- Replacing sump.
- c20let steel rods - why such a price vary?
- Engine misfire when under load?
- help with c20xe in a kit car
- x20xev cylinder head
- peugeot 106 engine swap
- part no. oil squirters?
- Astra Mk3 Turbo Project stuck already.
- corsa secondary air injection pump
- nova v6 requirements
- turbo confusion!
- HELP! Ecotec 2.0L Awful rattle..
- NO EML light??
- c20let fault code
- Dump valve
- c20let astra g van
- possible fueling problem with 'let ??
- c20let boost issue
- Throttle position sensor??
- Help Please???!!!
- x14xe, any advice oh how to....
- calibra v6 hgf?
- height of a standard c20let head
- need help
- First time removing a c20xe from a mk3 astra, tips and advice needed
- The Vauxhall 3.2 V6?
- Which Rad, help with part numbers
- c14nz manifold pressure sensor location!
- 8v waterpump question
- sabb turbo engine how different from let?
- f20 gear box trouble
- Skyline zaust on an astra??
- Engine type???
- amal valve set up??
- XE flywheel fit Calibra V6 ?
- bit smokey
- help seting up gears please
- Corsa direct to box linkage
- C20XE strange noise
- gearbox pic any1 help
- Excess pressure in coolant system after rebuild?
- LSD gen needed. Brand ive not heard of
- FMI £69, what u think..
- 1.6 nova gte engine won't start, any ideas?
- Clutch arm pivot on F18
- f20 gearbox problem
- high idle speed
- Sports mode stays on?
- help needed !!
- c20 let wiring loom
- 2.5 v6 torque setting's please(ASAP)
- head torques and angles for x20xev?
- Whats is this?(again) Pics
- What are these engine parts and vac hose? Corsa GSi (quick reply plz!)
- C20NE engine water overheating..engine ok at the mo?
- Is my clutch or gear box broken?
- Problem with my 1987 Kadett
- One cylinder not firing as it should?
- C20LET only running on cylinders 1 and 4??
- Inlet Airpipe Size
- x16xe c16se oil pumps
- polished pistons
- Range Rover Intercooler Fitted With Pics
- nova xe suspension setup.
- air flow meter 20seh
- Which Omega Pistons?
- 1.6 16v....flat as a witches tit
- c20 xe conversion
- overfueling when cold
- X20XEV in a 97 astra van HELP!!!
- Warmed up C20LET no cold start- blue smoke when revved at stand still
- Intercooler to big??? c20let
- xe into a low-blow van
- Astra Diesel Van to Petrol engine conversion
- what do people think of......
- Fitting clutch on a corsa b sri 8 valve
- Increase Power In 1.6 Sport ?!?!
- c20xe misfire
- power steering
- What all connects to a Transfer Box?
- 2001 1.0 corsa wiring diagram needed????
- Z20LEt/C20LET Cylinder Sleves...Were from?
- Nova into Corsa
- XE Flywheel, which one have i got??
- want my car to be quicker
- Knackered Turbo?????
- C16XE query (loom mainly)
- stuck with conversion
- such a thing as a thicker head gasket??
- xe piston size
- no spark on my DIS 2l 16v
- Dump Vale Setting
- Quick question on doing a compresion test
- the best cone filter for my let?
- Ecotec starting problem when cold with ECU light/limp mode, yet fine when hot?
- welded rear diff's- what they like to live with?
- uprated fuel pump and injectors c20let
- cav front shocks on mk3 astra
- cally/cav engine mount on astra
- boost on1.5td nova?
- Pinking..
- xe keeps cutting out!!!
- my slow car
- will this clutch fit my car?
- quick question re: e16se steel rods
- problems with my Diesel Turbo!!!
- power steering fluid leaking..Help!
- f16cr or f20
- mk3 gsi bumper removal & intercooler fitment
- c20xe big bhp
- Mk3 Astra 1.6 auto box prob
- need info on the F28 gearbox please
- Recommend me a Manual Boost Controller
- strong fuel smell 1999 corsa 1.0
- vectra 2.5 v6 conversion
- LET Plugs/misfire
- c20xe ongoing problems...
- Limiter on a combo
- can i use xe rad for let??
- crank shaft sencor
- Removing Mk3 Astra Fuel Pump
- Cant Engage 5th Gear Mk3 Astra
- corsa b xe no 5th gear???!!!
- nova 1.2i cam belt??
- C20LET- Blue smoke when warm and revved
- 1.4 8v spi to 2.0 8v
- What's the small plug/box next to the header tank on a Corsa GSi?
- Fuel Questions For C20let
- LET - recon turbo smokes and leaks oil?!
- Realistic revlimit for an XE on hydraulic lifters?
- starting
- Pics Please of ICV on an XE
- overfueling c20let
- What is this? (pic)
- XE no fuel
- EGR Valve problem???
- rwd conversion in astra
- f20 speedo ring in an f28?
- GM V8's
- Corsa Sport Driveshaft 4 C20xe Conversion
- head gasket?
- vectra c20 let question
- help fitting c20xe into corsa-c
- has anybody fitted a c20xe into a corsa-c?
- Random intermittent behaviour Corsa B X14XE...
- Fitting a GTE digi dash into a Corsa B? Help?
- Fitting a GTE digi Dash into aa Corsa B??
- calling all 2.0 8v corsa owners
- finally the c20ne started in my astra,, by hotwiring the FUEL RELAY wire
- astra coupe turbo abs/speedo sensor
- XE/LET rear plastic water pipe - different types??
- Rad Weld??
- C14se injectors
- f28 in a corsa- rear mount?
- C14SE Tappits and valve clearences
- Panel or cone what is best???
- misfireing let
- astra G using abit of oil
- xe tapping/rattling
- Stuck on 2 wires
- Gearoil F.A.Q'S
- Coolant Temperature Sensor? Symptoms
- xe and let exhaust gasket
- Timming Tools?
- LET - Injector voltage low
- very smokey 1600 ecotec
- v6 exhaust manifold
- corsa c20xe slight overheating
- Deadlock problem
- None Vauxhall Help needed.....
- c20let fault code
- cav v6 redtop power?
- Wiring loom question
- Advice needed on corsas and astras earth to starter!
- x14xe decat with 2.25" exhaust?
- Cavalier Ecotec Engine - More help needed!
- kkk turbo repair kits?????
- Astra let exhaust manifold to mid box
- cav running gear astra mk3 help
- fuel stavation? revs dying when comin off the clutch?
- help
- Is this a fake Sard ?
- Corsa GSi stayed from execution... but what is the problem? Mystery...
- C20LET chips from France/Europe
- Fluctuating Boost
- F20 gearbox, whining and vibrating!
- Pros and Cons using a Kent cam belt and a stock1
- C20XE top end rebuild problem :( help plz.
- 4WD Nova ??
- help with clutch on a xe/let (where to find one)
- Cavalier 1.7td / F18 linkage.
- Is there one?
- Very funny problem
- F20 box ratios - how to tell?
- Cambelt on a redtop -technical guide?
- c20let engine oil
- Brown 98 ron octane plug
- Finding 2.5 inch pipe for astra let
- twin 40 carbs
- twin 40 carbs
- cooling hoses
- Cold start problem C20LET
- just quickly
- Vauxhalls name for amal valve?
- WTF I dont get it?
- EGR and Z12XE
- 1.6 16v astra mk 3/4 bottom end the same???
- 1400 16v to F13 gearbox
- Advice please on engine mods for vectra gsi 2.6 v6
- 1.6 Supercharged (yes or no)
- red looking oil on sparkplugs?
- Converting Vectra GSI to a Diesel Engine......
- Too much boost!!
- c20let boost leak
- 20xe Hall Sensor Probs!! (dizzy)
- Swirl pot
- C20let flat spot
- Quick question regarding airfilter and turbo
- 3 bar fpr & cream injectors
- Chip Or Remap?
- Suitable oil 20seh
- Crank Sensor
- 1.4 SPI head noise
- 3.5 Bar Regulators where from
- Please Help: Z20LET Stuttering and Jerking at half throttle
- C20LET Plugs
- What Cams For My Spec????
- astra intercooler + pipework
- nova cv joint failure and gear oil please help!
- calibra turbo help
- Voltage when running
- convertin 1.8 carb to MPI?? possible?
- Which XE clutch do i have?
- lamba sensor and sump c20 let
- bottom end rebuild...prices??
- calibra turbo rad
- Clutch clips
- which plugs do u use on phase 2
- Shocking..earthed a live on the battery
- XE onto engine stad...what bolts
- f28 removing it out of my corsa! best way?
- C14NZ Basic Mods
- Emissions
- xe removal attn benn
- XE REBORE
- advice needed URGENTLY:C20XE headbolts
- What is it??
- Can you get 22 spline driveshafts on a F13 gearbox as standard?
- ASTRA GTE Transducer Needed for C20XE Conversion
