- c16xe injecters
- wiring trouble
- has anybody got a c20let in or around the derby area that is willing to try my ecu???
- Making an electic f28 run a mechanical speedo?
- Vectra B - No Coolant, overheating, misfire
- Fitting throttle bodies to 20xe but what about water outlets on head?
- Omega 3.0 V6 into Cavalier question
- C20let turbo big problem
- Corsa b van diesel to a c20xe/let
- Mk3 Astra 1.7td gm engine problems
- Best gearbox for corsa let and which f28 mechanical or electrical speedo?
- Help Choosing Gearbox
- What Actuator....
- HELP please c18xe keeps reading rpm sensor changed 6 times including cam sensor?
- Corsa 1.5td no fuel from pump!
- feul pressure?
- 20xe will not fire
- speedo not working astra G. and aircon pump Q c20xe
- C20xe sump gasket
- knock sensor
- z20let head bolt torque settings anyone?
- c20let t3 upgrade info.
- nova mount pics
- Handbrake light???
- C25XE fault codes 57 & 31
- XE Corsa driveshaft issue.
- Z20LET or C20LET
- f28 get rag box ???? help please
- F13 shafts
- C20LET piston ring gaps
- Nova 14NV engine timing help
- c20let boosting issues..
- Rs turbo spark plugs???
- C20XE oil cooler
- switched live 2.0xe
- eds phase3 any help
- c20let ecu,s
- question about paperclip test
- how can i check my ecu is okay???
- AC Delco Pressure Sensor, Vivaro 03
- redtop corsa outer cv joint
- Corsa xe high idle
- need help with my 1.8 single point ohc engine mods
- exhaust collector divider
- Early c20xe hall sensor
- 1.6 8v Help PLEASEEEEE :)
- C20xe Running In Problems :s
- 8v Camshaft Information
- What engine code - 1999 Vectra SRi 140 2.0 16v
- Engine chapping when hot.....Z14XE
- Insignia OPC (VXR) speed limiter removal
- c20xe starter motor
- vectra 2.2 dti pinking at approx 2500 revs and above
- 20xe wiring :S
- help astra vrx
- Oil return feed and driveshaft issue (+pics)
- C20NE sump??
- corsa engine code
- Anyone Know Where I Could Get An Oil Pump?
- corsa c sri engine
- quick ecu question
- redtop stutter and start up
- EPS Sensor Problem
- vectra c sxi loud wirring/rumble noise from gearbox area
- how to wire in x20xev loom into astra van
- f28 gear selctor mounting bracket?
- smoke on tickover
- redtop corsa random misfire !!
- G cams C25XE
- 2.0 dti astra van mk4 want a bigger turbo
- Monitor EGT or Wideband A/F for lean running?
- Astra VXR remap or no remap???
- f20 short shifter
- C20Xe engine removal
- C20let running funny
- C20xe lifter silent one day, noisy the next
- f18 gear box trouble
- oil light takeing its time to go out HELP ????
- corsa gearbox advice needed
- big block hubs and brakes
- C20XE Corsa doing my nut in !
- pollyurathane engine mount inserts
- corsa sport hesitates to accelerate when fully accelerating
- Yukspeed Rally Spares
- 02 sensor
- plug for oil sensor??? c20xe
- z18xe vectra b ecu needed
- What oil x16xe?
- c20let boosting high
- engine wiring
- fired up at last,but what a let down.
- slight gearbox whine
- 8v round port inlet manifold
- C20LET stock turbo water cooled question
- Z20leh turbo
- 6 spined crank pulley bolts!!!!!
- Cam belt/water pump
- f28 rattling but cant find the problem
- need help on wiring the engine back up
- Nova 20seh Starter motor problem?
- Need photos of a X14XE engine
- c20let starts on bump but not the key ???
- ticky x14xe
- is a stage 3 garrett any good with phase 3.5 let is it a good turbo
- I beam v H beam rods?
- best oil for lsd gearbox
- Preformance parts
- F20 corsa b shafts and inners?
- z20let crank
- Mk 1 Tigra Coolant Drain Advice [car is in the air now, need help!]
- help needed asap(c20xe)
- poss diff rumble z18xe poss f17?
- recomended turbo re-build companys
- c20let astra van, need help!!!!!!!!!!!!!!!!!!!
- Pug 306 1.9 d clutch
- Messed up removing timing belt 1.7DI engine
- bonnet struts
- C14SE problems
- astra f23 advice on fitting cables
- corsa c conversion
- Gizzmo boost controller
- any advice please
- 09' astra 1.7 cdti cam timing marks
- What engine to use?
- Cooling fan cut in/cut off Omega 2.0 16v CDX T reg
- O2 sensor problems
- c20xe wont start, got fuel and spark!
- C20XE Corsa running problems
- ecu immobiliser problem i THINK URGENT HELP NEEDED
- Will this combination work?
- F28 Stripdown tips
- Astra V6 runs for a few seconds after switching off
- C20XE Red Top Engine For Sale...
- 2000 vectra sri 140 sump plug size?
- 1.7d starter motor fitting advice please
- oil pressure
- nothing sporty but need help!!!
- C20LET Corsa. turbo advice
- fitting Quaife ATB Differential in a F28 getrag box
- C25XE coolant pipework
- Plumes of white smoke from exhaust - new engine
- 2.0 8v - corsa
- EDS phase 3 engine spec please?
- mk4 astra x20xev mount
- Can someone please help me with a charge cooler query
- the boost pipe from the ecu?
- 8 valver in astra mk4??
- revving problem corsa c
- valve rework for ecotec
- Cant shift 1st gear to 2gear, why?
- K16 Recirculation Valve - Blocked off?
- what boost will a std k16 make safely?
- Corsa 1.2 1997 EGR??
- zafira rear engine mount
- c20let vernier pully on z20let? for an xev inlet cam
- C20LET Astra Mk4, Speedo/Wiring clocks/Hub trouble.
- What BHP can you get from a 20clet with minor mods
- is the xe/let any match for the ford cosworth?
- are xe lambdas the same as let ones???
- Cavalier V6 Knock Sensor
- gearbox troubles
- Is this standart GLYCO crank bearing (C20LET) ??
- Vauxhall IAC cleaning proper way
- 2.0 8v into mk4 astra, what mounts & driveshafts best to use??
- x14xe help
- c20xe running problem
- vectra and cav mounts
- Gearbox problem?
- c20ne turbo any advise
- can anyone tell me if they're diffrent, early/ late 20XE AFM
- z14xe bottom end
- E16se Cam help
- Astra 1.6 16v engine mods? any suggestions ??
- corsa v6
- What had the x16xe fitted?
- what flywheel do i need
- Anyone Converted a Corsa C engine?
- whats the best 3ltr cams to put into a c25xe?
- torque settings
- V6 Metal Rocker Covers
- Cav V6 Issue
- EDS phase 3 some question and a litte help
- HELP NEEDED PLZ ! x25xe / y26se vectra conversion HELP . . . . . .
- Vectra diesel starting problems
- 1.4 8v corsa loom help!!
- redtop corsa and tigra ??
- what shafts should I use on a c20xe corsa?
- LET rwd setup water feed
- Z20let oil pump on a C20let?
- remapped astra gsi turbo z20let problems
- C20xe not starting
- noisey engine
- universal 02 lambda
- few little things left i need to do but i dont no where to put them
- Would you reuse this Cometic?
- overboost??
- X20 XEV Newman cams problem :(
- c20xe timing
- Z19DTH simptoms of a misfire issue
- FSE Power Boost Valve
- xe early and late type cam difference?
- Xe rwd turbo conversion
- Vectra + F23
- c14nz help
- max boost on c2olet
- Big BHP advice? C20LET
- Quick Q - what throttle cable - Corsa B XE/LET
- afm causing trouble any ideas
- Mk3 Astra need more power HELP PLEASE!!!
- After repairing ECU now have more fault codes?!?!
- throtlebody z18xe
- C20LET coolant hose route
- maximum bhp on a standard kkk16 turbo on c20let
- will dispak cams fit early dizzy head!
- what price for a dealer to insp for chain rattle?
- Can a 2.0 8v head fit on a 1.4 8v
- piston/bore damage help
- Corsa xe Engine Management Light
- closed
- fastest C20LET 8second 1/4 mile
- A problem that NO ONE CAN FIX on Z20LET Mk4 Turbo!
- Corsa B uprated rad supplier
- Is OIL cooler necessary on C20LET
- Yes & No oil pressure getting worried now....
- F28, which LSD?
- Urgent Help Needed - Vectra 2.5ltr v6 Fitting F28 Problem
- Saab reds
- vxr dump valve fitting PLEASE HELP
- v6 lump in an astra mark 4
- X20XEV/C20XE issues
- Cali started, squeeled and stopped!
- Corsa C20LET, power steering help
- what is the best intercooler kit
- power power power :)
- Alloy radiator
- unusual engine code xej,advice please
- oxygen sensor problem
- V6 turbo...what management to use???
- has anyone a guide to 2.0xe connectors on the loom
- Ticking noise, after warm up.
- 2ltr Red Top engine question!!
- Better Gear Lever/Linkages
- inlet 2 bits not sure where they go
- ticking clicking, could it be oil pump??
- Advice Needed Engine Erratic Idle and No Power. (Corsa b xe)
- Corsa B X10XE
- F28 + quaife lsd- oil?
- eunning in new shells
- Pls, what socket size (torx E) for main bearings half-bridges on C20LET ? ASAP
- c20let's got me stumped
