Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. what does an oil breather do?
  2. Fuel Regulator Faulty?
  3. Need Advice
  4. FSE and other mods on cav v6?
  5. 2ltr 8v SEH running fast
  6. x16xe Rebuild/tuning
  7. mk4 astra 16 16v redtop conversion
  8. failed mot on emmisions/em light on
  9. engine conversion
  10. smoke ???!!!!! help
  11. 1.6 engine with 1.4 head, pro's/cons ?
  12. 4x4
  13. C20let dies when touch accelerator
  14. ECU light on when warm, limp mode...
  15. Decat info for you peops...
  16. Clutch x14xe to x16xe
  17. 18se wont rev when cold?
  18. Corsa C20LET (upgrade path)
  19. corsa 1.4 over heating
  20. Hesitating 20NE
  21. timing belt kit for x1.6xe
  22. help please lads c20let flat as a fart.
  23. Couple of LET/Astra related questions....
  24. any 1 done a 2.0 8v conversion into corsa
  25. C20LEt Engine in Astra Mk3 pipe work issues
  26. f23 gearbox rebuilg kits etc?
  27. Recirc Valve, quick question
  28. Big up / thanks to Track n Road
  29. Are all 2 litre shafts the same?
  30. c20xe cts part number
  31. bailey motorsport products-can u buy parts of a dump valve seperate from them direct?
  32. vectra x20xev alt belt routeing
  33. fault codes/sensors
  34. mains torque settings
  35. Diesel Tuning?
  36. Oil cooler, which is feed and return
  37. how to boost up vectra v6 power
  38. 2.0 8v engine mount
  39. MK 3 Astra GSI problems
  40. 2.0 8v coil
  41. my nova gsi mullered again, any help please?
  42. C20let Pressure/vacuum Lines?
  43. gear linkage corsa c20xe
  44. Wiper switch in nova...
  45. 2.2 head
  46. my f 23 gearbox is whineing in my astra G will an f18 box fit/work whats different?
  47. turbo boost problem
  48. Drive shafts
  49. ECU + Oil light keep comming on
  50. Which gearbox?
  51. mk2 astra v6 3 part drive shaft problem
  52. v6 vec runnin real bad
  53. FAO ppl who know about nitrous
  54. c/20xe/j Cylinder head codes
  55. flippin F28 oil leak
  56. Quick question - Astra SRI (mk2)
  57. in need of c20xe and ecu?
  58. 1.6 8V bottom ends - can someone help me?
  59. phase 3 let spark plugs!
  60. Anyone know anything about Renaults?
  61. Limp mode when started from hot (C20LET)
  62. more 20seh questions (sorry!)
  63. Inlet manifold gasket leaking
  64. Advice needed on upgrading turbo on C20LET
  65. XE manifold mk2 or mk3
  66. Engine management light after changing clutch cable?
  67. C20 LET into a corsa B... Need help with the linkage...
  68. c20let revs increasing
  69. Attempting to refit a C20LET
  70. 20XE Engine / C20XE Loom/ECU Lamba Needed?
  71. Eco-Tec cali - whats the difference between...
  72. X14XE and X16XE Bottom end what the difference?
  73. no lambda on motronic 2.8, can it be done.
  74. Mineral oil gone like water?
  75. 200bhp + Astra Ecotec?
  76. Electronic boost controller setup eg apexi
  77. Wireing problem on c20let
  78. Corsa overheating
  79. what do you guys reckon on this
  80. Looking for a How To On cooling?
  81. Lambda interference???
  82. best bike carbs for e16se???
  83. Swap and height probs
  84. are these pumps the same?
  85. paper clip test ?
  86. C20NE idle control valve.
  87. conrods for vectra v6 sri
  88. ecu????
  89. Vectra 1800 Auto - Stalls, but runs in reverse?
  90. F20 gearbox problem
  91. More Boost!!! Help newbie
  92. heater matrix question
  93. Courtenay Grp N Chips with Cams
  94. Mot (no Cat?!)
  95. V6 Cam Duration and Turbo Application.
  96. XE 2” Performance Exhausts
  97. Urgent help - mpi pump in spi nova tank??
  98. Slight tapping from Vectra GSI V6
  99. c20let over-boost
  100. Compression for an 87 Nova
  101. vectra collant problems
  102. Opel Manta Gear ratio spec
  103. getting cursed at
  104. Catalytic Converters ????????
  105. c20let into astra G
  106. cams
  107. late c20xe on carbs??
  108. X20XEV into Mk2 Astra
  109. Corsa Redtop drive shaft
  110. Vectra Supertouring
  111. Gotech management problems
  112. 1.0 to XE wiring diagram
  113. 18iengine convertion for corsa
  114. wiring XE
  115. XE cam choice
  116. port and polishing
  117. valves and rocker arms
  118. F28 Clutch advice
  119. C20XE fuel pump wiring
  120. Mapping, what fuel?
  121. help again please
  122. corsa 20xe running temp
  123. fuel Injector Relay
  124. C20XE not starting, no noise from the starter??
  125. Down on power??
  126. cav turbo head bolts
  127. C20LET Paddle clutch suppliers
  128. small block turbo cams
  129. 4x4 running gear
  130. C20LET Custom Inlets (Pictures)........
  131. Another random turbo diesel question, how big a turbo?!
  132. 1.8 16v Vectra mis-fire
  133. Number 4 cylinder low power.
  134. C18NZ to SRI transplant
  135. f20 box
  136. Engine Orientation???
  137. cleaning tappets
  138. 20XE Corsa - Fault Code 44 - Air/fuel mixture too lean (weak)
  139. Flywheel has a few cracks-Worth risking??
  140. Mk4 Astra Kangaroo Petrol
  141. F18 gear box > SEH 8v
  142. Carb'd to injection fueling problems....
  143. Oil cooler on CORSA LET
  144. XE fuel rail threads
  145. What drives nearside front wheel, F28 or TXB?
  146. corsa f28 gear linkage
  147. two layer metal head gasket
  148. c20let cams
  149. 310mm brakes off corsa c fit a corsa b?
  150. Maul Sensor?!?!?
  151. Highly Recommended when running Ph2 on C20LET
  152. 1.7td isuzu engine cold start advance
  153. standard pistons
  154. c20xe on r1 carbs
  155. Cambelt snaped
  156. Lambda sensor
  157. crank sensor part number???
  158. C20LET running problems
  159. Vectra 2.0 XEV ticks over perfect but won't rev - help!
  160. 20xe on f16
  161. c20 let pistons wanted
  162. gearboxes
  163. egr valve operation
  164. Best mods for an Astra MK2 8v GTE
  165. What bolts...........
  166. Radiator on Corsa C20LET
  167. c20let help please
  168. 2.0 8v 130 into a corsa?
  169. fuelling on a carbed corsa
  170. Leaky sump gasket 3rd time replace
  171. extreme isuzu tuning
  172. Urgent help needed!! x14xe
  173. ARP bolts
  174. zafira gsi won't start
  175. Opie Oils 10% Off Week!!!
  176. Remus Race Tubes???
  177. Lambda sonde pre-heating
  178. lcd transducers
  179. VTS Locked Box???????
  180. gearbox oil
  181. electrical non-start issue?
  182. XE ECU numbers/models
  183. FAO C20LET owners (hoses)
  184. As mentioned in the general discussions area, I'm trying to suss out the boost contro
  185. corsa engine conversion from 12i to 18i
  186. quick question
  187. Whats overboost
  188. corsa seh shafts
  189. What exhaust size for a Corsa LET?
  190. Anyone know much about old engines? (50's 60's Austin)
  191. top speed on 230bhp (dyno) corsa LET?
  192. Gearboxes on c20let in corsa
  193. XE conversion fuel pump wiring. PICTURE
  194. corsa diesel gearboxes
  195. C20XE Clutch Kit
  196. c25xe gear linkage?
  197. c25xe cav cdx clutch how to?
  198. Fuel Pressure Regulator for C12NZ ?
  199. 16xe carb ignition help!
  200. X20XEV cams on 1998 astra 1.8 sport??
  201. c20let into a corsa
  202. astra coupe turbo p1106 error
  203. engine transplant
  204. could it damage the turbo or not?
  205. What are the benefits of continuously adjustable cam timing on a turbo engine?
  206. gte 2.0l 8v drive shaft problem
  207. driveshaft problem
  208. Are nova driveshafts the same length as Corsa ones?
  209. question - can a car be started without a battery
  210. De-Cat on k reg?
  211. What sump for a xev block c20let
  212. What clutch?
  213. What do you guys reckon to this ? Tubular manifold bought off MIG club member.
  214. Help with part no on EPC
  215. Vacuum Hosing sizes..
  216. ICV help needed!!
  217. plz help
  218. engine won't rev past about 3000 revs
  219. Regal Car Engineering
  220. 2.0 8v poor running
  221. mk3 gsi mounts and fuel systems.....
  222. 1.4 SPI not starting
  223. Is this an X16XE
  224. Plug leads for a LET with XE coil pack setup
  225. cambelt tensioner problem
  226. c16xe into nova sr exhaust
  227. Isuzu Vs GM engine appearance.
  228. Non return valve in block....C20XE
  229. xe or let?
  230. re-using flywheel bolts.
  231. 2..5 or 3.0 Engine..
  232. Astra ECU
  233. Car conversions legality / Mot rules
  234. comp ratio
  235. timing 20xe
  236. knock sensor question
  237. blow off valve HELP
  238. Some more help needed (C20LET)
  239. Erm, what's this and where do I mount it? (C20LET)
  240. f3 gearbox
  241. c20let ecu
  242. What to do now???
  243. Main bearing bolts for c20let-where??
  244. vectra diesel.....are they all slow???
  245. Corsa LET does it need a cool running thermostat?
  246. XE Corsa cutting out
  247. dump valve on new vxr astra
  248. Spot the difference? F20 boxes.
  249. running in
  250. astra driveshafts
