- GTE 16V not cutting off/limiter
- air coming through the air filter c20 let
- c20 xe crank bolt
- horrible tapping noise?????? HELP
- c20XE Flooding/Over fueling: Wont Start HELP Please!
- fuel problems
- 20seh into corsa gsi
- Eating petrol and exhausts
- Head bolts / exhaust studs for a LET
- NOS & TURBO "yey or nay??"
- zafira gsi - clutch problems and drinking oil??
- Corsa cutting out at random
- Is the XE throttle body the same as the LET jobbie?
- can anybody help?!?!?!1?1?
- "Fuel Pump" fault code-hmmm?
- has the f18 got small or big input shaft splines?
- Omega X30XE Auto Box Failure
- overheating calibra 4x4 turbo
- C25XE into a mk1 Astra
- Mk2 and Mk3 exhaust system.
- c20let,xe cam inlet cam swap
- Engine parts 20seh
- c20ne hoses??
- Phase 4 people - map sensor part number needed
- nove gte four branch manifold
- Z20LET Problems
- Corsa C LET
- c20let pistons into 3.0 V6, cooling+ compression ratio questions?
- Multec-S Ecu fault codes-4 digit?
- I have this fault code plz help
- Cambelt????
- can you convert a f20 box to hydrolic clutch??
- c20let-timming xe inlet cam using a vernier, proper?!
- WHITETOP????
- corsa xe over heating
- Equal length driveshaft question - intermediate shaft length
- c20let tuning?
- Lambda sensor, pre cat z20LET
- help needed em light on
- C20XE Over Fueling Badly HELP PLEASE!!
- Where to get XE to Type-9 bellhousing
- ECU light not working on my LET corsa
- Clutch
- c20let actuator
- Z20LET q's.
- upgrade my c20let
- red top time
- Z20LET Valve Spring, Retainer, Lifter Spec's
- xe/let oil pump (need a nylon press relief valve)
- 2.0 8v exhaust
- 2.2 astra coupe problem
- MBE engine management - opinions needed fast
- Nova 2.0
- Corsa outer CV
- Mod Advise: E16SE
- c20xe
- throttle cable
- 16v nova, where to put ecu?
- Anyone heard of/using/used a scan gauge?
- Gearbox
- Oil cooler help?
- 1.6 16v astra doing jerky movements
- manifold
- 1600 engine and 1400inlet
- How much POWER ?!?!
- Ecotec 'winged' Sump vs XE/LET Sump
- Calibra turbo smells of petrol from exhaust, overfuelling??
- Advice servicing X25XE V6 Calibra; inlet manifold, rocker cover gaskets etc...
- Red top v6 in a mk1 astra help
- Help Puttin 1.4 16v into 1.2 8v Corsa
- 1.6 8v engine mount
- f25 gearbox info
- c20let crank measurements
- F28 Mechanical or Electrical drive
- GM engines
- redtop in a td isuzu astra
- high power c20let spark plugs
- F28 Plastic Speedo Drive!!!
- NE block versas xe block , differences
- Equal length driveshaft splitting?
- Cally Ph3.5 c02 to high...
- ARP con rod bolts
- Astra GTE which gear box.
- coscast or not?
- Astra LET Radiator fan problems
- Corsa GSi IDLE issue Help,
- bonded sump gasket and baffel plate
- xe head
- Turbo Radiator - I need your help!
- engine change
- Vectra 2.2 DTi - Hard to start from cold.
- Raise bhp on a 1.7TD Izuzu engine astra
- Driveshaft ?
- Signal for EPS
- Fan belt off a Cally
- coscast block
- splutering
- F28 Gear Linkage Question
- corsa tensioner
- Let with f20
- Wheres my diagnostic plug? Astra g 1.7 td
- Saab 2.3 turbo
- gear cluster
- Fitting new in-tank fuel pump
- Temp sensor whereabouts???
- bent valves on a V6?
- C20LET Cambelt intervals?
- Mk3 Astra 1.7td (isuzu) No diesel.
- opinions on oil jets
- c20let horrible tapping noise
- Astra 16V 1.6 XEL Ecotec cambelt snap - queries!
- MK4 Astra DTi whistle
- mkV SRi Turbo and CDTi Help
- 2.0 XE oil pressure delay -
- C20LET wiring problems
- MBE/XE experts needed
- engine swap 8v/16v
- Late C20XE - Firing order
- Corsa EGR valve, really need advice!
- vectra sri 140, replacing engine?
- Acl Bearings
- Cracked wastegate
- astra mk2 fuel pump conversion query
- c20xe exhaust manifold on to x20xev
- *help*c20let probs*help*
- whats this part and whats it do? lol
- Nova converted to run F16? What do I need?
- corsa b gsi steerring rack
- mk4 F23 2.2 160 clocks c20let
- Z20LET Major Oil Trouble
- Cam Followers C20XE
- mk3 astra F28 linkage alignment set up!
- c20let wastegate bush
- Astra VXR Engine - Gearbox bolts
- corsa gearbox
- C20XE Running rough, TIMING??? Bogging down and smoking HELP PLEASE?
- injector problems
- Do this go here (radiator switch)
- coolant hoses
- What do these sparkplugs show?
- Opinions on uprated head gasket for Evo 5 LET?
- no fuel Pass the regulator
- different types of coolant
- Corsa SRi 16v, will a small block 8v engine fit in?
- Anyone else had problems with twin 45's on XE? :(
- Vectra Gsi - non starter
- BKR6-EIX or BKR6EIX-11
- calibra 2.5 v6 redtop upgrades any ideas???
- Cylinder No.1 not working
- 8v 2ltr into rally car
- calibra turbo with turbo d engine!!!
- just woundered what difference this would make..
- P0325... My Vectra mostly drives like crap...
- Intercooler Pipes
- c20let on f23 mk4 box help
- C20let - funked turbo?
- 97 vectra cambelt snap
- 17K miles on the same oil, OK?
- big front mount intercooler
- programeable ecu's for c20let
- C14se re-build to replace c12nz, few q's
- Astra C20LET
- C20let - uprated injectorss...
- v6 - 6speed???
- Driveshaft removal HELP!!!!!
- compression problem
- Omega V6 Manual / Auto
- 20xe rocker cover
- can a brake bias be fitted with abs???
- what turbo / manifold fits DSOP?
- what oil in a f28 with quaife lsd fitted
- emissions
- Oil Leak
- running in problems
- 1.2 Nova engine in a Corsa HELP :(
- LET ECU Question
- Removing speedo cable
- arp flywheel bolts
- oil cooler
- Thinking Of Buying A V6 Calibra.
- Alloy Heads
- Y26SE ECU Remap
- C16XE tuning and Hyd lifter advice
- c20let turbo engine management light trouble!!
- manifold
- hall sensor on redtop
- Fuel hose ID for mk2 GTE 16v
- hall sensor problem
- signs of power steering failure?
- 2.0 16v and MOT's
- F28 speedo drive, is it removable?
- please help
- c20xe head weight
- Early and Late XE use the same fuel relay?
- Is there a gasket on the exhaust flexi joint?
- will a gsi rad fit a 1.2i???
- How do you do the paperclip test?
- best engine to turbo
- Best but cheapest engine conversion!!
- best cams for xe?
- Pics of the Z20LET oil pump on C20LET pick up pipe mod?
- Mondeo 1.8TD Problem.......
- turbo or not to turbo..
- Head gasket gone? Opinions on uprated head gasket for Evo 5 LET?
- Mk2 Cavs - C20LET Conversion
- another c20let actuator question
- C20LET PAS/quickrack help
- Try Working This One Out ??????????
- EVO-5 Chips limitor question,
- Warm omega V6
- gte gearbox query
- Random Problem!
- corsa stuff
- Help an ageing hippy understand fuel injection ??
- 2.0 DTI fuelling issues
- Crank sensor - degrees BTDC?
- C20LET advice needed
- Odd LET fuelling issue (again)
- Throttle bodies and wiring DTA
- c20let chips
- 20seh Power steering (corsa help!)
- c20xe into corsa gsi
- Oil pump for an LET?
- c20let actuator
- fault code help
- Idle speed hunts
- Oil Pipe Connections on XE / LET oil pump
- redtop cutting out
- Ecu light piggen me off..
- Crankshaft sensor
- Astra GSI Z20LET
- Leaking intercooler?
- running hot or not ?????
- upgrade
- Running an XE with a pourous head, ok ?
- stainless or alloy intercooler piping
- hard to start an sounds like its runin on 3 clyinders
- Gutless 2.0 ecotec vectra, cat glowing bright orange.
- diffrences with c20let
- oil smell of petrol
- 20se into corsa
- C20let ARP rod bolts.....
- single v 20seh
- c20let exhaust manifold bolts! washers?
- de catin the corsa
- c20 let spark plugs
- diaphram for wastegate needed
- Opie Oils June Prize Draw!!!
- nova cam carrier on 2.0 8v?
