Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. spark plugs and idle
  2. what spec will this be
  3. distributor leak??
  4. C20let phase 2 which turbo
  5. nova sr 1.4 - running prob :(
  6. C20let turbo cylinder head torque settings
  7. 20 Seh Main Bearing Bolts.
  8. Urgently need help with torque settings...
  9. New engine oil pressure
  10. Corsa B SRI Help!!!
  11. Sportex anyone?
  12. how do i test if ive got a boost leak c20let
  13. Benefit of tophat
  14. X16XEL - where do these ends go???? Help ...
  15. Please?! Need help with my engine
  16. which gearbox is in...
  17. Timing Belt parts?
  18. running hot
  19. Calibra V6 Kompressor
  20. 4x4 light Question
  21. Can i go turbo with £1500
  22. astra sport 1.6 16v gearbox
  23. Astra clutch.. input shaft
  24. Fleetway clutch kit
  25. mk4 multec-s ecu pinout, temp gauge fault
  26. f28 into mk4 astra c20let
  27. C20XE Corsa Mounts
  28. c20let codes
  29. veccy cutting out
  30. how to turbo an 8valve
  31. Quaiffe Diff, How do I tell?
  32. Spare wires, SEH conversion
  33. X25XE heads, X30XE block, tech advise please!!!
  34. c20let ecu reset
  35. let oil cooler
  36. what power can the cav/cal turbo rear diff handle?
  37. c20let-fault code 15 cts high voltage??
  38. car wont start
  39. r1 carbs, what bits what?!?!?! help!!
  40. astra mk4 1.8 16v two cat pipes?
  41. nova gsi wiring loom
  42. Corsa ABS with Big Shaft conv.
  43. c20 let over heating
  44. max rpm on a 3.0l
  45. c20let boost
  46. head conversion
  47. F28 gear box for drag race???
  48. nova gearlever help
  49. v6 wont start.
  50. mk3 Astra flywheel?
  51. measuring bores
  52. knock - a good link inside
  53. air lock
  54. Revving high on tickover
  55. Which ECO engines have a top mount TB?
  56. Boost dropping .
  57. 2 litre Ecotec engine, having probs firing it up
  58. 2 litre corsa
  59. Decat Pipe (C20NE - C20XE)...
  60. Quick C16XE loom plug identification
  61. Closed Loop on MBE 967
  62. what are these manifolds like?
  63. X16XEL engine bay photos?
  64. need a conversion guide
  65. tigra turbo c20let intercooler
  66. Thermostat sheared bolt help
  67. c20let c20xe head whats the differance
  68. should an air flow meter be hot???
  69. My Cav failed its Mot for Emissions
  70. Diesel engine locking tools??
  71. retop into ecotec
  72. corsa 4x4?
  73. AHH new crank sensor now it wont start!!
  74. wastegate exhaust
  75. Cavalier MK3 1.8i missfire Please help !!!
  76. C20LET Code 57
  77. Dastek Unichip and adjustable rev limiter.
  78. 2.0XE vs 2.0LET
  79. Which RWD Manifold?
  80. Fault code help
  81. Reading fault codes on a V-reg corsa
  82. code 13 c20let why?
  83. c20let boost-adjusting it down by actuator but its not doin nothing!!!
  84. Mounting Oil Cooler on it side
  85. uprated gearbox for x16xe
  86. c20let piston rings?
  87. Astra mk4 cranks but no start
  88. Astra GTE Wierd timing???
  89. Gearbox boffins..
  90. part number??
  91. how to change crank sensor???LET???
  92. 20seh crankshaft
  93. Nova XE no chassis mod???
  94. how do i install my superchip?
  95. 1.8 16v Vectra - Cam Belt Snapped
  96. c20let oil feeder pipe to turbo (corsaB)
  97. Exhaust heat shield - Astra Mk3 16V - needed?
  98. C20Xe crank bolt size
  99. how much
  100. help with astra c20let conversion
  101. sorry to bore you with more tb woes
  102. 14xe corsa egr etc
  103. astra fuel pump any diffrence in 2.0 16v ecotec and xe pumps?
  104. Quick sensor question
  105. flywheel bolts stuck?????
  106. Were is this on my V6 vectra ?
  107. Is there gold in them there hills???
  108. equal length driveshaft help
  109. Trying a phase 3 on my Cally T. Help & idea's
  110. Whistling fuel pressure regulator,is this right?
  111. Izusu 1.7d Corsa - which fuel pump?
  112. 1.6i 16v running like a dog...
  113. Webber 32/34 carbs.
  114. 1990 cav gsi xe what fuel pressure reg? 2.5 or 3.0
  115. who does LET engine rebuilds??
  116. C20XE Irmscher ECU
  117. x20se mod.
  118. plug gap on evo5 or phase 3.5
  119. mk4 astra drive shaft same as mk 3? / changing driveshaft
  120. why is my fuel pump pulsing?
  121. c20let actuator
  122. cam sensor help
  123. timing belt 1 tooth out?
  124. apexi avc-r boost controller
  125. What do you think of this air filter??
  126. c20let upgrade to 350bhp
  127. C16xe into nova using Multi V Belt alternator (quick question)
  128. Compression on XE
  129. Log book changes
  130. Gearbox feels too tight
  131. oil spray jets
  132. rear disk to corsa b
  133. c20let major problem
  134. Custom Wiring Loom
  135. NE and SEH engines????
  136. Fitting catch tank-16xe
  137. After 6 months im LETing thanks to mig.
  138. SPark plug holes filling with fuel? Help please
  139. calibra rear diff
  140. corsa 1.4 16v rattle
  141. vectra went bang
  142. is it dangerous ?
  143. 1.7td fuel pump
  144. 1.7 td astra fuel pump
  145. common problem?
  146. cav carb hard 2 start wen hot???????
  147. injector colours
  148. c20let inlet manifold and throttle body?
  149. Can someone comfirm what this Part # is
  150. how good are mvaux
  151. Help needed 1.6 cav clutch
  152. nova linkage
  153. Let cold start running probs
  154. nova c20let swirl pot
  155. afm
  156. Speedo drive broken in F28
  157. help please help! c20xe problems
  158. Which side is fuel feed and return?
  159. more power from a vectra 20di
  160. kent,essex,sussex carb tuners???
  161. c20xe/r1 carb manifold... where can i get one?
  162. Corsa xe gearbox
  163. Mounting Blow Off valve into a Z20LER??
  164. help short shift gear for vectra gsi
  165. low-temp fan switch??
  166. Calibra Turbo clutch - which one?
  167. will this fit??
  168. Is the afm of cali turbo same as the 2.0l afm??
  169. quafie atb diff tyre question
  170. C20XE Coolant system
  171. Diagnose this car engine problem...Rover Headgasket?
  172. What BHP you got 1600 16v ??
  173. Z20LET Wiring Diagram Needed.....
  174. head x14xe
  175. mk4 astra c20let gear box best i for it
  176. Where can i get guides for my head ??
  177. Gear Selector Weld Question -- Why?
  178. Lambda sensor wires
  179. help let cutting out!!!
  180. X16XEL water pump marks??
  181. Car cutting out once temp reads above 90
  182. Astra V6 queries / Omega V6 queries
  183. calibra 2.0 8v cold start
  184. ast mk.3 1.4 running cold
  185. C16XE lower spring retainer removal
  186. idle please help
  187. astra 1.7td gm engine 1.7dtl
  188. Manta Inlet Manifold And Manta 2.1 Carb
  189. temp gauge...
  190. info needed on part numbers
  191. what engine should i use
  192. nova gte engine
  193. v6 burring noize? air con apparently?
  194. c20let pulley
  195. C20let P.A.S. pipe (fs)
  196. C20let P.A.S. pipe (fs)
  197. Exhaust Wrap?!?!?
  198. engine management light & chips C20LET
  199. turbo rebuild price??
  200. Yet another cam belt question...
  201. Nova big block outer CV's?
  202. f20 let gearbox problem
  203. fault code 13 on c20let ?
  204. Where can these be found?
  205. management light
  206. f28 starter info required plus other v6 stuff
  207. tigra c20let running bad
  208. 1.9mm head gasket
  209. Tightening head bolts: mystery bang!
  210. vectra r reg kicking like a bronco
  211. XE gated and baffled sump?
  212. je piston rings and specs
  213. dump valve (c20let)
  214. weight driffrences
  215. Hesitation when accelerating
  216. best air intake (z20let)
  217. Which diff for f28
  218. bhp ecotec
  219. astra mk3 308mm discs
  220. 1'ltr Corsa problems
  221. Spark plug change
  222. DumpValve Help 4 Z20LET!!!!
  223. c20xe in corsa gsi
  224. help with cambelt
  225. oil pumps mk3
  226. c20let oil pumps
  227. c20let oil pumps
  228. Nova gsi throttlebody and manifold onto corsa sri engine?
  229. vectra 20 di tune
  230. snapped cam belt....
  231. let eds phase 1 power???
  232. Chipping 2.2 DTI Vectra (2000)
  233. c20let turbo advise
  234. diff bearin preload setting??
  235. doing my head gasket
  236. xe conversion
  237. tirga trouble
  238. fitting new oil pump on let xe
  239. Fitting a LET and F28 into a Mk2 Astra GTE 8v
  240. z20let head gasket on c20let, tight?
  241. PLEASE HELP X14XE engine hesitation
  242. over heating
  243. just blown my head gaskit
  244. g-tec
  245. Corsa B ECU Reset
  246. 1.7 CDTI question
  247. Thread sizes on xe blocks (oil temp)
  248. no fuel on x16xe
  249. DIY Stylee oil pressure sender installation (Get broadband)
  250. Is this my engine number
