Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. which oil is best for old type 1.6 Tigra? 10w-40 or 5w-30?
  2. 8v turbo...
  3. How many HP on a non-turbo ?
  4. spark plug gaps on c20let (BKR8EIX)
  5. 1.6 8v Corsa - which driveshafts
  6. engines and transmission
  7. rwd corsa
  8. xe corsa top coolant pipe
  9. Fuel set-up for carbs ?
  10. Corsa XE ashley exhaust.
  11. Are Tigra 1.4 and 1.6 heads the same?
  12. Engine management light
  13. C20XE Power Steering Belt
  14. ecotec accelerating problems
  15. C20LET dump valve not working?
  16. mbe ecu - maps?
  17. c20let valve timing - xe inlet cam, no timing marks...
  18. engine not straight
  19. Vectra GSi, Intermittent EML and Missing
  20. x22xe block and 20xe crank
  21. Advice on V6 nova's please!
  22. How much power can push the GT2876R in the C20let.
  23. Blanking dizzy hole C20XE
  24. c20let, not performing/pulling correctly
  25. V6 Engine Problem
  26. a cople of bits i got
  27. early mk2 astra gte ?
  28. Ecotec 2.0 - TBs now running properly
  29. How to reset the gear linkage on a V6?
  30. xe inlet cam into let
  31. Power steering question???
  32. auto gearbox problem
  33. XE Manifold question, quick one.
  34. calibra F28 front mount needed
  35. air flow meter, possible...
  36. New bolts needed!
  37. c20let managements
  38. car smells of petrol?
  39. phase 2 let with saab reds what presure ?
  40. mk4 gsi flutter noise instead of dump valve?
  41. redtop fault code help
  42. Car won't start !!!!!
  43. X14xe Ecu Swap
  44. big valves
  45. C20LET Coscast Head How Much?
  46. Megasquirt?!
  47. Dirty Diesel Problem - Fault Code P0105
  48. xe let cranks the same?
  49. uprated engine rubbers?
  50. what is this thing (x20xev)
  51. calibra 2.0 cutting out (idle)
  52. What compression tester to fit XE/LET?
  53. help desperatly needed with 2001 1.6 8v astra
  54. Corsa diesel van engine up-grade?
  55. pistons
  56. Need some pics or the xe let drivers side mount!
  57. 20XE Alternator Spec
  58. tigra/corsa blue plastic fuel lines under car - question?
  59. C20XE ECU Part numbers
  60. Corsa 1.0 problems...
  61. Benifits and loss's of R1 carbs??
  62. How to tell genuine & fake sard FPR's?
  63. is there a way to stop blowing exhausts?
  64. How many amps does a LET starter motor draw on cranking?
  65. c20let 87mm je pistons compresion ratio
  66. 1.5 to 1.7 Isuzu
  67. veccy 1.8 eco, 02 sensor wires, how many?
  68. Gear linkages ??
  69. Can't get into reverse (F28 on Saab 900R)
  70. Changing Cam Belt
  71. C14NZ ECU - Replace with which ECU ?
  72. Mk3 astra 1.4 Four branch manifold
  73. Mk4 Astra Diesel alternator - charging relay???
  74. V6 TUNING?
  75. Eh where does this go?
  76. Is anyone running Evo5 chips?
  77. egr
  78. calibra 4x4 quest!!
  79. Pros and cons of charge cooling
  80. ECU remap
  81. F10 gearbox diff whine?? Help!!
  82. ex winged and baffled sums
  83. XE Flywheel Difference
  84. MOT emissions.
  85. cavalier c20xe (gsi)
  86. Corsa Let Issue after head rebuild!
  87. garrett t04
  88. XE Porous Head Question
  89. 1.7 diesel tuning - confused
  90. mk4 astra van engine ideas?
  91. Quick F28 question
  92. What gearbox on a V6?
  93. Had the Nova on the rollers, dodgy Amal Valve ?
  94. torques settings z20let steel gasket + c20xe
  95. z20let steel gasket.rivets question?
  96. compression ratio advice needed
  97. Throttle bodies throttle cable!!
  98. c20let spark plugs
  99. Phase 3 c20let and vxr injectors
  100. qucik piston question
  101. head bolt size? c20xe
  102. x17dtl tuning?
  103. Where's best for C20LET Tuning/Setups?
  104. ecu and cat question.
  105. Anyone Know The Answer
  106. C20XE problem. Non running.
  107. Brand new fuel tank-Worth painting before fitting?
  108. Corsa B 1.5 TD (isuzu) Glow Plug Problem...
  109. what will this be bhp plus quatermile
  110. Astra coupe ecu location
  111. xe exhaust bore
  112. engine number on c20xe
  113. wynns hydraulic valve lifter treatment
  114. car wont rev past 4k.
  115. water injector on ph2 let
  116. Anyone know what this bit does ? (X20XEV)
  117. Will An F28 Fit A V6 Cav?????
  118. Tappets on x14xe
  119. Silicone hoses for 2ltr ecotec cav?
  120. Chips Any Good???
  121. Nova gsi flywheel on x14xe
  122. running problems
  123. Leaking Water Pipe on C20LET. Help!!!
  124. How to do a good service?
  125. someone with access to modern EPC
  126. any1 got some pics of a c20ne/20seh so i can see what connects where?
  127. V6 Mk4 Astra - flat spots
  128. Z18xe two cats??
  129. sound clip wanted
  130. Help Needed Asap Rough Running c20xe ?
  131. C14se - where does this sensor go - (pics)
  132. which transducer will fit?
  133. My XEV engine died today!
  134. f16 onto xe??
  135. Balancer shaft removal
  136. C20LET & Z20LET bottom ends. Need help quickly!
  137. "Tech2" in North Manchester
  138. Injector Experts! Are my Pico's the correct Impedance for MBE?
  139. engine mounting?
  140. Picture of a standard LET header tank?
  141. Exhaust Rebaffled?
  142. Reccomend me a decent actuator .
  143. scorpion exhaust
  144. Oil Leak - Dizzy\Hall effect chamber thing
  145. LET Cam snappage! Can I fit a standard cam with an uprated one?
  146. How to remove a Carlton/Cally T rear inner CV ?
  147. exhaust problem
  148. Silly question C20LET to SAAB 93
  149. Nova Quick Shift???
  150. 2.5 to 3.0 swap, info needed
  151. Car wont start after floods...
  152. GTE 8valve missfire engine gremlins?! HELP
  153. msd v6 question
  154. c20let idle valve
  155. finishing off redtop convrsion
  156. c20let cambelt-snap need help
  157. Vectra fitting bigger Dti turbo
  158. Crankshaft torque!!
  159. 145000 on a redtop?
  160. kkk16 turbo
  161. oil pipe keeps bursting c20let pic included
  162. Solid donut mounts, What had them?
  163. Advice!! full clutch kit or just pressure plate for f28?
  164. Vectra B V6 to C20LET
  165. how do u wire and connect up an external fuel pump?
  166. VXPaul Inlet Manifold
  167. job of the amel valve
  168. let f28 paddle clutch what flywheel?
  169. Oil pressure relief valve position on C20XE
  170. 2ltr Ecotec dipstick tube
  171. F18 Gearboxes and Flywheels.
  172. C20XE Baffled Sump Options
  173. Mains bearing clearance?
  174. C20XE
  175. mk3 gsi dispac inlet hose
  176. spark plugs?
  177. 1.6 gsi loom
  178. tapping cav v6
  179. Lined C20 LET block?
  180. c20let missing
  181. Earth to fuel rail *help*
  182. corsa xe help
  183. c20let bare block weight?
  184. astra gsi turbo exhaust
  185. overskimmed XE cyl head
  186. stripped sump nut thread
  187. 2 types of transfer boxs?
  188. Direction of coolant flow
  189. is it possible
  190. Xe without Lambda
  191. Cavalier high rev problems.
  192. fitting turbo to xev
  193. injector compatibility
  194. fitting a 1.8 16v into a nova...
  195. what is a wastegate valve on a cavalier turbo.
  196. how to get ecotech to xe power????
  197. How/when should a 1.7TD Isuzu lump run?
  198. Smell of petrol inside calibra cabin
  199. forged piston clearance / bore size
  200. mounting redtop into mk3 astra 1.4spi with PAS
  201. My c20let bottom end is....
  202. Det....explain this word please.
  203. X16XE, 2 questions on EGR and ICV! Please help...
  204. c20let maybe boost problem
  205. 1.2 Corsa question
  206. c20xe cam cover breather mod?
  207. Which rubber mount
  208. MBE XE Base Map needed to fire her up!
  209. Xe Nova using F16 box?
  210. corsa c14se engine and gbox troubles
  211. xe and c20let cam info
  212. Anyone convert an F28 to an external slave?
  213. Clicking from bottom end???
  214. xe inlet cam idendification
  215. gearbox guru's help me sort out my final drive. :-)
  216. fueling problems
  217. Nova electric PAS... Gravity fed?
  218. Mantzel inlet tube part number
  219. turbo set up
  220. driveshaft lengths?
  221. bailey dump valve
  222. Lambda on Mk2 16v GTE
  223. help needed on corsa
  224. emissions test would it pass
  225. corsa gsi on carbs
  226. Does my crank need a regrind?
  227. emission problems
  228. how do u tell if you're running lean??
  229. nova back engine mount bracket
  230. supercharger layout
  231. what oil is best for my Tigra?
  232. urgent:camshft sensor help wanted please
  233. XE rebore and over sized rings
  234. GTE outer CV's on a GSI (F20)?
  235. Parts Needed For Red Top Conversion
  236. Help, Gear Box Problem!
  237. c20let help need advice
  238. Quick LET Sensor question
  239. c20let power upgrades?
  240. what type of signal is the RPM wire?
  241. Corsa 2.0XE manifold...
  242. help needed, 4x4 light on
  243. Lambda Sensor
  244. xe knocking solved! pics!
  245. x14xe tuning
  246. Corsa gsi or sport??
  247. aircon and a turbo in a cavy?
  248. oil pressure guage on a LET??
  249. Exhaust Wrap. How much do I need?
  250. what fuel pump?
