: Engines and Transmission
  1. C20XE distributors!?!?
  2. Camshaft fitting
  3. what engine have i got
  4. 16v brakes - pistons?
  5. Best exhaust for a mk4 Astra?
  6. Water Injection
  7. Breather Mod question
  8. Standard Intercooler
  9. Oil Pressure Sensor
  10. performance heads
  11. re-wire 2.0 ecu 1.8 help
  12. Coil-Bound Springs?
  13. alternator removal (without engine removal)
  14. Injector muck - ideas please...
  15. Exhaust Help Please
  16. headwork and valve size
  17. 2.0 8v engine wiring help
  18. clutches
  19. No spark on Carlton
  20. Nasty-Sounding Exhaust
  21. Unichip Loom Connections
  22. Fuel Pipes on Cav Turbo
  23. Another oil pressure question
  24. How to increase oil pressure?
  25. FAO Gary P - MT196 base fuel pressure
  26. KKK-K16 Max Boost, Info is in
  27. any experts on cav turbos
  28. whats the breather pipe actually do??
  29. where 2 get injectors?
  30. Power-flow systems.....
  31. 4x4 breather pipe, maybe?
  32. Injectors How Do You Clean Them ??
  33. Superchip Upgrade results
  34. *help* V6 Gearbox Jammed
  35. nova semi fixed
  36. turbo question
  37. engine plans
  38. Rocket Cover Gasket + Head Gasket
  39. Vacuum pipe from brake thingy to inlet
  40. Advice + Help needed!
  41. pls advice on engine transplant~
  42. Intercooler Colour
  43. Can i mate an F28 to a C20XE
  44. astra mk2 rear coil overs
  45. What radiator ?
  46. Me and the cossie head are in crisis talks, anyone with input please contribute
  47. where all 4x4 cavs Turbos?
  48. what hapens 2 the oil cooler when
  49. which plugs u all use for ya C20XE?
  50. FAO Gary P :head gen
  51. Dangling wire from back of turbo engine.
  52. Dry Sumps
  53. Remus Exhaust
  54. Change in Power Delivery
  55. Uprated Cams & Clutch
  56. Running a rebuilt engine in
  57. Fiddling with fuel lines....what you must remember to do....
  58. power loss
  59. Set of tappets..........
  60. carb
  61. found my engine number
  62. What Clutch?
  63. Best exhaust system?
  64. astra/belmont gls i 1.8 e-reg
  65. Cav turbo master cylinder on a MK1 Astra GTE
  66. Power gains with a Irmscher exhaust?
  67. Is there a 'Plug in chip' available?
  68. Turbo calipers
  69. Turbo Help
  70. 2ltr 16v V 1.8ltr 8v
  71. Piston and valve intimacy, more news
  72. engine number
  73. Clio diesel help needed please.
  74. Differential set-up in the F20 gearbox..?
  75. 8v head onto 16v block
  76. Crank sensor session and ECU entertainment.
  77. Need Engine Specs For A Rebulid (fao Animal/oddball)
  78. FAO Gary P re: your old jenvey 48's inlet manifold
  79. High Mileage Vaux Diesels - any good ?
  80. Whats the difference between these gear boxes?
  81. weber carbs
  82. vectra 2.2 dti turbo 16v CDX
  83. 4X4 Oil Renewal
  84. Induction Kit for C14NZ
  85. What Carbs?
  86. Serious 4X4 fault please help if you can
  87. Would you attempt replacing a head gasket yourself?
  88. 20XE fuel pump relay
  89. where 2 get bonnet lifters
  90. nitrous
  91. head gone pourous?
  92. Rear Disc Conversion - Pressure Regulating Valves
  93. which carb is best???
  94. Nova GTE Petrol Pump
  95. astra/belmont 1.8 gls i
  96. Symptons of head gasket
  97. Summary of Clutch faults
  98. f16 same ratios as a f20?
  99. Turbo
  100. Urgent help required - Cambelt Auto Tensioner
  101. Return of the Fuel Pressure Regulator!
  102. Intercooler
  103. More Intercooler gen?
  104. GearBox oil
  105. Which Oil?
  106. Intercoolers!!?
  107. Which C20LET/F28 clutch?
  108. C20LET engine oil
  109. Exhaust, does it need to be round?
  110. Rocker cover gasket
  111. Powerflow Zorsts
  112. Strut Brace and engine bracket
  113. KW to BHP
  114. Fuel Pump Prob(I Think)
  115. Recirculation dump valves
  116. cav turbo actuator
  117. F20 or F16
  118. 1.6 Carb Vs 1.6i Engines
  119. Astra SXI 1.8
  120. Changing Cav Turbo Cambelt
  121. 2.0 16V Ecotechs
  122. FAO Simon
  123. 20xe airbox Vs Nova panel.
  124. pics of turbo engine in mk3 astra
  125. Powerflow exhausts
  126. which dump valve for cavalier turbo
  127. where does my oil go?
  128. C20XE in GSI vs C20XE in GTE
  129. C20XE suspect temp' sensor.
  130. Superchip
  131. Dump Valves
  132. How active is your oil pressure gauge?
  133. oil pressure @ idle on 20XE ??
  134. is it worth getting the injectors cleaned?
  135. Unichip...
  136. fao ladies with TB's/carbs and dodgy linkages
  137. Cav Gsi Induction kit?
  138. Exhaust Diameter?
  139. Trip Computer Fuel Sensor problem
  140. superchipping
  141. 1.3 or 1.2
  142. Electric fuel pumps and throttle cables.
  143. cavalier turbo
  144. Water Injection Schematic - following on from an earlier thread
  145. Spark Plugs and OE ignition leads.
  146. 2ltr Turbo Engine into Mk2 Astra GTE 16V
  147. FAO Cav/Cally Turbo knowledgeable people
  148. cavalier 4x4 turbo
  149. F25 and F28/6 gearbox identification
  150. Camber kit problems
  151. New Aquamist CD
  152. Nova 1.3 SR cam specs
  153. cav sri 16v ecu fault 19 Crankshaft Sensor (Incorrect Signal)
  154. Is it posible to be checked the engine head for "cracks" or porous?
  155. F18,F18+ gearboxidentification
  156. F10, F13, F16, F20 Gearbox idefication
  157. nova gearbox
  158. C20XE intake mod
  159. nova engine convertions
  160. nova gearbox,can any one help
  161. HOw can i tell if my clutch is slipping/dieing....
  162. crankshaft sensor
  163. Oil leak revisited.
  164. F20 Gearbox oil
  165. Evo 6 Induction kit on C20LET
  166. Spark Plugs
  167. Fitting Dump Valve
  168. HELP finding a camber kit
  169. Turbo conversion
  170. The REDTOP Judder Test.. step this way.
  171. I've re-profiled the cams, bored out the block, lightened the flywheel....
  172. Fuel consumption
  173. mmmm... 8 injectors
  174. Engine Ticking ??
  175. F28
  176. fitting a valver
  177. What Exhaust?
  178. breather on trottle?
  179. Since fitting the water injection my.....
  180. cam belt cover skimming cam belt?
  181. knocking Noises on Cav Turbo
  182. Custom Exhaust System for Nova
  183. Bottom pulley - bolts siezed
  184. Interesting Info re. SBD 196 kit
  185. 2.0 Nova Gearbox Fitting Probs!!
  186. best cam for1300 nova
  187. bottom block bore
  188. 16v engine into a nova info needed
  189. CAV GSI 16v 20xe lump - hesitation
  190. engine managment warning light
  191. Headlamp Setup
  192. UPDATE: Engine
  193. FAO Richie And Turbo Owners
  194. Powerflow exhausts ???
  195. Sump gasket
  196. Please, help me! There is a oil in the coolant tank!
  197. Sump sealer
  198. Turbo Clocks
  199. Ohh my new engine............
  200. Burning oil smell
  201. Fuel injection information
  202. 4x4 trouble again!!
  203. Putting Oil Pressure gauges in your car......
  204. intercoolers?????
  205. Where to mount electric fuel pump?
  206. c20 let help!!!!
  207. Cav Headlamp adjustment
  208. High Boost Plugs for C20LET
  209. converting to injection.
  210. engine mounts
  211. 1.8 bottom block
  212. engine transplant
  213. Engine stalls immediately after starting, whats wrong
  214. 2.0 8v block
  215. C20let Hesitation
  216. Which Carbs Weber or Dellorto?
  217. FAO people with twin headlights
  218. C20NE in a Cav SRi?
  219. Gearbox
  220. SRi Head gasket
  221. starting/choke problem on mk2 1.3 astra
  222. Why not to buy a superchip, or any other fixed map chip upgrade
  223. chip cav gsi?
  224. Dimmer light on Kenny head unit not working
  225. Corsa gearbox help
  226. Oil Pressure Sender
  227. Engine / Gearbox weights
  228. Fuel Filter - cav gsi please help
  229. Fuel Crisis
  230. Sump gasket
  231. reverse gear prob...again
  232. Clutch -turbo with f20
  233. Fao 4x4 peeps
  234. Valver into mk3 Astra
  235. oil pressure sender for digi dash???
  236. Cavalier gsi 20xe with a 6 speed box
  237. F25 gear ratios???
  238. Cav Turbo Plug Gaps?
  239. gear box
  240. C20 Let
  241. Turbo Tuning......Again!!
  242. Nova Turbo Or 2.0 16v
  243. Turbo Engine Transplants
  244. omega air inlet enquiry
  245. 2.0 XE into a Tigra? advice needed.
  246. Turbo or throttle Bodies ????
  247. old clutch + 200bhp =
  248. 2.0 XE Head Job
  249. it wont start!
  250. Water injection???
