Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. engine knock/rattle problem
  2. Kadett GTE TURBO
  3. Courtenay Air deflection plate
  4. mk3 astra with 2l 8v problem
  5. fuel pressure regulator
  6. Whats the difference c20let -c20xe blocks???
  7. C16SE fast road cam?? MOD Help
  8. timing chain set-up on a 1.0 3 pot engine
  9. XE LET Dizzy
  10. Corsa XE fuel lines
  11. xe cam locking tool
  12. Gearbox in Redtop Cav SRi's
  13. will this mount work 2.5
  14. Servicing a MK3 astra gsi (c20xe)
  15. C20let Headgasket
  16. wee question
  17. X16XEL vacuum pipe diagram?
  18. X16XEL - engine mount foo barred?
  19. Omega 2.5 V6 breather problem
  20. Transfer Box Drain Plug Torx Size?
  21. air flow meter? z20let
  22. C20LET overfueling at idle?
  23. just been to vauxhall
  24. Corsa engine
  25. Lambda position
  26. Nova Rad.
  27. Transfer Box Drain Plug Torx Size?
  28. What does the c-clip do on a 20xe dizzy
  29. Nova C20XE on R1 Bike Carbs HELP!!!!
  30. stutter/ misfire on part throttle Z20let engine
  31. Setting new actuator
  32. 2.0 XE Nova Running Webber 45's, Advice Need Please
  33. HELP PLEASE c20xe crank sensor
  34. forged conrods
  35. Help on spark plugs
  36. head gasket gone ? oil press
  37. high octane on a V6?
  38. Lighten and balancing a c20let crankshaft
  39. coil pack!
  40. New Simtec 56.5 fault code
  41. C14se inlet - whats this pipe conection (pic)
  42. k26 turbo
  43. Uprated block c20let
  44. Manta Gearbox type
  45. corsa xe nearly fixed
  46. Panel filters
  47. Vectra Facelift X20XEV Cutting Out??
  48. Corsa 2L 8v to XE or LET
  49. mk astra c14se to c16se or c20xe
  50. T15 / GT15 turbo - whats the differance?
  51. 2.1 xe???
  52. Carbs or no carbs???
  53. Arse - wrong tool?
  54. 20XE Code 48
  55. Fault Code
  56. f28 on an xe
  57. zafira gsi turbo
  58. timing belt question
  59. Induction kit on a V6, good or bad?
  60. c12nz-----c14nz
  61. v6 no a/c or pas witch belt?
  62. X20XEV transplant woes; no spark!
  63. Wide Band reading Result Onto C20LET
  64. Converting F28 to hydraulic...which slave?
  65. early xe crank shaft sensor
  66. ITG air filters?
  67. want some noise
  68. corsa let exhaust-silencer or no silencer?
  69. F28 Hydraulic Clutch Setup........
  70. plumbing in a adjustable fuel pressure reg.
  71. Best Induction???
  72. No Spark C20XE
  73. 1994 c20xe with ecotec cam cover
  74. c16xe process for turbo
  75. OOps, look what i found on my V6 :(
  76. help with turbo
  77. No Compression - C20let
  78. how much fluid in a f28???
  79. phase 2 and 3?
  80. F16 CR what car was they in???
  81. F16 CW what car was they in???
  82. how does the amal valve wrk c20let
  83. z20let into corsa c 1.8 sri whats needed?
  84. Astra x20 Let
  85. Throttle body and Turbo Setups...
  86. X14xe and x16xe timing belt kits!! help !
  87. Z20 LET
  88. V6 into Astra Mk3
  89. Apexi Induction Kit
  90. F20 query
  91. Clutch checking?
  92. converting 1.8 carb to 1.8 mpi usin c20ne parts.
  93. 2.4i into a Cavalier CDX
  94. F28 fitting in a nova with engine in?
  95. Astra G not starting
  96. flywheel would you use this one???
  97. nova rear gearbox bracket
  98. c20let missing problem.
  99. xe / let dipsticks
  100. z20let corsa b
  101. anyone know where to buy turbo kits???
  102. Quick quest
  103. where do i get z20let oil pump from??
  104. Intake pipe.
  105. converting 2.5 v6 with auto box to manual??
  106. help
  107. Omega 2.5td Auto box problems
  108. corsa b sport 16v bottom end
  109. Best way to run new pistons in
  110. Basestock categories and descriptions
  111. 14SE Head advice please.
  112. what would a leaking wastegate do ?
  113. Early XE sensor plug help with pics
  114. quick f18 question (v6 astra conv)
  115. Corsa XE Fueling
  116. Simtec 56.5 fault codes
  117. Loosing compression? Help?
  118. C18SEL rebore questions
  119. smokey corsa sport
  120. GSi Gear Box
  121. firing order
  122. x20xev into mk3 astra 1.4ls
  123. x20xev into mk3 astra 1.4ls
  124. astra 20xev into bay of x14xe
  125. C20XE ecu's
  126. twin 45's
  127. zero boost on c20let???
  128. C20XE Early Limiting.
  129. Do I need a new ECU?
  130. Astra 2.0 Turbo Poor Fuel Consumption.
  131. LET into Mk3 Cav Gsi (problem)
  132. nova c20let pipes info
  133. convertin 1.8 carb to 2.0i mpi?? possible?
  134. smokey jo
  135. corsa conversion help
  136. c18xe smallblock, what head job and injectors?
  137. Nova c20xe dizzy type wont start over fueling
  138. Coils
  139. Astra/Vectra Gearbox problem - Please help me.
  140. Another 4x4 problem! helpski!
  141. Oil Cooler AstraVan - Info Needed
  142. f16 close or wide
  143. X20XEV Cav CDX Oil Leak!!!
  144. Weber Help!!
  145. X18XEV Oil Leak...
  146. Cav turbo fuel pump in cav 1800ls-XE conversion
  147. After I broke the 1600 16v for the 4th time I decided to go big block...
  148. Cooler C20LET on a Astra Mk3
  149. C20xe Clutch Etc
  150. Martin Tinker - calibras 4WD
  151. Tuners/Rolling road in Midlands/leciestershire
  152. Water temp and Oil pressure
  153. F18 top F20 swap---------1998 Vectra SRI
  154. Anti roll bars
  155. seh into corsa fuel lines
  156. xe knock on idle
  157. 20xe into 1800SPI cav
  158. Car won't start - C14NZ
  159. Corsa gsi xe help!!!
  160. Temp Sender location - x30xe
  161. engine swap
  162. info on oil cooler for a c16xe
  163. removing gearbox sender
  164. astra gsi c20let speedo ????
  165. 2.0 8v boring?
  166. F28 linkage, mk2 16v Astra
  167. c20let fluctuating & splutering
  168. Flywheel Trouble...
  169. ecotec to redtop wiring problems
  170. How do i check if my CTS is working?
  171. headgasket on x14xe auto. big blu plug at back left of engine
  172. c20let c20xe temp sender
  173. wanted x20xev wiring diagram
  174. Fitting equal length driveshafts to c20xe
  175. best way to turbo 8v engine?
  176. 20Let Dyno graph
  177. corsa xe wont start
  178. Missfiring
  179. engine dies when you blip the throttle
  180. c20let turbo help!!!!!!!!
  181. head gasket?
  182. Advice needed on conversion
  183. wont start??
  184. Z20LET turbo problems
  185. xe random reving
  186. still wont start...
  187. cav 17td driveshaft help urgent
  188. c20let clutch
  189. need more boost help
  190. Xe inlet cam into a C20let
  191. F28 Gearbox Problem.
  192. c20xe into 1.4 ls astra
  193. Slight fuel leak-Where from?
  194. astra sxi gearbox
  195. gearbox problem-grinding when putting into reverse?!!!
  196. Engine Cutting Out
  197. cav sri redtop
  198. C20XE Hot Running
  199. Z20LET low boost issue
  200. are KS bearings any good
  201. Fuel Pipe Change on a Calibra
  202. Corsa with 2.5 V6
  203. actuator/ turbo help
  204. **urgent** what is needed to change f20 to a f28 gearbox on a astra mk3 C20LET
  205. no rev counter after fittment of chipped ecu?? help
  206. valve timings
  207. Redtop, Webber 45, Turbo, Megajolt...
  208. an extra pipe?
  209. LET yellow injectors
  210. Where are these sensors located?
  211. I can feel a knocking through the pedals...
  212. xe intermittent knock + rough idle
  213. ANybody near Halifax (leeds way) want to have a look at my car or try their ecu?
  214. best turbo to use??
  215. would this cam really give the hp they tell you
  216. hydraulic lifters in c16xe
  217. F28 oil leak
  218. IAT sensor question
  219. engine managment light on :(
  220. Identify the C'LET Illness
  221. corsa xe shafts
  222. how do i time up my c20xe
  223. 400 miles away from home - non start diesel from cold
  224. Custom fuel rails
  225. engine management light
  226. shot blasting
  227. x16xe & x14xe inlet boxes ? ie mentzel
  228. quickty gearbox
  229. x16xe spark and oil problems
  230. high revs
  231. Cam belt intervals
  232. z12xep
  233. Which gearbox oil to use with F20 with Quaife LSD?
  234. c20let 5 spd box
  235. Cam upgrade
  236. Coil to dizzy wiring. 20XE
  237. Engine warning light
  238. C20NE into astra g mk4
  239. wee question about revs sticking
  240. saab reds in ph2 let what presure do i run
  241. Swapping an F28 Quaife into an F20
  242. Can I use the paperclip fault code method on a '99 Astravan (1.7 tdi)
  243. Srange Miss Fire? Please help!
  244. 2001 Astra transmission fluid
  245. Corsa LSD
  246. oil leak and hard to start when hot!
  247. C20let Clynderhead
  248. De-cat on 2.5 v6
  249. 1.8 spi upgrade?
  250. Vectra V6 Clutch-How much ?????
