Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. engine rebuild, c20let where to go??
  2. f18 gearbox
  3. F18 box?
  4. converting a XE to LET
  5. c20let running **** after head gasket change
  6. ARP head bolts, replace when change head?
  7. Rad for a c20let.
  8. PLEASE help z20let astra coupe turbo rocker gasket
  9. rought with the smooth??? - heads??
  10. Vectra 1.7 td good engine?
  11. urgent exhaust help required
  12. blues or creams
  13. engine runs like old desiel motor when cold started??
  14. Redtop Corsa Exhaust
  15. 1998 vectra 2.0 16v dti starts problems
  16. Making my own manifold
  17. Heat wrapping a tubular manifold
  18. C20let & F28 in MK4 astra
  19. Conversion but i want to keep me air con
  20. Nova Let gearbox - buzzing
  21. Clutch cable won't adjust right
  22. XE Nova temp gauge reading hot but engine not
  23. Air flow meter wire order for dispack XE
  24. opel vectra 2.5v6 convert to 3.0
  25. doea any 1 know if its poss
  26. 300 bhp from z 20 let
  27. cambelts...round vs. square
  28. T34 / C20let mannifold?
  29. VECTRA oil
  30. tubular manifold t34 turbo on corsa c20let
  31. Will the Quaiffe diff in my F20 box...
  32. starting problems vauxhall cavalier gsi
  33. Which fuel pump?
  34. Engine Problem 14. 16v Corsa
  35. help o/heating probs
  36. How to fit Frontera 2.3 I/C in astra mk3 c20let?
  37. c20let, problem!
  38. water pump for c20let?
  39. misfire
  40. best place/make of pipe work to buy??
  41. cluch or gearbox??
  42. Corsa C20xe Running Weird When Cold!
  43. K-reg 1.2 nova, valve safe or not???
  44. X25XE Diagnostic Socket
  45. Missfire/bogging down/holding back
  46. vectra variable vane turbo help
  47. heatwrap 4 branch or not?
  48. 308mm brakes
  49. clutch for uprated c20let
  50. mount problems
  51. How much for the conversion
  52. fuel pumps
  53. turbo rebuild - thoughts
  54. No spark
  55. any 1 know
  56. Dbilas Throttle bodies on x16xe (l)
  57. help needed please
  58. Cavalier starting troubles :S
  59. sizes needed - corsa b bodywork mount
  60. 4wd corsa/nova
  61. Need advice on Engine swap for R reg 1.8 ls vectra
  62. cheapest way to xe my corsa
  63. 8v head work
  64. Astra GTE 8v Fault Code
  65. Cavalier 4 x 4 gearbox number
  66. Non Vaux help/advice!
  67. Cav v6 rear axel Q
  68. c20let turbo
  69. engine rebuild
  70. actuator bracket on c20let
  71. oem re-circ dv spacer
  72. kreg 1.7td ...will a M reg engine fit ???
  73. corsa driveshafts
  74. My RR Graphs from today... Anyone seen my torque???
  75. Mk2 Astra 16v GTE
  76. amal valve queries...?
  77. rear Suspension
  78. Cavalier Fuel tank strap, captive securing studs, ones broken
  79. Washers under cover
  80. converting my manual to auto help
  81. how do i convert my astra mk3 2 5 stud
  82. Vectra V6 corrugated EGR pipe
  83. T34 or T38?
  84. Cost on an engine conversion/Possible job
  85. Lumpy idle and cutting out
  86. Astra MK3 won't start
  87. high idle x14xe mk3 astra
  88. Struggling Redtop.
  89. will a 1.6 16v gear box fit a 1.4 16v engine
  90. Engine management light showing
  91. c20let hairline cracks in flywheel
  92. phase 4 and suitable clutch + c20let rebuild questions
  93. Camshaft
  94. Turbo Technics Hybrid, what do they do
  95. Bleeding 1.7 Isuzu Diesel
  96. c20let non return valve in breather pipe??
  97. X20XEV Inlet Elbow
  98. dodgey idle on LET when warm
  99. c20let boosting funny
  100. c20xe no spark or fuel?
  101. astra gsi turbo running funny!!
  102. Is this true??
  103. Cavalier Red Top Problems
  104. fitting a c20let in a veccy
  105. 1.5td corsa probs!!
  106. c20let headgasket,!? uprated ??
  107. Good clutch for f20 gearbox
  108. btcc type xe heads - where?
  109. Cavalier exhaust differences....
  110. no ecu light/temp gauge/over fueling
  111. Broken Bolts in gearbox help plz!
  112. c20xe in to mk3 1.4 astra
  113. Slightly rough running
  114. dirty cam cover (oil breather blocked)
  115. LET limp mode again code 27
  116. vectra v6
  117. ecotec oil pressure
  118. Corsa engine conversion
  119. V6 Flat spot low down
  120. Vectra 2.0 SRI help please
  121. let high tick over
  122. Coscast and GM
  123. Saab 2ltr turbo in a nova
  124. what mods for a Gsi Vec
  125. nova saloon c20xe fuel prob
  126. mk3 gsi strutbrace
  127. What timing kit
  128. will a x20xev head fit a c18xe?
  129. c20xe cranking advance
  130. odd fuel problem with 1.2 nova?????
  131. ECU Light | High rpm
  132. Nova kent cam
  133. gm 20xe head
  134. x14xe, oil change at 15000km? (9000miles)
  135. very low fuel pressure
  136. pointers removing let from cali
  137. C20XE chip
  138. How to check an automatic gearbox?
  139. C20LET into Mk4 Astra Coupe
  140. c20let screamer pipe
  141. Input needed on making XE throttle body manifolds...
  142. vectra interior fit astra???
  143. Boost Problems C20 Let
  144. f28 clutch, uprated or not?
  145. cooling system retaining pressure
  146. c20let not starting when it wants??
  147. Autobox questions
  148. W reg Omega 2.2 running problems??
  149. what manifold fits?
  150. ARP Rod Bolt tightening.
  151. C20XE cutting out under hard acceleration
  152. Fuel pressure Adapter
  153. C20 XE AFM on 8V?!
  154. c20xe what manifold?
  155. Oil pressure gauage for c20let
  156. AP Paddle clutch
  157. Enlarged top hat for c20let
  158. X25xe GSI VECTRA Engine swap
  159. Lightened flywheel c20let
  160. Non Vaux - Ford Diesel engine question
  161. Do I need the amel valve
  162. x16xe throttle blanking, details request
  163. C20XE In KitCar Advice & Pointers!....(TB's...Fueling..ECU's)......
  164. thick head gasket on c20let due to head skim
  165. What Power Should I Be Expecting?
  166. which manifold for a c16xe?
  167. Engine Reconditioning
  168. astra G mk4 1.816v sxi sri?????
  169. Evap Valve c20let
  170. corsa xe conversion rr mount/ gearlinkage
  171. Changing engines?
  172. CORSA GSi torque settings needed
  173. Corsa c20XE Driveshaft issue
  174. Urgent help on car please!
  175. Recommend me good uprated leads/plugs
  176. Location of Fuel Pump Relay on a Vectra S Reg 1.8 ecotec
  177. veg oil
  178. Bolt head socket bit???
  179. snaped my xe camshaft tensioner!!help
  180. buying xe conversion shafts!
  181. F28 Into Vectra GSI 2.5V6
  182. Omega 2.5 v6 coolant problem
  183. x20xev cavalier sri non-starter
  184. Strange boost drop in 3rd gear
  185. astra mk4 engine conversion
  186. Missfire
  187. F16 Short shifter dimensions?
  188. omex 600 users
  189. Performance increase 1300cc Carb SR
  190. C20XE head gasket problem maybe
  191. 5 studding a Nova
  192. Vectra v6 fuel rail
  193. Sachs kit is a LUK kit?
  194. Vectra 2.5 v6 crankshaft sensor
  195. vectra 1.8 16v missfire (not coilpack)
  196. F20 4x4 Q's
  197. Pinking problem
  198. I want to bleeding bleed the coolant system
  199. Stainless Steel Exhaust for Nova 1.2?
  200. R1 carbs on XE (again)
  201. dbilas dynamic question, help please.
  202. Non Vaux, Mitsu Pajero 2.5 TD knocking, Advise please
  203. which bolts
  204. Noise tappets
  205. bought a mk3 astra turbo few problems? please help
  206. piston rings
  207. 1996 1.7td astra van, gm - hard to start
  208. Tappets? Far to loud.
  209. 6 speed whats involved in fitting
  210. Help What Ignition Module For Carb Set Up ?? On C20 Xe
  211. No clue,is this the clutch?
  212. 24v manta q's help needed asap
  213. 200SX tubular manifold ready for ext.WG ?
  214. C/R Question and advice for C20XE
  215. Corsa Let Probs!!
  216. Nova turbo conversion
  217. increasing an x.e to a 2.1
  218. let/f28 what clutch should i use
  219. Gearbox worries!!
  220. code reading a astra 3 1.4
  221. 1.4 8v engine trouble(again)
  222. How to stop a s**t ecotec tapping
  223. redtop to c20let swap
  224. vecy c20let just died
  225. just broke my coil lead!bodgetastic ideas needed!pic inside
  226. 5th gear problem on f20 box
  227. XE hunting and juddering plus more
  228. x20xev cyl head torque settings
  229. F28 speedo drive problems
  230. 1.8 ecotech oil pump qs engine is knocking top end
  231. 4x4 Mk3 Astra
  232. C20XE not firing on 2&3
  233. what sump c20xe
  234. c20xe shafts
  235. turbo 8v ecu
  236. X25XE Vectra / Omega Differences
  237. Vectra 2.0 Xev Whats The Valve For On The Gearbox Side Of The Inlet Manifold??
  238. Rolling Road Results + Power @ Flywheel & wheels query
  239. Whats this pipe??
  240. few problems with xe corsa
  241. xe conversion temp gauge prob
  242. C20LET Sump gasket
  243. corsa xe spluttering.no ecu light on!! help
  244. What engine mounts for trackdays?
  245. xe corsa spluttering but no ecu light on!! help
  246. Door wiring loom plug. What contacts are used......
  247. rebuilding a c20let head
  248. New lease of life... CATALYIC
  249. Nova Let Radiator?
  250. dump valve on my z20let gsi turbo
