Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. abs removal in corsa gsi...how?
  2. F13 Box
  3. need driveshafts for the astra?
  4. combustion chamber volume
  5. C20LET Starting Probs
  6. corsa C 1.8 tunning help please
  7. Quick Q - what model box was fitted to a MK1 Astra GTE?
  8. camshafts
  9. astra 2lt 2000 diesel fails to start
  10. crankshaft pully removal
  11. can anyone see anything wrong with this spec?? (16xe on bike carbs)
  12. Fault code reader, anyone Chester area got one?
  13. 20xe pocketed pistons
  14. astra 1.4 8v fault code 44+45!WTF!!
  15. speedo cable to gearbox sender needed!
  16. how good is the 3.2 steel crank?
  17. nightmare f28 box in a corsa
  18. c20let gearbox question?
  19. Will a corsa b 1.2 spi engine without P.A.S, fit a corsa b with P.A.S?
  20. saab engine
  21. Short shifters
  22. corsa b exhaust
  23. head porting - polishing (diy)
  24. smokey cav
  25. MOT and cv boot
  26. what to do with powersteering pump in nova
  27. engine mout time
  28. need help on gearbox and flywheel 2002 astra
  29. Identify the Part!
  30. xe into an mx5?
  31. CALLI/CAV 4X4 questions
  32. xe swap late to early
  33. c20xe
  34. mk3 astra downpipe
  35. c16 trouble
  36. XE cam pulley differences?
  37. c20let gasket on downpipe
  38. C16XE advice everythin!!
  39. Knock Sensor
  40. Corsa 1.6 16v motor to fit on 1.4 16v loom
  41. Pipercross Require car for development
  42. 2.5V6 (Cammed) or 3.0V6
  43. corsa diesel help
  44. c20let smoking
  45. Let problems again
  46. early 20xe into Mk3 18. Sport, engine mounts
  47. let into corsa c
  48. Monaro
  49. need a guide to c20let
  50. 1.7 TD Mk4 Astra Battery light on sometimes
  51. lightened flywheel
  52. Can i fit airbags to my cav turbo?
  53. F20 Gear Ratios
  54. afm to turbo intake pipe
  55. c20let cams help??please
  56. 2.0 8v cam HELP
  57. lambda sensor help !!
  58. Pic Request
  59. Changing Gearbox
  60. clutch arm snapped
  61. Tigra 1.4 16v fault codes
  62. 1.2 SXI 04' Advise on noisy chain.
  63. V6 Chip on the bay?????????
  64. X10XE - Idleing Issue
  65. Astra radiator help please
  66. when i fit f28 to nova, what linkage?
  67. put new wishbone on, now it knocks!!!!
  68. con rod oil ways
  69. Mk3 engine into Mk4 Astra
  70. Corsa misfiring if throttle pressed too fast?
  71. idle question about figuring out gearbox code
  72. quick help needed. actuator fitting?
  73. corsa sport problems(video uncluded)!!!
  74. Low comp pistons for c20let needed
  75. Low compression on 3, Misfire on 4. Any ideas?
  76. How much does a nova fuel tank hold?
  77. cant make out engine number
  78. Will my gears work?
  79. x18xe1 block/head
  80. Astra MK4 Redtop
  81. pulleys
  82. redtop and ecotec bottom end?
  83. v6 engine not starting
  84. Forged pistons with standard rods?
  85. 2.0 16v alt differences
  86. Z20LET boost leak
  87. cv joint help needed
  88. thicker head gasket to lower compression
  89. corsa turbo shaft setup
  90. Price for LET...
  91. Rebuilding bottom end c20let
  92. Corsa let cutting out every now and again?
  93. magnacore ht leads c20let
  94. Swapping F20 internals into an F25?
  95. What does this sound like to you?
  96. Changing from ecotec to red top in Astra Gsi, Help needed.
  97. fuel pumps/swirl pots
  98. Nova 2.5" exhaust system
  99. Xe Oil Pressure
  100. X25XE Running rich. Causes?
  101. V6 oil cooler
  102. Engine Fail - Hall sensor -> High Voltage
  103. Wanted, speedo cable drive, screws into top of gearbox.
  104. what oil on 230 bhp xe
  105. Diesel to a Petrol :\
  106. inlet manifold xe/let?? any diff?
  107. Info on availability of Throttle bodies for 2.016v eco engine
  108. Zafira 1.9 Diesel Airbox
  109. head rebuild
  110. Car runs lumpy on startup, then idles fine?
  111. too much air !!!
  112. Cosworth inlet plenum on a c20let?
  113. coolant temp sensor
  114. need a "yeah it'll fit" before i buy on ebay
  115. cavalier injection question
  116. Cavvy mk3 gearbag question??
  117. gearbox gasket
  118. Fuel lines
  119. Heat Wrapping
  120. Picture required please
  121. XE with F16
  122. nova turbo f20 or f28
  123. C20let all valves worn up, what brand should i get?
  124. cav gsi problem
  125. 3.2 V6 Questions!! Help Needed PLZ
  126. weber alpha on a carbed redtop info?
  127. Heaviest cams for a mainly road/little track use redtop?
  128. c16xe gearbox oil how to fill up
  129. head gasket problems
  130. Cav Internal Shifter into Nova
  131. Problems
  132. Decat pipe
  133. 2.2 let?!
  134. C20let Omex 600 Base Map
  135. clutch for f20
  136. Airbox and Filter
  137. c20xe or c20let nova?
  138. oil in coolant, oil empty, C20XE
  139. Drive shafts & hubbs
  140. f20 gearbox, need help.
  141. High CO emisions - causes
  142. oil pressure
  143. Turbo diesel engine question
  144. c20get parts
  145. M.O.T re-test tommorow...
  146. battery problems
  147. Innovate LM-1 wideband o2
  148. larger AFM on an E16SE nova gte
  149. xe problem
  150. XE oil pressure sender for VDO gauge ?
  151. Quick 2wd conversion kit driveshaft seal question
  152. Oil catch/breather tank
  153. CV Joint??
  154. Sark plug question with pics. What caused this?
  155. 1.6 8v into a corsa b 1.2l,
  156. Rad for a V6
  157. spax rsx can i get these fixed
  158. c20xe crank tolerances
  159. water pump
  160. Cav GSi cluth cable pain
  161. Lamda sensors - do i need a specific one?...
  162. Astra VXR injectors in LET...
  163. 2.2 Vectra poor running
  164. can someone help me with smokey turbo syndrome?
  165. Another year goes buy & another C20let bottom end is on route...
  166. turbo woes let
  167. x25xe engine cams
  168. Increased CR management?
  169. Anyone got a pic of a sbd 16xe TB inlet manifold
  170. Differerence between T34 2wd and T34 4wd?... for c20let?
  171. V6 ecu upgrade!
  172. sfi bolts
  173. Astra 'f' 1600 > 2.0
  174. broken key in fuel cap help!!
  175. nova 16v brake upgrade
  176. conversion hubs and shafts for corsa
  177. 2.6 v6 vectra what cams are in it?
  178. Z20LET Problem.
  179. 4X4 Ideas
  180. Bad Luck Begins, URGENT HELP?!
  181. C20XE fault codes dont make sense
  182. 2.0 cdti 2001 astra - turbo problems
  183. Are these fmic's any good?
  184. Major Issue With Gearbox - HELP!!!!!!!!!! Stuck
  185. Help, Starter Motor Jammed On C20LET?
  186. c20let late type
  187. V6 Manifold to gasket Leak.
  188. nova c20xe throttle cable
  189. 4x4 nova turbo
  190. corsa torbo niggles
  191. How much differance do enlarged tophats make?
  192. corsa let owners, what clutch cable?
  193. Corsa 1.5TD just head gasket?..
  194. Punto Problems- Missfire??? Help!
  195. Astra G OPC
  196. corsa mounts
  197. C20XE white smoke on first start
  198. 1.6 16v corsa engine in a nova need help with wiring
  199. 2.0 8v into Vectra, R plate?
  200. f28 box in a corsa
  201. noisey f20
  202. Jerky Vectra
  203. What to do next to my engine???
  204. vxr aftermarket throttle boddies..
  205. Are all f20 gearbox speedo driven
  206. engine code
  207. Is this f20 box speedo cable driven
  208. Redtop, Cast iron bottom end?
  209. x14xe inlet manifold problems
  210. Vmax Evo5 fuel pressure
  211. f20 diff freeplay settings
  212. nova sri gearbox fit on corsa 1.416v
  213. Corsa Diesel Gearbox info
  214. Where comes from this tube?
  215. is the 2.0 ecotec a straight swap for c20xe
  216. will this fit x16xe
  217. 20xe safety?
  218. difining a vxr lump from a mk lv sri
  219. C16xe gsxr bodies - getting there, few q's
  220. vxr conversion
  221. Broke my Inner CV joint on my Corsa LET
  222. Mot / Emissions
  223. GT2876R turbo blown?????????
  224. symptoms of having wrong fuel pump (c20let corsa)
  225. Hunting/Lumpy Idle/Kangarooing at low speeds
  226. 2.0 8V Bike Carbs?
  227. melted piston 2 on c20let
  228. nova 2.0 8v shaft probs
  229. C20LET Oil Feed Pipe?
  230. xe 4x4 question
  231. c20let loom info
  232. knackered head?
  233. oil pump
  234. oil pressure
  235. X16ser??????????
  236. Astra G MK4 - 1.7 DTi Cooling Questions
  237. Ecotec Gearbox Woes
  238. Fitting Oil Cooler Sandwich Plate to C20LET
  239. Z20LET & X20XEV Engines
  240. How to wire an LET to a mk3 gsi
  241. C25xe weight
  242. injectors
  243. good clutch for a f20
  244. C20NE differences?
  245. What I need to fit a 2.0l8v in a 98 corsa 1.0l
  246. conversion mounts
  247. Z22SE oil leak
  248. veccy 2.0 16v petrol
  249. anybody with tech 2 near to stoke on trent ?
  250. c20xe coil pack to dizzy wiring plz help!!
