- 300bhp on phase2 and k16?
- Ecotec, 8 valve and xe blocks
- Hi all
- c20xe oil temperature question
- old isuzu diesal in to newer combo van
- C20LET boosts at 1400rpm?
- Finding out bolt thread/sizes
- Mk4 gsi wastegate/acurator noise??
- C20xe spluttering under load..
- 300bhp LET engine build
- f28 questions
- timing marks - 2.0 8v - urgent help please
- I need 300hp HELP
- c20let still not sparking!!
- Warm starting problem
- Z20LEH turbo bearing play
- C20xe engine how to get 200bhp out of it
- anyone know the part numbers of the xe cams
- Meriva 1.7CDTI BHP?
- cav mk3 rear wheel bearing disc
- 3" Top hat
- z20let vaccume diagram
- saab flywheels?
- Clet phase 2. Whats required?
- Saab Engine into a vectra b 2.2 51 reg
- arp torque settings
- C20LET: balancing head chambers how much difference is allowed between chambers?
- my 1.6 Y reg astra is jerking when taking off
- Z20LEH oil pump
- Replacement Exhaust Astra G 2.2
- Vectra SSRI 130 ECU
- converting a y26se to run on a x25xe loom/ecu
- C20xe non starter :(
- f23 lsd/ fitting
- tuning mk4 astra van
- c20let missing on boost
- whats the best way to start tuning a astra coupe turbo ??
- 2005 astra 1.7cdti engine swap
- Programmable ECU for LET?
- let turbo coolant pipes into nova
- Xe oil pressure - low or???
- kkkk16 turbo banjo bolt
- burning smell coming through my vents on my astra coupe turbo any ideas
- c20xe turbo
- Electronic boost controller
- mk3 gsi hand brake cable question (5 stud)
- Z20LET timing problems
- Z18XE starting issue
- x20xev will it fit ??
- Turbo reconditioning
- White smoke upon starting (2002 Diesel)
- manifold xe
- X16xe no power
- c20xe loom change (what ecu to use)
- egr valve
- Xe pistons at what price,
- c20xe starting pain
- Corsa Sport Engine Noise
- Corsa B 1.6 sport missfiring
- what fuel pressure should a std c20xe be running?
- what are peoples views on this c20xe chip?
- C20LET corsa offside driveshaft issues
- Cavalier GSI C20XE running temp?
- C20XE very strange problem with the oil pressure
- c20xe no spark problem
- Sniper or Sportex backbox?
- programable ecus? help
- can anyone help running out of ideas 1.3cdti 05 combi van no boost while driving
- ebay servicing kit??? is it worth it?
- De-restricting and Drilling Airbox - How to Guide
- ARGH... XE/LET Clutch components
- help please
- Clutch and pressure plate upgrade!?
- LET Head scratches - to skim or not to skim?
- 20SEH crank into 20XE... Please read.
- EGR 5p Mod?
- o2 sensor
- Cts issues on late type C20xe
- phase 2 c20let idling up and down and jerking/hesitating at low revs
- corsa 1.7d not starting
- mk3 astra 2.5 v6
- Vectra 3.2 V6 2003 problem
- early 20xe - idle 200-300rpm anyone had similar
- XE Early Oil Pump
- C20LET burning oil when left idling
- Cometic gaskets and squish rate
- vectra cdti injector no.3 problem...
- astra mk4 F17 box problem?
- C20let misfire
- XE Head Gasket
- C14nz corsa b backfiring at motorway speed?
- 2 plugs 'blacker' than the other two & FuelParts Coil Pack???
- What can cause a drop in boost pressure?
- best uprated c20xe cams and pulleys
- idling issues 20seh
- astra sri turbo 190 smokeing
- tx autosport cam pulley for zlet/leh
- 1.7CDTI Astra Low power/ cutting out/ whining
- Astra G Oil Leak
- dumpvalve not working c20let
- nova turbo f28 box - which selector?
- To use a ported KS head, or standard coscast?
- C20XE REDTOP cracked block, can I build into a C20NE
- Mk2 & mk3 xe exhausts the same!
- C20XE later Coilpack engine, your overfueling problems that are now solved
- c20ne oilcooler on e16se. possible?
- C20let knock sensor probs
- 1.6 Corsa Engine Differences?
- porting polishing let head inlet and exhaust
- Early & Later C20XE lambda sensor - is it the same?
- Missing oil pressure after engine overhaul
- New XE Cam caps?
- c20let iat sensor
- C20LET metal water pipe renewal.
- Astra mk4 gearbox change f18 possible?
- C20XE Porous Head Mod Question
- c20let sensors
- Ecu identification seh ser ne etc
- Gearbox Help Please
- Port matching exhaust manifold?
- corsa let max fuel pressure 3.0bar
- Astra MK4 2000 no heat, no engine temp reading, white smoke blowing!!!!!!
- c20xe/c20let inlet manifolds
- identifying a standard let exhaust valve
- C20xe flat flywheel step?
- Engine replacement ideas/help please.
- external wastegates
- early/late c20let head issues
- 16xe rocker cover??
- C20xe not firing
- Fault Cylinder 3 misfire - possible cause?
- what bolts for pressure plate to flywheel?
- C20let tensioner same as another engine?
- C20XE and C20LET stock camshafts - data of timing
- External wastegate vacuum
- Which Cam? 20seh + R1 Carbs
- cleaning top of the block for cometic headgasket
- xe breather hose size?
- water hoses c20let corsa b
- 1.6 SXI what can you do to the engine?
- z20let stalling
- Vibration from front offside when taking foot off gas
- external wastegate sticking open
- f28 Gear oil
- Diesel Gearboxes........
- Modding a Z20let engine
- astra mk4 1.8 conversion to a c20let ???? i need help please :)
- Walbro pump Clet
- c20xe and c20let clutch & fly wheel
- Z20LET into Mk3 Astra - Throttle
- Head gasket
- Calibra 911 Turbo ?
- Need help with my vectra please
- c20let problems
- wanting to fit fse valve to gte
- Rear lambda sensor Z20LET - how to?
- Coscast head= Porous ?
- Fse
- z20let coupe blue smoke, oil burning smell and noises
- Fault 16 Knock Sensor C20XE
- C20xe air flow meter question
- Need Help! on my corsa 2.0 8v C20NE
- Corsa losing coolant help
- c20let head gasket arp studs
- 1.0 corsa-B poor starting when warm
- vacuum for zlet dump valve
- non vaux gearbox question
- Tial f38 external wastegate
- who is running a cometic head gasket successfully
- Corsa GSi Air mass meter quesiotn. urgent help please
- Accelerator Pedal wiring loom? Z20LET?
- Astra MK4 Z18XE Erratic Idling
- 4.18 or 4.5 cwp for f13
- c20xe and c20let bottom end???
- corsa d fault codes?
- gearbox whine
- Is this a corsa isuzu engine?
- Corsa c20xe alternator muilty rib belt what one to use? Pics to explain
- How much nitrous can an 8v take?
- z20let crank pulley
- 1.7 DTI - Good engines?
- 1.7dti astra estate 2001 (changing fuel pump solenoid)
- twin engine corsa
- +1mm valves on an let advantage or disadvantage
- Camshaft advice z18xe
- should a let head always be skimmed when removed or using cometic
- standard cams .....
- C20LET Question.
- nimonic and 214 stainless steel valves
- C20XE Clutches
- C20NE Problem need help!
- 2.0 8v problem
- Info needed - Foam in Fuel Tanks.....
- High voltage to injector
- Corsa 1.7DT Engine
- 20seh turbo conversion help
- vectra diesel engine light - intermittent
- X16xe engine tuning
- c20xe sagem dispack
- LET MANIFOLD -mazda MX5 OR 200sx ?
- pot type flywheel clutch fitting
- Corsa - gte wiring help!!!!!
- C20XE '96 CORSA B DriveShaft questions
- Z20LET Vacuum lines HELP!
- new vaux engines, no fuel return pipe?
- leaking abs unit
- water and oil leak
- Omega 2.5 V6 misfire
- which is better solud lifters,cams,double springs headwork and xe cams
- Corsa sport overfilling and miss firing now and again
- sick 1.4 twin port
- z20let ticking and missing slightly
- shelling a standard let block
- vauhall astra 1.6 16v head
- nova engine conversion, 2.0 8v or 1.6 16v
- corsa v6 gearbox
- corsa c20xe
- Mid throttle misfire!
- c20let code 13,22
- setting up c20let
- c20xe spluttering on low rpm help needed
- corsa red top need help cutting out and over fuelling
- C20XE wiring into 1.2 16V Corsa B
- engine management light
- coolant hoses long shot
- Drilling Hubs
- astra estate mk4 project
- AfterMarket FPR and Blank C20XE
- Bad Miss when driving on X16XEL
- F16 box
- amal valve?
- i need help identifying the make of my oil pump
- combo van glowplug symbol flashing
- Timing Belt Replacement Problem
- X14XE Rally Engine - Oil Restrictor Mod
- f28 gear selector adjustment weird problem
- Turbos EFR..... exist or not?????
- C20LET on idle what gal/h is displayed on the trip computer?
- Corsa C wont start.
- is zlet and zleh same flywheel bolts pattern?
- corsa redtop brake servo pipe
- These any good?(Oil advice)
- 1.7 td cav putting white smoke through interior vents and abs light on
- saab engine wiring help
- tuning box for 2003 1.7dti installation
- Fuel injector o rings?
- Turbo help.
- Converting a cavalier from c18nz to c20xe (redtop).
- Vauxhall Cam Chain Engines Using Oil
