Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. rocker cover
  2. Help Needed please astra low blow
  3. New to the world of Vectras!!
  4. Anti-Lag
  5. help with egr position on x12xe.
  6. Are these any good?
  7. X20XEV Vectra ECU light
  8. service on c20let
  9. Immobiliser Replacement Query
  10. How can u get more power from a 1.3 nova?
  11. C20LET oil leak from sump
  12. what bhp will these cams give me (v6)
  13. Coolant Header Tanks
  14. C20XE DISPACK ECUs Motronic 2.8
  15. Which Chris A mounts for XE corsa?
  16. oil pump question
  17. Are C16XE pistons pocketed..?
  18. k16 turbo recon who best and how much
  19. c20LET wont start
  20. Is this Bent ??
  21. Regal steel headgasket for c20let
  22. Fault Code P1635 (A) Vec Sri DTI (Video Clip)
  23. Holds 4 Psi, Sometimes Overboosts to 10 Psi & Splutters Badly!!
  24. C20LET Starting Probs
  25. Power boost valve astra
  26. coolent problem!!
  27. shud u b able to move actuater manually?
  28. Turbo Recomendations???
  29. Which speedo cable to run corsa clocks off an F20?
  30. corsa c20let fan
  31. Running-in
  32. frontera "A" coolent sensor location???
  33. Turbocharging an Xe
  34. Uprated Fuel Pumps
  35. Corsa GSi Piston diameter
  36. Cambelt and Clutch change 1600 Corsa B sport - ADVICE
  37. Plug gap for c20let?
  38. X20XEV Cam Sensor Wiring
  39. Will Changing ECU Disable Immobiliser?
  40. mounting trouble
  41. could it just be the fuel filter??
  42. dump valve not very loud?
  43. lifters
  44. C20XE on dizzyless
  45. bigger turbos?
  46. Astra standard dump valve spring?
  47. are vx diesel shells stronger?
  48. c18xe smallblock oil press. what should it be in z18xe and c16xe
  49. mods for xev engine please!!
  50. corsa redtop keeps loosing power
  51. corsa b engine
  52. LSD oil
  53. Engine Mount Problems ?
  54. LET inte XE`d nova
  55. Do all LET's use early type airflow metre?...
  56. bike carbs
  57. which ford type 9 box for a rwd redtop?
  58. Turbo Downpipe questions.
  59. Diagrams needed of LET...
  60. rev counter
  61. x14xe/x16xe dblas inlet
  62. How to get more out of my corsa sport
  63. LET conversion, What radiator?
  64. Vec GSI rocker gaskets
  65. C20XE Quad throttle conversion issues
  66. Wiring trouble - Simtec 56.5 speed signal input
  67. IF I....have removed the lambda and earthed pin 20 in the ecu
  68. Maximum BHP using standard rods XE
  69. cold starting 20 sri
  70. c20xe ecu GQ does any one know what model its for coil or dizzy?
  71. Exhaust.
  72. My plans for tuning my LET, opinions please!
  73. f28 reverse gear selecting
  74. C25XE Alternator....
  75. Purge Valve C25XE....
  76. corsa xe problems plzz help!!
  77. Water pump change.
  78. Frontera intercooler for Phase 2
  79. 3.0 v6 calibra no spark or fuel
  80. Engine Overheating
  81. 20xe core plug size
  82. best location for my wideband sensor on my let?
  83. help with my drive shafts
  84. where to t into 4 dump valve?
  85. urgent help needed
  86. Easytronic info please
  87. Rear wheel drive c20let's
  88. xe return fuel pipe leaking
  89. engine sounding noisy when cold & smoking ??
  90. problems with my c20let
  91. Cam belt tensioner needle
  92. Will A Z16XE Fit/Work Instead Of A Z14XE ????
  93. vectra diesel clutch problem
  94. Rev counter probs on a Vectra C20XE conversion
  95. Where can i get this part?? c20let
  96. F28 linkages in corsa??
  97. vectra v6 idleing and hesitation
  98. X16XEL burning oil (alot of oil)
  99. ecotec/red top
  100. Why change the fuel filter?
  101. Nova MAP sensor ???
  102. head gasket for c20let
  103. Vectra x18XE GLS Autobox... Troubles!
  104. oil level
  105. Astra sloppy box??
  106. 20xe cam timing help.
  107. Corsa xe redtop radiator issues
  108. crank shells
  109. 1.6 16v Engine fault. Any ideas??
  110. xe clutch question
  111. best cams for c20xe
  112. Z20LET trouble
  113. C14SE con rod pic
  114. XE - Replacing Oil Cooler Sandwich Plate Gasket....
  115. Cav/Cally V6 rocker covers
  116. Bosch 044 Fuel Pump
  117. gunson faultfinder
  118. 1600 cranks
  119. vectra c intake pipe "how to"
  120. redtop missfire!
  121. Engine oil Type for astra gsi turbo
  122. remove fault light "F"
  123. Technical info Z14ZEP
  124. A/f Ratio Gauge!! Wideband Lambda??
  125. help on engine management light coming on
  126. Cambelt cover 20SEH/C20NE
  127. v6 calibra crunchs when i put it in 2 reverse
  128. heres one for you tech heads!!!!
  129. Corsa B 2.0 xe wont start
  130. Has anyone welded a V6 manifold?
  131. Are chargecoolers efficient for big BHP?
  132. C14SE con rods
  133. Vectra C 2.0 Diesel starting probs
  134. How to remove auxillary belt??
  135. vxr injectors on c20let
  136. one way valve on breather pipe from rocker to tophat
  137. 14se cooling/engine prob
  138. X14XE Tigra, Poor Running and How to improve?!
  139. C20let Head Gasket Gone?
  140. C20XE Engine Problems!
  141. Cam Belt Change X16XE
  142. wiring help corsa b
  143. Carbon canister do i need it??
  144. Will an f16 fit my cav 95 2l 16v eco?
  145. clutch release bearing
  146. What indications do get when...
  147. c20xe into corsa b help
  148. bosch fuel pump specification?
  149. best plugs for x25xe from halfords?
  150. Lambda Sensor??
  151. Nitrous Refills
  152. Frontera Starting Help!!!
  153. Nova gsi exhaust question
  154. Corsa sport drive shafts - xe conver.
  155. fuel pump and swirl pot info
  156. Doh, Fault Code 74 - Voltage High Air Flow Sensor
  157. c20let rolling road advice please
  158. Rev problem
  159. X20XEV power mods
  160. Best Facet fuel pump for a 190 brake redtop?
  161. Engine judder that no-one can find a solution too, HELP HELP
  162. Low temparature reading on Vectra C 1.8
  163. hesitation
  164. 1.4 Flair Single or Multipoint?
  165. X20XEV with Z20LET turbo, minimum parts???
  166. Where to get nice quality Jubilee clips
  167. What Sump bolts to use with XE one piece gasket/baffle plate
  168. Calibra turbo lost all power-steering fluid?
  169. f28 gearbox (please help me)
  170. Phase 2 boost delivery
  171. c20let coscast head rebuild
  172. c20let max boost? 56 psi
  173. Cam shaft sensor location on an 02 plate 2.2 ltr omega
  174. HKS SSQV fitted... idle problem...
  175. 1994 astra gsi 1.8 16v(pre ecotec) should i cam it??
  176. Fault Codes on X1.8XE1 Engine (Help!)
  177. Dry sumping a LET
  178. urgent help needed!!!
  179. Engine cambelt problem
  180. water sound???
  181. Brake Cilinder vacuum with Jenvey DTH, question
  182. turbo help
  183. Heater not blowing hot?
  184. where is the hall effect switch
  185. can u solve my problem no1 can so far so ud have to be pretty good
  186. An MOT / emissions question... long, sorry.
  187. Car not 'fast idling'
  188. Injectors in X14XE
  189. c20xe is refusing to tickover
  190. Manta LET gearbox
  191. fitting quaiffe on f20
  192. Tiny water leak, but where?
  193. Diff bearings (useful info!)
  194. XE rods/piston combo + prices please
  195. z20let dump valve problem
  196. gearbox woes!
  197. Nova C14se fails to idle
  198. 1.6 16v Ecotec
  199. C20let
  200. LET on a manta box
  201. Water pump
  202. 1994 astra gsi(1.8 16v pre ecotec??? should i convert to a c20xe"red top"??)
  203. What do i need to fit bike carbs?
  204. f18 gear selector pin
  205. Idea - Adjustable/Variable Ram-Pipes for side draught carbs
  206. Distributor to Dis pack
  207. Cav turbo F28 clutch cable problem
  208. c20xe is idling at about 4000 rpm
  209. f20 help please
  210. Z20let help wont run help help
  211. water pump & timing belt
  212. How do u fit a dump valve??
  213. Z20LET Removal
  214. c20let std boost??
  215. how to remove water pipe on top of turbo?
  216. Vectra 2.2
  217. electric supercharger!
  218. Helllpppp!!!!! Nova
  219. zafira 2.2 engine rattle
  220. Sump bolts
  221. Pic of a friction plate for a 1.8i cav please
  222. ARP head studs and head gaskets
  223. Are RWD drive shafts splined at the hub?
  224. C20LET Cambelt Change!! HELP !!
  225. Help Corsa C20 Let not firing!
  226. How 2 change clutch in 1.8i cav
  227. (VXR injectors) will they cope with 300-350 BHP
  228. x16xel low compression on cylinder 1
  229. Help !! Gear stick problem
  230. icv and knock sensor wiring
  231. 2001 Astra 1.4 16v Z14XE ??
  232. XE brather modification. Whos done it an how does it work???
  233. c12nz intermittent stalling after 20 miles
  234. vectra V6 hunting
  235. Cost Help for V6 Clutch Kit + Fitting
  236. setting up the autuator spring
  237. c20let think ive blown it
  238. cav misfire
  239. What engine do i have
  240. Studs
  241. Vecta a c20ne fuel pipe diameter?
  242. r1 injection
  243. Zafira 2.0 DTI lost boost
  244. reverse light wiring
  245. Help Identifying clutch type (PICS)
  246. f28 gearbox bolt thread size
  247. ecu fault codes
  248. vectra st200 crank seal
  249. Thrust Bearing Help
  250. X16XE ARP Rod Bolts?
