- Dizzy less XE motor FPR.
- dbillis inlet and cams
- power needed!!!!!!!!!
- Wanted Amal valve!!
- Calibra Turbo HELP Please
- Astra mk3 fuel lines
- differences in 4x4 shell and standard shell
- loud nasty tapping noise?
- Best way to port a head?
- Box on 280bhp corsa
- Ooops- Nova Alternator 2.0 Clearance
- c20let into nova what conversion kit?
- engine doesn't fire up always on first turn of the key
- astra mk3 turbo Larger intercooler
- c20let sump fit on a c20xe
- v6 cav not starting
- Tech 2 - Laptop reader..Any Gen
- HELP Non return Valve
- best clutch for c20let
- ARP Rod Bolts
- Turbo Broken
- Dumpvalve Or Not?
- what sort of power ca i expect this E16SE to make?
- mk2 digi dash into mk3 astra
- EGR valve?
- c20xe want to put carbs on wat do i need
- Corsa-B axle to Nova?
- Tech 2 help
- C20XE coolant circuit pipe mystery...
- f20 problems
- 1997 VAUXHALL Astra 1.6 LS Estate
- nova xe clutch change
- where to get a charge cooler pump?
- has anyone removed their ABS system before?
- LET Engine Number - Something a bit odd?
- ford cosworth grey injectors (403's).
- No Spark - LET?
- Pro's and con's of Throttle bodies
- head gasket gone ??
- Z20LET same casting as LET round the back?
- sodium filled valves
- How to split a CV joint?
- Astra MK4 intercooler
- bit of a prob.
- standard boost in bar for let
- what gearbox can i use?
- lamba sensor prob
- c20let boost problem
- 1.2 c
- clutch slipin since put new box in
- 2.0l XE big wing steel sump for rwd application
- one thing left for 2L 8v into mk3 astra LS... loom on battery side!!
- SPI Cav to XE conversion fuelling question
- Z20LET VXR TURBO FITMENT QUEREIES! (plus why does my let turbo unit keep failing?)
- Dis Pack to Dizzie Heads?
- Glazed / Shiny cylinder
- Astra GTE Radiators
- Exhaust!!
- c20let under piston oil squirters
- took the gamble and lost... :(
- XE Misfiring - DTA ECU
- engine tune up, help needed
- Is this any good ?
- corsa gsi
- quick xe wiring loom question..
- help needed. head fitting went wrong!
- corsa b tappets
- 1.7td drive shafts on a 1.8ls?
- nova c20let conversion advice
- 4x4 Tranny box problems (on behalf of a mate)
- which clutch
- 4x4 astra
- c20let with a f18???
- supercharged
- Conversion Price
- c20let weight?
- Inlet flow
- MBE 225 Map
- v6 missfire !!! HELP !!!
- Idle Control Valve 2.0 LS Vectra help 1998
- piccies of the broken valve guide or DET
- build manual
- vectra exhausts
- Head job has got complicated C20XE
- help needed
- Exhaust for my C20LET
- Vectra GSI Oil Filter
- Corsa coolant temperature problem
- ealry xe pistons into late xe block
- Deglazing or honing...is it needed?
- Nova engine conversion questions.
- 3.0 v6 cams
- Redtop firing spark plugs but not injectors
- KKK26 Turbo Upgrade
- This site appears to be a bargain for sensors
- deisel tuneing
- Unknown plugs on loom
- SAAB 1.8T into an AstraG?
- reverse is now 1st gear
- corsa turbo conversion fueling-help!!!!
- Car cutting out randomly?
- ANY IDEAS?
- Astra G powerflex front engine mount
- help
- Early/Late XE ICV's same or different?
- over fueling (c20let)
- advice on how to make my 1.8 16v go better
- std c20let oil cooler is it controlled by a thermostat
- C20LET cut out
- c20xe and c20let block difference
- Multi-v or double pulley c20let
- Vectra B V6 differences Question
- C14SE big end bolt torque setting
- Trying to find ICV on my C14SE (picture included)
- Mayo
- just got myself an XE advice required
- Z22SE Ignition Module
- valves meet pistons
- Amal vave
- which box for my astra let..
- c20xe headgasket failiure.....
- phase 3 c20let help needed pls
- Drive shafts can some one explain please ?
- A dizzy weekend
- C20XE idle problem...
- inner CV
- Vectra C 2.2 SRi suddenly does not have 100% and has a vibration
- Nitrous With 40's
- Raspy exhaust
- Castrol magnetec 'for fords'
- help needed finding rattle source in engine area
- C20LET hot start valve
- replacing xe with let
- Vectra B/Astra F23 driveshafts - interchangeable?
- Bolt size when tapping out a f28 frear mount?
- XE Water Pipes
- Did It Again.
- hot airfilter
- let idle problem
- 1600 8v
- Definitive Service List
- Ph2 not boosting right
- Sandwitch plate for senders.
- v6 into astra gearbox
- Amal valve
- V6 help!
- head removal help
- XE conversion shopping list
- Engine mods for a MK3 SRI.
- hesitating gsi
- 1.6 16v upgrades
- any windscreen fitters in leeds?
- air filter
- driveshaft nighmaree
- c20xe bad tick over and wont rev
- Thoughts on this gadget????
- C20let - upgades and advice please!
- XE Calibra spluttering n cutting out
- Z20LEH con-rods stronger than C20LET rods?
- engine conversion
- Gearbox 20XE
- 1991 1.8 carbed cav
- Nova gearstick problem
- c20 let timing settings???
- Xe oil pressure sender thread
- R1 bike carbs fuel presure
- head gasket and water pump
- Z20LET running issues?
- v6 plenum
- intercoolers
- Air con, conected to engine revs?
- F28 Driveshaft Seal & Info?
- OIL PUMP UPGRADE for c20let
- c20let power
- 4x4 cally clutch
- Guide to removing and cleaning up an AF13 Autobox selector switch..
- 1.6 gsi wiring props :-(
- Oil on clutch / flywheel
- what box would fit a mk4 astra c20let
- C20XE idle issue
- Ignition Module
- fitting c14se big end bearings
- Smoking XE
- Fuel fittings on Mk4 Astra - are they JIC?
- C20LET cutout problem
- boost controller
- Z20LET recirc valve problem
- CV boot help!
- Paddle ClutchsW
- astra internal linkage in a corsa ?
- X12XE Fuel Pressure Problem, Possable Crank Sensor?
- "Sport" button
- Glazing
- Enlarged V6 TB
- Bike carbs/TBs on a V6??
- arp head studs - c20let - removal
- Ecotec v6 in mk4 astra
- XEV ECU/immobiliser question
- engine converstion
- vectra 1800 playing up
- any ways to un complicate the v6 engine?
- 1.7td LOW BLOW can i use an ISUZU instead
- Limited Slip Diffs
- Intercooler Piping?? MK3 Astra
- Dump valve
- boost gauge readin
- slim fan size
- Recommended engine fitters in Swansea
- Help! Tigra Cam belt snapped! Timing marks needed!
- Knock Sensor code 16
- corsa c20xe runin funny
- F18 gearboxes
- c20xe corsa gear linkage??
- c20let running prob with new chips/reg/injectors
- fuel in oil
- c20let compression psi
- is there such a gear box as the f13 ???
- Astra Mk4 1.6 16V Sport (Ecotech) engine q's:
- Corsa xe conversion
- z20let turbo ?
- VXR injectors on a LET
- Bosch 044
- Air intake hosing
- Which R1 Carbs?
- not boosting right on LET
- pre load on quafie ATB diff!?!?
- let miss firing and this is what i found
- Astra Coupe Turbo Z20LET Running Problem/Management Light
- z20leh injectors on a 20xe
- 1st Gear switch frigged out??
- Bike carbs on xe
- f23 gear box mk4 astra
- Did the C20xe/LET have two different CAM covers?
- engine damper
- 1.4 sr turbo what carb?
- changing to a bigger radiator on a cally turbo
- Induction kits?
- Astra GSI Exhaust help - 2 / 3 box, cat replace
- Vivaro---lack of power! wont rev up past 4000
- 299.76bhp 302ft lbs phase 2 corsa :)
- General Running (C20XE) - Flat (ish) through entire rev range
- C20Let black smoke when fired from cold
- Standard Crank How much bhp ?
- DTi CDTi Issues anyone...?
- What ECU should i run??
- Clutch travel
- c20xe in to mk3 estate
- F28 question
- F20 Box diff filling
- torque settings needed (help)
