Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. c20xe dizzy type not sparking
  2. Random engine problem
  3. any Pug experts? need clutch lever removal help
  4. bulkhead mod when fitting 20xe into corsab
  5. C20LET steel Rods
  6. XE cracked head issues....
  7. gear stick play???
  8. TB Kit BHP
  9. Overboost Issue
  10. another miss fie question
  11. Corsa 2.0 XE Help Please
  12. twin 45s on xe
  13. k26 regal stage 3 race turbo
  14. can i use this manifold on my LET?
  15. What can i use to clean piston faces?
  16. c20xe turbo
  17. rebuilding a coscast
  18. f28-fitting a f20 speedo ring
  19. 16v brake conversion
  20. New lifters to go with Piper 285c cam?
  21. Strange plug on a 20XE loom?
  22. 1.8 block?
  23. Fitting F20 diff bearings
  24. selecting gears
  25. f28 or f20??
  26. Omega Auto -> Manual gen
  27. can ARP rod bolts be used again?
  28. AFR dropping very low????
  29. LET switching off
  30. does c1.4nv crank fit c14se
  31. Dropping the gearbox.Quick question
  32. C20Let vernier pulleys fitting?
  33. Wierd Judder
  34. coolant hoses (c20xe into corsa)
  35. F20 Diff bearing preload
  36. Diameter of turbo hose???
  37. Mineral water?
  38. C20LET, mysterious loss of coolant, headgasket ?
  39. clutch on f20 gearbox
  40. good idea bad idea? mk4 air feed...
  41. c20xe pistons in 8v engine,
  42. C20LET T3 fitment and manegment
  43. no oil on camshaft
  44. Intercooler spraying
  45. vetra 2.6 fuel pressure regulator
  46. roose hoses??
  47. URGENT HELP! -engine wont rev over 3k, n spluttering etc
  48. XE/LET cambelt covers
  49. vectra diesel exhaust fumes smell like paraffin
  50. X10XE Flywheel lightening?
  51. powerbox
  52. Transfer Box Leaking
  53. diagram for turbo vaccum piping(c20let)
  54. Any benefits to swapping V6 inlet?
  55. small end play?
  56. Dblias inlet manifolds
  57. No spark on an XE conversion
  58. Decat on a mk4 Gsi
  59. c20let radiator is gone again.
  60. Adjustable fuel pressure reg?
  61. X20XEV Cutting Out issue????
  62. c20xe question
  63. got xe, spend more on it or go let???
  64. New Clutch For C20XE
  65. will redtop starter fit 1.5td??
  66. Clutch For 300+ Bhp C20let???
  67. whats the difference on these engines?
  68. turbo oil feed and return
  69. C20LET into my Corsa B Gsi.Problems?
  70. 1.6 injectors
  71. Possible to drive with no transfer box?
  72. Differences between early and late coscast heads
  73. vectra 2.5 v6
  74. Major sump probs.
  75. Corsa engine help
  76. 2.0 XE lacking of power
  77. engine numbers?
  78. vectra computer light in dashboard
  79. Nylon oil pump release valve
  80. Omega rear hub removal
  81. v6 oil squirters?
  82. what is the most bhp any1 has got from standard 25xe rods?
  83. EGR location on a Tigra 1.4?
  84. Fuel Regulator X30XE
  85. Bottom pulley bolts, XE/XEV same?
  86. c20let erratic idle/ dead spots = fuel pump problem?
  87. middle box on c20let
  88. Mk3 GSi Oil Leak :(
  89. X16XEL Manifold.
  90. amal valve question..... help
  91. what fuel pump
  92. Blocks on high powered LET's
  93. URGENT!! help needed
  94. Calibra turbo bicycle chain sound??? help, please help me.....
  95. Mix + Match XE/XEV Few Questions......
  96. 1.8GTE to c20xe (redtop) conversion
  97. Corsa B 1600 85000 miles
  98. Astra turbo coupe engine
  99. x20xev engine
  100. xe sump removal, manifold off?
  101. timeing belt renew
  102. remove egr or not???
  103. Recommended HT leads for XE on carbs?
  104. Alternator bracket for twin carbs in a 2l8v
  105. valve conversion?
  106. 1.6 8 valve
  107. xe to let
  108. XE into a corsa c
  109. Easytronic Gearbox>>>>>>help
  110. Oil Cooler removal
  111. xe ecu s whats the difference
  112. any one with pics of astra mk3 gsi on turbo rims??
  113. Cooling - need more
  114. c20xe question
  115. burning oil at higher loads/revs
  116. Swapping a X16Xe for a X20XE
  117. fitting air fuel gauge
  118. V6 (C25Xe) Chip?
  119. new mahle pistons slightly different from old
  120. X25XE doesn't start. What could be wrong?
  121. air flow meter issues
  122. EGR valve
  123. list of things for LET rebuild...
  124. 2.0 sri 8v Lightend Flywheel
  125. will an f10 gearbox fit my c14se ?
  126. is my gearbox broken?
  127. Calibra DTM Timing Belt Tensioners (Gen needed)
  128. vectra info
  129. 3.0 V6 Turbo??
  130. z20let TURBO ????
  131. Main bearing bolts?
  132. Calibra Turbo: bush kit???
  133. Uprated fuel pressure regulator for C20LET
  134. what fuel pump?
  135. so whos used a supercharger?!
  136. Can you run an inner CV on a 2wd F28 without a support bush ?
  137. One spark short of a conversion
  138. Sensible engine mods for standard xe nova.
  139. Corsa C 1.2 gear selection probs,
  140. Raid Induction Kits - all look!
  141. I've been a numpty. Anyone with x20xe can help..
  142. Where Can I Get A Phase 3 Eds Chip
  143. XE SUMP
  144. tuning a redtop
  145. Driving with cracked sump?
  146. 1600 reving
  147. Help with ECU&wiring
  148. water inlet & outlet sizes c16se
  149. Airbox for TB's
  150. 2.5 v6 vectra emu light on
  151. need some advice about my corsa gsi c16xe engine
  152. Quick head bolt query!!!!!!
  153. air con in to a mk3 astra gsi!
  154. part number for 8v rubber sump gasket!
  155. spark plugs
  156. XE Struggling When Cold
  157. Stripped threads in Let block
  158. xe questions
  159. powerbox
  160. Chain Or Belt?
  161. C20XE Re-build
  162. c20xe manifold
  163. corsa gsi - fule pipe help?!
  164. timing????help
  165. gsi or sri
  166. F28...Which Car
  167. no petrol getting into the engine???
  168. 3.0 v6 vectra help needed
  169. what happens when a fuel pump relay fails? & where do u find them on cars?
  170. air box for v6
  171. 1997 Corsa 1.2 oil capacity?
  172. How to check an for inlet/vaccum leak and faulty injectors?
  173. How much boost on a standard 16v?
  174. corsa timing question.
  175. XE Oil pump renewal, what else can be done at the same time?...
  176. injector colour
  177. corsa LET question - running hot?
  178. DIY Clutch Replacement Guide 20XE
  179. mounting help
  180. conversion help
  181. xe sump
  182. let cam pulley bolts, stretch bolt?
  183. cali turbo oil losss
  184. Core Plugs?
  185. Arp Rod bolts 8v 16v 1.6
  186. how to flush coolant
  187. Could Corsa in-tank pump be used externally?
  188. mk4 astra f18 mechanical to f23 cable???
  189. fuel railing on c20ne/20seh engines.
  190. Redtop Head!
  191. vxr Injectors on phase 2
  192. xe cranks all the same
  193. XE and LET head
  194. c20let head-gasket upgrade! which one?
  195. how much boost on c25xe is safe? (project planning) lol
  196. where to get a exhaust system???
  197. Can you by-pass the Fuel pump relay?
  198. boost valve td
  199. c20let rear crank seal
  200. x16xe egr help
  201. How to Change Diesel Fuel Filter
  202. TD radiator opinions
  203. C16XE queries (nova conversion)
  204. Running a diesel on neat vegetable oil.
  205. f20 exeperts, what goes here?
  206. Used fault checker, and...
  207. engine mod with egr???
  208. lifters
  209. Standard XE Compression Ratio?
  210. Bailey nova tanks... on a corsa?
  211. mk4 astra sri 2lr z20let conversion drive shafts?
  212. C20XE on Carbs/twin 45s
  213. jeney linkage
  214. order for HT leads?
  215. Nova gearbox noise any ideas??
  216. Driveshaft question for F20 box
  217. Mass airflow sensor and idle control valve the same?
  218. x14xe ebay manifold, off here?
  219. URGENT HELP NEEDED! c20ne not firing!!
  220. oil leak nova gsi
  221. Vectra C 2.2 SRi misfire?
  222. tuning ecotec 2.0litre 16v engines
  223. putting a turbo back onto my car?
  224. cylinder head-will it fit??
  225. manifolds for 18xe
  226. xe sump gasket
  227. Another smokey Z20 LET
  228. Help needed getting 4x4 working?
  229. VecB 2.0 Eco to 2.2SRi 150 q's
  230. Short Shifter For F20
  231. 2.2 Turbo?
  232. 2.0 8v solid lifters
  233. My 4x4 system trys to bang threw the floor!
  234. f28 speedo drive
  235. URGENT HELP REQUIRED! 2.0i 8v c20ne engine
  236. DELCO ecu pinout?
  237. v6 2.5 into.........
  238. Piston options poll.
  239. What size mahle pistons available
  240. Oil leak from distributor 20XE
  241. Replacing sump.
  242. c20let steel rods - why such a price vary?
  243. Engine misfire when under load?
  244. help with c20xe in a kit car
  245. x20xev cylinder head
  246. peugeot 106 engine swap
  247. part no. oil squirters?
  248. Astra Mk3 Turbo Project stuck already.
  249. corsa secondary air injection pump
  250. nova v6 requirements
