Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. c20xe missfire ???
  2. Are these pistons funked?
  3. sport inlet
  4. C20let Nova Help Needed
  5. 1.2 8v manifold/exhaust
  6. Which Engine
  7. corsa xe conversion kits????
  8. FAO mk3 astra owners
  9. cavlier gsi rev counter
  10. URGENT Vectra B V6 Help
  11. what turbo
  12. vectra sri 130 dti EGR FAULT
  13. engine conversion people
  14. egr location help
  15. driveshaft seal?
  16. X16XEL Nova - fault code 1410
  17. c20let new tappets
  18. vectra sri 130
  19. torque settings xe
  20. CTS resistance test results
  21. nova xe spluttering help please!
  22. F28 what can it take
  23. let immobilser ecu/loom question
  24. is it my clutch or gearbox?
  25. What gearbox?vectra sri x18xe1
  26. r1 throttle boddies
  27. Smokey Vectra B 140
  28. Terrible idle on C14nz after high lift camshaft replacement
  29. Short shifter
  30. f28 gearbox oil.
  31. Weird Calibra gear issue?
  32. F13 ratios question
  33. carbon cannister on a 2.o 8v
  34. A few let problems
  35. c16se
  36. Omega gearboxes
  37. Management Codes
  38. vectra sri 130 dti loseing power
  39. Cocast head help!
  40. 2.0 ecotec into corsa b?
  41. Best and easiest way to get power??
  42. c20let oil catch tank (again)
  43. 1.8 gsi corsa engine
  44. help with fault code
  45. Induction kit
  46. Ecoshed issues
  47. problem with new cams
  48. c20let corsa traction?
  49. F17 no 2nd - Snapped Synchro-Mesh?
  50. Answers From The Oil Expert
  51. calibra turbo shocks?
  52. porous head ?
  53. Vectra idling issues.
  54. C16XE or X16XE?
  55. C20XE in to a vectra b
  56. Broken 48 Dellorto. Anyone any good with alloy welding?
  57. Valve or Turbo oil seals???????
  58. anyone ever r1 bodied an XE ?
  59. Any Advice on a Over-Fuelling 1.4 Xsara?
  60. Astra GSi 4wd help
  61. Help with Corsa fuel lines in engine bay please
  62. vauxhall astra gsi mk3 rear axle FOR SALE
  63. RON plug???
  64. Crank cap bolts. Use again?
  65. Getting an Omex 600 mapped....
  66. c20xe plugs 1nd2 wet???
  67. Inlet manifold heat spacer, to decrease inlet temps?
  68. c20let rocker cover mod how?
  69. Tappets for c20let (late)
  70. corsa track car
  71. Mk3 Astra 1.8 16v ecu fault codes
  72. Ecotech mk3 astra Auto - Engine change
  73. C20 XE no power under load...
  74. Top hose for corsa LET/XE?
  75. Which turbo engine
  76. sticky revs
  77. Nova carbs.... what was original equipment on which models?
  78. c14se head???
  79. codes 93 and 94
  80. TV's Tech notes for XE inlet cam (this months issue)
  81. HELP!!!!!
  82. Turbo a calibra engine
  83. Strange wire on XE loom
  84. FMI going to be too restrictive ??
  85. xe compression test
  86. question regarding water pipe ontop of turbo (c20let)
  87. Please Help
  88. Need new rad 'but which one??
  89. Urgent Help Needed!!!!!!!!!
  90. 20 seh front crank oil seal
  91. corsa c20let phase 2 whats required???
  92. Need help with Redtop Corsa
  93. Boost gauge pipe??
  94. 2.1 16v corsa
  95. First impresions of this vectra gsi please
  96. Vauxhall 1.4 16v sport cambelt
  97. help cav gsi can't get rid of fault code 93
  98. What EP of Gearbox oil to use
  99. Xe water temp
  100. c20let in to corsa
  101. gearboxes and ratios
  102. manta-c20xe and type 9 box question
  103. XE in a Corsa... Coolent Temp?
  104. Putting gearbox on C20LET problems?
  105. Urgent: VecB X20XE drive belt route
  106. vectra sri 130dti power losted
  107. Vauxhal Part number required please
  108. C20LET Not Boosting
  109. what shafts/hubs/cvs for nova xe?
  110. xe inlet cam timing on let
  111. Piston Protrusion above block deck
  112. My engine cuts out everytime i stop
  113. 8 or 4 injectors
  114. Help me fit a 16v head to an 8v block
  115. 1.6 pistons into a 1.4??
  116. best injectors for c20xe
  117. 2.5 V6 into Astra mk4 (HELP)
  118. DTi 16v tuning ideas?
  119. Twin engine c20let
  120. Electronic speedo for XE
  121. Induction for a 2.0i
  122. CTS HIgh Voltage - Electrical Help Needed
  123. calibra driveshaft
  124. Cat saps power?
  125. clutch not disengaging after box fitted
  126. Smallblock Engine, Options?
  127. 3.0 in a nova/corsa??
  128. drive shaft snapped
  129. gearbox help!!!!!!!!!
  130. Annoying starting problem
  131. c16se
  132. DTi Trouble?
  133. alternative to garrett t34
  134. Need pics of F28 standard clutch against F20
  135. 1999 veccy gsi gearboxes
  136. 1600 sump/pickup
  137. only 3 exhaust branches with heat wrap
  138. corsa engine mount
  139. C20XE Not running right!!
  140. C20LET forged pistons
  141. Engine coolant
  142. Engine number HELP PLEASE!!!
  143. I Smell Petrol :s
  144. Corsa B 1.2 16v conversion to 1.6GSi
  145. XE head onto LET, deck height Q, different part numbers ?
  146. Valve spring clamp
  147. what carbs fit a 1.8?
  148. throttle body
  149. No oil getting to the top of the engine
  150. gsi fuel pump?
  151. xe project wont rev past 3000 revs
  152. c20let hot start valve
  153. Clutch question
  154. 20seh overheating
  155. what is this under the bonnet?
  156. Valve Timing 20 seh 8v.
  157. 20 seh airlock.
  158. need a bit of help
  159. condensation cause white cream??
  160. XEV Bottom End Brace? Is it needed?
  161. what engine is this??
  162. 1.2-1.8 corsa c
  163. Where is the ICV on a z20let?
  164. white cream under oil cap on a re-built engine!
  165. What goes on inside an engine!
  166. Vectra B Acceration Problems??
  167. Mk4 Astra losing power,
  168. Bike carbs/throttle bodies
  169. engines
  170. Nova GSI Fuel Tank?
  171. c20xe engine conversion in to Daewoo Lanos
  172. AEM wideband
  173. Late XE Timing Belt and Waterpump Replacement
  174. is a MPI pump a must for 2.0 corsa?
  175. 1.2 spi starting problem
  176. early c20xe timing belt tenson!
  177. Two Different C20LET Wiring Loom? :O
  178. c20let in astra mk3 gsi, help!!!!!
  179. c20let in astra mk3 gsi, help!!!!!
  180. f25 to f23 vectra v6
  181. 16v to 8v can i do it??
  182. Saab Turbo Engine Conversion
  183. 3 year old petrol.
  184. help - fitting new cam belt to late c20let
  185. Turbo gurus - k16 ex manifold with a gt17 ?!
  186. Standard XE piston sizes all over the place?!
  187. Emissions
  188. Headbolt Torx key size ... LET ?
  189. ICV red plug, Knock sensor Black plug?
  190. Quick question - Where do you buy RTV from?...
  191. HELP - Power loss
  192. fuel tank vent valve
  193. z20let decat fault code???
  194. Penny valve on ur c20let kkk16 turbo...
  195. c20let kkk16 turbo
  196. astra g coupe 1.8 tuning HELP!
  197. tuning a v6
  198. Oil pressure switch v6
  199. vectra sri 2.2 dti130 timing chain or belt
  200. Heater matrix, or something else?
  201. over fueling on xe
  202. Torque Settings
  203. Need to remove the transfer box
  204. Uprated C20 LET Valve Springs
  205. Turbo coolant return
  206. F20 box jumps out of reverse
  207. c20let gear selector
  208. no spark or fuel pump!!!!! on 8 valve sri
  209. cold water
  210. engine wont idle XE
  211. C20LET, Possible to keep over boost when fitting an MBC ?
  212. too much petrol!
  213. 1.8 out red top in - Advice Please
  214. Injector information
  215. F25 conversion to F20?
  216. How do you clean TB?
  217. Whats the difference???
  218. OBD - OBD2 and Euro Model Fault Reading
  219. c20xe big end bearings......
  220. Help Please - Vectra GSI Cutting Out
  221. c20let boost/runnin problems
  222. vectra gearbox/shaft question
  223. HELP! gearbox info!!!
  224. More Engine Hesitation
  225. exhaust question
  226. driveshaft seal
  227. Difference between Frontera 2.3 intercooler and 2.8
  228. C20let gearbox F20
  229. c20let running lean???
  230. c20xe whats the oil pressure??
  231. oil squitters
  232. uprated fuel pump for C20let
  233. 04 reg Vectra C 2.0 DTi starting problem
  234. ecotec not geting hot
  235. First Look Pics - Z20LET Tubular Manifold......
  236. Vauxhall Calibra Hesitation on acceleration
  237. 1.8 sport to Z20LET conerstion?
  238. GM to izuzu td engine
  239. External Wastegate Clarification
  240. stainless steel manifold vec b
  241. equal length drive shafts
  242. differnet ratio
  243. Fmic pipework
  244. C20LET ecu, different types?
  245. Redtop expansion tank top
  246. Will this work, trying to pipe up fmi intercooler
  247. complete noobi questions
  248. Omega 2.0 not running right
  249. Z20let manifold
  250. clutch or thrust bearing?
