: Engines and Transmission
  1. GTE 16v - The Fuel Pipe from Tank to Pump.
  2. CIH Engine parts needed
  3. astra g v6 clutch problem
  4. tigra 1.4 auto,cutting out/speedo stopped working
  5. decat and remus on a vec b 2.2 dti
  6. Advice on Ecotek Valves
  7. ecotec 1.4 tigra
  8. c18xe vs x18xev block
  9. Bike Carb's
  10. upgrade
  11. piston movement
  12. How to brands make the torque flat on diesels?
  13. Variable inlet on Z18XE
  14. Astravan Slight oil leak
  15. f23 few questions
  16. 2.2 DTI On F23
  17. Mk4 astra engine swap
  18. Vectra VXR
  19. LS1 cooling system info needed
  20. early or late xe info needed plz
  21. xe / let inlet
  22. c6 calibra into mk3 astra
  23. x30xe bore ware what done this damage? pic inside
  24. corsa sport misfire and erratic tick over
  25. C20xe camshafts
  26. C20xe overfueling and cutting out
  27. fuel pump
  28. what head gasket (c20let)
  29. what cars can i get an ecotec pipe from?
  30. Vextra GSI miss fire, usual things tried
  31. twin 40s need some advice
  32. Mystery oil loss
  33. astra g twin port needs engine
  34. corsa sport problem
  35. FLYWHEELS For Corsa B GSi
  36. vectra v6 cutting out.. help please!!!!!!
  37. c20xe rocker cover breathers??
  38. LET standalone management- Idle control valve ?
  39. What's this on this exhaust manifold?
  40. GT3076R restrictor question
  41. this f28 linkage fit my corsa b?
  42. tuning
  43. 1.8 smallblock tuning
  44. What oil in C20LET??
  45. bolt snapage
  46. C20let aiming for 280bhp- std injectors?
  47. superchips???
  48. Bike carb fuelling
  49. Z20LET making funny noise
  50. Fuel regulator ports
  51. zafira gsi feels underpowered
  52. 2.0 calibra non runner
  53. Exhaust wrap how many layers..
  54. is the turbo shot???
  55. c20xe corsa
  56. timing belt tension LET
  57. whats best engine for mk4 van
  58. Cv joint???
  59. c20let coscast vs GM
  60. Running in a C20let?
  61. 2000 tigra
  62. mk4 astra 2002 sxi 1.6 16v keeps stalling
  63. Z20let into mk4 sxi help pls
  64. c20let transmission advice
  65. diagnostic socket problem (c16xe with 16-pin socket)
  66. Anyone clued up on fly-by-wire throttles?
  67. snapped gear linkage ?
  68. f16 speedo drive? press off?
  69. Broken Fuel Pump Symtoms??
  70. C20xe Rocker Cover Gasket
  71. c20xe corsa, should it be faster? Help!
  72. c20xe corsa, should it be faster? Help!
  73. head gasket and clutch change x14xe
  74. a belmer trying to wire his car up
  75. Corsa sport 1.6 16v engine conversion out of 1.6 16v astra
  76. c20xe/let into diesel mk4 astra
  77. xe dis pack ending , what does the cam sensor do
  78. Smoking Z20LET
  79. Different F23 Gear Ratios
  80. wideband readings with external wastegate
  81. 2.2 head gasket
  82. help!! c20let is arching and sparking !
  83. what engine monuts do a need to put a 2.0 8v into my corsa b ?
  84. Mum's Corsa D any real tuning potential ? .
  85. What drive shafts will my c20seh have?
  86. Time to warm up the wallet (C20LET build)
  87. What head bolts to buy?
  88. Head removal x20xev
  89. Does 8v sump gasket fit a 16v?
  90. Who has run engines without a cambelt cover?
  91. any 1 selling a cheap c20xe ?????
  92. Codes
  93. x30xe crankshaft position
  94. car jerking
  95. corsa gsi starting problem and battery light
  96. corsa 1.2-2.0 8v conversion
  97. lambda sensor
  98. c18xe corsa drivshafts!!!!!!!!!!!!!
  99. nitrous
  100. astra mk4 c20let
  101. Diesel pump failure - hard to fix?
  102. xe cam c20let
  103. Retarding?
  104. external wastegate
  105. Zafira X16XE P0170 Fault Code
  106. QED bodies throttle linkage
  107. Corsa B with f28
  108. Tb's and nitrous?
  109. Strut Braces
  110. can i take the engine out like this?
  111. is it all rite to power wash a gearbox ?
  112. knock sensor????
  113. Astra 1.3 Running like crap
  114. Fault code help
  115. Cav SRi back box...
  116. C20let Turbo question
  117. 1.2 8v corsa 1996 running problem
  118. help needed c20let transmission
  119. c20xe wont rev above 6k
  120. Corsa b 1.2 spi died, over fueling?
  121. Astra coupe radiator.
  122. corsa f28 quickshift
  123. Exhaust system-help?
  124. Tech2 Cruise Control Vectra 2.0DTI
  125. Megasquirt help needed
  126. equal length driveshaft question
  127. Cav 1.7td into Calibra?
  128. does anyone know if you can buy piston rings seperately?
  129. where is the best place to get service parts for 2.0 8v?
  130. r reg 1.7td astra van non start!
  131. Oil sump removal
  132. turning up pump and boost on isuzu 1.7 td
  133. tiger seal or sikaflex??
  134. best place to get porous head mod done
  135. How to tell how much an XE/LET head has been skimmed?
  136. x20xev turbo conversion
  137. replacing crank seal and/or oil pump seal
  138. how many people run EBAY intercooler cores?
  139. Bypassing internal fuel pump to fit R1 pump
  140. V6 (Z32SE) Tuning Parts and Info
  141. Engine stalls then won't start
  142. Refitting head on old block?
  143. Is Amal Valve essential?
  144. Witch Is Better
  145. c20let block on 8V head?
  146. Z18XE Help
  147. corsa turbo wheel bearig trouble!
  148. x14xe cams
  149. c20xe to c20let
  150. C20LET Std Actuator
  151. Hard getting into 4th
  152. c20let problems
  153. manifold glowing x16xe help
  154. Nova turbo wont get fuel?
  155. Power cap for my xe.
  156. Can Anyone Identify This Sensor?
  157. vectra 2.2 eml on again
  158. cutting out at idle, and missfire when puling away
  159. vectra v6
  160. x16xe limit ..
  161. rwd conversion
  162. Cylinder head torque settings
  163. 2.0 Lt number 1 piston
  164. C20XE, blue smoke and petrol in oil. Cause??
  165. corsab motor help plz!!!!!!
  166. calibra 3ltr conversion
  167. c20xe problems
  168. soild engine mounts?
  169. piston rings for wossner pistons , short question
  170. Converting Early C20LET to Late Timing Belt Setup
  171. New clutch am I wasiting my time?
  172. Corsa B 1.2 16v bent valves? (X12XE)
  173. carlton 3.0 24v flywheel problems
  174. fuel reg
  175. corsa inner cv jionts c18xe
  176. Diesel tuning in a mk3/mk4 astra van.
  177. Diesel won't start
  178. think iv got a sticking lifter
  179. Possible hgf opinions please!!
  180. M32 gearbox into my mk4 astra GSI
  181. xe/let thread sizes
  182. no oil getting to top end of engine
  183. do you have to change head bolts everytime you remove the head?c20let
  184. XEV cam in ZLET
  185. Vxr piston
  186. C20XE SBD Manifold
  187. Spongey Gears,
  188. unmatched engine
  189. f20 and f28 gear linkages
  190. Does anyone know if these exhausts are the same?
  191. noise levels/sound of 3" on box system?
  192. c20xe internels
  193. c20xe lack of power!
  194. Having car problems....
  195. will this ebay head gasket be ok for my let?
  196. how hard is it to fit a c20xe (redtop) or a c20let engine
  197. whats needed c20xe to bike carbs
  198. any 1 no if a z20let turbo will bolt rite on 2 a c20let
  199. click click click... c20xe
  200. dbilas dynamic inlet on x16xe
  201. c20xe - No spark when warm
  202. Thoughts on adapting C20XE to fun on bike injection throttle bodies
  203. Mains Shells
  204. Spark plug socket
  205. front and rear diff ratios
  206. vectra sri fuel problem? helllpppp!!!
  207. corsa c20let gearbox spacers
  208. engine mounts
  209. 1.7 d combo van starts but wont run
  210. c20xe or x20xev injecters ?
  211. Rs turbo plugs bcr8es in phase 3 turbo ya/na
  212. Corsa C faulty ECU??
  213. fse regulater on xe?
  214. anyone know what they are doing with carbs?
  215. astra coupe z20let 124000k?
  216. What the doosh is this?
  217. 1.7D combo Van to Redtop HELP !
  218. CAR DIAGNOSTIC plug for vectra
  219. astra mk4 c20xe
  220. 1.2 8v to 1.6 8v converison - asap Please
  221. Calibra 8v - Adding turbo?
  222. what do you think about these??
  223. C20LET into an Astra Van MK3...?
  224. Calbra Brakes On To Corsa :S
  225. hesitant, am i right in thinking . . . .
  226. steering rack gaitors
  227. meriva recommended oil?
  228. corsa c20xe induction?
  229. x20dtl fuel pump fit y20dth????
  230. XE. Block - Gearbox gasket?
  231. c20xe nova problem!
  232. c14se ECU same as c16se?
  233. one c20let rod damaged. can i just replace one or will i have to get a set?
  234. 1.4 sri corsa c
  235. 1.4 sri corsa c
  236. Piston sizes??
  237. 1.7cdti corsa c which engine?
  238. z10xe help, timing chain problems
  239. calibra turbo AFM help please
  240. XE running on bike carbs. which pump?
  241. Coscast Head Skimmed Almost As Much As It Could Be
  242. corsa b combo 1.7d gearbox help
  243. Vectra B Fuel Problem
  244. Which size drill & tap for gearbox ?
  245. Coscast Head Onto Gm Head Block
  246. F23 diff in F28
  247. EPC request
  248. Dump valve - which one?
  249. need help bad on my xe!
  250. SRi power help
