Google
PDA
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218
  1. Can you test AFM?
  2. decent t3.4 turbo
  3. 1.4L -> +1.6L
  4. Which gearbox for a C25XE?
  5. help needed non starting 1.0l corsa
  6. injectors (pics)
  7. performance coil
  8. Manual gearbox oil for omega
  9. Weber final fitting small questions
  10. can someone tell if this is the correct ecu for an x16xe
  11. Injector Flow rate and ECU fuel Map Query
  12. Whistling from C20LET
  13. nitrous kits and info?
  14. astra gsi c25xe
  15. Couple of questions about c14nz
  16. Easy way to tune xe
  17. C20let part
  18. c.v is stuck!
  19. T34 turbo manifold? (see pics)
  20. wire it up?
  21. Oil Cooler "ON" temperature
  22. C20/Z20/X20 Cams
  23. Intermittent problems Car keeps stalling
  24. astra mk4 upgrade
  25. Astra MK3 Turbo - Rebuild and best spare parts.
  26. 16xe conversion, ecu options
  27. Vectra V6 transponder help
  28. Pic Request
  29. astra g - engine on signal
  30. V6 Oil Cooler Question.
  31. 4x4 rear diff and shaft probs
  32. C20let Alternator and starter motor part number
  33. Removing 2.0 XE valve stem oil seals
  34. white smoke when cold (izuzu 1,7 t.d cav)
  35. Astra GSI Engine Mount Pictures
  36. 33 splines on 1998 astra gsi driveshaft?
  37. 2.0 16v Ecotec non start
  38. 1.7td nova conversion
  39. torque setting for TX.box to F28?
  40. x16xe driveshafts
  41. phenolic inlet heat sheilds
  42. vxr core into kkk16?
  43. corsa 1.4 8v idleing problem(again)
  44. knackered lamda sensor symptoms c20let
  45. Lightened flywheel??
  46. astra coupe z18 xe1
  47. Vectra gearbox
  48. Blocked breather pipe on x16xe
  49. mk3 astra gsi v6
  50. Injectors, FPR, Boost.
  51. xe cam in to a let
  52. xe inlet cam
  53. Hydraulic Lifters of Ebay
  54. Auxiliary belt tensioner problem. Help!
  55. x16xel to x16xe
  56. Coscast and cometic question
  57. 280BHP XE
  58. 20SEH Turbo
  59. Vectra V6 won't start :(
  60. torky
  61. 3.0 CDTI question
  62. C20XE loom + ECU indentification
  63. Polished and ported heads
  64. wich LET manifold for T3/K26
  65. vectra v6 idle problem
  66. c20xe with f16 box
  67. coscast head 2 fit newer redtop? where i can get1?
  68. C16NZ - What sensors does it have?
  69. i want to fit 40's to my astra
  70. C16XE pistons - info on getting them pocketed asap
  71. need to go faster
  72. Xe Timing Check and other queries
  73. oil cap scummy
  74. How to balance throttle bodies?
  75. Coupe Turbo servicing intervals...
  76. Astra F gsi holding back problem
  77. Block difference C18XE, C18XEL and X18XE
  78. Head Gasket and Bolts advice please for c20let
  79. speedo drive?
  80. Tempreture
  81. XE/LET fuel rail question
  82. Corsa 1.5 D - Problems
  83. Timing belt snapped
  84. what filter??
  85. Exhaust advice please
  86. Heaters playing up...
  87. VXR engine into an astra coupe turbo.
  88. clattering noise from 2000 rpm to the high end
  89. Inlet manifold adapter
  90. corsa v6 power steering problem
  91. cam pulleys
  92. Sard return pipe
  93. Vectra SRi 140 - Reliability
  94. Engine mounts?!?
  95. How much is this setup worth???
  96. Headskimming = Thicker headgasket?
  97. Whats this sender?
  98. fule pump not swiching on - astra g
  99. Suitable filler "putty" for alloy inlet manifold
  100. vmax evo5 fueling
  101. how much gearbox oil dose an f23
  102. Lost power
  103. cav 1.7td tuning
  104. Help with Renault Laguna
  105. Re-conditioning
  106. X14XE Engine Cutting Out
  107. let diagram
  108. Think my XE's knackered!!!
  109. Boost hose bore?!
  110. Gearbox questions
  111. What power?????? c20xewith bog brothers carb conversion
  112. how do you connect a oil catch tank?
  113. 20xe what can i do to it
  114. direction of coolant flow
  115. FAO: Turbo Owners
  116. Non Vauxhall question
  117. What box for me?
  118. cam degrees
  119. CAn someone with a LET check this hose for me please?
  120. Adjusting corsa clutch pedal height - Cant turn plastic bit
  121. car keeps conking out!
  122. Taking a drive shaft out
  123. c20let radiator question
  124. Traction Control Fault Codes
  125. 2.0 8v engines. Which to go for?
  126. penny valve
  127. V6 alternator fan
  128. gears all gone
  129. EEeeek!! Engine not starting!!
  130. What oil for an F20 box?
  131. A 4x4 switch?
  132. corsa v6 conversion
  133. Can any good come out of this?
  134. early 20xe info
  135. keeping power steering on c20xe conversion
  136. Which Plugs for C20LET
  137. XE kangarooing at 2k rpm
  138. c20xe into 16v corsa b, with power steering
  139. engine blowing smoke
  140. c20let f18
  141. How 2 Remove Rocker Cover+Head-C20XE
  142. power upgrade questions
  143. detting??
  144. c20let phase 3.5+ kits
  145. non starter
  146. F20 box stuck in gear but selector is in neutral
  147. XE Crankshaft fan belt pulley question
  148. Nova GTE/GSi engine into mk3 cavvy??
  149. Peugoet Rad question
  150. C25XE Engine Parts
  151. Engine numbers/M.O.T. 2.5V6
  152. Tuning a standard Mk2 Astra Gte 16v
  153. KKK26 turbine + KKK27 compressor 400 bhp+
  154. What turbo to upgrade to on LET?
  155. c20let inercooler pipes
  156. radiator hose id
  157. GSI 16V MANIFOLD upgrade?
  158. E30 3 35
  159. more XE help needed please
  160. DTA basemap onto MBE ECU
  161. c20xe + f20
  162. c20let damaged pistons question
  163. fitting a oil pressure gauge onto my z20let
  164. C20LET Rev / missfire issue
  165. gm xe spark plugs
  166. Corsa V6 Alternator Belt????
  167. Some 2.0 8v Head advice please
  168. a couple of c20let head rebuild questions
  169. C20let hesitation
  170. v6 oil cooler change???
  171. converting a c20xe to a c20 xe turbo
  172. Thought I'd have a go at the porous/cracked head modification!
  173. difference betweek cometic and not?
  174. Torque settings and order for c20let with ARP and steel gasket
  175. Which Ecotec fits a nova or corsa b?
  176. c20xe overfueling
  177. Oil on the sump
  178. z20let/c20let
  179. gearbox for a c20let?
  180. 1L corsa really hard to start.
  181. Cav GSI WEB flexy bit on exhaust
  182. gearbox problem, likely cause?
  183. Strange noise on my C20LET, F28 gearbox related?
  184. Which Mk4 astra diesel to go for?
  185. Nova XE Exhaust manifold
  186. Which way round??? Corsa b xe
  187. vectra 1.8 ecu probs
  188. gearbox problem
  189. Water cooling system problem(c20xe)Cracked!
  190. 3.0l V6
  191. c20let funny problem
  192. cav gsi runnin bad
  193. recon turbo
  194. gsi runnin bad
  195. C16xe Idleing Problem
  196. coscast or not?
  197. any help please
  198. torque setting
  199. 1999 Corsa 1L 12v won't start!!
  200. corsa equal lenght drive shafts???
  201. redtop dizzy and coil pack
  202. Vectra 1.7Td to Sri
  203. will a c16xe go in a tigra with a x14xe ok and run on x14xe wiring?
  204. Where to buy glow plugs online ?
  205. Corsa LET Starting Prob
  206. Inner cv removal
  207. x25xe vectra gsi to astra conversion
  208. Power boost Valve
  209. kent cams
  210. fuel reg
  211. Well that's SERIOUSLY bad.........:(
  212. Just bought Engine for transplant!!
  213. redtop hesitating
  214. Best exhaust for redtop
  215. Too much pressure!
  216. Corsa B C25XE running hot.
  217. cav gsi conversion to diesel
  218. crank sensor on a 2.6 omega?
  219. Best cracker turbo for my c20let?
  220. EBay F28 Gearbox Saga or Careful Research And Never Take Anyones Word!
  221. How to tell what gearbox is fitted to car
  222. Guide to Converting Rear Nova Mount for Big Block Conversion
  223. flat flywheel size
  224. dizzy to dispack
  225. C20NE to C20LET?
  226. c20let dont like mornings
  227. Crisp gearchange when cold, difficult when warm?
  228. fidanza fly
  229. corsa f28 modified linkage problems
  230. corsa c and c20let with f28 gearbox mounts
  231. fwd v6 techie question
  232. what are the syptems of a failled head gasket?
  233. co emissions
  234. GSi Cavalier RWD
  235. Part Numbers where from ????
  236. adapting engines and boxes - clutch options
  237. k26 turbo wants need
  238. How can I lower emissions on C20LET?
  239. corsa engine mounts
  240. anyone good with immobilsers/alarms near stoke?
  241. 1 & 4 STILL not firing...
  242. smoking!!!
  243. vauxhall firenza
  244. 1.4 8v.... who's built a lairy one??
  245. Mates XE'd Nova won't idle.
  246. Enlarged throttle body question...
  247. turbo help
  248. Tuning Webbers
  249. vectra engie problem won't start
  250. abs removal in corsa gsi...how?
