- X16XE ARP Rod Bolts?
- Astra Mk 3 Wont Start On First Turn
- Dyno Graph - Any help with diagnostics?
- Vectra V6 SRI Clutch/Gearbox help
- Throttle body conversion
- c20let wiring
- C20LET or Z20LET ??
- Help! I've never driven a turbo..
- short shift???? which one?
- Tigra 1.6 16v OEM manifold off - problems
- XE corsa drive shaft options
- drive shaft help
- Cam pulley timing marks (bizarre Non-vaux)
- help - sister just bought 1.7td astra van p reg and its overheated
- New battery time! Best one to get?
- which belt?
- Corsa B lower cross member
- hyrdocarbon figure on my mot
- turbo spooling up louder?
- need help with my dads golf gti!?!?!
- torque settings
- timing marks 2.0 ecotec
- what is the 1 way valve on a c20let
- x14xe engine number
- How easy is it to re-build a turbo?
- Driveshafts - F20
- equal length driveshafts??
- astra van s reg 1.7 td gearbox info needed
- Carlton TB on 20SEH
- hall sensor and actuator
- what clutch for a c20let?
- water leak help!!!
- Vivaro cutting out..Injector sensor code?
- sri 1.4 8v shafts
- Quiaffe F20 20XE
- c20xe afm
- c20xe starting problem/misfire
- Answers From The Oil Expert Part # 2
- Engine Managment light.... Help!!
- Corsa C 20XE conversion...
- EGR valve location
- sounds like noisey tappets could be cams???
- What RPM does you std C20LET Boost?
- can i run high comp pistons on a 16xe on bike carbs?
- Engine Codes... Hmmmm
- anyone know how 2 tune the x20xev
- Engine installer in South wales
- Calibra V6 Y32se transplant
- Diff bearings
- Vibration after fitment of lightened flywheel.
- 20xe or what?????
- Vectra cracked manifold woes.
- v6 compression readings
- Saenz rods, peoples verdict
- MOT emissions help
- what fuel pump is best 4 c20let conversion in gsi?
- c20xe rocker cover gasket
- Carbs to a X20XEV
- astra h 2.0 turbo
- corsa conversion
- C20LET slow revving ??? arghhh!!
- corsa 1.4 16v sri
- V6 Calibra Won't start, any suggestions?
- Iridium Spark plugs
- Any Diesel Pump experts in or know where to ask? Not Vauxhall
- c20let onto f20?
- vectra auto loom to manual GB? help please
- 2001 vectra sri 150 2.2
- 20xe installer needed!
- c20let underfuellin do u think?
- best place to get corsa c20let phase 2 setup in scotland ???
- My calibra died on m11 yesterday( check out what happened)
- Corsa oil light
- C20XE idles at about 1500/1600 rpm when warmed up but not from cold
- F28 Gearbox - Should I be worried??
- Engine Upgrade.
- Does this fit to F28 gearbox
- Upgrading Turbo Help
- Evo5 or Phase 2/3
- let into nova q`s
- Fitting an X16XE into a nova
- max lift cam for v6
- Clutch Change
- Engine conversion
- z20let cam cover gasket
- timing marks
- c20xe short oil filter??
- wanting technical advice
- V6 transplant
- vectra 1.7td advice
- what's mahle forged
- 16v head...
- Best fuel pump for Corsa Let
- 1400 blocks??
- nova dizzy vacuum pipe
- HELP!!! corsa LET wiring
- rolling road notts or derby
- Astra Mk4 1.6 16V struugling at low revs?
- Mega squirt C20LET help
- help.. car lacks power..?
- Which Fuel Pump?
- Which Clutch?
- C20let / Nova Gsi Gte 1.6 Alternator?
- what injectors
- Couple of Q's about oil & fuelling (C20LET)
- Has anybody ever changed......
- Fueling problem on c20let.
- how much for a C20LET rebuild?
- Engine problems
- Pic request: F28
- HELP corsa 1.2 sxi AFM PROBLEMS
- Corsa sri engine problem advise
- Fitting facelift Petrol tank to prefacelift Cav?
- corsa 2.0 16v 120mph???
- Spark Plugs?
- c20let running badly
- Astra SRI engine????
- swirl pot- nova.
- C20LET idling at 2000rpm?????
- Knocking Noise Help
- Intermittant ticking...?
- P reg omega elite 3l V6 wont start
- aluminium crank pulley
- Corsa GSi 1.6 16v TB Set up problems
- which gearbox
- engine questions? nova..
- kit car with a 2.1 pinto lump on twin fourties help please
- Nitrous on V6???
- Tuning a Y26SE
- Vectra C 2.0 Diesel in tank fuel pump
- what corsa xe shafts are these?
- 1.3 head onto 1.4?
- C XE Brief loss of power 2mins after warm start
- x14xe corsa - egr fault, smoking a bit now...
- Major rattling/tapping at startup..1.6 8v
- DIS onto C20LET
- astra auto gear box
- abit lumpy on start up
- driffrence in heads
- what size engine will twin 40's run?
- c20let running no boost
- Engine code for...
- xe lowered compresion?
- How much NOS C16SE?
- C20NE Nova starting problems
- Building a LET cheaper then buying one???
- c20let project
- Torque settings for c16xe
- SMokey
- Crank sensor!!
- why cant my c20let hold boost
- charge cooler removal
- C20XE ECU from a 1991 GTE 16V FP Ident?
- engine movement
- strange xe problem
- New Tigra Comparison
- XE Chip/Mapping
- epc part number f28
- C20xe exhaust manifold on C20ne??
- Injector differences? 20NE v C20NE
- My 20SEH dosen't like.......
- Engine conversion problem, 1.2 8v to 1.4sri 8v
- Webbers and the alternator bracket
- Engine Tuning, Not Vaux but i would like some help anyway!
- x20xev crankshaft ladder ?
- Calibra v6 gear linkage - Cost to replace?
- Z18XE/X18XE1 ... X18XE heads
- XE inlet cams
- Vectra C20XE revs counter & speedo help!
- Dodgy coilpack?
- seh rev limit?
- XE oil cooler pipe OD?
- Dump valve
- Actuator set up
- Weber Emulsion tubes?
- C20XE Tuning help
- clutch recommendations
- Is this padel clutch any good?
- 20SEH standard cam data needed
- Wot psi should i run
- nova 1.6 8v not running right
- Engine Manuals...
- what shall i change on the engine while its out.
- anybody with bannana do me a part number check?
- Fiesta 1.6si engine into Corsa b
- Thrust bearing help
- ...please..kkk16..dimensions
- Please Help
- quick question
- Transfer Box Temp Sender
- Corsa XE conversion issues...the nightmare begins!
- Whats The Differance
- why cant my c20let pull skin off custard?
- Z20LET and cat's
- Vectra Sri 2.2 Dti Start Fault
- c20let gearing
- C20let Mounts
- Turbo a corsa 1.2
- turbocharging a c14se
- Is there a alloy 1.4 block?
- 1.6 compression ratio
- gte gearbox fault
- let pistons into 8v??
- Keeps breaking down
- Remap / Chipped ECU
- Nova C20LET problems
- oil preasure, whats the right psi
- what bar is the fuel pressure reg on the vxr fuel rails?
- OIL LACK????
- diesel gearbox
- Clutch help on a VW
- Looking to see if anyone has come across this before
- how to get fault codes on LET conversion
- Uprated Actuator.
- frontera
- No Spark On C20NE + Left Over Wire
- cavalier mounts !
- Little Bit of Advice Needed Please....
- Oil Light
- which way round...
- f23 on 1.8 16v mk4 astra?
- Corsa GSi speedo cable mystery (with pics) CAR MAY BE DRIVEN INTO A WALL
- Voltage for uprated fuel pump
- air leak some where on let.
- c20xe to c20let
- safest psi?
- c20let t34 exhaust manifolds
- zafira gsi k&n induction kit
- nova c20let
- fault code p1405 linear egr position
- Urgent Help, Clutch Size on C20XE
- Vectra 1.8 LS
- looking for rough price on thischeers
- Turbo kit to Vectre X18XE. where?
- c20let- whys it eating spark plugs?
- Which clutch for F20 and F28 and where to buy
- HELP Irmscher 1.3 injection kit fitting!
- Fuel Vent Vaule
- astra v6 info needed
- Steel Rods, Oil Hole
- ??? about v6 vectra engines
- Nova F28 and lowered tie bars?
- F28 speedo ring change
- c20xe
- help with C20LET oil pumps
- Corsa b F28 M-Tech quick shift
- C20LET build problem help plz.
- running rich
- gear box oil capicity
- Noisy lifters after reconditioning C20XE
