: Engines and Transmission
  1. What do i need to fit twin 40 webber carbs to a 1.2 nova
  2. 2.0 8v (c20ne) - sohc or dohc?
  3. Nova Turbo building...cont
  4. fuel pressure regulator
  5. Engine Getting Hot
  6. vectra v6 exhaust > 2.0sri?
  7. Gearbox change?
  8. Throttle linkage
  9. Fuel Line problems - FAO Cav Gsi owners
  10. what max boost can i run with a standard headgasket
  11. can high boost cause head gasket problems
  12. Lower strut brace - exhaust hit solved.
  13. how can i make custom exhaust rubbers?
  14. Vauxhall 2.0 16V head-Fluxe
  15. Oh dear (gearbox).
  16. turbo problems
  17. Crank sensor
  18. wheres my gears gone!!!!!
  19. Fitting a F28 instead F20
  20. Catalytic convertor question?
  21. Major brake headache
  22. Getting rid of the CAT
  23. Whine from cam belt ??
  24. Engine rebuild time.....
  25. testing the TPS on a C20LET
  26. can i use 15/50 synthetic in my turbo
  27. cav turbo rad slightly expands,why!
  28. Driveshafts/Cvs Cav Gsi - Urgent answer please
  29. nos on calibra turbo
  30. timing belt change
  31. ICV - how do i locate it on a 2.0 16v ecotec engine?
  32. Good timing (gearbox).
  33. Spoiler brake light wiring
  34. "Headlights on" warning BUZZER
  35. Gearbox info needed
  36. Dark Brown color on the Spark plugs OK?
  37. is there a 10/40 fully synthetic oil
  38. C20XE chamber shape.
  39. turbos and nos
  40. Gte Cam
  41. 1.2 16v Corsa Exhaust
  42. regal autos TB kit for 2L 8V NE good
  43. corsa xe conversion
  44. 1400 16v engine
  45. 1.2 to modded 1.3 whats the score?
  46. Oil Pressure Sender for a Nova 993cc MkI
  47. Where has my engine gone?!?
  48. Carb to Injection
  49. Oil cooler
  50. does the f28 have a boost limiter in first and second
  51. Interesting info on TIS
  52. Best place to buy for a calibra turbo
  53. Headlamp bulbs
  54. Coilovers?
  55. carbs?
  56. oh rats! my engine blew up today!
  57. Engine management, DTA, MBE or emerald?
  58. cav turbo clutch
  59. question for anyone with E.P.C and a knowlege of txb's
  60. Piper cams for a cav gsi.....
  61. Over-fueling Corsa?
  62. Cheapest way to turbo a 2.0 8valve engine
  63. Coil overs
  64. Belmont exhaust mount?
  65. fuel cap
  66. Valve Grinding Help. Leaking Valves?
  67. Calling all motorbike heads.
  68. Octane booster miracle
  69. 8v cambelt
  70. Couple of faults
  71. lifters
  72. Water injection
  73. Motronic 2.8 and limp home mode
  74. what pressure is a cav turbo fuelpump
  75. how long can F20 last?
  76. Engine Swap Question
  77. 1400 head on a 1200
  78. Superchips?
  79. 1400 with 1200 head??
  80. propshaft removal on turbo
  81. cav turbo juddering when cold
  82. I can hear my tappets!
  83. power cap for astra GSI
  84. XE and LET distributors
  85. Gearbox dying - how l much longer until it expires?
  86. Oil temperature on Turbos and NA's
  87. F20 Gearbox ratios
  88. Clutch release arm
  89. fuel pressure
  90. Principles of Twin Turbos
  91. can i super charge my turbo what bits do i need
  92. adjusting F20 gear linkage
  93. Pictures of XE's with induction kits please??
  94. V-TUNING powercap type thing
  95. Anyone using Regal's new T3 Turbo
  96. astra 1.8 8v fuel pressure
  97. serious lack of power
  98. Driveshafts?
  99. turbo brakes on 4 stud
  100. Oil Pump Farce
  101. Removing Turbo From Manifold
  102. Project: Uber 8 Valve..... on a budget - Ideas please!
  103. Calling all tefal heads- URGENT!
  104. Exciting new modifications to your car - please read and comment
  105. redtop in a corsa pics please
  106. gsi gearbox
  107. Best Chip
  108. cav turbo ecu question
  109. GM cam removal tool
  110. radiator tempreture switches, are they all the same?
  111. Cav Sri gearbox on a 1.8i????
  112. URGENT: Cav Driveshaft Removal
  113. Front Engine Mount for Corsa
  114. Cat replacement pipe
  115. Cambelt-all that bad?
  116. 1.6 16V Tuning
  117. Petrol Tank plumbing
  118. 1.6 16V Mk2 Astra wiring
  119. Oil pumps
  120. turbo brakes on 4 stud
  121. Conrods
  122. Water pump quickie
  123. Cams
  124. Throttle Bodies
  125. Turboed Car users...
  126. cav16vecotech1995(n)turbo conv.
  127. Fitting a chip?
  128. headporting specialists enter here
  129. turbo 4x4 txb question
  130. Nova 1.4i - 5th gear problem
  131. Which Backbox??
  132. Exhaust Quickie!!
  133. Oil Pressure guage
  134. Irmsher Backbox
  135. how much bhp will i have?????
  136. I heard a rumour (re Mantzel powerbox).
  137. Air Filter
  138. head work on 1.4 16v
  139. cleaning up valves
  140. Update on commercial diesel probs
  141. Cam cover back plate rattles? anyone else??
  142. please help cavvy turbo keeps backing off??
  143. GSi 16V F20 -> F28 Conversion
  144. F28 Gearbox
  145. How many silencer boxes...
  146. Engine Fulsh.
  147. Spark Plugs
  148. Block honeing
  149. ecotech code 92
  150. Loud noice from engine
  151. fuel tank vent valve?
  152. Astra 16v engine pics needed...
  153. corsa engine bays
  154. Astra 1.6 16v & Astra 1.8 16v
  155. Ngk Plugs Or Bosch
  156. brake pad indicators
  157. Petrol Tank plumbing
  158. Change in Power Delivery?
  159. Cam belt slipage - oh no!
  160. 8v conrods Vs 16v conrods
  161. at last photo of my cav mk2 calibre convertible turbo
  162. Turbo Maybe
  163. phase 2
  164. oil return turbo question
  165. how do you plumb in a bleed valve on mr2 turbo
  166. Boost guage location??.......
  167. 8valve inlet water gallery
  168. Turbo Engine Rebuild
  169. Flickery Oil Light
  170. MK2 Astra Turbo Strut Brace
  171. SBD Type-A Manifold Query.
  172. Bonnet struts/lifters
  173. Adjusting the Boot Catch
  174. Spark Plug (Removal & Type)
  175. performance 2L 8v pistons?
  176. Porous heads
  177. vectra v6 cam belt swap
  178. vectra v6 engine out?
  179. no lambda sensor
  180. Uprated Clutch
  181. Headwork Question
  182. Should high power NA cars smoke?
  183. Exhaust for 16V Nova
  184. Rebuild... Knock Sensor Location
  185. are the lamda sensors on cav turbo and non turbo 16v the same.
  186. Bosch Motronic 5.1
  187. cleaning up head/valves
  188. new gaskets
  189. Replacement Bleed Valve / Nipples
  190. ECU Turbo Fault
  191. problems with turbo engine
  192. New user needs help!
  193. Throttle body mod?
  194. Best cam
  195. Astra - fuel starvation?
  196. More power from 1.4 spi lump
  197. fuel lines
  198. Oil warning light
  199. Rear camber queries
  200. phase 2
  201. starter motor
  202. 2.0xe into corsa
  203. which chip is best for cav turbo unichip,super chip or the phase chips
  204. how much to fit a clutch?
  205. help missing vectra
  206. C20XE crank pulley
  207. Tick Tick Tappets
  208. cat info for blagging mot's
  209. Oil Pump, it all went a bit tits up really.
  210. Oil Pump Replacement - Difficult?
  211. fuel pump
  212. My oil leak is sorted...???
  213. Standard cam spec
  214. inlet manifold
  215. Inlet manifold hose connection
  216. calibra rear camber
  217. MOT HELP: Cat's???
  218. Fuel Pump relay
  219. Where to put oil pressure and temp senders
  220. Drive shafts
  221. 1.6 16V Mk2 Cat replacement
  222. Engine Conversion Boffins
  223. Engine oil consumption
  224. Bosch Fuel pump flow rates Part Nos
  225. Pistons and conrods change?
  226. Help On Coilover Q's please
  227. Oil Pump
  228. rotor arm 2.0xe
  229. Omega 3.0 throttle bodies..
  230. turbo unit
  231. will scorpion Grp A cav turbo exhaust fit a GSi 2WD???
  232. CRAP! I found my engine problem!!!
  233. Engine Transplant
  234. Idle Controll Valve On 1.8eco
  235. 1.8i engines
  236. What Revs at What Speeds?
  237. leaky piston rings - new engine??
  238. AFM Problem
  239. http://www.powerchips.com/ - any gen?
  240. radiator tempreture switches
  241. Nova Sportex mild steel backbox?
  242. Head components
  243. Clutch Cable
  244. Pinking
  245. cav turbo smoking often on idle only
  246. water injection best jet locations
  247. Clutch Problem (i think)
  248. HELP!(first start after work in my head..)
  249. Mr. Animal is a top bloke & my engine is finally going back together!!
  250. Quaffe LSD
