Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. calibra turbo rear axel on astra van
  2. how long can you?
  3. fuel pump
  4. LET special inlet manifold
  5. Exhaust manifold
  6. xe no spark
  7. FAO those with carb conversions:
  8. TPS C20LET sensor bosch number ?
  9. And disaster show up.....
  10. Driveshaft removal
  11. Best V6 Plenum?
  12. C20XE Torque
  13. Bosch Fuel Pump
  14. Frontera Intercoolers.......
  15. c20xe poor running - dispack
  16. Manifold wrap
  17. What cam is this? - PICS
  18. what the best way to fit nitros to mk3 astra
  19. Phase 2 info
  20. astra G wont start *help*
  21. c20xe misfire
  22. Locking xe cams for t-belt change
  23. X20XEV tunning ideas
  24. c20let head gaskets
  25. cool running thermostat help??
  26. C20Xe oil leak
  27. Engine warning light
  28. New clutch, but wich one ?
  29. gearbox question
  30. I'm thinking of buying a Vectra B V6
  31. E16SE lots and lots of smoke
  32. z20let
  33. Ecotec 2.0 head / 1.8 block
  34. problem on my C20LET , engine has stall, engine start but ?
  35. Corsa C20LET F28 - tie bar problems.
  36. Z20LET Pipercross Viper
  37. c20let metal afm pipe work where sell them
  38. corsa b, intercooler fitting?
  39. Astra G Intercooler Fitting?
  40. 2.0 Ecotec Vectra trouble
  41. Cracked head? Water/ Oil Mixing
  42. vectra v6 clutch adjust
  43. c20let or z20let in corsa b?
  44. c20let not getting fuel to rail
  45. XE Rebuild Advice/Spec/Shopping List
  46. corsa 2L ecotec
  47. F15 Gearbox (NOT CR)... some info needed
  48. 2 ltr nova shafts?
  49. Noise from Pass. side front
  50. Calibra 2.5 V6 Red top
  51. nosels
  52. C20XE
  53. Omega V6 Starter Motor removal?
  54. Photo guide: X16XE Corsa GSi idle control valve change
  55. oil feed pipe
  56. z18xe cams n remap
  57. Calibra Fuel Pipes - Part From Vauxhall????
  58. Speedo Help!!!
  59. gearbox noise
  60. Vectra-C Cambelt or Chain?
  61. redtop wont start
  62. vectra clutch issues
  63. ABS Help Please!!
  64. cleaning idle control valve and throttle?
  65. any diesel experts?????
  66. EDS Phase 2, Saab Red Injectors?
  67. Tapping from the LET
  68. Throttle Bodies on a LET
  69. Changing manifold on an XE corsa...
  70. Use c20xe M2.5 cams in an M2.8
  71. changin dizzy to coil pack on redtop
  72. fault code 93!!!!!!
  73. Problems, Car Cutting Out
  74. what gearbox do i have??
  75. let pistons rings
  76. 1700 td gm engine and box
  77. xe corsa problem (underpowered)
  78. F10 or F13
  79. internal or external
  80. Lambda Sensor?
  81. Flash Codes Vs Full Diagnostic
  82. Noisey tappets after a track session ?
  83. !turbo recon! anyone now someone good
  84. Cav Fuel Pump Relay Location
  85. p0420 fault code
  86. Dispac XE in Nova - No spark
  87. crank sensor 8V and 16v the same??
  88. twin 40s on a 1.2...
  89. Fuelrail problems ?!?!
  90. Vox-All - Inlet Manifold Version 2............
  91. C20XE on Carbs, No Spark, Any suggestions ?
  92. Witch spark plugs for c18xe engine with turbo?
  93. 2l 8valve Turbo- 7 PSI boost- what bore exhaust???
  94. V6 Gear box onto C20Let ?????
  95. fitting a 2ltr 8v in my nova
  96. would this cause an oil pressure drop
  97. Open vs Locked differential
  98. Nova engine into corsa wiring
  99. bigger injectors?
  100. Viper on a LET?
  101. Plastic thing under gearstick snapped - no gears (astra mk2)
  102. replacing dizzy on XE...
  103. XE cams in a LET
  104. Smoke from my oil catch tank?
  105. adjustable fpr
  106. LET Idle
  107. nova driveshafts
  108. z20let/c20let pistons
  109. Apexi AVCR settings
  110. XE on bike throttle bodies(HOW TO?)
  111. 20seh Camshaft Question
  112. corsa turbo build
  113. Will this fit a Calibra 8v...
  114. C20XE Conversion !! Help !!
  115. Spinning a shell
  116. Standard LET KKK Turbo v's Hybrid KKK unit
  117. Z20LET coil pack same part as 2.2 ?
  118. 1.8 vectra
  119. problem with dump valve
  120. Fuel escaping from filler cap
  121. Problem whit high idle on c20xe
  122. Corsa C20xe drivehsafts HELP
  123. redtop fuel pump
  124. torque setting
  125. c20let oil leak
  126. Cam belt snap on c14nz
  127. '92 Astra 1.6 GLS Auto - 'Box Fuse Blowing
  128. fiat bravo problems SOMEONE HELP PLEASE
  129. v6 with no pas or a/c belt help
  130. fault code reading on a corsa 1.0, how?
  131. V6 Calibra not revving past 4000 - 5000 rpm
  132. redtop startin problem ( help )
  133. oil pump
  134. Whats the difference between egc and egr valve?
  135. f23 box info needed
  136. cav turbo tapping when warm...
  137. help wanted fitting a 2.5v6 in a 1.6 8v
  138. Driveshaft spacer were from
  139. spi to mpi
  140. 3.2 cams in to a 2.5??
  141. cooling pistons
  142. Setting F28 Linkage
  143. Bottom Pulley on LET Nova
  144. tubular manifolds
  145. Clutch and pressure plate advise for Astra gte turbo "LET"
  146. 1995 vectra 16v
  147. Its LET go!
  148. Astra/ cavalier selector in a nova.
  149. wiring help C20XE
  150. v6 into corsa b. how hard?
  151. Hello what kind of garett is it?
  152. 20seh cool running thermostat????
  153. f28 diff bearings
  154. x16xe strange idle
  155. does anyone have a pic of c20let standard pistons
  156. corsa b ecotech problem
  157. 1998 x14xe corsa problems
  158. C20XE Dispac ECU Code
  159. Ecotec serpentine to v-belt setup
  160. C20ne Injector Size
  161. LET or XE on Tb's?
  162. spark plug gap
  163. 350bhp on standard let bottom end
  164. x14xe ecu
  165. Sloppy Gear change/lever
  166. Wheres the powercap or sfi box?
  167. LET cam box baffle, sealant or no sealant
  168. rough idle on astra mk3 gsi
  169. whats gear boxes fit ???
  170. what gearbox does a manual 3.0 omega use
  171. Why is my xe smoking??
  172. Clutch and flywheel swap for Calibra C20XE
  173. Does this sound ok?
  174. Fitting twin webber 40's...
  175. xe holding back
  176. C16XE
  177. Really strange misfire @ 21psi
  178. 1.4 8v tourqe settings
  179. Battery died, dash light not lit
  180. nova c20let exhaust size
  181. Corsa 1.9 Diesel Block
  182. Ecotec Question?????
  183. best plugs for ph2 let
  184. c20xe coil wiring
  185. let wont idle
  186. nova sr engine
  187. 87mm headgasket (c20xe)
  188. Fuelling a C25XE in a Mk3 Astra
  189. 2.0 16v Calibra
  190. vectra V6 sump bolts
  191. F28 into corsa questions!! Help
  192. rpm in 5th , diesels
  193. HELP!!!! speedo signal problems
  194. reconditioned engines 20xe
  195. What belt to use with X20XEV, single V setup
  196. Distributer Vacuum Advance, Question
  197. Using a Rocker Cover Breather Filter On A C20LET Instead of A Catch Tank?
  198. clutch release bearing?
  199. x16xe burning oil
  200. converson
  201. c20xe nova mk1 aaaaahhhh
  202. C20XE F16 to F20
  203. F23 gearbox into a cav turbo. Impossible?
  204. C20 LET
  205. Spec some cams for me!!
  206. webber 40's
  207. Fault Code Vehicle Speed Sensor??
  208. Dam I Need A New Hobby.
  209. non vauxhall question, vw polo ht leads.
  210. Gearbox issue about 1.7DTi Corsa 122hp
  211. Cav turbo smokes from startup some times...
  212. redtop fault code help
  213. Tell me what oil for my xe??
  214. Line XE Cams up
  215. cams on 20xe
  216. Oil catch tank C20XE?
  217. Rattle After Acceleration
  218. Its in!! Just! Woohoo!
  219. 20xe timing belt
  220. A quickie - CTS location on a 1.6 16v
  221. corsa xe conversion
  222. Most FWHP from a C20XE on standard inlet..
  223. v6 and f20 drive shaft info
  224. V6 Fuel Pressure Regulators
  225. installed my cat cams last night
  226. C20 LET Warm starting issue
  227. Oil smoke question (not the turbo?)
  228. ffs
  229. V6 Omega Auto engine removal ?
  230. Engine conversion dillema???
  231. ABS Problem
  232. HT leads - is a high resistance good? or a low resistance?
  233. v6 oil pump
  234. Fitting a mod chip to a 2.0 8v GTE
  235. blown gear box
  236. 16v Rods Or 8v???
  237. what can go for the xe to go in? (pic)
  238. xe convrsion wont start
  239. Help needed astra mk3 4x4 turbo
  240. boost problem c20let (help please)
  241. nova strengthening plates!
  242. fitting a c20let in to a nova
  243. chip in piston 20xe
  244. F20 Final Drive Ratios
  245. XE & C20let FPR
  246. Torque settings on x20xev
  247. thrust bearing
  248. LET missing on and off!!!
  249. f23 and f40 diff's
  250. Ive Killed my Cav Turbo time for a mad engine
