Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. help needed on wiring please!!!
  2. C20XE Dizzy options.
  3. Were to buy V6 tuning parts?
  4. Cam belt on xe??
  5. engine code
  6. short-shift for gsi
  7. Cleaning iridium plugs?
  8. Adjustable Fuel Pressure Reg
  9. Mk5 Astra 2.0t SRi (5 door) 'S' button?
  10. Vectra V6 help.
  11. F18 to F20?
  12. anyone know what would cause these codes. x18xe
  13. vectra 2.0 dti fmic and fitting
  14. Search for the missing spark
  15. engine code help
  16. Twin 40's...
  17. diff help
  18. C16SE ECU engine managment light wiring...
  19. C16SE oil pump, oil pressure sender...
  20. Dump valve quiet ?
  21. Clutch dodgey maybe?
  22. gear selection sloppy help.
  23. Engine managment Light
  24. Fitted my Recon Diesel Pump to 2.0l 16v astra diesel but not running?
  25. Corsa 20XE M Tech Quick Shift
  26. x14xe head gasket advise
  27. Original Height of cylinder head 2.0 8v ???
  28. Irmscher chip
  29. Clutch problem on C16XE
  30. nova sri to gsi conversion wiring
  31. GearBox ratios
  32. ekotek valve
  33. vectra 2.0 16v gearbow problems help!!!!!!!! please
  34. ecu problems
  35. Remapping
  36. Anyone near Bradford fancy helping me change water pump & cambelt on a redtop??
  37. Redtop - One stop ultimate tuning guide?!
  38. breather mod
  39. voltage vs AFR from standard xe lambda sensor
  40. C20LET running problems
  41. Corsa C20LET
  42. C20let head bolt torque settings
  43. sergestions for nova TD
  44. My C20let is smoking! HELP
  45. ECU Readout [Pin trick]
  46. Big Petrol Leak!!
  47. oil change after piston ring run in
  48. help!! vectra gsi tuning
  49. C20NE misfire
  50. lsd for f28
  51. C20LET downpipe, thread for lamda semsor M18 x 1.5 ??
  52. what spark plugs c20let??
  53. X25XE into cav
  54. "porous" head fix in situ? Just how bad can it get? lol
  55. Gearbox Issues!
  56. rally gearbox (RWD) for C20XE
  57. c20let manifold vacumn pressure
  58. c20xe temperature
  59. f28 clutch frication plate - anyone have one?
  60. c20let bigend bearings
  61. holding back really badly
  62. fan on bumper side of rad, which way do i want it spinning?
  63. water pump failure? what to look for?!
  64. Clutch problem
  65. Help me choose a turbo for my engine
  66. Wont run with fuel pump on?? C20xe
  67. 8v sump gasket on c20let! tap tap tap!
  68. High tickover (XE)
  69. My plans Z20LET
  70. X20XEV Holding Back/Hesitating
  71. C16XE
  72. Nova 1.4SR head on a 1.2 block?
  73. Cally turbo phase 3 boost prob help!!!!
  74. 8V Turbo.
  75. xe into a nova, help please
  76. mk3 cat
  77. what should the psi be on td astra ??
  78. xe and let dizzys??
  79. c20let idle speed control valve interuption??
  80. mk3 astra airflow meters and exhausts!
  81. snaping a 8v rod
  82. bizzare let cambelt problem
  83. Lpg Conversion!
  84. c20 xe loom
  85. quick question
  86. f25 question
  87. v6 inlet systems
  88. What fpr for a c20let ph2?
  89. this headgasket look right?
  90. Fuel pressure reg for v6
  91. Sump gasket help needed
  92. Gearbox for Astra G
  93. F28 2WD rear engine mount, broken, options
  94. Fitting bike carbs tech guide (pdf)
  95. New Gearbox needed
  96. Turbo/Supercharger on an X30XE
  97. XE misfiring - Was fine earlier?!
  98. let, boost drop off????
  99. C20XE engine earth
  100. i need to compare 3.0 v6 or redtop
  101. Fuel pump question, got a bit muddled
  102. 3bar reg & blue injectors..
  103. Getting the most out of a C20XE
  104. quaife diff
  105. Corsa C 1.3 CDTi engine problem
  106. extra bhp
  107. oil cooler
  108. Corsa X10 > X14xe conversion fault code question
  109. Having a daft moment - XE/LET oil capacity
  110. which AFM 2.0 8valve ???
  111. c20 xe oil pump + pistons
  112. ATS 1.4 16v
  113. 0-60mph?
  114. Omega Strut Braces
  115. Length of a nova short drive shaft?
  116. need my driveshaft out, do i have to .......
  117. C20LET running problems fueling?
  118. X16XE block over-bored to 1650cc
  119. XE running lean apparently...
  120. C20LET holding back????
  121. Sometimes it won't start!
  122. KKK Turbo Question
  123. Parts list: Spec me a 260-280BHP LET
  124. XE getting hot really quickly
  125. Piston Opinions........
  126. A perfect tuned engine ?
  127. F23 Gearbox Dismantling Instructions
  128. Making my own powerbox for x16xe
  129. Cam shaft sensor
  130. Late XE Loom into a Corsa B - whats this plug do??
  131. XE Flat Flywheel Weight
  132. C16XE Air Box
  133. qucik rev limit question
  134. f28 gear box into a vectra b
  135. 1800cc Mk3 Astra GSi engine
  136. SBD type c cap head bolt size??
  137. xe weight?
  138. beware recon driveshafts.
  139. c20xe wiring
  140. c20xe piston diferences???
  141. smoking:(
  142. Bosch Part number
  143. WOnt start? fuel and spark and good compression? HELP PLEASE!
  144. V6 MK1 Nova
  145. Bike Carbs to a 1400 sri
  146. Fuel Pressure Regulator
  147. FAO Standard 1.6 16v engine owners
  148. another xe problem
  149. Setting fuel pressure?
  150. Clicking noise near cam belt
  151. 1600 16v cams into 1400 16v head
  152. Amount to get skimmed off 20seh head
  153. exhaust???help
  154. z20let into veccy b
  155. yet another xe running problem strange can suss it out
  156. F25 Gearbox oil problem...
  157. R1 throttle bodies? and red top engine mods
  158. Timing marks on X16XEL?
  159. what carbs fit a 1.8?
  160. Book time for clutch change?
  161. gearbox gsi
  162. gear box proplem vectra gsi
  163. tuning a gsi vectra 2.5 v6
  164. Z20let engine mods?
  165. Splitting shafts from CV's?
  166. help ! anyone who knows about hondas
  167. No spark and no fuel or fuel pump? 2.0 16v
  168. Help. LET-misfire-killed 6 O2 sensors
  169. Corsa B C20XE jumping out of 5th Gear
  170. c20xe or X20XEV ecotec
  171. Evo 5 Chips with standard turbo
  172. calibra turbo holding back
  173. Boost vs Exhaust connection question,
  174. quick actuator question
  175. 2.5v6 into 1800 cav
  176. cav gsi floor pan question
  177. C20XE Poor Running After H/G
  178. C20NE tuning...
  179. Vectra clutch problem - Please help
  180. F13 Gearbox??
  181. calibra runs from a jerry can, but not from tank
  182. rallycam with throttle bodies help
  183. m.o.t nightmare
  184. 2.6 mv6/vectra gsi flywheel
  185. Fuel Pump advice please
  186. cant select 5th gear - Astra 1.7D '96 - help!
  187. de-badge?
  188. V6 cambelt?
  189. what cc would 80mm pistons make in a 1600 block?
  190. c20let block advise
  191. FAO Mark T - width of V6/F20 driveshaft bracket spacer
  192. How do I read the fault codes on my c20xe nova?
  193. Turbo Opinions................
  194. 2.0 16v Wont start! Help Please!
  195. Motorsport CV Joints
  196. swapping an xe corsa to a let??
  197. C20XE Exhaust Purchase
  198. can i map a ecu to how i want???
  199. Header tank boils over
  200. 1.6 16v engines
  201. 3.5 bar press reg
  202. Vectra SRI CDTI 150bhp-SLUGGISH UNDER 3000 rpm
  203. Overfueling
  204. 1400 spi nova--1400 T40??
  205. Heater problem in a corsa 15 diesel?
  206. C'LET Oil cooler
  207. mvaux clutch??? 650bhp
  208. F28 2nd Gear Grinding (Syncro?)
  209. y20dtl turbo
  210. ZLET fmic and turbo.
  211. Late Calibra XE induction hose
  212. car keeps cutting out - changed the idle speed control valve twice - HELP !!!!
  213. lightened crank pulley (20 seh)
  214. B&S Phase 3 chips
  215. Please tell me what this turbo is and what it's worth
  216. Vectra B Gearbox
  217. Strongest engine and box mounts where from ?
  218. V6 Cavalier Bhp?
  219. F13 On A 2ltr
  220. Starter motor
  221. Calibra v6 to 3.0 Mv6/Elite ?
  222. 2 ltr corsa conversion
  223. X16XE Inlet manifold 5th Injector
  224. Water cooled turbos
  225. Raising the rev limiter with crystal quartz
  226. astra fuel pump problem
  227. Can Anyone Help ?
  228. ECOTEC??
  229. Talk me through changing/adjusting a fan belt on my car.
  230. throttle bodies ???
  231. VXR Turbo on Z20LET
  232. Cylinder Honing.....
  233. c20ne v 20seh (flywheels)
  234. HELP!- cavy not firing!
  235. T3 on C20LET, what to do with breather that went to Comp housing ?
  236. C20xe loom in c20let
  237. inlet manifold
  238. C20NE Loom
  239. How confusing, am I at risk????
  240. Need Help please!!!
  241. f28
  242. c20XE Will not start! Flooding/Over fueling: Wont Start HELP Please!
  243. injectors question
  244. Does this sound right???
  245. Which Vx RWD boxes mate up to XE/LET/V6?
  246. Spaceframing questions, advice needed
  247. 2.5 v6 upgrade advice
  248. astra gte 16v rev problem
  249. pic request for corsa with bulk head removed
  250. Voltage for uprated pumps and fpr bar?
