- Vectra Diesel starting question
- fitting c20xe to mk4 astra 2.0sri
- Astra F mk3 GSI 16v ...CTS sensor problem?
- 2.8T VXR Into Astra G
- corsa c 1.4 sri PROBLEMS CUTTING OUT
- z20let Tapping from cold
- precat decat
- astra sri temp / thermostat / overheating
- best head gasket for c14se?
- any reason i shouldnt buy this C20LET Turbo?
- x20xev info needed
- v6 tubular manifolds
- astra coupe stalling after changing battery
- v6 ecu help
- C20LET Missfire
- Whats the best gearbox to use on my C20NE
- Will a Z20LET run with no exhaust?
- 8v turbo knock help
- 1.4 8vsri head on to 1.2 8v
- 20xe suspected head gasket help!
- Safe Power from standard C20LET
- Corsa Redtop starting and gearlinkage issue
- vectra c vxr engine into corsa c ???
- final drive ratio identification
- c20let earths
- vectra clutch losing pressure
- corsa x20xev conversion
- Engine swop price
- electric f28 on corsa
- How to set up F28 gear selector
- Garrett gt restrictor
- help needed with air con removal on x16xe please
- 2L Turbo Vectra white smoke
- C20let standard boost
- Fuel Lines
- Mk4 Astra X18XE1 swtich valve solenoid
- corsa b x20xev need help please!
- C20LET no compression
- 4wd gear box options
- Corsa b x16xe problem
- Engines with HG failure left standing for a long time. Problems?
- Mk3 Astra Key code???
- z16xe turbo ecu dump needed or ignition retard map
- Lingering and flickering oil light
- Omega Y26SE History lesson :)
- Going to courtney for remap
- What resistor value for X20XEV EGR delete?
- 1.6xe astra mk4 too 20xev help.
- 20seh Loom (Fitting engine into a chevette)
- c20xe gm head
- mk3 astra gsi traction control problem
- debilas throttle bodies
- how hard is it to put a 2.0 litre saab engine in a corsa b!!
- c20xe Equal Length shafts
- z20let cluch help needed
- Pontiac firebird overheating
- C20xe and C20let throttle sensor
- Fuel pump REALLY loud
- x30xe 0mega astra MK4 no spark
- Mk4 X20XEV Lexmaul / Help???
- c20xe head gasket
- Few questions regarding CLET/ZLET/ZLEH
- C20LET Opinions.
- Z10xep into x10xe corsa b
- Z22se wrong oil Cause cam lift
- z12xe big end bearings
- C20xe Corsa running on after ignition is turned off! Please help!!!
- Vectra idle problems.
- Mk3 Astra chip and transponder
- afr gauge location?
- Vectra engine fault, ECU light on.
- Astra C20LET engine failure
- C20XE sparking problem
- Damage to big end bearings from my redtop astra
- gt28r questions
- Recovery emergency !!!
- GM 10-40 Semi in Corsa B 1.5 TD?
- Astra F/MK3 C16se to c20xe conversion?
- astra 5 sri turbo
- E16SE cam in C14NZ
- 97 Vectra - Hole in casing between gearbox and diff
- Corsa b 1.0-engine cutting out
- C20let wont start
- x30xe ecu codes (getting code 55)
- C20let overfuelling
- Astra 1.7 CDTI engine bay wiring
- No power from ECU. 20XE
- z20let whining when first started
- Question about Crankshafts ???
- Limp mode?
- xe wont run, popping/bangging
- rolling rd results
- tx tophat on my zlet problem
- clutch suggestion, slipping hell.....
- Astra 1.4 turbo Sri cambelt
- 98 reg astra 2.0 16v runs lumpy after 5000 reevs
- Redtop fitting to mk4 astra Questions - help please :)
- Saab turbo into MK4 astra
- C20xe lambda sensor
- GT2871 -fited - what to do with amal pipes ? :(
- Who makes inlet manifolds for bike carbs?
- nylon relief valve
- Dump valve not dumping...
- hard or rubber fuel lines
- c20let problems! still ongoing!
- 1.8 engine help please (z18xe)
- Mk3 astra sport 1.8 engine?
- Corsa 2.0 8v keeps cutting out poor fuel consumption
- sr oil pressure guage
- 20 SEH oil pressure
- 1996 Astra running badly
- Xe Torx bolt socket sizes
- Corsa 1.2 8v to 1.4 8V Swap, wont start.
- mk4 astra gsi z20let only boosting to 7 psi
- 1.7TD stainless steel exhaust manifold?
- X20XEV weight
- Use rvt sealant on boost pipes?
- 05 combo 1.3 cdti hard to start
- c20let oil pressure / temp
- X20XEV What goes where?
- not idleing c20let
- Custom inlet manifolds
- quaife f13 diff using f20 side gears
- Are 8v small block flywheels all the same?
- core/freeze plugs
- c20let fuelling problem
- corsa b 1400sri 8v gearbox .
- Fuel rail pressure? XE
- Vectra B 2001 with intermittent misfire problem
- C20XE Corsa which throttle cable? URGENT!
- c20let over boosting
- twag conversion looms
- X20XEV What goes where???
- C20XE TPS wiring
- c20ne timing belt cover
- X20XEV vacuum hose location???
- V6 Cavalier sump gasket fit V6 Vectra
- c20let oil pressure on t3?
- f20 cv joint problem
- Mk4 Astra Z17DTL - error code and engine rev limit at 3.5k
- Nova throttle cable / accelerator cable
- zafira 2008 1.9cdti auto spanner light on and sport button not working
- Corsa B Radiator
- 1990 nova 1.4 sr bogging down
- help/info needed from vauxhall gurus OMEGA 2.0
- gearbox speed sensors
- Diff bearings part number.
- Oil in intercooler pipework - Turbo oil seals shot, can't bea anything else can it?
- Yet another digi dash question.... Sorry! F20 in corsa b
- Quaiffe ATB F20 & F23
- z20let oil in water..
- C20LEt with F18 clutches?
- Clutch Help
- C20XE running on few a few seconds after key is swiched off????
- what vacum dhould the ports show on a well built head
- C20XE Backfire through induction???? hesitation?? WTF? please help!.....
- Driveshaft identification
- gearbox id
- Astra GSi - oily smell after new turbo fitted..help
- Carb setup on coil pack c20xe
- c20let smoking on tick over
- dry sump tank capacities
- Oil feed banjo thread size? Saab.
- C20let oil return thread .
- C20let corsa b only boosting to 5psi
- calibra engine
- stud size
- X20XEV-what injectors to use
- xe16 head types
- oil sandwich plate query
- z20let water system and pipe work
- I Want 200bhp from a C20XE Help or suggestions Please.
- C20xe on bike carbs questions
- 2.0 8V Corsa strong oil/petrol/exhaust smell in car ...... HELP
- saab astra
- Vauxhall Nova Club. Which fuel?
- C20XE Corsa over heating after heater matrix bypass!! please help!! so confused
- MK 4 MK3 GM engine heads and scavenging bits
- C20let Head gasket 88mm bore
- Want extra power v6 corsa
- Crankcase Ventilation system - Astra-G.
- Vauxhall Astra SXI 1.6 stalling
- What is required to Tune my SAAB B204 up to Stage 3?
- c20let eds phase 1
- Cav 1.3 to c20xe - first start up issues, c20xe Gurus look here please :)
- X20XEV ignition coil ht arrangment
- C20LET nylon oil pressure relief vale
- C20xe conversion
- astra sxi giving out blue smoke
- Air valve on x20xev
- z18xe
- Mk4 Astra auto kick down switch location?
- X18XEV1 starting and cutting out problem
- Corsa C20LET Build
- Cam Identification
- ARP main stud instructions
- need technical help z18xe throttle bodies...
- C20LET Which throttle body
- Sluggish diesel Pug 406HDi
- advantages of an xev crank on a let?
- closed cause im being a tool trying to by-pass selling rules.
- who have a z20let pump on his c20let
- mk3 c20let wiring questions
- Mk2 Cav 1.3 to C20XE - Radiator ok?
- Z18XE into Mk4 Astra van fuel pump problem maybe?
- Let with f23 box clutch help
- What to put on throttle bodies?
- XE Valve difference?
- engine swap from a z16xe to a x18xe1 astra mk4
- Lifting an F28 into position
- Is Z20LET inlet manifold an improvement on X20XEV?
- C20let corsa b boost pipe question
- does anyone stay near stirling that can have a look at my car ??
- nova c20let coolant pipes
- C20LET Nylon relief valve prices
- let oil feed bolt
- LET bottom pulley bolts problem
- Are my valves lapped in properly? C20XE
- Vectra 2.0 water temp sensor faulty?
- vectra b z18xe lpg wire connector help.
- c20let vmax tuning
- calibra turbo brake master cylinder upgrade
- Stripped down turbo
- engine for sale c20xe and various other bits :)
- Corsa B 1.2 16V Won't Start
- P1640 Quad Driver Module fault? X14SZ
- C20let corsa b boost/idle issue
- Gear stick feels spongy and has a lot of play...?
- astra z20let standard dump valve?
- where will i get a dump valve flange from for astra coupe turbo
- c20xe kangarooing - any ideas?
- c20xe high idle when warm
- Dimensions needed please.
- 1.7CDTI ETC location?
- V6 Transplant
- f16 broken cv
- Gear selector
- Clutch
- Coil pack or Dizzy?
- anyone had problems with Autovaux cam belt kits
- Hydraulic lifters(tapetts) dimensions on Coscast head
- 2.0 8v f15
- corsa b chassis plates
- C20XE idle problem
- valid c20let exhaust camshaft number??
- 3 way union on let inlet
- Astra H Clutch and Flywheel.
- Nova c20xe exhaust questions
- Vectra C Z20NET Blow off valve
