!
- whining noise with clutch UP
- let cam timing,degs-lift
- C20let help
- starter motor changing
- novice in need of help
- c20let boost
- HELP: Gearbox or Clutch? Won't go in gear!
- Calibra exhausts?
- corsa 300mm rear brakes
- Going from Mech to Elec speedo
- Alternator in 16xe nova conversion
- Which injectors for 230+ XE?
- engine stand for a c25xe???
- ecu problem
- 5 stud conversion help
- mk3 astra 'equal length driveshafts'
- Quick random question - turbo diesels and intercoolers
- 1.9mm headgasket c20let
- astra sport gearbox
- m reg corsa 1.2 8v
- Using nova alt/bottom pully on 16xe-Which bracket?
- "Quiet" Nova exhaust wanted.
- C20LET - plug order from, dizzy
- Corsa 1.0L 12v engine question - Chain or Belt?
- 120k miles service
- C20LET weight/ Haynes manual
- 3ltr v6 pistons same as c20let?
- quick question about auto box
- Red top head bolts?
- f28 in a corsa what transducer to use
- atempt to self modiy my engine
- please help! annoying orange dash light
- Steaming but cant see from where
- engine rev's and plays on its own
- What size thread for sensor in LET top hat ?
- mk2 astra v6 needs wireing up in leicester HELP PLEASE
- where can i get a GOOD quality headgasket for a c14se
- tuning c14se
- new engine is cutting out
- F18 Gearbox oil level
- corsa 2l gear linkage problem?
- group buy on live remap
- Sump Capacity X14XE
- Forged Pistons and Steel rods
- ETS electric supercharger
- c20xe running problems
- Effects of a shortened Inlet (TB's)
- ..viscozitiy of silicon oil...
- coscast head torque
- xe belt and pully
- 1.6 inlet on a 1.4
- Help! Floppy cam belt - cally redtop
- Rally design exhausts
- removing the inlet on a c16xe
- c20let on dispak???? why not
- chrome heat shield
- minor car problems
- Corsa Missing on 2&3
- Vauxhall Part number?
- starter moters
- c20let rocker breather mod????
- 1.7 TD not starting
- 2.0 8v corsa
- Cams
- Can someone confirm my problem
- c20let knock sensor fault
- cutting out a round abouts
- Z20LET possible mass airflow sensor failure?
- Can somebody check this part number please?
- Cleaning my engine block face
- c20xe ECU in corsa?
- help!!!!! turbo corsa
- v6 miss frie/back fire in air box
- xe conversion gearbox spacer
- c20let idle issues
- F28 Oil Capacity???
- vxr injectors and rail
- 3 litre cam stampings.
- 20XE wirring again.....
- sensor in top hat? c20let
- no speedo
- How much to get a xe flywheel lighten..
- Recirulation Valve C20let Help ??
- Porous head repair?
- recirculating c20let help?
- z20let in a corsa b probs????
- buying a v6?
- vxr fuel injectors
- help please
- Fuel pressure Regulator 4.0 bar
- C20LET age????
- uprated sump gasket?
- Ecotek valves
- Corsa 20seh Gear Linkage Problem
- flywheel clutch is it a problem????
- Can I Put Redtop/ecotec Injectors In My 20seh
- drive shaft wont fit cv joint
- LET loom question x2
- Snapped exhaust cam 20XE
- 20xe corsa
- corsa 2.0 8v
- gearbox ratio's speed / revs etc
- nova xe
- best fuel regulator for C20LET??
- C20XE not starting
- whats the main cause of mains going
- 1.4 engine help
- c20let timing problems
- 1.0 12v gearbox on a 1.4??????
- Lightweight Flywheel+Clutch 20XE
- Worth fitting a Flat fly inplace of POT type?
