- oil filter sandwich plates:- how hard to change?
- 8 Valve GSi?
- nova conversion question....
- Flip engine upside down for sump gasket change
- engine management corsa
- C20XE Engine Code for Insurance...
- GSI engine on lpg?
- One click Cav won't start
- 2.0 8v astra gte f reg
- F20 no 5th or reverse, linkage been adjusted ...
- tapping omega v6
- engine dies for no reason
- nova shaft conversion
- throttle bodies info
- water pipes replace ments..how
- nova c20xe
- Someone to fix my corsa in London area
- nova conversion shafts wat do i use
- Bottom end advice.......c20let....xe
- FWD Convertion. What size bolts?
- Corsa C20LET header tank?
- kkk k16, what is this bit??
- Oil Sump Gasket Calibra Turbo
- R1 or Hayabusa in a corsa??
- oil pump c20let
- 1 new engine..several new problems...MK3 1.4spi
- c20xe hesisting!
- what do we think about this ebay item?
- piston rings
- corsa c20xe driveshaft help
- motronic 2.7 and different injectors
- X20XEV into Daewoo Nexia (Mk2 Astra) - Which exhaust?
- X20XEV into Daewoo Nexia (Mk2 Astra) - Which clutch parts?
- f16 gearbox
- 52 plate astra turbo trouble selecting 1st
- janspeed centre section
- 22 spline shafts
- trigger wheel difference c20xe
- Crack in Manifold!!
- Speedo Incorrect
- cally turbo shafts in XE astra
- building a let. from scratch (engine building advise)
- Z20LET cooling system issue
- F28 Speedo drive?
- rough running let. help please!!
- best dump valve for the let?
- xe drinking water!!!
- C20XE - No1 Cylinder
- wires confused
- corsa let- correct way to fit water pipes cuming off the turbo?
- Engine loom
- help needed please alternator connection
- c20let boost problem
- c20xe head gasket
- starter motors
- Alternator
- Can i fit an astra sport c18xel engine into a Nova?
- Clutch advice - no drive in gear
- cav CV joint fouls corsa knuckle
- cALIBRA rEDTOP qUESTION??????
- Main and big ends? - types of baring?
- exhaust fumes help
- no gears on my f20
- oil squirters???? anyone fit these
- V6 bottom end gen...
- v6 cally breather pipes
- Astra G thottle boddies
- ASTRA G throttle bodies
- vectra playing up - anyone help??
- sensor talk. + codes
- C20XE Cranking speed
- Coil pack identification (pics)
- SBD Lightend Flywheel question
- glow plugs
- ARP bolts and studs
- corsa gsi head
- LET & ZLET valve sizes?
- XE green wire by dizzy?
- LET cut out ?????
- calibra v6 engine breather pipes
- 16v manifolds
- failed emmisions...
- redtop to c20let
- lower fuel consumption
- Need ideas asap! My cav wont boost past 10psi wtf
- k reg cav sri
- Will astra G 308mm front disks work on a 200ts (284mm)?
- Possible cause of xe high idle / overfueling?
- knock sensor question.
- idle problems
- tb + injectors ????
- AFM pipe routing
- c20let problems
- 16v turbo manifold
- lost reverse f13
- c20xe misfire when warm heavily sooting plugs!
- cavalier engine mounts
- Boost gauge readings...
- MBE wiring.
- Need help big time!
- fuel pump c20xe
- top speed with a f20 gearbox
- c20let clutch
- wheres the crank sensor on a c20let
- Small block XE tutning website?
- engine swap info
- F23 3rd gear problem (cranking)
- X20XEV main cap torque setting?
- XE Problem (Banging when engaging gear) slightly urgent
- C25XE fault codes, in limp home mode...
- Whcih intercooler for my Corsa C20LET
- c20xe verry bad idle
- Code 24 (vehicle speed sensor), should i change cam or crank sensor though?
- Smoke!! C20let
- Z20LET oil leak - is it coming from the turbo?
- poorly calibra :(
- Gear Change Problem – Any Ideas?
- Spark Plug gap settings Corsa B x14xe
- What transfer box have I got?!
- vxr injectors. What fuel pressure do u run??
- lengthening AFM wires on LET
- Stage 1 of Stage 3 CDTI is Complete....
- what would cause this to an oil pump
- flash code "144" what is it?
- calibra miss fire
- Corsa LET fuel pump
- 16v GTE/GSI driveshafts
- fitting guide for gearbox and clutch c20let
- petrol probs
- Timing sequence??????
- corsa c20let rad and intercooler
- JUST REBUILT Gsi HeadS , problems
- Late cav dis xe in nova misfire/ pop back under heavy accelleration?
- XE ECU
- corsa that wont rev over 4000rpm ??
- Gear Ratios
- How much is a standard C20LET turbo worth?
- tigra wiring
- c16xe-noisy lifters?
- actuator
- let wont start help
- 2.3td frontera oil pressure prob?
- porous mod needed
- C25XE high oil pressure - 5 bar...
- Wastegate worn, leaking boost, will it cause damage
- Magnetic sump plugs?
- redtop starting problem
- Manifold to CAT/DeCat gasket????
- Another clutch question????????Anyone clued up????
- gearbox????
- XE corsa fuel pipes.
- mk4 astra c20let air filter
- Lots Of Blue Smoke
- c20let 1.9mm head gasket
- c20xe 4k tickover???? help needed
- corsa let heater matrix pipes
- Regal Autosports C20let inlet cam
- XE Throttle Body Upgrade
- Changing the crank pulley
- Astra GTE/ GSi Engine Differences?
- whats needed for 20seh into corsa?
- Weight of bare block...
- Strange Misfire.
- Fault code 113 on LET
- cylinder head gasket 1.4 corsa 1997
- 20XE - Pressure and temp senders
- engine swap
- bore size
- c20xe to c20let
- let lamba sensor
- Might need a new Lambda (C20LET)
- where doi i start - ZLET's
- c20xe fast road cams
- 3.0 24v in a manta
- New to club tech question on transfer box
- Girdle removal???
- C20let fault code
- corsa xe fuel pump
- Turbo boost control- Boost presure high, out of range ECU code!! HELP
- Cam belt cover
- c20xe/c20let - why are fitting kits different?
- fluctuating revs
- best place to take my car to put it on rolling road im in ipswich
- vectra 2.0 16v sri
- porous head mod?
- Poor Performance After Service
- which oil for a modified c20let?
- chris astley strengthing kit
- LET Nova Exhaust help.
- XE cam belt roller, what way round?
- knocking 2.2dti anyone heard of this.....
- 20SEH Nova, Miss fire and high idle
- oil coolers
- Isuzu white ring mod where?
- need a pic of a corsa gsi
- gearbox for a c14se
- y17dt tapping noise?
- weird noise
- ECU fault light C20XE
- Nova fuel tank breather
- converting from carb to MPI?
- oil lack
- How to remove F28 from Calibra Turbo?
- oil pressure gauge on calibra
- nova turbo
- nova gsi holding back
- v6 astra abs speedo wiring
- Suspension Judder
- c20xe/c20let bottom pulley (crank pulley)
- Still can't start my 20XE nova...
- C20XE Tappets
- Buzz sound from turbo
- XE oil pressure sensor thread?
- thread of xe rocker cover bolt
- While stripping the engine for a vp44 diesel pump change i find this.....
- Back Boxes
- Manta rally setup - dog box on an XE?
- Water pipes
- Adjusting the cambelt on a V6?????
- Totally de-catting a Zlet
- Nova 16v engine guide.???
- info on turbocharging a c16xe
- xe corsa hubs/bearing play
- astra 1400.....What to do??
- no drive F20...
- Cav Gsi - No drive in any gear - Clutch issue?
- What size drivebelt for single V pully on XE
- Nova speedo cable...
- Opel Meriva 1.6 Transmission
- turbos
- pourus xe
- Cav steering pulls harshly when accelerating
- Late XE - fuel relay
- XE' CORSA
- Signum 2.2 petrol - fuel pumps
- RED TOP
- Fitting LSD to an F25 box
- Differences between X25 and Y26
- Alternative ways of starting an Omega Auto IGN SWITCH FAULT
- Vauxhall powered mini help
- o2 emissions
- Cally Turbo starting help WEIRD problem
- More Fault Codes
- C20LET fuel regulator
- Engine Tuning
- 20XE bottom pulley issues
- car running lumpy
- c20let timing belt
- Oil – You get what you pay for!
