: Engines and Transmission
  1. rolling roads- any advise on where to go and a rough price please
  2. quaife gearbox?
  3. Is xe flat flywheel better/lighter than dish type?
  4. whitch tps is this
  5. 1.6 engine codes
  6. top hat gasket PN
  7. best headgasket for c20let?
  8. 1ltr 12v
  9. HELP remove front exhaust manifold cav v6 c25xe
  10. help! corsa driveshaft xe problem
  11. just put new block on my gsi let not boosting right and spluttering
  12. f28 problems
  13. where too get a plated diff from?
  14. c20xe dizzy and none dizzy engine differences?
  15. X20XEV runing on - dieseling
  16. fitin 5th injector on coras 1.4 16v turbo
  17. weird ticking with video
  18. what ignition system on mk3 astra 1.8 sport
  19. corsa 1.4 16v
  20. cable to electric speedo ??????
  21. Radiator question
  22. Install a external Fuel Pressure Regulator
  23. Waste gate chatter???
  24. 2.0 8v into a corsa
  25. Silicone hoses?
  26. whats the bare minimum
  27. Exhaust manifold
  28. Are these the symptoms of a driveshaft being too long?
  29. astra mk4 front upper strut brace :S
  30. Omega V6 ecu into Cav V6
  31. LSD into 2.0 omega??
  32. mv6 help needed pls
  33. breather pipes from the rocker cover?
  34. help identifying xe inlet cam
  35. What engine mount
  36. C12nz overfueling
  37. zlet acl main bearing wanted
  38. Aux belt on an x14xe
  39. Egr Valve
  40. C20LET sport air filter question
  41. x30xe in mk3 astra
  42. Xi2xe corsa engine nightmare
  43. Where is my engine code
  44. 3.0 v6 engine conversion
  45. fitting c20let in mk 4 astra
  46. X20XEV water/oil issue
  47. 2.5 V6 conversion in a nova or corsa etc possibly RWD & Rear fitted
  48. Advice and guidence needed (Vectra GSI Engine Swap)
  49. vectra c cdti 6 speed f40 gearbox
  50. Part Number For Coscast Head Core Plugs
  51. hub question
  52. 20SEH ECU's
  53. Throttle bodies or turbo??
  54. redtop wont start
  55. redtop help!! few probs, misfiring, and lamda wiring!
  56. Anyone know old cars ? 1977 Chaser .
  57. x14xe engine mount
  58. Genuine GM C20let/C20xe Hyd Lifters
  59. No coolant return from turbo z20let with leh turbo
  60. in need of a f20 gearbox!!
  61. Mk1 nova 1.3sr ,idling problem,
  62. C21xe on R1 carbs runnign at high idle
  63. Info, F18/F20 gearboxes
  64. throttle pos sensor C20XE Engine M3 GSI 2.0 16V
  65. injectors c20xe
  66. quick gearbox question
  67. what benifits from earlyer type flywheel on coil pack type c20xe
  68. intermitten glow plug light
  69. looking for a how to for changing timing chain on a 2.2 vectra
  70. who's local to gateshead
  71. loud click/tick on z16xe
  72. need help engine number on c20xe???
  73. Astra V6 - what exhaust middle section?
  74. Cav V6 engine in Astra - no fuel or spark
  75. can anyone help 1.6 16v head on a 1.4 16v bottom end?
  76. gearbox problem zafira gsi
  77. c20let engine management light help
  78. car slows down when going up hills
  79. astra H 1.8 design limited?
  80. Water feed for 2860
  81. High pressure in coolant? Please help
  82. Need Advice Please
  83. engine swop
  84. Bypassing amal valve with a MBC ? God or Bad?
  85. what parts am i missing???
  86. Astra G X14XE to X16XE conversion probs!
  87. where to find jenvey throtle bodies for c20xe ???
  88. Can i put a head off a 1.8 sri Ecotec corsa on to a 2.0 Ecotec bottom end?
  89. c20xe going through spark plugs
  90. xe inlet cam
  91. Is this to be expected?
  92. are c20let and z20let exhaust mainfolds the same fitment
  93. C20LET gearbox solutions
  94. driveshafts
  95. do i set fuel pressure with vacuum pipe off? c20let
  96. X20XEV Head on a Z18XE
  97. driveshaft question
  98. Really need a F16 or F20 gearbox for corsa b xe in Hampshire area. Help!!
  99. Is this the Fuel Regulator? Picure attached - M3 GSI 16V RED TOP
  100. Any one any iders on how to by pass imoblisers v6 corsa.
  101. Clutch Pedal stays down sometimes Astra GTE
  102. c20let oil pressure readings (psi)
  103. F13 box and GTE dash?
  104. 20Xe into 12. 16 Corsa B Wiring help
  105. corsa x14xe cutting out/poor reving
  106. Z20let rocker gasket issues
  107. C20let boost fault
  108. Mk1 Astra, running problems !
  109. V6 fault code 74
  110. 1.9 cdti differential
  111. X18XE1 Annoying Missfire!!!!
  112. Fitting A Rear Crank Seal C20LET
  113. c20let engine number - whats yours?
  114. fitting nova sr into 1.2 spi
  115. Astra G 1.4 (X14XE) now power when in gear HELP PLEASE!!!!
  116. Mv6 engine
  117. Piston Slap
  118. jenvey inlet mnifold for c20let
  119. Tell me about fitting C25XE into Astra mk3
  120. C20LET Missfire at 1.2 BAR GT28 Turbo, ECU?
  121. c20let flywheel.
  122. Noise/whine on tickover 2005 astra 1.7 cdti any vaux tecnicians on here pls
  123. Identify these injectors please
  124. c20xe engine number
  125. Z20LET Turbo upgrade
  126. F20 4x4 box
  127. z18xe modifications
  128. 2.2 road tax, how much is it?
  129. 1.7CDTi or 2.0DTi?
  130. engine technicain/builder/mapper course
  131. c20xe minimum flywheel thickness
  132. cavalier 4 stud hubs are they same as cailbra
  133. corsa b gsi idle problem
  134. V6 Corsa Runs for 2 secs then dies any 1 any ideas?
  135. HELP! kkk16 is knackered---- what turbo do i get nxt!
  136. head gasket and cambelt kit
  137. ecu for dizzy C20XE?
  138. c20xe idle problem
  139. decat, strait through
  140. I love vaux 8v engines!!
  141. Lamba sensor 20xe
  142. saab turbo engine in to corsa b
  143. Ecu remap
  144. redtop engine
  145. no signal to injectors, any ideas?
  146. Adjusting weber fuel pressure regulator
  147. cracked turbo manifold - easyfix?
  148. z20et advice
  149. 20XE/LET Oil Cooler Banjo Size
  150. C20xe Inlet manifold tuning
  151. astra mk4 1.8 16v upgrades
  152. c20xe single v pulley
  153. where is the engine number on the c25xe?
  154. c20xe
  155. Z20let smoking
  156. headgasket????
  157. Corsa B hub carrier - c20let question
  158. astra f23 gearbox info required
  159. is any one running a griddle on their c20let?
  160. turboin corsa sport 1.4
  161. c25xe fires up then dies
  162. x14xe running on 2?
  163. Can somebody please confirm the thread on a c20let / xe head bolts please
  164. Actuator / boost problem .
  165. Standard turbo mannifold gasket or uprated? (c20let)
  166. what is this called
  167. x18xe1 ecu alarm
  168. X20XEV ecu light
  169. Front mount on a astravan 2.0 dti 16v
  170. joys of owning a corsa 20xe,please help
  171. Info on C20xe needed
  172. mk4 astravan c20xe conversion
  173. Eds phase 3.5 power....
  174. Corsa b 1.6 turbo?
  175. corsa b gear ratios
  176. Uprated fuel pump for c20xe
  177. emissions fail :(
  178. mk4 astra 2.0 code flashing
  179. What power can a standard C20LET clutch cope with?
  180. 1.8 16v Throttle Body on X20XEV
  181. x22xe lost all collant and developed v noisy cylinder Help!
  182. c20let air flow meter
  183. Bleeding coolant z20let, please help
  184. help c20let smokin
  185. ASAP help, f28 diff goosed??
  186. solis lifters and shims
  187. Cavalier TD 6 Speed???
  188. Standard C20LET Turbo Rebuild
  189. 1600 8v mpi engine rebuild.
  190. upgrading my engine
  191. help wont revs to 4500rpm and rises instantly
  192. Need more torque!!
  193. remaping
  194. Can i get an uprated clutch for this set up
  195. fitting downpipe,middle section and back box on vectra b x18xe1?
  196. help rebulding a c18nz engine for maximum bhp
  197. 2.2 power
  198. C20XE Bottom End - C18NZ or 18E ??
  199. c20let build, Torque setting?
  200. Anyone identify this port please
  201. Removing diff from gearbox?
  202. Egr valve
  203. x14xe head on x16xe how does it turn out?
  204. Car will not start, has a spark and seems to be getting fuel; Corsa B 1.2 X12XE
  205. Do V6 engines have bolt hole for equal length driveshafts?
  206. X16xe group n exhaust
  207. red top valves
  208. x20xev running in limp mode need help
  209. A question about the 4x4 system...
  210. Problem After Fitting VXR Turbo to Z20LET
  211. X18XE engine into a cavalier 1.8 ohc
  212. whats the first thing to let go on z20let?
  213. c20xe wiring
  214. WANTED F16 or F20 GEARBOX for my C20SEH sri 130
  215. C20XE Misfire
  216. Right i need engine help or somewhere to go
  217. Spin up to fast for clutch ??
  218. crank spec
  219. F28 questions
  220. c20let arp torque settings in (NM)
  221. c20let into astra mk4
  222. x10xe for z10xe
  223. Problem ugent!!!!
  224. Corsa B X12XE NON RUNNER Please Read.
  225. c20let head bolts torque settings
  226. anyone using blow through afm?
  227. f28 Speed Question
  228. Silicone hoses for bike carbs!
  229. c20ne flywheel on c20xe?
  230. carsandguitars68 on Ebay!
  231. 18Se!
  232. c12nz problems corsa ls 1.2 1994
  233. nylon relief valve pressure ?
  234. dry sump plumbing question
  235. c16xe running problems again!!!
  236. 6 speed gearbox corsa D
  237. fuel gauge reading incorrectly?
  238. Any1 got an uprated/racing clutch for c20xe
  239. c20xe idle control valve
  240. Oil pressure relief valve for 2.0 SEH
  241. C20LET lack of power
  242. Corsa Engines..... (1.4)
  243. taking x14xe out of corsa. advice ??
  244. automatic gearbox AF 23 missing 3rd gear
  245. gutless carlton gsi 3000 24v.
  246. vectra 1.8 X16XEV (i think lol) rattling
  247. hard to tune a corsa let on the road. dam
  248. Cossie actuator which one??
  249. Injectors and fuel pump
  250. Want to fit an F18 and clutch to a late XE
